AJLElectronics:
There will be a period of "floating in hyperspace" whilst the switch is passing through its travel. It shouldn't be a problem if you have debouced it in software, but I would go with a decent pullup externally (10K or so) and pull the D12 input to ground via the switch.
The floating during switching doesn't bother me. It will likely be switched four times a year, so the brief hyperspace will not affect the functioning of the device.
PerryBebbington:
There is nothing wrong with what you have done based on the schematic.
There might be something wrong with the code you have not shown us. Please, when you post it use code tags </>
It is also possible that your actual wiring is not as you think it is, maybe a photo of what you have would help us to know.
I suggest you create a simple program that reads D12 every 250ms or so then send 'High' or 'Low' to the serial monitor to show its status.
Please also read:
General guidance and
How to use this forum
Thanks.
Thanks for all the startup tips with this forum!
My code is in Dutch, so it's a bit harder to understand for you. I commented in the code at the relevant points.
//2x sensor and 1x switch
#define SensorBassinS1 A1
#define SensorSiloS2 A2
#define ZomerstandS3 12 //<input definition
//9x optocouplers
#define BassinStartBronpompUitK11 2
#define BassinStopBronpompUitK12 3
#define BassinStopInfiltrerenK13 4
#define BassinStartInfiltrerenK14 5
#define SiloMinimumNiveauK21 6
#define SiloStopInfiltrerenK22 7
#define SiloStartInfiltrerenK23 8
#define SiloStartVulpompK24 9
#define SiloStopVulpompK25 10
boolean Zomerstand; //<depends on the input
float S1V0 = 180; // 0.88 * (1023/5)
unsigned int S1m3pV = 3100;
float S2V0 = 180; // 0.88 * (1023/5)
unsigned int S2m3pV = 88;
const int BassinGrootteKuub = 3000;
const int SiloGrootteKuub = 22;
const byte SampleGrootte = 40;
float KuubBassin;
float KuubSilo;
int ProcentBassin;
int ProcentSilo;
int DrempelK11;
int DrempelK12;
int DrempelK13;
int DrempelK14;
unsigned int UitlezingS1;
unsigned int UitlezingS2;
char LaatsteDisplay = 'S';
LiquidCrystal_I2C lcd(0x27, 16, 2);
pinMode(SensorBassinS1, INPUT);
pinMode(SensorSiloS2, INPUT);
pinMode(ZomerstandS3, INPUT); //<the pinmode setting
pinMode(BassinStartBronpompUitK11, OUTPUT);
pinMode(BassinStopBronpompUitK12, OUTPUT);
pinMode(BassinStopInfiltrerenK13, OUTPUT);
pinMode(BassinStartInfiltrerenK14, OUTPUT);
pinMode(SiloMinimumNiveauK21, OUTPUT);
pinMode(SiloStopInfiltrerenK22, OUTPUT);
pinMode(SiloStartInfiltrerenK23, OUTPUT);
pinMode(SiloStartVulpompK24, OUTPUT);
pinMode(SiloStopVulpompK25, OUTPUT);
lcd.init();
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print("NIVEAUPROCESSOR");
lcd.setCursor(0, 1);
lcd.print("START METING...");
Meting();
RelaisAansturen();
//Shows both tanks alternatingly
if (LaatsteDisplay == 'B') {
DisplaySilo();
else {
DisplayBassin();
LaatsteDisplay = 'B';
void Meting() {
UitlezingS1 = 0;
UitlezingS2 = 0;
//takes amount of samples from each input sensor
for (byte i = 0; i < SampleGrootte; i++) {
UitlezingS1 += analogRead(SensorBassinS1);
UitlezingS2 += analogRead(SensorSiloS2);
delay(100);
//determines avarage and calculates real life value
UitlezingS1 /= SampleGrootte;
KuubBassin = map((UitlezingS1 - S1V0), 180, 215, 0, 3320);
ProcentBassin = ( KuubBassin / BassinGrootteKuub ) * 100;
UitlezingS2 /= SampleGrootte;
KuubSilo = map((UitlezingS2 - S2V0), 180, 185, 0, 22);
ProcentSilo = ( KuubSilo / SiloGrootteKuub ) * 100;
void DisplayBassin() {
lcd.clear();
lcd.print("BASSIN");
lcd.print(UitlezingS1); //printed for debugging
if (Zomerstand) { //<Zomerstand is defined further below
lcd.print('Z'); //printed for debugging
if (UitlezingS1 < S1V0) {
lcd.print("FOUT SENSOR");
else {
lcd.print((int)KuubBassin);
lcd.print("m3 / ");
lcd.print(ProcentBassin);
lcd.print("% ");
void DisplaySilo() {
lcd.clear();
lcd.print("ZANDSILO");
lcd.print(UitlezingS2);//printed for debugging
lcd.print('Z');//printed for debugging
if (UitlezingS2 < S2V0) {
else {
lcd.print((int)KuubSilo);
lcd.print("m3 / ");
lcd.print(ProcentSilo);
lcd.print("% ");
void RelaisAansturen() {
//Determines which thresholds to use for K11-K14
if (digitalRead(ZomerstandS3) == HIGH) { //<digitalRead of the input
DrempelK11 = 45;
DrempelK12 = 55;
DrempelK13 = 65;
DrempelK14 = 70;
Zomerstand = true; //<setting the Zomerstand variable
else {
DrempelK11 = 40;
DrempelK12 = 45;
DrempelK13 = 50;
DrempelK14 = 55;
Zomerstand = false; //<setting the Zomerstand variable
//Aansturen optocouplers
if (ProcentBassin > DrempelK11) {
digitalWrite(BassinStartBronpompUitK11, HIGH);
else {
digitalWrite(BassinStartBronpompUitK11, LOW);
if (ProcentBassin > DrempelK12) {
digitalWrite(BassinStopBronpompUitK12, HIGH);
else {
digitalWrite(BassinStopBronpompUitK12, LOW);
if (ProcentBassin > DrempelK13) {
digitalWrite(BassinStopInfiltrerenK13, HIGH);
else {
digitalWrite(BassinStopInfiltrerenK13, LOW);
if (ProcentBassin > DrempelK14) {
digitalWrite(BassinStartInfiltrerenK14, HIGH);
else {
digitalWrite(BassinStartInfiltrerenK14, LOW);
//Aansturing optocouplers zandsilo
if (ProcentSilo > 10) {
digitalWrite(SiloMinimumNiveauK21, HIGH);
else {
digitalWrite(SiloMinimumNiveauK21, LOW);
if (ProcentSilo > 60) {
digitalWrite(SiloStopInfiltrerenK22, HIGH);
else {
digitalWrite(SiloStopInfiltrerenK22, LOW);
if (ProcentSilo > 70) {
digitalWrite(SiloStartInfiltrerenK23, HIGH);
else {
digitalWrite(SiloStartInfiltrerenK23, LOW);
if (ProcentSilo > 80) {
digitalWrite(SiloStartVulpompK24, HIGH);
else {
digitalWrite(SiloStartVulpompK24, LOW);
if (ProcentSilo > 90) {
digitalWrite(SiloStopVulpompK25, HIGH);
else {
digitalWrite(SiloStopVulpompK25, LOW);
