Hello Everyone,
4D Systems has just released our latest product, the 4Duino!
The 4Duino is an Arduino compatible display module with built-in 240x320 resolution TFT LCD Display with Resistive Touch, and Wi-Fi capabilities, perfect for IoT (Internet of Things) Applications.
At the heart of 4Duino is an ATmega32U4 8-bit microcontroller from Atmel. The same microcontroller is found on popular Arduino Leonardo. 4Duino features a 2.4” colour TFT LCD display, with resistive touch. It is powered by the feature-rich 4D Systems Picaso Graphics Processor, which offers an array of display functionality and options for any Designer/ Maker. In addition, the 4Duino features the popularESP8266 Wi-Fi module which is pre-programmed with the AT command set firmware, enabling the 4Duino to have many Wi-Fi capabilities right out of the box.
The 4Duino also features an on-board microSD connector, and headers in the layout of an Arduino, including power pins (5V, 3.3V, GND and VIN), 20 digital IO pins, of which 7 can be used PWM outputs and 12 pins have Analog input capabilities.
The 4Duino is easily programmable with the Workshop4 IDE and its 3 different 4Duino based development environments.
The Workshop4 IDE has new functionally added, and is now able to program the on-board Atmel processor using the popular Arduino programming language, just like the popular Arduino IDE, but with the added dimension of graphics – with the aid of the 4D Systems Picaso GPU. Creating Arduino based GUI’s does not get any easier.
The 4Duino design has incorporated a TFT LCD Touchscreen Display and Wi-Fi solution with the intention of providing a flexible and hugely capable hardware platform. This will enable Markers and Designer to significantly improve the quality and the scope of their projects, and do so rapidly with the aid of the 4D Systems Workshop4 IDE.
Check out all the details on the 4duino.com website, and from the 4D Systems website.
http://www.4dsystems.com.au/product/4Duino_24/
You can program the 4Duino using the Arduino IDE. You can program the 4Duino from the Workshop4 IDE too! Program Arduino code directly into the Workshop4 IDE, and have all the benefits that come from using a 4D Systems GPU.
If you have questions or need support, we have just set up an area on our forum. Ask away!
4D Systems Forum - 4Duino Area
There are a number of example projects and videos up on the 4duino.com website too.
Enjoy!!
