The value that you read here with no current flowing through your sensor would be your offset.
The offset is the value that a sensor reports when nothing is happening....
According to the code that value is 512. Makes sense, that is exactly in the middle, so it can measure both positive and negative current.
Now: Does it really read 512 (value printed to Serial should be 0) if no current is flowing?
And: What does it read when a positive or negative current is flowing? If this number is significantly different from 512, we would know that the sensor is actually working... (step 1).
Use a 'slow' fuse (the ones used in cars are usually of 'slow' type). Those will allow a high rush in current for a short time even if it is much higher than the nominal value of the fuse.
A 'fast' fuse will burn out during the rush in...
I am not convinced the cheapy relay in the video will work voor long at this high current (and with an inductive load). A car relay would better.
The wires on the motor in the video tell me that 5A is probably the max. continuous current of the motor. As said: rush in or stall current may be much larger!
At 40A those wires will get so hot that insulation may be damaged.
OK I'm back on deck.
Here is the code I have at the moment.
#define Relay A1
int analogPin = A0; // Current sensor output
long int sensorValue = 0; // variable to store the sensor value read
Serial.begin(9600); // setup serial
pinMode(Relay, OUTPUT);
sensorValue = analogRead(analogPin);
// wait 2 milliseconds before the next loop
delay(200);
Serial.println("ADC Value: ");
Serial.println(sensorValue);
// set value on which you want to switch off Motor. normally motor oprate between value 512 to 525.
// I set 530 value on which motor switch off for 5 seconds.
if(sensorValue > 515)
digitalWrite(Relay, LOW);
delay(5000);
digitalWrite(Relay, HIGH);
I tried to make a video for you of the ADC working but I seem to be unable to download it to here. so here is some photos from the video. There does not seem to be any change in the numbers except when the motor stops so do the numbers scrolling.
I guess that means the sensor is not working.
I have tried 2 different sensors and they are both the same.
Soooo These sensors are not suitable for this application.
Do you think I try a different brand of sensor or do you have another suggestion?
#define Relay A1
delay(200);
if (sensorValue > 515)
delay(5000);
(You have to use the code tags, just click on the appropriate button in the toolbar.)
I got this error. Bugger, got it wrong some how. I think I forgot to change the relay to 5v. I only have 1 pin for 5v and the the current sensor is on it. Is there another pin somewhere? Photo of my Uno below
C:\Users\PC\AppData\Local\Temp.arduinoIDE-unsaved202441-4376-1o8du7j.v20n\sketch_may1b\sketch_may1b.ino: In function 'void loop()':
C:\Users\PC\AppData\Local\Temp.arduinoIDE-unsaved202441-4376-1o8du7j.v20n\sketch_may1b\sketch_may1b.ino:6:14: error: 'define' was not declared in this scope
void loop() {define Relay A1
C:\Users\PC\AppData\Local\Temp.arduinoIDE-unsaved202441-4376-1o8du7j.v20n\sketch_may1b\sketch_may1b.ino:6:14: note: suggested alternative: 'rewind'
rewind
C:\Users\PC\AppData\Local\Temp.arduinoIDE-unsaved202441-4376-1o8du7j.v20n\sketch_may1b\sketch_may1b.ino:11:14: error: a function-definition is not allowed here before '{' token
C:\Users\PC\AppData\Local\Temp.arduinoIDE-unsaved202441-4376-1o8du7j.v20n\sketch_may1b\sketch_may1b.ino:16:13: error: a function-definition is not allowed here before '{' token
exit status 1
Compilation error: 'define' was not declared in this scope
#define Relay A1 // not wrong but not preferred Arduino nomenclature or pin assignment
long int sensorValue = 0; // an int would be fine here, more than a big enough container
delay(200); // this is 200 milliseconds, just saying
// edited value for ease of observation
// but I set it at 325 to see both conditions with nothing attached to Arduino
if (sensorValue > 325)
delay(5000);
So this code works as far as I can tell, with nothing hooked up to my trusty Genuino Uno R3. The "out of scope" error is often due to misplaced curly braces in setup() or loop(). Did you delete one by mistake? If you click just to the right of any curly brace, the IDE will show you with either text or a nifty box where its mate is. Great feature if you ask me.
Also, get the relay off A1. The analog pins can be used as digital outputs, but it not the usual way. Maybe someone else here can comment, but I think your reading an analog signal on A0 and switching an OUTPUT on A1 can be introducing noise on your relay pin.
If you mean the new sketch, just save as whatever you like. Make it meaningful in your growing sketchbook though, maybe "projectActuatorV1" and then in setup(), right after Serial.begin(9600);, it's a good idea to print what sketch is on the Arduino, with version if applicable, so maybe:
Serial.println("projectActuatorV1");
Serial.println(); // just a blank line
delay(1000); // give yourself a sec to notice
I copy your code and place it after the brace on Void Loop. Is this correct? It states " // put your main code here, to run repeatedly:" Or should it go Void Setup? " // put your setup code here, to run once:"
You mean me? If so, here's your same code with the suggestions. Don't forget to change sensor threshold value to whatever you calibrate for.
const int analogPin = A0; // const because the pin assignment never changes
const int actuatorRelay = 7; // pin D7
int sensorValue = 0; // regular int because this value will change
Serial.println("projectActuatorV1"); // make sure this always matches sketch name
pinMode(actuatorRelay, OUTPUT);
delay(200);
Serial.print("ADC Value: ");
digitalWrite(actuatorRelay, LOW);
delay(5000);
digitalWrite(actuatorRelay, HIGH);
Oh, and super important: if you got something working as intended. make a note at the top of the sketch, like a comment. Say something to yourself like
// DO NOT MODIFY - WORKS AS INTENDED
Then make a new sketch, copy/paste the good one, delete the comment I just suggested you use for the good one, and make experimental changes to the copy - NEVER make experimental changes to the good working one.
delay(5000);
It comes up with this error
C:\Users\PC\Documents\Arduino\Actuator_Stop\Actuator_Stop.ino: In function 'void loop()':
C:\Users\PC\Documents\Arduino\Actuator_Stop\Actuator_Stop.ino:6:15: error: 'sensorValue' was not declared in this scope
void loop() { sensorValue = analogRead(analogPin);
C:\Users\PC\Documents\Arduino\Actuator_Stop\Actuator_Stop.ino:6:40: error: 'analogPin' was not declared in this scope
C:\Users\PC\Documents\Arduino\Actuator_Stop\Actuator_Stop.ino:6:40: note: suggested alternative: 'analogWrite'
analogWrite
C:\Users\PC\Documents\Arduino\Actuator_Stop\Actuator_Stop.ino:17:18: error: 'Relay' was not declared in this scope
C:\Users\PC\Documents\Arduino\Actuator_Stop\Actuator_Stop.ino:17:18: note: suggested alternative: 'delay'
delay
C:\Users\PC\Documents\Arduino\Actuator_Stop\Actuator_Stop.ino:22:18: error: 'Relay' was not declared in this scope
C:\Users\PC\Documents\Arduino\Actuator_Stop\Actuator_Stop.ino:22:18: note: suggested alternative: 'delay'
delay
C:\Users\PC\Documents\Arduino\Actuator_Stop\Actuator_Stop.ino: At global scope:
C:\Users\PC\Documents\Arduino\Actuator_Stop\Actuator_Stop.ino:28:1: error: expected declaration before '}' token
exit status 1
Compilation error: 'sensorValue' was not declared in this scope
Where do I put the sensor value and what value should I put?
