2 dc motor 1 adafruit motor sheild and 1 joystick
hi i'm working on an inspection robot project i need to controle a pan and tilt camera and 2 dc motor
i want to use a game controller (logitech, ps2, ps3, xbox) for even more option like relay or electric air valve
i've got the 2 servo to work with only a thumbstick. but controling the 2 motor not so easy..
i use an Adafruit motor sheild and after some research here is what i've comme with
i would like some help and or advice and please i am still a newbie
#include <AFMotor.h>
#include <SoftwareSerial.h>
AF_DCMotor motor(1,2, MOTOR12_64KHZ); // create motor #1, 64KHz pwm
int motor1;   // left side motor
int motor2;   // right side motor
int vertical; // y
int horizontal; // x
    pinMode(A0, INPUT);
    pinMode(A1, INPUT);
    pinMode(11,OUTPUT);     //motor 1
    pinMode(3,OUTPUT);      //motor 2
        horizontal = analogRead(A0); //Read the horizontal axis of the joystick
        vertical = analogRead(A1);     //Read the vertical axis of the joystick
        delay(5);
        //Back Forward
        if(vertical < 400 && horizontal > 500 && horizontal < 600)
                Serial.println( motor1.run(BACKWARD) motor2.run(BACKWARD));
                while(vertical < 400)
        //Left
        else if(horizontal < 400 && vertical > 500 && vertical < 600)
                Serial.println(motor1.run(BACKWARD)motor2.run(FORWARD));
                while(horizontal < 400)
        //Right
        else if(horizontal > 600 && vertical > 500 && vertical < 600)
                Serial.println(motor1.run(FORWARD)motor2.run(BACKWARD));
                while(horizontal > 600)
        //Forward
        else if(vertical > 600 && horizontal > 500 && horizontal < 600)
                Serial.println(motor1.run(FORWARD)motor2.run(FORWARD));
                while(vertical > 600)
        //Stop
        else if(horizontal > 500 && horizontal < 600 && vertical > 500 && vertical < 600)
                 Serial.println(motor1.run(RELEASE)motor2.run(RELEASE));
                 while(horizontal > 500 && horizontal < 600 && vertical > 500 && vertical < 600)
Ref this - which is likely what you want (based on your sparse description):
http://forum.arduino.cc/index.php?topic=311477.0
