12 Hour analogue clock from speedometer- Feasible?
Ok so what I have is an old speedometer as pictured
What I have in front of me is my Arduino UNO, an Adafruit Motor Shield V2 and 28BYJ-48 Stepper motor.
What I want to do is slowly increment the hand on the speedometer from 0mph (12 o clock) through the hours up until 120mph (11:59) and then the arm swing back to the beginning.
What I want to know is, is the stepper motor the best idea? Would a servo be better? Anyone got any other ideas?
Thanks!
Ash
Does the speedo still have all its inards?
Mark
That speedo might be worth a few bob ...
Yes a stepper is the way to
Go and should do the job fine. You’ll need to junk most of the speedo innards and drive the hand direct.
You could also have a minute hand...
Thanks, the speedo does have its innards but its chromatic so it used a cable that spins a magnet to move the needle so I can't use its built in function!
How can I program the motor to move at the correct rate togo from 0 to 12? I am a little new to this!
Thanks
Ash
If it’s chronometric sell it and buy something else - chronometric speedos are worth a fortune !! (£00’s) and you’ll just wear it out or break it . Please don’t do that !!
If you bought a more modern dash instrument , you may well find it’s already driven by a stepper motor.
Anyhow I don’t think it would work as you suggest as a stepper would not be quick enough
hammy:
No its not an antique I think its a reproduction of the smiths speedometer! I want it to move very slowly over a 12 hour period and then move back to 0 once 12 is hit (doesn't matter if it takes a while to get back as long as it stays in sync with time!
Cheers
Ash
But you have to rotate the input continually for the needle to move , maybe 100rpm or so at 12 O’clock which a stepper won’t easily do. It’s also likely the needle will waver about a fair bit as well as making a lot of noise .
That speedo would be about £600 to buy ...
Hi yeah sorry my plan was to gut the speedo and just use my stepper to move the needle directly.
Even with a proper motor in there I dont want it spinning constantly to keep the needle at a certain time is all!
Yeah this isn't an original it cost me £15!
Cheers
Ash
A normal DC motor would work with the original innards. You can control the speed of the motor (and hence the indication of the time) using PWM. Over a period of 12 hours, you will need to increase the PWM from O to the value that corresponds to 120 mph.
Removing the innards will give you other options; I'm not familiar with steppers and servos so can't really advise there.
If I were to run this on a motor, what attachment/pinion would I need for the end to fit a speedometer square cable end? I have searched every term I can think of and just get back normal pinions!
Thanks!
