5V Overvoltage protection circuit
Hello everyone!
I am trying to build my first protection circuit for a project and I am having some issues. The project basically consumes around 0.5A and it works at 5V. I decided to make a protection circuit that cuts the voltage if gets to 6V. I did some research online and found a circuit with PNP transistors to be a good one. So I built the following circuit:
However, it is not working. If I put a voltage higher than 6V it still goes through and after reviewing everything I can't manage to find what is failing...
Here are the parts I used:
ZENER: https://www.mouser.es/ProductDetail/Micro-Commercial-Components-MCC/SMBJ5340B-TP?qs=ZNK0BnemlqHJq1hQMWEIvQ%3D%3D
PNP Transistor: https://www.mouser.es/ProductDetail/ROHM-Semiconductor/2SAR574D3FRATL?qs=qSfuJ%252Bfl%2Fd7dUuPev%2FfRjQ%3D%3D
If you replace your circuit with a DC-DC converter that can take e.g., 3-12V input then it will continue to work at 6V.
Problem is with Vbe of Q5 (about 0.6 V). With 6 V Zener the threshold is too high. Try 5V1 Zener or even lower voltage.
Here is the same circuit I found online. The resistor values are different from yours. I don't know if that matters, but it might.
Today I am getting new Zener diodes so I will do some tests to see if it works properly.
As the load consumes 500mA, the base of Q2 needs 50mA or so, so R3 should be 220 ohms. ZD1 can be 4V7 for more precise voltage limiting.
Q2 cannot be a BC557 (which is only rated at 100mA), so that needs fixing too.
Maybe you want to look into using a crowbar circuit that uses an SCR instead of a series pass transistor. It functions only on an over-voltage condition, then limits the output voltage to about 1 volt.
It shorts the power supply and relies on a fuse in the power supply to blow to protect the circuit and the power supply.
Tom... :grinning: :+1: :coffee: :australia:
I prefer FOLDBACK CURRENT LIMITING . I know what you're thinking "Foldback current limiting is practically
idiot proof so I must be an idiot to recommend it". You can say that but I have found that
when you have foldback current limiting you can pretty much stop worrying about overcurrent.
Am I missing something? Why not just regulate the voltage to 5V?
I am supplying power with a 5V adapter, and I accidentally connected a 24V and fried it... That is why I was looking for overvoltage protection. I am not an expert, could you explain what type of circuit would it be? And would the voltage regulation work with a situation like this?
A 5V regulator with a 36V input ?
OK, just learned something new! However, I have a doubt, do they heat up?
Do WHAT heat up ? (not sure what heat has to do with voltage)
Just wondering if during operation the regulator heats up a lot or not. Just googled it and, I have seen that linear regulators heat up a lot since they are very inefficient but switching regulators don't heat up as much but might generate noise.
FYI
Efuse
You obviously didn't read the datasheet or the
info on the website. It's NOT a LINEAR regulator.
it's a Switching DC2DC CONVERTER !
Description: "Linear Regulator REPLACEMENT"
Sorry, you do not need "overvoltage protection".
You need something quite different, and I do not think we can really provide it for you. :thinking:
You really are quite ambiguous.
Sorry if I sound ambiguous... I will try my best to sound more precise in future posts. And thank you for all the suggestions!
