Hello,
I'm trying to change the frequency of timer 5 to 50 Hz the following way but I don't get an output (on the oscilloscope):
const byte servo = 45;
pinMode(servo,OUTPUT);
// initialize Timer5
cli(); // disable global interrupts
TCCR5A = 0; // set entire TCCR1A register to 0
TCCR5B = 0; // same for TCCR1B
// set compare match register to desired timer count:
//313 = 50 Hz
//156 = 100 Hz
//80 = 200 Hz
OCR5A = 313;
// turn on CTC mode:
TCCR5B |= (1 << WGM52);
// Set CS50, CS51, CS52 bits for prescaler value: 1024
TCCR5B |= (1 << CS50);
TCCR5B |= (0 << CS51);
TCCR5B |= (1 << CS52);
TCCR5B |= (1 << CS12);
// enable timer compare interrupt:
TIMSK5 |= (1 << OCIE5A);
sei(); // enable global interrupt
void loop{
analogWrite (servo,12);
Currently I'm using an adafruit touchscreen that takes most of my pins away, so I only have access to pins 44, 45, 46 to generate a pwm output. I've tried using the servo.write function as well as the writemicroseconds function to generate a signal but I have issues with the output pwm signal (it goes to a high resolution servo and it appears that the counter is off sometimes, causing noise due to the servo trying to compensate). Therefore, I'm planning on using analogWrite to generate the duty cycle and timer5 to generate the frequency. Is this wise, or is there a better alternative to doing this? (PS... I have changed the value of timer5 using a prescalar (TCCR5B = (TCCR5B & 0xF8) | 0x05) which outputs 30Hz, but I need a way to output 50Hz) Thank You.
