2x2 matrix - 1 code working fine other not
Hello everyone.
I was trying to build upon 2 circuits from Arduino CookBook. Multiplexing LEDs 8x8 matrix. The code and circuit controls 64 LEDs with 16 pins. For understanding I built just a 2x2 matrix (which uses 4 pins - apparently not useful but by increasing number of LEDs in a row or column does not increase the no. of pins so the same circuit can be extended).
The problem which I am facing is that I am not able to control individual LEDs as described in code. Whole row lights up together instead of single LED when I use the simple 1 pin HIGH and 1 pin LOW method. With another method described in that book which uses bitRead and bitmaps, the same circuit works fine. I am pasting the 2 codes here as well as attaching my circuit diagram and breadboard configuration. Perhaps someone can explain me why I am not getting desired result with 1st method while getting it correctly with 2nd?
1st method: (I change the code for 2x2 matrix replacing 8 by 2, 63 with 3.)
matrixMpx sketch
Sequence LEDs starting from first column and row until all LEDS are lit
Multiplexing is used to control 64 LEDs with 16 pins
const int columnPins[] = { 10, 9};
const int rowPins[] = { 4, 3};
int pixel = 0; // 0 to 63 LEDs in the matrix
int columnLevel = 0; // pixel value converted into LED column
int rowLevel = 0; // pixel value converted into LED row
for (int i = 0; i < 2; i++)
pinMode(columnPins[i], OUTPUT); // make all the LED pins outputs
pinMode(rowPins[i], OUTPUT);
pixel = pixel + 1;
if(pixel > 3)
pixel = 0;
columnLevel = pixel / 2; // map to the number of columns
rowLevel = pixel % 2; // get the fractional value
for (int column = 0; column < 2; column++)
digitalWrite(columnPins[column], LOW); // connect this column to Ground
for(int row = 0; row < 2; row++)
if (columnLevel > column)
digitalWrite(rowPins[row], HIGH); // connect all LEDs in row to +5 volts
else if (columnLevel == column && rowLevel >= row)
digitalWrite(columnPins[column], LOW); // turn off all LEDs in this row
delayMicroseconds(300); // delay gives frame time of 20ms for 64 LEDs
digitalWrite(rowPins[row], LOW); // turn off LED
// disconnect this column from Ground
digitalWrite(columnPins[column], HIGH);
2nd code:
byte bigHeart[] = {
B01,
B11};
byte smallHeart[] = {
B11,
B10};
const int columnPins[] = { 9, 10};
pinMode(rowPins[i], OUTPUT); // make all the LED pins outputs
digitalWrite(columnPins[i], HIGH); // disconnect column pins from Ground
int pulseDelay = 800 ; // milliseconds to wait between beats
show(smallHeart, 800); // show the small heart image for 100 ms
show(bigHeart, 1600); // followed by the big heart for 200ms
delay(pulseDelay); // show nothing between beats
// routine to show a frame of an image stored in the array pointed to by the
// image parameter.
// the frame is repeated for the given duration in milliseconds
void show( byte * image, unsigned long duration)
unsigned long start = millis(); // begin timing the animation
while (start + duration > millis()) // loop until the duration period has passed
digitalWrite(rowPins[row], HIGH); // connect row to +5 volts
for(int column = 0; column < 2; column++)
boolean pixel = bitRead(image[row],column);
if(pixel == 1)
digitalWrite(columnPins[column], LOW); // connect column to Gnd
delayMicroseconds(300); // a small delay for each LED
digitalWrite(columnPins[column], HIGH); // disconnect column from Gnd
digitalWrite(rowPins[row], LOW); // disconnect LEDs
Whats wrong in 1st code and whats right in 2nd one? Secondly, i believe my circuit configuration is correct but if I am missing something and someone can point out?
I believe a pin is in undefined mode (neither HIGH nor LOW) until it is defined for 1st time in loop method. To return that pin to undefined mode again, should it be declared like
pinMode(pin no., INPUT);
? Is it correct way?
a quick glance at your first code:
for (int column = 0; column < 8; column++)
should be column < 2 since you do not have 8 columns in your matrix
it was by mistake as I copied it from the original code while writing this post.
first check your circuit to make sure you can control each led individually:
something like this should cycle through each LED in the matrix
digitalWrite(columnPins[0], LOW);
digitalWrite(rowPins[0], HIGH);
digitalWrite(rowPins[0], LOW);
digitalWrite(rowPins[1], HIGH);
digitalWrite(rowPins[1], LOW);
digitalWrite(columnPins[0], HIGH);
digitalWrite(columnPins[1], LOW);
digitalWrite(columnPins[1], HIGH);
you could try adding some temporary delays to your code to slow things down to see how the LEDs are being lit
also, your setup for method #1 should need a tweak
pinMode(columnPins, OUTPUT); // make all the LED pins outputs
pinMode(rowPins, OUTPUT);
to
arslanzaidi, do please go back to your fist post, select "Modify", highlight the code section and use the "Code" icon to mark it as such.
Makes it much more readable.
