Good day,
as a beginner I need advice on a project.
I have a code with 10 scales with hx711 but the code freezes during the process. On the LCD whenever it has to display the value from the scale.
Thanks for the advice.
code:
LiquidCrystal_I2C lcd( 0x27, 20, 4 );
#include "HX711.h"
byte c_hacek[8] = { //definice znaku c s háčkem = č
B01010, // jednička svítí
B00100, // nula nesvítí
B01110,
B10000,
B10000,
B10001,
B01110,
#define calibration_factor_1 23000 //This value is obtained using the SparkFun_HX711_Calibration sketch
#define calibration_factor_2 23500
#define calibration_factor_3 23500
#define calibration_factor_4 -22300
#define calibration_factor_5 23500
#define calibration_factor_6 23500
#define calibration_factor_7 23500
#define calibration_factor_8 23500
#define calibration_factor_9 23500
#define calibration_factor_10 23500
#define DOUT1 28
#define CLK1 29
const int Tare1 = 25;
#define DOUT2 30
#define CLK2 31
const int Tare2 = 22;
#define DOUT3 34
#define CLK3 36
const int Tare3 = 23;
#define DOUT4 38
#define CLK4 40
const int Tare4 = 24;
#define DOUT5 5
#define CLK5 6
const int Tare5 = 26;
#define DOUT6 42
#define CLK6 44
const int Tare6 = 8;
#define DOUT7 47
#define CLK7 49
const int Tare7 = 9;
#define DOUT8 51
#define CLK8 53
const int Tare8 = 12;
#define DOUT9 2
#define CLK9 3
const int Tare9 = 4;
#define DOUT10 32
#define CLK10 33
const int Tare10 = 7;
HX711 scale1;
HX711 scale2;
HX711 scale3;
HX711 scale4;
HX711 scale5;
HX711 scale6;
HX711 scale7;
HX711 scale8;
HX711 scale9;
HX711 scale10;
lcd.init( );
lcd.backlight( );
lcd.createChar(1, c_hacek); //odeslání definice 2. znaku
scale1.begin(DOUT1, CLK1);
pinMode(Tare1, INPUT);
digitalWrite(Tare1, LOW);
scale1.set_scale(calibration_factor_1); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale1.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
scale2.begin(DOUT2, CLK2);
pinMode(Tare2, INPUT);
digitalWrite(Tare2, LOW);
scale2.set_scale(calibration_factor_2); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale2.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
scale3.begin(DOUT3, CLK3);
pinMode(Tare3, INPUT);
digitalWrite(Tare3, LOW);
scale3.set_scale(calibration_factor_3); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale3.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
scale4.begin(DOUT4, CLK4);
pinMode(Tare4, INPUT);
digitalWrite(Tare4, LOW);
scale4.set_scale(calibration_factor_4); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale4.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
scale5.begin(DOUT5, CLK5);
pinMode(Tare5, INPUT);
digitalWrite(Tare5, LOW);
scale5.set_scale(calibration_factor_5); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale5.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
scale6.begin(DOUT6, CLK6);
pinMode(Tare6, INPUT);
digitalWrite(Tare6, LOW);
scale6.set_scale(calibration_factor_6); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale6.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
scale7.begin(DOUT7, CLK7);
pinMode(Tare7, INPUT);
digitalWrite(Tare7, LOW);
scale7.set_scale(calibration_factor_7); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale7.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
scale8.begin(DOUT8, CLK8);
pinMode(Tare8, INPUT);
digitalWrite(Tare8, LOW);
scale8.set_scale(calibration_factor_8); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale8.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
scale9.begin(DOUT9, CLK9);
pinMode(Tare9, INPUT);
digitalWrite(Tare9, LOW);
scale9.set_scale(calibration_factor_9); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale9.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
scale10.begin(DOUT10, CLK10);
pinMode(Tare10, INPUT);
digitalWrite(Tare10, LOW);
scale10.set_scale(calibration_factor_10); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale10.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
Serial.println("Readings:");
lcd.clear() ;
lcd.setCursor(0,0);
lcd.print("V");
lcd.write(byte(1)); //zobrazí č (znak 1)
lcd.print("elstvo 1:");
lcd.setCursor(12,0);
lcd.print(scale1.get_units(),1); //scale.get_units() returns a float
lcd.print(" kg"); //You can change this to kg but you'll need to refactor the calibration_factor
/*Serial.print("Hmotnost: ");
Serial.print(scale2.get_units(),1); //scale.get_units() returns a float
Serial.print(" kg"); //You can change this to kg but you'll need to refactor the calibration_factor
lcd.setCursor(0,1);
lcd.print("V");
lcd.print("elstvo 2:");
lcd.setCursor(12,1);
lcd.print(scale2.get_units(),1); //scale.get_units() returns a float
Serial.print(scale3.get_units(),1); //scale.get_units() returns a float
lcd.setCursor(0,2);
lcd.print("V");
lcd.print("elstvo 3:");
lcd.setCursor(12,2);
lcd.print(scale3.get_units(),1); //scale.get_units() returns a float
Serial.print(scale4.get_units(),1); //scale.get_units() returns a float
lcd.setCursor(0,3);
lcd.print("V");
lcd.print("elstvo 4:");
lcd.setCursor(12,3);
lcd.print(scale4.get_units(),1); //scale.get_units() returns a float
delay (2000);
lcd.clear() ;
lcd.setCursor(0,0);
lcd.print("V");
lcd.print("elstvo 5:");
delay (2000);
lcd.print(scale5.get_units(),1); //scale.get_units() returns a float
lcd.setCursor(0,1);
lcd.print("V");
lcd.print("elstvo 6:");
lcd.print(scale6.get_units(),1); //scale.get_units() returns a float
lcd.setCursor(0,2);
lcd.print("V");
lcd.print("elstvo 7:");
lcd.print(scale7.get_units(),1); //scale.get_units() returns a float
delay(2000);
lcd.clear() ;
lcd.setCursor(0,0);
lcd.print("V");
lcd.print("elstvo 8:");
lcd.print(scale8.get_units(),1); //scale.get_units() returns a float
lcd.setCursor(0,1);
lcd.print("V");
lcd.print("elstvo 9:");
lcd.print(scale9.get_units(),1); //scale.get_units() returns a float
lcd.setCursor(0,2);
lcd.print("V");
lcd.print("elstvo 10:");
lcd.print(scale10.get_units(),1); //scale.get_units() returns a float
delay(2000);
