Hi guys
I began to work with the display "4DLCD-FT843" (4.3" SPI Display with embedded FT800 and Resistive Touch) with the shield "4Display-FT843-ADAM" on Arduino one, and I got this code (attaching code) from (http://forum.arduino.cc/index.php?topic=296126.0). But I don't understand how set the ISP module. Because now I want work with the Launchpad Tiva-C-TM4C123G.
I hope that anyone can help me with this. I am frustrated.
Regards!
- Copyright (c) Future Technology Devices International 2014
- propriety of Future Technology devices International.
- Software License Agreement
- This code is provided as an example only and is not guaranteed by FTDI.
- FTDI accept no responsibility for any issues resulting from its use.
- The developer of the final application incorporating any parts of this
- sample project is responsible for ensuring its safe and correct operation
- and for any consequences resulting from its use.
/ - @file HelloWorld.ino
@brief Sketch to display hello world on FT800.
Tested platform version: Arduino 1.0.4 and later - @version 0.1.0
- @date 2014/17/05
/* This application demonstrates the usage of FT800 library on FT_ADAM_4DLCD_FT843 platform */
/* Arduino standard includes */
#include "SPI.h"
#include "Wire.h"
/* Platform specific includes */
#include "FT_ADAM_4DLCD_FT843.h"
/* Global object for FT800 Implementation */
FT800IMPL_SPI FTImpl(FT_CS_PIN,FT_PDN_PIN,FT_INT_PIN);
/* Api to bootup ft800, verify FT800 hardware and configure display/audio pins /
/ Returns 0 in case of success and 1 in case of failure */
int16_t BootupConfigure()
uint32_t chipid = 0;
FTImpl.Init(FT_DISPLAY_WQVGA_480x272);//configure the display to the WQVGA
delay(20);//for safer side
chipid = FTImpl.Read32(FT_ROM_CHIPID);
/* Identify the chip */
if(FT800_CHIPID != chipid)
Serial.print("Error in chip id read ");
Serial.println(chipid,HEX);
return 1;
/* Set the Display & audio pins */
FTImpl.SetDisplayEnablePin(FT_DISPENABLE_PIN);
FTImpl.SetAudioEnablePin(FT_AUDIOENABLE_PIN);
FTImpl.DisplayOn();
FTImpl.AudioOn();
return 0;
/* API to display Hello World string on the screen /
void HelloWorld()
/ Change the below string for experimentation */
const char Display_string[12] = "Hello World";
/* Display list to display "Hello World" at the centre of display area */
FTImpl.DLStart();//start the display list. Note DLStart and DLEnd are helper apis, Cmd_DLStart() and Display() can also be utilized.
FTImpl.ColorRGB(0xFF,0xFF,0xFF);//set the color of the string to while color
FTImpl.Cmd_Text(FT_DISPLAYWIDTH/2, FT_DISPLAYHEIGHT/2, 29, FT_OPT_CENTER, Display_string);//display "Hello World at the center of the screen using inbuilt font handle 29 "
FTImpl.DLEnd();//end the display list
FTImpl.Finish();//render the display list and wait for the completion of the DL
/* bootup the module and display "Hello World" on screen /
/ Initialize serial print related functionality */
/* Set the Display Enable pin*/
Serial.println("--Start Application--");
if(BootupConfigure())
//error case - do not do any thing
HelloWorld();
Serial.println("--End Application--");
/* Nothing in loop api */
