3,5" SPI TFT Display ansteuern
Hallo,
Ich bräuchte Hilfe beim ansteuern dieses Displays
ICh habe es so an einem UNO angeschlossen ohne Touch und sd.
belegung
Die Libraries Adafruit_ILI9488 master habe ich installiert.
doch es erscheint nur ein heller hintergrund weiter nichts hier mal der Code
  This is our GFX example for the Adafruit ILI9488 Breakout and Shield
  ----> http://www.adafruit.com/products/1651
  Check out the links above for our tutorials and wiring diagrams
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional)
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
#include "SPI.h"
#include <Adafruit_GFX.h>
#include <ILI9488.h>
//#define TFT_CS         PA1
//#define TFT_DC         PB3
//#define TFT_LED        PB0
//#define TFT_RST        PB4
#define TFT_CS 10
#define TFT_DC 9
//#define TFT_LED
#define TFT_RST 8
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
ILI9488 tft = ILI9488(TFT_CS, TFT_DC, TFT_RST);
// If using the breakout, change pins as desired
//Adafruit_ILI9488 tft = Adafruit_ILI9488(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
  Serial.println("ILI9488 Test!");
  tft.begin();
  // read diagnostics (optional but can help debug problems)
  uint8_t x = tft.readcommand8(ILI9488_RDMODE);
  Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9488_RDMADCTL);
  Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9488_RDPIXFMT);
  Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9488_RDIMGFMT);
  Serial.print("Image Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9488_RDSELFDIAG);
  Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
  Serial.println(F("Benchmark                Time (microseconds)"));
  Serial.print(F("Screen fill              "));
  Serial.println(testFillScreen());
  Serial.print(F("Text                     "));
  Serial.println(testText());
  delay(3000);
  Serial.print(F("Lines                    "));
  Serial.println(testLines(ILI9488_CYAN));
  Serial.print(F("Horiz/Vert Lines         "));
  Serial.println(testFastLines(ILI9488_RED, ILI9488_BLUE));
  Serial.print(F("Rectangles (outline)     "));
  Serial.println(testRects(ILI9488_GREEN));
  Serial.print(F("Rectangles (filled)      "));
  Serial.println(testFilledRects(ILI9488_YELLOW, ILI9488_MAGENTA));
  Serial.print(F("Circles (filled)         "));
  Serial.println(testFilledCircles(10, ILI9488_MAGENTA));
  Serial.print(F("Circles (outline)        "));
  Serial.println(testCircles(10, ILI9488_WHITE));
  Serial.print(F("Triangles (outline)      "));
  Serial.println(testTriangles());
  Serial.print(F("Triangles (filled)       "));
  Serial.println(testFilledTriangles());
  Serial.print(F("Rounded rects (outline)  "));
  Serial.println(testRoundRects());
  Serial.print(F("Rounded rects (filled)   "));
  Serial.println(testFilledRoundRects());
  Serial.println(F("Done!"));
void loop(void) {
  for(uint8_t rotation=0; rotation<4; rotation++) {
    tft.setRotation(rotation);
    testText();
unsigned long testFillScreen() {
  unsigned long start = micros();
  tft.fillScreen(ILI9488_BLACK);
  tft.fillScreen(ILI9488_RED);
  tft.fillScreen(ILI9488_GREEN);
  tft.fillScreen(ILI9488_BLUE);
  return micros() - start;
unsigned long testText() {
  tft.setCursor(0, 0);
  tft.setTextColor(ILI9488_WHITE);  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(ILI9488_YELLOW); tft.setTextSize(2);
  tft.println(1234.56);
  tft.setTextColor(ILI9488_RED);    tft.setTextSize(3);
  tft.println(0xDEADBEEF, HEX);
  tft.println();
  tft.setTextColor(ILI9488_GREEN);
  tft.setTextSize(5);
  tft.println("Groop");
  tft.setTextSize(2);
  tft.println("I implore thee,");
  tft.setTextSize(1);
  tft.println("my foonting turlingdromes.");
  tft.println("And hooptiously drangle me");
  tft.println("with crinkly bindlewurdles,");
  tft.println("Or I will rend thee");
  tft.println("in the gobberwarts");
  tft.println("with my blurglecruncheon,");
  tft.println("see if I don't!");
unsigned long testLines(uint16_t color) {
  unsigned long start, t;
  int           x1, y1, x2, y2,
                w = tft.width(),
                h = tft.height();
  x1 = y1 = 0;
  y2    = h - 1;
  start = micros();
  for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
  x2    = w - 1;
  for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
  t     = micros() - start; // fillScreen doesn't count against timing
  x1    = w - 1;
  y1    = 0;
  y2    = h - 1;
  start = micros();
  x2    = 0;
  t    += micros() - start;
  x1    = 0;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = w - 1;
  x1    = w - 1;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = 0;
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
  unsigned long start;
  int           x, y, w = tft.width(), h = tft.height();
  start = micros();
  for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
  for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
  int           n, i, i2,
                cx = tft.width()  / 2,
                cy = tft.height() / 2;
  n     = min(tft.width(), tft.height());
  start = micros();
  for(i=2; i<n; i+=6) {
    i2 = i / 2;
    tft.drawRect(cx-i2, cy-i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
  unsigned long start, t = 0;
  int           n, i, i2,
                cx = tft.width()  / 2 - 1,
                cy = tft.height() / 2 - 1;
  for(i=n; i>0; i-=6) {
    i2    = i / 2;
    start = micros();
    tft.fillRect(cx-i2, cy-i2, i, i, color1);
    // Outlines are not included in timing results
    tft.drawRect(cx-i2, cy-i2, i, i, color2);
  return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
  int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
  start = micros();
  for(x=radius; x<w; x+=r2) {
    for(y=radius; y<h; y+=r2) {
      tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
  int           x, y, r2 = radius * 2,
                w = tft.width()  + radius,
                h = tft.height() + radius;
  // Screen is not cleared for this one -- this is
  // intentional and does not affect the reported time.
  start = micros();
  for(x=0; x<w; x+=r2) {
    for(y=0; y<h; y+=r2) {
      tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
  int           n, i, cx = tft.width()  / 2 - 1,
  n     = min(cx, cy);
  start = micros();
  for(i=0; i<n; i+=5) {
    tft.drawTriangle(
      cx    , cy - i, // peak
      cx - i, cy + i, // bottom left
      cx + i, cy + i, // bottom right
      tft.color565(0, 0, i));
unsigned long testFilledTriangles() {
  int           i, cx = tft.width()  / 2 - 1,
  start = micros();
  for(i=min(cx,cy); i>10; i-=5) {
    start = micros();
    tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
      tft.color565(0, i, i));
    tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
      tft.color565(i, i, 0));
  return t;
unsigned long testRoundRects() {
  int           w, i, i2,
  w     = min(tft.width(), tft.height());
  start = micros();
  for(i=0; i<w; i+=6) {
    i2 = i / 2;
    tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 0, 0));
unsigned long testFilledRoundRects() {
  int           i, i2,
  start = micros();
  for(i=min(tft.width(), tft.height()); i>20; i-=6) {
    i2 = i / 2;
    tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i, 0));
könnte mir da jemand weiter helfen.
vielen dank
Dann solltest du den Uno schnell von der Spannung trennen.
Dein Display kann nur 3,3 Volt an den Pins ab und der Uno liefert 5 Volt.
Du brauchst für SPI einen geeigneten Levelshifter, z. B. den CD4050.
Hier noch ein Beispiel zum Anschließen:
ok danke habe gerade einen von AZDelivery TXS0108E bestellt hoff der geht
So wie @HotSystems schreibt es ist ein 3,3V Display, auch wenn der Verkäufer schreibt das er ist auch für Arduino stimmt das nur zum teil, den es gibt auch 3,3 V Arduinos.
Um viel spaß mit dem Display haben, hole dir ein ESP8266 kosten nicht die Welt, und hat WIFI on Board :wink:
Meide YT Videos wo das Display wird am uno genutzt funktioniert 2. 3 Stunden Max. wenn schon, danach braust du neuen.
ich will das erst mal am uno testen es muss nachher am mega laufen
Las dir zeit bis das Modul kommt.
Es wird zu 100% mit Uno Mega funktionieren, jedoch wird nicht so schnell sein wie am ESP.
Ok, wird wohl funktionieren.
Ich kenne den nicht, was nichts heißen soll.
was ist esp ein Display
Such nach ESP8266, es ist auch ein Board wie Uno, Mega, Nano, nur mit WIFI, viel mehr Speicher aber 3,3V.
Was möchtest du konkret machen mit dem Display?
ich habe eine Große Steuerung mit dem Mega gebaut und es sind noch 10 Pins frei ich dachte ich könnte ein Bild anzeigen lasse bei bestimmten Aktionen
Ok dann warte bis das Modul kommt, sei nicht hektisch und klemme das Display nicht direkt an Uno Mega
Na ich bete das ich es noch nicht geschrottet habe
Hoffe auch.
Für Uno Mega ist die beste Lib vom Oli Kraus
danach nimmst du die Einstellung, bei allen Beispielen
Ucglib_ILI9341_18x240x320_HWSPI ucg(/*cd=*/ 9, /*cs=*/ 10, /*reset=*/ 8);
Das kannst du lasen auch bei Mega nur die Pins MOSI auf 51, SCK 52.
MISO ist bei dem Display nicht erforderlich.
Mit dem LED Pin kann man das Display ein , ausschalten
Danke für den Tip wenn ich den Levelshifter habe teste ich es
Habe alles jetzt am am UNO mit Levelshifter so verkabelt wie von HotSystems gezeigt wurde leider bekomme ich immer noch kein Bild
nicht mit meinem Sketch auch den von Oli Kraus. keine Reaktion auf dem Bildschirm.
mein Treiber-IC: ILI9488 für das Display vielleicht liegt es daran der ist bei Oli nicht drin.
Brauche immer noch Hilfe
Mit welchem Levelshifter hast du es aufgebaut ?
Ob der drin ist, kannst du doch selbst sehen.
Du musst den richtigen einstellen.
Ohne das funktioniert der nicht.
Das solltest du woher schreiben sollen,
Den kann zur zeit nur TFT_eSPI ist aber für 32Bit Systeme also nix mit
UNO, Mega.
LCDWcki kann den auch, nur der Treiber ist für RasPI und STS, also auch nix für dich.
Das größte SPI Display für UNO, Mega ist 2,8" mit ILI9431, der wird durch mehrere Lib unterstützt
er ist von AZDelivery Kompatibel mit TXS0108E
im Oli ist der Treiber Treiber-IC: ILI9488 nicht drin
und mein Sketch geht nicht
Das versteh ich jetzt nicht.
Du hast doch anfangs vom Adafruit Treiber geschrieben. Wieso jetzt ein anderer.
Und wenn du einen anderen Levelshifter nimmst, heiß es nicht, daß meine Beschreibung dazu passt. Du musst schon die Beschreibung zu dem von dir verwendeten Levelshifter verwenden.
ist auch für 32 Bit Systeme
#elif defined(ESP8266)
  #include <pgmspace.h>
#endif
#ifdef ARDUINO_STM32_FEATHER
Also wird auch nicht funktionieren, hol dir ein ESP8266, oder ESP32
