16 by 2 LCD only displaying half of screen
I have been using arduino for some time now and have been tinkering around with it. My most recent project is a camera slider and for the most part everything was going great until i came home and turned it on to be greeted with by LCD having blocks on the last 8 segments of both rows. I've searched for possible causes and checks continuity of my circuit and everything seems to be linked correctly, yet it still will not show the second portion of the screen. Please refer to the image to see what i'm talking about, i've also linked my code incase however it still contains my slider coding.
#include <MultiStepper.h>
#include <AccelStepper.h>
#include <LiquidCrystal.h>
AccelStepper stepperX;
#define home_switch 13
// Stepper Travel Variables
long TravelX;  // Value of stepper
int move_finished=1;
long initial_homing=-1;
long SpeedX;  //Value of speed
long AcccelX; //Value of acceleration
const int rs = 12, en = 11, d4 = 6, d5 = 7, d6 = 9, d7 = 8; // LCD
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
   lcd.begin(16,2);
   lcd.print("HOMING");
   lcd.setCursor(0, 1);
   lcd.print("Please Wait");
   pinMode(home_switch, INPUT_PULLUP);
   delay(5);
  stepperX.setMaxSpeed(200.0);
  stepperX.setAcceleration(100.0);
// Start Homing procedure of Stepper Motor at startup
  Serial.print("Stepper is Homing . . . . . . . . . . . ");
  while (digitalRead(home_switch)) {
    stepperX.moveTo(initial_homing);  // Set the position to move to
    initial_homing--;
    stepperX.run();  // Start moving the stepper
    delay(5);
  stepperX.setCurrentPosition(0);
  initial_homing=1;
  while (!digitalRead(home_switch)) { // Make the Stepper move CW until the switch is deactivated
    stepperX.run();
    initial_homing++;
    delay(5);
  Serial.println("Homing Completed");
  Serial.println("");
  stepperX.setMaxSpeed(300.0);
  Serial.println("Enter Travel distance (Positive for CW / Negative for CCW and Zero for back to Home): ");
  lcd.begin(16,2);
  lcd.setCursor(0, 0);
  lcd.print("Speed:");
  lcd.setCursor(7, 0);
  lcd.print(SpeedX);
  lcd.setCursor(8, 1);
  lcd.print(TravelX);
  lcd.print("Move to:");
  delay(3000);
  while (Serial.available()>0)  {
  move_finished=0;
  TravelX= Serial.parseInt();
  if (TravelX < 0 || TravelX > 1850) {  // Make sure the position entered is not beyond the HOME or MAX position
    Serial.println("");
    Serial.println("Please enter a value greater than zero and smaller or equal to 1850.....");
    Serial.println("");
    lcd.begin(16, 2);
    lcd.print("Wrong Value");
    lcd.print("Range: 0-1850");
    delay(2000);
    Serial.print("Moving stepper into position: ");
    Serial.println(TravelX);
  lcd.begin(16, 2);
  lcd.print("Moving to");
  lcd.setCursor(10, 0);
  lcd.print(TravelX);
  lcd.print(TravelX/60);
  stepperX.moveTo(TravelX);  // Set new moveto position of Stepper
  if (TravelX >= 0 && TravelX <= 1850) {
// Check if the Stepper has reached desired position
  if ((stepperX.distanceToGo() != 0)) {
    stepperX.run();  // Move Stepper into position
// If move is completed display message
  if ((move_finished == 0) && (stepperX.distanceToGo() == 0)) {
    Serial.println("COMPLETED!");
    Serial.println("");
    move_finished=1;
    lcd.begin(16, 2);
    lcd.print("Move completed");
    delay(2000);
    lcd.begin(16, 2);
    lcd.print(SpeedX);
    lcd.print(TravelX);
There are two chips (or more likely epoxy blobs) on the back of your display. One of them is the HD44780U (or equivalent) LCD controller and the other is an HD44100 (or equivalent) auxiliary controller chip.
The HD44780 contains the logic and the memory to deal with up to 80 characters but it only contains enough circuitry to deal with displaying 16 characters. Each HD44100 (there may be more than one on a larger display) adds the capability to display an additional 16 characters.
So, in your case it appears that either the HD44100 is defective or one or more of the pc board traces connected to that device has been damaged.
Don
