5v Led to Arduino Nano Connections
Hello, i have an 4 cable RGB strip that needs to connect to Arduino Nano, The LED is 5v. Which cable goes where on the arduino nano? The cables are + R G B
Thank you!
You can't connect LED strip directly to arduino. Arduino can not provide enough current to feed multiple LEDs.
You need to use some transistors or MOSFETs and additional power supply
