3-Speed, Reversible Fan (DC Motor, L293D IC)
I need help with my code.
Problem Statement:
Design circuitry hardware and code that will allow the change of 3 different speeds using one pushbutton and allow to change direction using another push button.
I have created the following circuit and the following code.
Can anyone please guide me as I am having trouble getting my code and project to work correctly.
#define spButton 5
#define dirButton 6
#define pwm1 3
#define pwm2 2
#define EN1 4
#define ledPin 13
boolean motorDir = 0;
int motorSp = 0;
int spVal = 0;
int speed1 = 120;
int speed2 = 188;
int speed3 = 255;
// Variables for reading and storing button state:
int speedButtonState;                // the current reading from the input speed pin
int lastSpeedButtonState = LOW;      // the previous reading from the input pin
int directionButtonState;            // the current reading from the input direction pin
int lastDirectionButtonState = LOW;  // the previous reading from the direction pin
// the following variables are long's because the time, measured in miliseconds, will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0;  // the last time the output pin was toggled
long debounceDelay = 50;    // the debounce time; increase if the output flickers
  pinMode(spButton, INPUT);
  pinMode(dirButton, INPUT);
  pinMode(pwm1, OUTPUT);
  pinMode(pwm2, OUTPUT);
  pinMode(ledPin, OUTPUT);
  // read the state of the switch into a local variable:
  int speedReading = digitalRead(spButton);
  if (speedReading != lastSpeedButtonState)  // If the button state is different from last time
    lastDebounceTime = millis();  // reset the debouncing timer
  if ((millis() - lastDebounceTime) > debounceDelay) {
    if (speedReading != speedButtonState) {
      speedButtonState = speedReading;  // Store the state of button in speedButtonState
      // only toggle the LED if the new button state is HIGH
      if (speedButtonState == HIGH) {
        digitalWrite(ledPin, HIGH);  //turn on the LED
        spVal = spVal + 1;
        if (spVal >= 4)  // When stat >= 4, set it as 0.
          spVal = 0;
      } else
        digitalWrite(ledPin, LOW);
  switch (spVal) {
    case 1:
      motorSp = analogRead(speed1);
      if (motorDir)
        analogWrite(pwm1, motorSp);
        analogWrite(pwm2, motorSp);
      if (!digitalRead(dirButton)) {  // If direction button is pressed
        while (!digitalRead(dirButton))
          ;                    // Wait until direction button released
        motorDir = !motorDir;  // Toggle direction variable
        if (motorDir)
          digitalWrite(pwm2, 0);
          digitalWrite(pwm1, 0);
        case 2:
          motorSp = analogRead(speed2);
          if (motorDir)
            if (motorDir)
            case 3:
              if (motorDir)
                if (motorDir)
What have you done to determine the error?
I had the direction control working but as I tried implementing my switch statements for each speed, the hardware stopped working. I am having trouble getting the switch statement to work for each speed with direction switching. I hope that makes sense. Lol
Makes sense!, But what have you done to debug your switch statememt? Are you using serial.Print() to show the location in your code and the value of your switch statement?
No, i am new at this. I was hope someone could guide but i will have a looking into debugging.
