Hello Im trying to interface 8 bit parallel TFT w/ NodeMCU. This is the module I have
I have tried david_prentice's MCUFRIEND_kbv Library with some hacks to no avail. I tried to hack the library for ESP8266 (updated write_8 and read_8 functions in mcufriend_sheild.h and defined SUPPORT_4532) - using these connections
LCD_RST <=> RST
LCD_CS <=> GND
LCD_RS <=> GPIO15
LCD_WR <=> GPIO14
LCD_RD <=> 3V
LCD_D0 <=> GPIO0
LCD_D1 <=> GPIO1
LCD_D2 <=> GPIO2
LCD_D3 <=> GPIO3
LCD_D4 <=> GPIO4
LCD_D5 <=> GPIO5
LCD_D6 <=> GPIO12
LCD_D7 <=> GPIO13
Not sure if LCD_RST, LCD_CS and LCD_RD shortcuts are allowed by the library software.
Anyways - the first question at hand would be - is it possible to run 8 bit parallel tft w/ ESP8266, followed by - which library can do the job if possible.
hardcode the ID (0x9341) instead of reading it from the module as we have pulled LCD_RD to high.
Comment out serial comm parts as I am using TX and RX pins for data
After this I faced one issue - ESP8266 kept resetting during the test. Turns out the watchdog wasn't being fed periodically. Maybe some esp8266 guru or @david_prentice can suggest the right place for yeild(); function for WDT within the library. For now i went ahead and disabled the WDT (I know that's not a very intelligent thing to do - but for POC it works now). For now i disabled it via
The title says that you have an 0x4532 e.g. LGDP4532 controller.
There is NO WAY that a LGDP4532 will respond to 0x9341 commands.
Seriously. cbm80amiga has shown that you can use a ST7781 with NodeMcu if you forgo LCD_RD, and Serial comms. You just need to use LGDP4532 registers and commands if you have an LGDP4532.
But since an ESP32 has got more pins and it is almost as cheap as the ESP8266 it seems a false economy.
ESP8266 or ESP32 should complete the Adafruit Tests in about 1.0 seconds
From your Adafruit_Report photo, it detects the ID as 0xCFCF which is totally unknown (and unsupported)
Ah-ha. You are using a pin-starved NodeMCU board. Since you have no LCD_RD functionality, the tft.readID() means nothing.
What ID have you used for tft.begin(ID); ?
If you used tft.begin(0x4532); and it worked, you almost certainly have an LGDP4532.
If you used tft.begin(0x9341); and it worked, you probably have an ILI9341.
You can always plug your shield into a proper Uno. Then we can see exactly what you have got by running the regular examples.
