3D Printer Program
Hi guys i want to build a 3d printer, i have alredy my design and otw to buy the item, but i wonder the different design is required a different program to the arduino? Thanks in advance
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
There are several popular firmwares for 3D printers. I use Marlin. Do a Google search for "3d printer firmware" to see more alternatives.
I have see some youtube video about the turtorial diy but i plan on just changing the z axis mounting does it need a change in the firmware?
I have zero information to base an answer to that question on. I know nothing of your Z axis setup nor do I know what firmware of which you speak.
Firmware is using Marlin too, but this setup is using z axis like the Tarantula I3, because the mounting of the pulley of z axis where attached to the hot end is not available in my country, i plan to change it to the creality cr-10 mounting on the hot end pulley
