Hi I have a 4 digit 7 segment display with the setup: Arduino 4 Digit 7 Segment Display Tutorial
Now I'm using the code:
int i=0;
DDRD=0xff; // all pins 0-7 OUTPUTs
DDRB=0xff; // all pins 8-13 OUTPUTs even though we only use pins 8-12
PORTD=0x00; // make pins 0-7 LOWs
PORTB=0x00; // make pins 8-13 LOWs
while(1){
turnOnSquare(1);
displayDigit(8);
delay(2);
turnOnSquare(2);
displayDigit(8);
delay(2);
turnOnSquare(3);
displayDigit(8);
delay(2);
turnOnSquare(4);
displayDigit(8);
delay(2);
// paste the two functions after this line.
void displayDigit(int num)
switch(num)
case 0:
PORTD=B00000011; // pins 2-7 on
digitalWrite(8,HIGH); // turn off pin 8
case 1:
PORTD=B11100111; // only pins 2 and 3 are on
case 2:
PORTD=B10010011; // only pins 2,3,5 and 6 on
digitalWrite(8,LOW); // segment g on
case 3:
PORTD=B11000011; // only pins 2,3,4 and 5 on
case 4:
PORTD=B01100111; // only pins 3,4 and 7 on
case 5:
PORTD=B01001011; //B10110100; // only pins 2,4,5 and 7 on
case 6:
PORTD=B00001011; //B11110100; // only pins 2,4,5,6 and 7 on
case 7:
PORTD=B11100011; // only pins 2,3 and 4 on
digitalWrite(8,HIGH); // segment g off
case 8:
digitalWrite(8,LOW); // turn on pin 8
case 9:
PORTD=B01000011; // only pins 2,3, 4 and 5 on
void turnOnSquare(int num)
int d1=9,d2=10,d3=11,d4=12;
switch(num)
case 1:
digitalWrite(d2,LOW);
digitalWrite(d3,LOW);
digitalWrite(d4,LOW);
digitalWrite(d1,HIGH);
case 2:
digitalWrite(d1,LOW);
digitalWrite(d2,HIGH);
case 3:
digitalWrite(d3,HIGH);
case 4:
digitalWrite(d4,HIGH);
default:
// this should never occur, but do what you want here
So when I turn it on it displays 88:88 like I want it to but lets say I change the code so it'll display 12:34. It displays the top part of the one but not the top part of the two, the three is fine and the bottom leg of the four is gone. It works when I have all 8's so a segment isn't blown but it still act funny.
Please help
