0 - 10V PWM control
I have a small project where I am adding wifi controll to a 160W LED light unit (for my reef fish tank)
The unit is 2 channel controlling white and blue LEDs. They are currently controlled with a potentiometer on the top. This pot is 0v to 10v and I am looking to replace that with a ESP8266 but I am not sure the best way to go about it. I can control the LEDs up to 5v with normal PWM but need to be running the lights at near 10v really.
I figure my options are using a 2n222 transistor to bump the 5v pwm to 10v or using a digital potentiometer. Any input?
You need to find a digital pot that can work with voltages above the supply voltage.
Yes you can do this but you will need a 10V power supply.
I just bought a 10v power supply, I have a suitable transistor available. I guess I am asking what the best way to do it is?
I am going to be making a custom PCB for this and want it as simple as possible as I am clearly very inexperienced :o
Dimmable LED supplies usually already have a 10volt supply connected to the DIM pin.
You just need to PWM that DIM pin with an open collector (or open drain) circuit.
Connect the 2N2222 collector to DIM-in, and the emitter to DIM ground and ESP ground.
Connect the base via a 1k resistor to the ESP output pin.
Post a link to the LED supply if that doesn't work.
Leo..
The driver has a 4 pin ouput with a small potentiometer board connected. Its labeled VDM-, VDM+, V+ and ON/OFF
The V+ is 12 VDC
The ON/OFF is the enable line and needs to be connected to the V+ to turn the driver on.
The VDM- and + is the 10v I need to manipulate with the arduino. :slight_smile:
No link to the product?
Or a picture?
Can't you get that 10volt from the 12volt supply with a pull up resistor.
And use the circuit I suggested.
"this pot is 10volt"
How can a passive pot be 10volt.
How is that pot connected.
Leo..
This is the driver https://imgur.com/gallery/pdTm8?s=fbm
As its a cheap chinese led unit I can't imagine finding a schematic at all.
Regarding piggybacking the 12v off the driver itself that would be awesome if it could work.
If I am getting me r2/r1+r2 sums correct this circuit would suffice?
thanks
Use this image guide for posting pictures here.
No.
Ground of the Arduino must be connected to the ground of your device. In short I don't think the circuit is like anything you need.
You should at least post a diagram of that pot board, with parts values.
And/or take clear pictures of it, showing parts values and tracks.
Leo..
