Hell.
I am having problems with old 32x16 dot RED GREEN display, i am unable to find working library, but i remember that when i bought it i managed to get it working fast and with no problem. Would be realy nice if it would support 32x32 dots.
Most of the LED matrix libraries I find are for the MAX7219 but yours uses 74HC595. This library looks like it might work:
I does say you can control multiple panels.
Tryed that one samehow dos not work
i get this EROOR
loop:24: error: no matching function for call to 'LEDMatrix::LEDMatrix(int, int, int, int, int, int, int, int)'
LEDMatrix matrix(4, 5, 6, 7, 8, 9, 10, 11);
C:\Users\Linas\AppData\Local\Temp\arduino_modified_sketch_978029\loop.ino:24:42: note: candidates are:
In file included from C:\Users\Linas\AppData\Local\Temp\arduino_modified_sketch_978029\loop.ino:18:0:
C:\Program Files (x86)\Arduino\libraries\ShiftRegisterLEDMatrixLib-master\src/LEDMatrix.h:65:2: note: LEDMatrix::LEDMatrix(int, int, bool, bool, unsigned int, int)
LEDMatrix(
C:\Program Files (x86)\Arduino\libraries\ShiftRegisterLEDMatrixLib-master\src/LEDMatrix.h:65:2: note: candidate expects 6 arguments, 8 provided
C:\Program Files (x86)\Arduino\libraries\ShiftRegisterLEDMatrixLib-master\src/LEDMatrix.h:25:7: note: constexpr LEDMatrix::LEDMatrix(const LEDMatrix&)
class LEDMatrix : public BaseLEDMatrix {
C:\Program Files (x86)\Arduino\libraries\ShiftRegisterLEDMatrixLib-master\src/LEDMatrix.h:25:7: note: candidate expects 1 argument, 8 provided
C:\Users\Linas\AppData\Local\Temp\arduino_modified_sketch_978029\loop.ino: In function 'void setup()':
loop:71: error: 'class LEDMatrix' has no member named 'begin'
matrix.begin(displaybuf, WIDTH, HEIGHT);
C:\Users\Linas\AppData\Local\Temp\arduino_modified_sketch_978029\loop.ino: In function 'void loop()':
loop:79: error: 'class LEDMatrix' has no member named 'scan'
matrix.scan();
loop:83: error: 'class LEDMatrix' has no member named 'clear'
matrix.clear();
Multiple libraries were found for "LEDMatrix.h"
Used: C:\Program Files (x86)\Arduino\libraries\ShiftRegisterLEDMatrixLib-master
Not used: C:\Program Files (x86)\Arduino\libraries\Ultrathin_LED_Matrix-master
exit status 1
Here's the clue to the problem:
aliumas147:
You have two libraries installed that both contain a file named LEDMatrix.h. The code you're trying to compile is written for the Ultrathin_LED_Matrix library but the Arduino IDE chose the file from the ShiftRegisterLEDMatrixLib library.
Have you tried using the ShiftRegisterLEDMatrixLib library already? If not, it might be worth trying to get that one to work first since the Arduino IDE prefers it. You will find its example sketches under File > Examples > Shift Register LED Matrix Lib. If you determine that library to not be suitable you can then delete it from your computer, which will permit you to try the Ultrathin_LED_Matrix library.
Did you manage to get this working?#
I'm looking at getting this which looks like the same thing so just wondering how you got on.
