Hi all,
I’m wanting to log/capture data from a pressure sensor into the Arduino.
The sensor gets +5v and ground and gives a 0.5v - 4.5v voltage back, linearly from 0 - 15psi.
(it’s an automotive style sensor where the controller perceives < 0.5v is open circuit and > 4.5v is a short).
I can’t get my head around the scaling to give me an answer in psi???
I can read from the analog pin and get a 0 - 1023 result,
but I’m stuck at the maths where I use the reference voltage to convert it to meaningful psi, especially when 4.5v is full scale and not 5v.
Serial.println("Start psimeter 0.1");
// MEASUREMENT
// make 16 readings and average them (reduces some noise) you can tune the number 16 of course
int count = 16;
int raw = 0;
for (int i=0; i< count; i++) raw += analogread(A0); // return 0..1023 representing 0..5V
raw = raw / count;
// CONVERT TO VOLTAGE
float voltage = 5.0 * raw / 1023; // voltage = 0..5V; we do the math in millivolts!!
// INTERPRET VOLTAGES
if (voltage < 0.5)
Serial.println("open circuit");
else if (voltage < 4.5) // between 0.5 and 4.5 now...
float psi = mapFloat(voltage, 0.5, 4.5, 0.0, 15.0); // variation on the Arduino map() function
Serial.print(millis());
Serial.print(", ");
Serial.println(psi, 3); // 3 decimals
Serial.println("Signal too high!!");
float mapFloat(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
