433 MHz communication not working (virtualwire)
Hello !
After many research, I can't troubleshot that one :
I used the RX470-4 receiver and WL102-341 emitter (https://ae01.alicdn.com/kf/H07e734f33da142199914cc7499d1f811k.jpg).
Connected the standard way on stable 5v to arduino Nano (328p with oldbootloader), D12 for the emitter and D11 for the receiver.
I used the exemple codes of the virtualwire library for both of them. The emitter does red blinks as written in the code when sending data. But nothing happen to the receiver (no led blink nor messages on the serial monitor).
I tried with another arduino nano plus another 433MHz receiver, same results.
Tested both at short distance (10cm) or medium one (3/4m).
Do I have any way to verify (through code or tension measurements) what's working and what's not ? Do you have any idea what's wrong ?
At the emitter side, the tension between data and ground is around 2.5v (probably 0 and 5v at high rate) when vw_send is active, and 0v when vw_send is not active. This proves me that the emitter is working properly. On the receiver side I always have 0.6v-3v on data no matter the code.
I've successfully manage to establish communication a year ago, I was using a classic arduino UNO at the receiver side. Maybe my receiver here doesn't like the arduino Nano.
Thank you so much ! I feel stuck
Please post the code, using code tags, and a photo of a hand-drawn wiring diagram, with pins and connections clearly labeled.
You can test the code without the radios, by simply connecting the radio TX pin on one Arduino to the radio RX pin on the other. Don't forget to connect the grounds (GND).
have a read of how-to-get-the-best-out-of-this-forum
could you
  1. upload your receiver and transmitter code using code tags </>?
  2. provide links to the original modules?
  3. upload a schematic showing how you have wired the modules and powered them
Emitter code
// transmitter.pde
// Simple example of how to use VirtualWire to transmit messages
// Implements a simplex (one-way) transmitter with an TX-C1 module
// See VirtualWire.h for detailed API docs
// Author: Mike McCauley (mikem@airspayce.com)
// Copyright (C) 2008 Mike McCauley
// $Id: transmitter.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
#include <VirtualWire.h>
    Serial.begin(9600);	  // Debugging only
    Serial.println("setup");
    // Initialise the IO and ISR
    //vw_set_ptt_inverted(true); // Required for DR3100
    vw_setup(2000);	 // Bits per sec
    const char *msg = "hello";
    digitalWrite(13, true); // Flash a light to show transmitting
    vw_send((uint8_t *)msg, strlen(msg));
    vw_wait_tx(); // Wait until the whole message is gone
    digitalWrite(13, false);
    delay(200);
Receiver code :
// receiver.pde
// Simple example of how to use VirtualWire to receive messages
// Implements a simplex (one-way) receiver with an Rx-B1 module
// $Id: receiver.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
    vw_rx_start();       // Start the receiver PLL running
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
	int i;
        digitalWrite(13, true); // Flash a light to show received good message
	// Message with a good checksum received, dump it.
	Serial.print("Got: ");
	for (i = 0; i < buflen; i++)
	    Serial.print(buf[i], HEX);
	    Serial.print(" ");
	Serial.println("");
Here it is guys :wink:
By radio TX and radio RX pin, do you mean the TX/RX pin ? or the D11/D12 pin I'm using for the 433MHz emitter/receiver device ?
Yes, those pins.
if I run the code of post 4 on rf-433mhz-transmitter-receiver-modules connected to UNOs
it works OK the receiver serial monitor displays
setup
Got: 68 65 6C 6C 6F
Got: 68 65 6C 6C 6F
Got: 68 65 6C 6C 6F
Got: 68 65 6C 6C 6F
are you sure this code works on RX470-4 receiver and WL102-341 emitter ?
it is also worth noting VirtualWire library has now been superceded by the RadioHead library
Connecting D11 to D12, and GND to GND,I also obtain the same result (Got: 68 65 6C 6C 6F), so the program works fine, also succeed with my personnal code (sending "m1" or "m2").
But still no 433MHz connection. I changed the emitter voltage (from 5v to 3.3v as the datasheet required), still nothing. Also tried to change the data pin (D7 for emitter and D8 for receiver, plus specify that on the code with vw_set_rx_pin(8); and vw_set_tx_pin(7); ).
Also tried with brand new emitter/receiver (same models) and nothing works too...
Nothing could work, but I still have the TX led blinking on the emitter side, so I believe the problem comes from the receiver, probably a bad compatibility between the 433MHz receiver module and my Nano board. I will buy an UNO to verify that.
Also my Nano board comes from Aliexpress, it should not be a clone but the real board with a Atmel mega328p chip as written on it, and until now it works perfectly with different library.
tried receiver code on Nano and works OK - same output as post 7
Nice test. A real wire to eliminate the RF nature of the virtual wire.
The LEDs on either module are no indication of anything except that they are not burnt out.
Your test almost certainly proves that one or the other is faulty, they are not in tune or your antenna solution is inadequate, or the modules are too close or incompatible.
I wasted spent lotsa time using the simple 433 MHz R/T pairs. They can be made to work.
Essential is to start with the most basic code you did not write, using the circuits you did not design and the antennae and module spacing recommended for valid testing.
Find and purchase a respected pair of these devices. I haven't in years, or I say which ones have worked for me.
Alternative is to buy a keyfob/receiver works out of the box pair, and hijack it for your own purposes.
Not cheating. Life is short.
a7
Qiachip WL102+RX470 Module kit 433Mhz connect to a Nano and UNO so
ran the code of post 4 OK
