10pin smd PCB connector???
Trying to find a smd 10pin PCB connector to solder on my circuits the only good think I could find is this.
Any better suggestions about smaller connectors like sata or something else with 10pins and cheap as well, any ideas?
Not sure what your requirements are, but you can use a PTH connector as a SMD connector either by: adding it to the end of a PCB laying flat or you can bent pins ar right angles.
