Fan controller that controls nothing
So I am trying to make a fan speed controller using a Freenove ESP32 Wrover board. I want to be able to control the fan speed using PMW and have a squental push button going from OFF-LOW-MED-HIGH and cycling back to OFF. I am able to do a flashing light just out of testing, but the following code only give me a flashing onboard LED and a solid extarnal LED. The button does nothing.
Roger001.ino (1.2 KB)
  pinMode(8, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(10, INPUT_PULLUP);
  int counter=0;
digitalRead(10);
if (digitalRead(LOW);
  counter=counter+1);
switch (counter) {
  case 1:
    (counter==1);
    analogWrite(4, 85);
  case 2:
    (counter==2);
    analogWrite(4, 170);
  case 3:
    (counter==3);
    analogWrite(4, 255);
  default:
    analogWrite(4, 0);
    if (counter>=4)
      {counter=0;}
digitalWrite(8, HIGH);
  delay(150);
digitalWrite(8, LOW);
  delay(150);
Hi, @B3ND3R
Welcome to the forum.
Please post your code in the post?
Thanks... Tom.... :smiley: :+1: :coffee: :australia:
I will have to draw up the diagram later but it is as simple as I can I am using a LED in place of where the fan would be and I have the button wired as a pull-up circuit with a resistor
digitalRead(10);
  counter=counter+1);
There are sintax errors.
May be
if (digitalRead(10) == LOW) {
  counter = counter + 1;
work for you. :wink:
Hi, @B3ND3R
Can you please post this code also?
digitalRead(10);
Needs to be.
Thanks.. Tom.... :smiley: :+1: :coffee: :australia:
PS Semicolon edited :+1: @MaximoEsfuerzo
Without semicolon. :wink:
So I updated the code to
if (digitalRead(10) == LOW) { counter = counter + 1); }
and I get the following error
`ino:15:24: error: expected ';' before ')' token
15 | counter = counter + 1);
exit status 1
Compilation error: expected ';' before ')' token`
and I am running Arduino IDE 2.3.4
  • counter value is constantly re-initialized to 0 because is it local and not global
  • digitalRead(10); does set a variable to the state of the pin being read
  • if (digitalRead(LOW); counter=counter+1); doesn't make sense, look at what is inside the parenthesis
look this over
  • needs to use a valid PWM pin
  • decrements the speed from HIGH to Off
  • simply turns LED on when fan is on
// 3-speed PWM fan controller
const byte PinFan = 4;      // PWM pins are 3, 5, 6, 9, 10, 11
const byte PinLed = 8;
const byte PinBut = 10;
enum { LedOff = HIGH, LedOn = LOW };
byte butState;
int speed = 0;
void loop ()
    // adjust speed setting if button pressed
    if (isButPressed ())  {
        if (0 > --speed)
            speed = 3;
        Serial.print ("speed "); Serial.println (speed);
    // set pwm value for speed setting
    switch (speed) {
    case 3:
        analogWrite (PinFan, 255);      // high
        digitalWrite (PinLed, LedOn);
    case 2:
        analogWrite (PinFan, 170);      // medium
    case 1:
        analogWrite (PinFan,  85);      // low
    case 0:
        analogWrite (PinFan, 0);        // off
        digitalWrite (PinLed, LedOff);
bool
isButPressed ()
    byte but = digitalRead (PinBut);
    if (butState != but)  {     // state change
        butState  = but;
        delay (30);             // debunce
        return LOW == but;      // only return true if LOW
    return false;
void setup ()
    Serial.begin (9600);
    pinMode (PinFan, OUTPUT);
    pinMode (PinLed, OUTPUT);
    pinMode (PinBut, INPUT_PULLUP);
    butState = digitalRead (PinBut);
there's an extra parenthesis after the 1
You should find other pins to use instead of 8 and 10.
Gpio 6-11 are for flash memory.
My bad Ithe code I sent I was originally using a ESP32C3 DEV I changed the pins accordingly for the Freenove board. Which was a second board to verify it was not a hardware issue. I did look up what pins could do PMW and the digital I/O with pullup/pulldown capabilities.
Does that translate that your posted code is not the "real code"...?
No that is the code I am using I only changed the pins accordingly for the new board that is the code I will be using on that board specifically.
How would I setup the counter variable I only need it to be in 4 different values but to change between those values as the code runs
i showed how in my code using the speed variable
So that is the bool and if statement is how it is done correct.
Just trying to work it though so I understand for next time. The bool give a on-off input as a 1 or 0 what's the reason for the short delay of 30 millisecond. I am not quite understanding the if statement if you could elaborate on that for me.
bsides the various errors in your code, simply incrementing a counter whenever the buttow is LOW when pressed will
  • increment is 100s of time within the short time that it is pressed, and
  • there's no upper limit checked for to wrap from 0-4
isutPressed() returns true once when the button changes state and becomes LOW. This avoid incrementing some 1000s of times
and when pressed, it decrements speed, reseting it to 3, High speed, so that from 0 it goes to the High speed first, then subsequent button presses go to Medium, Low and Off.
So I have tried copying your code but it keeps saying is but pressed is not declared where am I missing it being declared
please post the code you get this error from
As you wish.
const byte ONBOR = 8;
const byte FAN = 4;
const byte BUTN = 10;
byte ButnState;
int SPEED = 6;
  pinMode(8, OUTPUT);
  pinMode(4, OUTPUT);
  ButnState = digitalRead (BUTN);
bool
isPressed ()
    byte BUT = digitalRead (BUTN);
  if (ButnState != BUT){
    ButnState = BUT;
    delay (30);
      return LOW == BUT;
  return false;
if (isPressed ()){
  if (0 > --SPEED)
    SPEED = 3;
  Serial.print ("Speed");
    Serial.println (SPEED);
/*  int counter=0;
if (digitalRead(10) == LOW) { counter = counter + 1; }
switch (SPEED) {
  case 0:
    analogWrite(FAN, 0);
  case 1:
    analogWrite(FAN, 85);
  case 2:
    analogWrite(FAN, 170);
  case 3:
    analogWrite(FAN, 255);
digitalWrite(ONBOR, HIGH);
  delay(150);
digitalWrite(ONBOR, LOW);
  delay(150);
