I have been designing my own version of the Dredd 3D Lawgiver Mk. II. (pic below for show, almost finished (; ).
The gun features an OLED display, which I have concluded to be an 128x32 OLED graphics display, and it displays the amount of different ammo are left in the gun. (also a pic from the movie below for reference).
The problem is I have no idea how to approach the coding side of this build. I have played around with a 16x2 LCD and I have learned to print text, show a temp / temps using a temp sensor, and to me that is pretty simple and easy. So I think I can learn to use this more advanced type of display if I can get some assistance.
The biggest and first step/question for me is how do I "print" stuff on the display. Once I learn the basic to that, I can start adding two LED's and a switch or two.
I have found the OLED screen that was used in the movie, info of it are in the link below under the pic of it.
As the gun isn't that big I think I'll use Arduino nano or arduino mini pro, both can control this type of display?
So to summarize this message:
how can I control and print text/grapics on the referred display?
how do I create grapics?
Can an Arduino nano/mini pro do the job?
I thank everyone in advance and I promise to post pics/videos about the progress I make!! And of course I will share the code!!
Thank you for your reply, Oliver! I think I just have to keep looking for a display with a more popular controller (if that's what SSD1306 for example is). The display really needs to be about 2.2" in size to fit my build.
I found a 128x32 display which uses SSD1309 IC and saw that u8glib supports that, but for 128x64. Any chance here? Here is the u8glib device list:
I'm just thinking this over and realized that as long as the display is about 2.2" in size and has an aspect ratio close to a 128x32 display, then it widens my range. The color must be blue on black as well.
And since the resolution on this is 256x64, I could use 2x2pixels to represent a single pixel. That way it would be like using single pixel on a 128x32 display.
SSD1309 and SSD1322 should be supported (at least i received feedback from users according to this), but using SSD1322 is a little bit slow because of size and graylevel depth. This also is independent from using 2x2. It is just the amont of data which needs to be transfered.
