4x Motor 4x BTS7960 problem, Arduino Uno
Hello, could you help me solve the problem?
I use an Arduino Uno as a controller, four bts7960 drivers (IBT-2) and four 24v 250w motors with worm gear (120 rpm output).
I have the principle of tank control.
I use PWM control, the right drivers are connected to pins 6, 5. The left drivers are connected to pins 10,9.
Everything works fine as I intended, but there is one thing.
After working from 5 to 15 minutes, one driver stops working in one direction, this is always driver number 4. I thought the problem is that the control signals to the driver quickly switches its potentials and the h-bridge does not have time to switch, so I set the switching time to almost the maximum(....setDeadtime(16000);), but the result is the same.
I have already burned 3 drivers, having tested the burnt driver, it does not burn out completely, only one direction of rotation burns out (when the maximum PWM signal is applied at the output of 0 volts), in the second direction of rotation, when the maximum PWM signal is applied, approximately 70% volts from the battery supply voltage.
Do you have any idea what could be the problem?
I use Li-ion 24 volts to power the power section and Twinhex 2596 LM2596 to convert to 5 volts and power the logic.
PWM_input_chanel_1 2 and PWM_input_chanel_2 3 - these are inputs from radio control receiver, but I think it does not matter, since before that I just controlled the joystick reading the analog signal.
connection diagram
arduino code
#include <GyverMotor2.h>
#include <avr/wdt.h>
#define PWM_input_chanel_1 2
#define PWM_input_chanel_2 3
volatile unsigned long start_time_pwm_1 = 0;
volatile unsigned long current_time_pwm_1 = 0;
volatile unsigned long pulses_pwm_1 = 0;
int pulses_width_1 = 0;
volatile unsigned long start_time_pwm_2 = 0;
volatile unsigned long current_time_pwm_2 = 0;
volatile unsigned long pulses_pwm_2 = 0;
int pulses_width_2 = 0;
volatile int int_1 = 0;
volatile int int_2 = 0;
GMotor2<DRIVER2WIRE_PWM> MOTOR_R(6, 5);
GMotor2<DRIVER2WIRE_PWM> MOTOR_L(10, 9);
  wdt_enable(WDTO_8S);
  MOTOR_L.setMinDuty(0);
  MOTOR_L.smoothMode(true);
  MOTOR_L.setSmoothSpeed(15);
  //MOTOR_L.reverse(1);
  MOTOR_L.setDeadtime(16000);
  MOTOR_R.setMinDuty(0);
  MOTOR_R.smoothMode(true);
  MOTOR_R.setSmoothSpeed(15);
  //MOTOR_R.reverse(1);
  MOTOR_R.setDeadtime(16000);
 pinMode(PWM_input_chanel_1, INPUT_PULLUP);
 pinMode(PWM_input_chanel_2, INPUT_PULLUP);
 attachInterrupt(digitalPinToInterrupt(PWM_input_chanel_1),PulseTimer1,CHANGE);
 attachInterrupt(digitalPinToInterrupt(PWM_input_chanel_2),PulseTimer2,CHANGE);
 MOTOR_R.setSpeed(0);
 MOTOR_L.setSpeed(0);
  wdt_reset();
  if(micros() - start_time_pwm_1 > 300000){
    int_1 = 0;
  if(micros() - start_time_pwm_2 > 300000){
    int_2 = 0;
  if(pulses_pwm_1 <= 2100 && pulses_pwm_2 >= 900){
      pulses_width_1 = pulses_pwm_1;
  if(pulses_pwm_2 <= 2100 && pulses_pwm_2 >= 900){
      pulses_width_2 = pulses_pwm_2;
  int spd_1 = percentSpeedFromRaw(pulses_width_1);
  int spd_2 = percentSpeedFromRaw(pulses_width_2);
  MOTOR_L.tick();
  MOTOR_R.tick();
  if(int_1 == 1 && int_2 == 1){
  MOTOR_R.setSpeed(spd_1);
  MOTOR_L.setSpeed(spd_2);
  }else{
int percentSpeedFromRaw(int value) {
  value = (value < 1000) ? 1000 : value;
  value = (value > 2000) ? 2000 : value;
  int valueDelta = 50;
  int middleRawValue = 1500;
  int minSpeedPercent = 5;
  if ( value > (middleRawValue + valueDelta) ) {
    value = (value - (middleRawValue + valueDelta))  * ( (255.0 - minSpeedPercent) / (2000.0 - (middleRawValue + valueDelta))) + minSpeedPercent;
    value = (value > 250) ? 255 : value;
    return (value < minSpeedPercent)  ? minSpeedPercent  : value;
  if ( value < (middleRawValue - valueDelta) ) {
    value = middleRawValue - value + middleRawValue;
    return (value < minSpeedPercent)  ? -minSpeedPercent  : -value;
  return 0;
void PulseTimer1(){
  int_1 = 1;
  current_time_pwm_1 = micros();
  if(current_time_pwm_1 > start_time_pwm_1){
    pulses_pwm_1 = current_time_pwm_1 - start_time_pwm_1;
    start_time_pwm_1 = current_time_pwm_1;
    }else if(current_time_pwm_1 < start_time_pwm_1){
void PulseTimer2(){
  int_2 = 1;
  current_time_pwm_2 = micros();
  if(current_time_pwm_2 > start_time_pwm_2){
    pulses_pwm_2 = current_time_pwm_2 - start_time_pwm_2;
    start_time_pwm_2 = current_time_pwm_2;
    }else if(current_time_pwm_2 < start_time_pwm_2){
engine control library
#ifndef _GyverMotor2_h
#define _GyverMotor2_h
#include <Arduino.h>
enum GM_driver {
    DRIVER2WIRE,			//(dir + PWM)
    DRIVER2WIRE_NO_INVERT,	//(dir + PWM)
    DRIVER2WIRE_PWM,		//(PWM + PWM)
    DRIVER3WIRE,			//(dir + dir + PWM)
    RELAY2WIRE,				//(dir + dir)
#define _GM_SMOOTH_PRD 50
template <GM_driver GM_TYPE, uint8_t GM_RES = 8>
class GMotor2 {
public:
    GMotor2(uint8_t pa, uint8_t pb, uint8_t pc = 255) : pinA(pa), pinB(pb), pinC(pc) {
        pinMode(pinA, OUTPUT);
        pinMode(pinB, OUTPUT);
        if (pinC != 255) pinMode(pinC, OUTPUT);
        setAll(0);
    void setMinDuty(uint16_t mduty) {
        minD = mduty;
    void setMinDutyPerc(uint16_t mduty) {
        mduty = constrain(mduty, 0, 100);
        minD = (int32_t)getMax() * mduty / 100;
    void reverse(bool r) {
        rev = r ? -1 : 1;
    void stop() {
        setSpeed(0);
    void brake() {
        setAll(1);
        speed = duty = 0;
    void setSpeed(int16_t s) {
        speed = s;
        if (!smooth) duty = speed;
        run(duty);
    void setSpeedPerc(int16_t s) {
        s = constrain(s, -100, 100);
        setSpeed((int32_t)getMax() * s / 100);
    void setDeadtime(uint16_t us) {
        dead = us;
    void tick() {
        if ((speed || duty) && smooth && millis() - tmr >= _GM_SMOOTH_PRD) {
            tmr = millis();
            if (abs(duty - speed) > ds) duty += (duty < speed) ? ds : -ds;
            else duty = speed;
            run(duty);
    void setSmoothSpeed(uint8_t s) {
        ds = s;
    void setSmoothSpeedPerc(uint8_t s) {
        s = constrain(s, 0, 100);
        ds = (int32_t)getMax() * s / 100;
    void smoothMode(bool mode) {
        smooth = mode;
    int8_t getState() {
        return dir;
    int16_t getSpeed() {
        return duty;
private:
    int16_t getMax() {
        return (1 << GM_RES) - 1;
    void run(int16_t sp) {
        if (!sp) return setAll(0);
        int8_t ndir = (sp > 0) ? rev : -rev;
        if (dead && ndir != dir) {
            setAll(0);
            delayMicroseconds(dead);
        dir = ndir;
        int16_t maxD = getMax();
        sp = constrain(sp, -maxD, maxD);
        if (minD) sp = (int32_t)sp * (maxD - minD) >> GM_RES;
        sp = abs(sp) + minD;
        if (GM_RES > 8 && sp == 255) sp++;
        switch (GM_TYPE) {
        case DRIVER2WIRE:
            digitalWrite(pinA, dir < 0);
            analogWrite(pinB, (dir > 0) ? sp : (maxD - sp));
        case DRIVER2WIRE_NO_INVERT:
            analogWrite(pinB, sp);
        case DRIVER2WIRE_PWM:
            if (dir > 0) {
                digitalWrite(pinA, 0);
                analogWrite(pinA, sp);
                digitalWrite(pinB, 0);
        case DRIVER3WIRE:
            digitalWrite(pinB, dir > 0);
            analogWrite(pinC, sp);
        case RELAY2WIRE:
    void setAll(uint8_t val) {
        digitalWrite(pinA, val);
        digitalWrite(pinB, val);
        if (pinC != 255) digitalWrite(pinC, val);
        dir = 0;
    const uint8_t pinA, pinB, pinC;
    bool smooth = 0;
    int8_t dir = 0, rev = 1;
    uint8_t dead = 0;
    int16_t minD = 0, speed = 0, duty = 0, ds = 20;
    uint32_t tmr = 0;
#endif
Hi, @pantiak
Welcome to the forum.
Can you please post your code using tags?
Can we please have a circuit diagram?
An image of a hand drawn schematic will be fine, include ALL power supplies, component names and pin labels.
Links to your hardware specs/data would also be good.
Thanks... Tom.. :smiley: :+1: :coffee: :australia:
I solved the problem, it was that in one of the motors the brush stood diagonally and closed several contacts at once on the motor armature, so there was a large current that destroyed the driver.
