i got an atmega8l(8mhz internal) and i programmed it using a parallel programmer and ponyprog, i used arduino ide to generate the .hex file with these settings in "boards.txt"
atmega8.name=Arduino NG8 mhz
atmega8.upload.protocol=stk500
atmega8.upload.maximum_size=7168
atmega8.upload.speed=19200
atmega8.bootloader.low_fuses=0xe4
atmega8.bootloader.high_fuses=0xd1
atmega8.bootloader.path=atmega8
atmega8.bootloader.file=ATmegaBOOT.hex
atmega8.bootloader.unlock_bits=0x3F
atmega8.bootloader.lock_bits=0x0F
atmega8.build.mcu=atmega8
atmega8.build.f_cpu=8000000L
atmega8.build.core=arduino
i first compile sketch, locate the hex file and upload using ponyprog, the problem is that the sketch is running very slow, i used the blink sketch and instead of 1 second delay ,there is a 8 second delay ,how can i fix this??
note:im not using any bootloader at all
