Hello! I'm pretty new to Arduino, but I have gone through helpful tutorials, and I think I have a grasp on beginner concepts, but I have a project idea that I'm struggling with.
The end goal is to connect an ultrasonic sensor to a 4 digit 7 segment display to display distance. Now, I've done some research on seven segment displays, but I still have some questions.
Here's my hardware:
5641AS Common Cathode 4 Digit 7 Segment Display
HC-SR04 Ultrasonic Sensor.
Here's some code that I got when I went to a tutorial video that I plan to use;
// 5461AS
int time = 5;
int pinA = 9;
int pinB = 8;
int pinC = 7;
int pinD = 6;
int pinE = 5;
int pinF = 4;
int pinG = 3;
int pinDP = 2;
int DIG1 = 13;
int DIG2 = 12;
int DIG3 = 11;
int DIG4 = 10;
void choose_digit(char num) {
switch(num) { default: // 0
default value digitalWrite(pinA, HIGH);
digitalWrite(pinB, HIGH);
digitalWrite(pinC, HIGH);
digitalWrite(pinD, HIGH);
digitalWrite(pinE, HIGH);
digitalWrite(pinF, HIGH);
digitalWrite(pinG, LOW);
digitalWrite(pinDP,LOW);
case 1:
digitalWrite(pinA, LOW);
digitalWrite(pinD, LOW);
digitalWrite(pinE, LOW);
digitalWrite(pinF, LOW);
case 2:
digitalWrite(pinC, LOW);
digitalWrite(pinG, HIGH);
digitalWrite(pinDP, LOW);
case 3:
case 4:
case 5:
digitalWrite(pinB, LOW);
case 6:
case 7:
case 8:
case 9:
void pick_digit(int digit) {
digitalWrite(DIG1, HIGH);
digitalWrite(DIG2, HIGH);
digitalWrite(DIG3, HIGH);
digitalWrite(DIG4, HIGH);
switch(digit) {
case 1:
digitalWrite(DIG1, LOW);
case 2:
digitalWrite(DIG2, LOW);
case 3:
digitalWrite(DIG3, LOW);
default:
digitalWrite(DIG4, LOW);
void decimal_place() {
digitalWrite(pinDP, HIGH);
void seven_segment(int number) {
unsigned char thousands = int (number/1000);
unsigned char hundreds = int ((number/100)%10);
unsigned char tens = int ((number/10)%10);
unsigned char ones = int (number%10); //1234
choose_digit(thousands);
pick_digit(1);
delay(time); choose_digit(hundreds);
pick_digit(2);
delay(time); choose_digit(tens);
pick_digit(3);
decimal_place(); // add decimal point
delay(time); choose_digit(ones);
pick_digit(4);
delay(time);
void setup() { pinMode(DIG1, OUTPUT);
pinMode(DIG2, OUTPUT);
pinMode(DIG3, OUTPUT);
pinMode(DIG4, OUTPUT);
pinMode(pinA, OUTPUT);
pinMode(pinB, OUTPUT);
pinMode(pinC, OUTPUT);
pinMode(pinD, OUTPUT);
pinMode(pinE, OUTPUT);
pinMode(pinF, OUTPUT);
pinMode(pinG, OUTPUT);
pinMode(pinDP,OUTPUT);
void loop() { int sensor_value = analogRead(A0);
Serial.println(sensor_value); seven_segment(sensor_value); delay(1);
And here are my questions:
1: How do you hook up the display?
I generally understand the pinout diagram idea, but online there is not one consistent way of hooking up the display. I've seen that transisors are part of the diagram as well as resistors, but I've also seen a lack of transistors work. I'd prefer not to use a shift register or transistors -- preferably just resistors, but I don't want to break anything on the display or my board. What should I do?
2: How does the display ground?
I'm just used to grounding things on the GND pin on my board, but on a diagram, they didn't use the GND pin; they just hooked it up to other pins. Now, with a bit more reading, I can accept hooking up an LED to two pins and setting one LOW for grounding it, but that's just one LED. How does this work on a 7 segment display? Is it with multiplexing setting only one digit on at a time, and then the electricity can ground through another display pin? So then, if you wrote all four digital pins as LOW (AKA ON), would that not work because there would be no ground and therefore no flow? Can someone explain this whole grounding idea?
Thanks for the help!!!
