Hi, I'm trying to choose the right board for my next aplication where I need the lowest power consumption together with a very fast wake up
I have discovered the Standby Mode thats keep ON the oscilator allowing a very fast wake up in combination with very low consumption, however this consumtion is not reflected in datasheet
Active Mode 8MHz: 10 mA
Idle Mode 8MHz: 1.6 mA
Power Down Mode: 66µA
Has anyone trying the power consumption in Standby mode ? Looking at Google I only get the same (wrong?) table
SLEEP_MODE_IDLE: 15 mA
SLEEP_MODE_ADC: 6.5 mA
SLEEP_MODE_PWR_SAVE: 1.62 mA
SLEEP_MODE_EXT_STANDBY: 1.62 mA
SLEEP_MODE_STANDBY : 0.84 mA
SLEEP_MODE_PWR_DOWN : 0.36 mA
If you remove the voltage regulator and the power LED from the Pro Mini, you will have a "bare bones" Arduino.
Follow this tutorial to get the lowest power consumption possible (about 100 nA in Power_Down mode, IF there is a genuine ATmega328p on the board).
However, the chances are that it is not a genuine ATmega328p.
srnet
December 3, 2022, 6:41pm
3
A Pro Mini is very low cost.
If you want accurate real world figures for power consumption, then I would suggest buying one, and measuring the power consumption for real.
My ask was about Standby Mode, in that same link it's say about 0.84 mA that seems to me unreal
Thanks for the hint about the chip, I have read about it and I will buy a SparkFun model so I understand it's going to be a genuine chip
Gammon measured that for a genuine ATmega328p, and I and others have independently verified most, if not all of his measurements.
I can recommend the following for such measurements.
[PPK2]
https://www.nordicsemi.com/Products/Development-hardware/Power-Profiler-Kit-2
The Power Profiler Kit II (PPK2) is a standalone unit, which can measure and optionally supply currents all the way from sub-uA and as high as 1A on all Nordic DKs, in addition to external hardware.
The PPK2 is powered via a standard 5V USB cable, which can supply up to 500mA of current. In order to supply up to 1A of current, two USB cables are required.
An ampere meter only mode, as well as a source m…
