I´m pretty new to using Arduino and coding, but I´m trying to run a Nidec 24h motor using an Arduino uno. According to the pinout sheet the motor needs a 20-30kHz PWM and duty cycle 20-100%.
How can I obtain a code to do that for me?
Would 32KHz be OK? Pretty sure Uno can do that.
Moved to Programming Questions....Please don't post in Uncategorized again.
I´m not sure, its the motor that requires it, but I can try
Which PWM pin on Uno are you using?
Different PWM pins use different internal hardware timers, so its important to know which timer needs to be changed to a higher frequency.
If you are using pins 5 or 6, I would recommend changing to use a different PWM pin. If you change the frequency for those pins, it might affect how delay() and millis() work.
For pins 9 or 10, try adding this to setup():
// Pins D9 and D10 - 31.4 kHz
TCCR1A = 0b00000001; // 8bit
TCCR1B = 0b00000001; // x1 phase correct
For pins 3 or 11
// Pins D3 and D11 - 31.4 kHz
TCCR2B = 0b00000001; // x1
TCCR2A = 0b00000001; // phase correct
for now I use 11, but I have all of them available to change if necessary
It is done by "manipulating the chip's timer registers directly". Interesting to look into; google will give you everything you need.
Alternatively, there are a few different libraries that will do most of the work for you.
TimerOne comes to mind. This example in particular seems appropriate.
Note: as PaulRB was getting at, this library will only work for pins 9 and 10.
Follow up question, because I'm genuinely interested:
After setting TCCR1A / TCCR1B like that, can you adjust the duty with analogWrite(), or do you need to manually change OCR2A / OCR2B?
I think so, but test it. It might be necessary to set TCCR1A / TCCR1B each time after you use analogWrite().
I got the scope out and checked (UNO R3):
Calling analogWrite() doesn't seem to affect the clock select bits; setting the clock select bits doesn't seem to change the duty set by analogWrite(). Same behaviour on all pins, on all timers.
Which is neat!
The source of analogWrite() function is freely available, you can make sure that it doesn't affect a timer control registers.
That would have been, uh, a more intellectual way to go about it, yes..
Yes you can.
