Hi!!!
I am working in a very similar project, until now I actually read properly channel A from two HX711 modules, there are still problems reading channel B mainly because the only way that I found to change chanel is with set_gain command, second, the gain can not be set equal for all channels
This is my code (Modified version from the great library at GitHub - bogde/HX711: An Arduino library to interface the Avia Semiconductor HX711 24-Bit Analog-to-Digital Converter (ADC) for Weight Scales..
#include "HX711.h"
// HX711.DOUT - pin #A1
// HX711.PD_SCK - pin #A0
HX711 scale(A1, A0); // parameter "gain" is ommited; the default value 128 is used by the library
HX711 scale1(A3, A2); // parameter "gain" is ommited; the default value 128 is used by the library
float cal1=0;
float cal2=0;
Serial.begin(38400);
//Serial.println("HX711 x 2 ");
scale.set_gain(128);
scale1.set_gain(128);
Serial.println("Before setting up the scale:");
Serial.print("read scale 0: \t\t");
Serial.println(scale.read()); // print a raw reading from the ADC
Serial.print("read scale 1: \t\t");
Serial.println(scale1.read()); // print a raw reading from the ADC
Serial.print("read average scale 0: \t\t");
Serial.println(scale.read_average(20)); // print the average of 20 readings from the ADC
Serial.print("read average scale 1: \t\t");
Serial.println(scale1.read_average(20)); // print the average of 20 readings from the ADC
Serial.print("get value scale 0: \t\t");
Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight (not set yet)
Serial.print("get value scale 1: \t\t");
Serial.println(scale1.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight (not set yet)
Serial.print("get units scale 0: \t\t");
Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight (not set) divided
// by the SCALE parameter (not set yet)
Serial.print("get units scale 1: \t\t");
Serial.println(scale1.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight (not set) divided
Serial.println("Calibrating HX711 1");
scale.set_scale();
scale.tare();
Serial.println("Put 1000g over LC #1");
delay(5000);
cal1=scale.get_units(10);
scale.set_scale(cal1/1000);
Serial.print("Calibration value : ");
Serial.println (cal1/1000);
Serial.println("Calibrating HX711 2");
delay(2000);
scale1.set_scale();
scale1.tare();
Serial.println("Put 1000g over LC #2");
delay(5000);
cal2=scale1.get_units(10);
scale1.set_scale(cal2/1000);
Serial.print("Calibration value: ");
Serial.println (cal2/1000);
scale.read();
scale.set_scale(107.f);
scale.tare();
scale1.read();
scale1.set_scale(107.f);
scale1.tare();
scale.set_gain(32);
scale.read();
scale.tare();
scale1.set_gain(32);
scale1.read();
scale1.tare();
scale.read();
scale1.read();
Serial.println("After setting up the scale:");
Serial.print(scale.read()); // print a raw reading from the ADC
Serial.print("\t read scale 1: \t\t");
Serial.print(scale.read_average(20)); // print the average of 20 readings from the ADC
Serial.print("\t read average scale 1: \t\t");
Serial.print(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight, set with tare()
Serial.print("\t get value scale 1: \t\t");
Serial.println(scale1.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight, set with tare()
Serial.print(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight, divided
// by the SCALE parameter set with set_scale
Serial.print("\t get units scale 1: \t\t");
Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight, divided
Serial.println("Readings:");
// Serial.print("one reading scale 0:\t");
// Serial.print(scale.get_units(), 1);
delay(100);
float A = scale.get_units(10);
float B = scale1.get_units(10);
scale.set_gain(32);
delay(100);
float C = scale.get_units(10);
float D = scale1.get_units(10);
Serial.print("\t A:\t");
Serial.print(A, 1);
Serial.print("\t B:\t");
Serial.print(B, 1);
Serial.print("\t C:\t");
Serial.print(C, 1);
Serial.print("\t D:\t");
Serial.print(D, 1);
Serial.print("\t Weight: \t");
Serial.println((A+B), 1);
Serial.print("\t Pos:\t");
if ((A+B)>500)
Serial.println((A10-B10)/(A+B), 1);
Serial.println(0, 1);
//scale.power_down(); // put the ADC in sleep mode
//scale1.power_down();
//delay(500);
//scale.power_up();
//scale1.power_up();
Did you be able to read properlly channel B???
