2.4 Inch TFT PCB
Hello.
can anyone help me give a custom pcb for the esp32 dev board to directly connect to the 2.4 inch tft plug to uno.
I would really appreciate it.
thank you
Could you provide a more detail about the project?
First of all - it is not clear to what board the TFT will be connected - to ESP32 or to Uno?
To esp32 Dev module
which 2.4" TFT are you using? give a link
have you considered a CYD_2.4inch_ESP32 - ESP32 and TFT on a single module - main problem is limited IO facilities - check user manual or schematic
It sounds like you may have a screen similar to this and want to connect it to an ESP32.
Is that correct ? https://de.aliexpress.com/item/1005006119518483.html
Do you also want to use the touch screen and the SD card reader ?
