first of all a big THANK YOU to Olli Kraus for this wonderful library!
I am at the beginning of experimenting with the Arduino world.
The OLED I am using has a TWI connection and GNG and Vcc.
I connected SDA of the OLED to A4 and SCK to A5, GND to GND and Vdd of the OLED
to Vdd of the Arduino Pro Mini (3.3V Wattuino Pro Mini).
There three different contructors for that kind of OLED in the u8glib I tried all.
The program does nothing more then reading micros() and printing that value with a
"C:" in front of it onto the screen.
Unfortunately the string containing the digits is somehow corrupted. It looks either like pixels are missing
or the digits are cutted by invisible limitation.
The display seems to be ok since the graphics demo runs witnout problems.
The according code fragment is:
unsigned long tmicros=0;
void draw(void) {
 u8g_uint_t len;
 u8g_uint_t hig;
 u8g.setFont(u8g_font_unifont);
 // u8g.setFont(u8g_font_osb21);
 tmicros=micros();
 u8g.drawStr( 0, 22, F("C:"));
 len=u8g.getStrWidth(F("C:"));
 // hig=u8g.getFOntAscent
 u8g.setPrintPos( len, 22 );
 u8g.print( tmicros);
void setup(void) {
 // flip screen, if required
 // u8g.setRot180();
Â
 // set SPI backup if required
 //u8g.setHardwareBackup(u8g_backup_avr_spi);
 // assign default color value
 if ( u8g.getMode() == U8G_MODE_R3G3B2 ) {
  u8g.setColorIndex(255);  // white
 else if ( u8g.getMode() == U8G_MODE_GRAY2BIT ) {
  u8g.setColorIndex(3);    // max intensity
 else if ( u8g.getMode() == U8G_MODE_BW ) {
  u8g.setColorIndex(1);    // pixel on
 else if ( u8g.getMode() == U8G_MODE_HICOLOR ) {
  u8g.setHiColorByRGB(255,255,255);
 u8g.setContrast( 50 );
void loop(void) {
 // picture loop
 u8g.firstPage();Â
 do {
  draw();
 } while( u8g.nextPage() );
Â
 // rebuild the picture after some delay
How can I display the digits correctly?
Thank you very much in advance for any help !
Best regards,
mcc
PS: Some more informations:
I had used this constructors, which no difference regarding the problem:
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE|U8G_I2C_OPT_DEV_0); // I2C / TWI
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_DEV_0|U8G_I2C_OPT_NO_ACK|U8G_I2C_OPT_FAST); // Fast I2C / TWI
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NO_ACK); // Display which does not send AC
The graphicsdemo of the u8glib shows no problems, the text output is somehow distorted as described above.
The display is directly connected to the Wattuino.
