24 bit read and write register of tdc7200 using SPI
am trying to read 24 bit register of tdc7200 but its reading zero every time please suggest me how to read 24 bit register …?
currently i am using function as below to reg 24 bit register if its wrong please guide me to get it correct
uint32_t readRegister24(byte address3)
SPI.begin(); // wake up the SPI bus.
SPI.beginTransaction(SPISettings(20000000, MSBFIRST, SPI_MODE0));
digitalWrite(SS1,LOW);
delay(1);
SPI.transfer(address3);
val1 = SPI.transfer(0xFF);
Serial.println(“val1”);
Serial.println(val1);
val2 = SPI.transfer(0xFF);
Serial.println(“val2”);
Serial.println(val2);
val3 = SPI.transfer(0xFF);
Serial.println(“val3”);
Serial.println(val3);
value = (val1 << 16) + (val2 << 8) + val3;
Serial.println(“value”);
Serial.println(value);
digitalWrite(SS1,HIGH);
SPI.endTransaction();
SPI.end();
return value;
Regards,
Rashmi HM
If there is no need for a fast frequency of transfers, you can use shiftin() function instead of the SPI Library.
https://www.arduino.cc/reference/en/language/functions/advanced-io/shiftin/
An example sketch to retrieve 24-bit samplings from an ADS1244:
  ADS1244
int DATA = 4;
int SCLK = 5;
  pinMode(DATA, INPUT);
  pinMode(SCLK, OUTPUT);
  // generate a 2.4MHz clock signal on pin 3
  pinMode(3, OUTPUT);      //CLK
  // 17.11 Register Description
  TCCR2A = 0x33;  // 0011 0011
  TCCR2B = 0x09;  // 0000 1001
  OCR2A  = 0x06;  // 0000 0110
  OCR2B  = 0x03;  // 0000 0011
  Serial.print("ADS1244\n");    // output 'AADS1244' (?) additional 'A' in front
  delay(100);
  // Code for reading the data:
  int32_t value = 0;
  //digitalWrite(SCLK, HIGH);  //enter slleep mode
  delay(300);
  digitalWrite(SCLK, LOW);  // wake up ADC
  // wait for data ready, stay in while-loop until LOW
  while (digitalRead(DATA) == HIGH);
  value = shiftIn(DATA, SCLK, MSBFIRST);
  value <<= 8;
  value |= shiftIn(DATA, SCLK, MSBFIRST);
  value <<= 8;
  digitalWrite(SCLK, HIGH);  // enter sleep mode
  //digitalWrite(SCLK, LOW); // 25th pulse to keep DATA high till next data ready
  // process as int24_t (two's compliment 24bit)
  value = ((signed long) (value << 8)) >> 8;
  Serial.println(value, DEC);
  Serial.flush();
Hello, since am trying to read the data stored in register and not at the pin s i dint get how shiftin() will be helpful to me so please explain in brief ..
Regards, Rashmi H M
