You have a slight misconception regarding current. Current isn't "sent" at a particular level, it is drawn/required by something. So you can apply 3.3V to the ASIC I/O pin and it will only require (generally) 1uA or so. The fact that the 74LVC245 can supply lots of current doesn't mean it is forced into the ASIC.
As another example, even though a battery can supply 1A (for example) of current, if you attach it to some LED's that only draw 20mA, then only 20mA of current will flow.
A power source (or digital output) provides voltage, the current is determined by what you hook up to it.
If you just want to connect a 5V output from the Mega to a 3.3V input on the ASIC, the easiest connection scheme is a voltage divider:
The Quick Shield: breakout all 28 pins to quick-connect terminals
Ok so as an example if it needs 20mA max but and you connect directly to the arduino I/O pin its supplying 40mA. Won't it fry the chip. Im really confused on this, I understand it draws what it needs but when sending a signal that will be at 40mA right?
It does not "send" 40mA. It is not supplying 40mA. It sends a VOLTAGE: 5V.
The voltage divider then reduces the voltage from 5V to 3.3V. The ASIC then DEMANDS a certain amount of current from that 3.3V voltage, most likely a very small amount: 1uA. While the Arduino is CAPABLE of providing UP TO 40mA of current, the number of electrons that actually start flowing (i.e., the current) is determined by what the ASIC DEMANDS: 1uA.
It is never good design practice to use way more circuit than you need to reliably do the job.
Well, I subscribe to the philosophy of "Good Enough" engineering, but whether it is "Good Enough" depends on what the "job" is.
An example: For an SD memory card interface, it has been variously reported that resistive voltage dividers don't work at the speed that SDHC cards can support.
On the other hand, level shifters with 74LVC245 or 74HC4050 chips work at all speeds that can be cranked out by the Arduino SPI port. For the price of a single chip (a few cents) I get consistent, reliable, efficient performance.
I have SD interface circuits from adafruit and also homebrew ones. Full speed Arduino SPI operation for FAT32 files on 8GByte SDHC cards. Haven't missed a byte yet. I mean, I'm not saying that it is impossible to use resistive level shifters in this application, but why would I waste my time on a questionable design? (See Footnote.)
I haven't used the particular Sparkfun level shifter circuit that was linked in a previous post, but it is an excellent example of a bi-directional level shifter employing well respected methodology used in I2C and other circuits where 2-way data flow is necessary. Typically I use a 2N7000 or some such thing. (Of course, it also works in applications that only require unidirectional traffic.)
Things like the 'LCV245 and '4050 are OK for one-way traffic. (And the '4050 is readily available in a DIP package which is convenient for breadboarding.)
Regards,
Dave
Footnote:
Been there; done that; got so excited that I spilled some good Sonoma County wine on the tee-shirt. (But at least it's not blood, which it might have been if I had shown up at a design review with resistors as level shifters in an 8 MHz circuit.)
Richard: With all due respect, I was responding to your unqualified criticism to the effect that there is no need to use active devices as level shifters since resistors will do the deed.
The specific example that I gave was gleaned from various posts on this forum where people have reported problems with store-bought SD card interface circuits using resistive voltage dividers. Perhaps lower values of resistance could give satisfactory RC time constant, but at the expense of additional signal loading, which might or might not be detrimental.
I hate to repeat myself, but my conclusion is this: Whether or not it is overkill depends on what the "job" is, and sometimes it is not overkill. (See Footnote.)
Regards,
Dave Footnote:
On this forum I am mainly concerned with breadboarding and other types of design where knowledge about carefully controlled circuit capacitance and transmission line characteristics is not available. My idea is to recommend circuits and methodology that give greatest chances of success to questioners who do not have the lab equipment or knowledge to wring out problems arising from little details like unknown input capacitance and stray wiring capacitance at a even a few MHz.
There is room for more than one point of view, and I like the fact that different people can speak up with different opinions (in a civilized manner, of course) on this forum.
Actually I should mention since I still havn't got this chip running, I think I might of fried it.
So in the datasheet it also mentions that there is a DATA and STROBE protection DIODE for sinking, max is 20mA and min is -20mA
I emailed the company that provides it and they wrote me this,
"The DATA and STROBE line will NOT be able to sink 50mA. Even the 20mA is not recommended as this is absolute MAX. Our datasheet shows the ASIC can only guarantee 0.4V when sinking up to 2mA."
So going back through what you guys said, I should just use resistors in series to lower the operating voltage/Current of the I/O pin to an acceptable level.
Will I still be able to send digitalwrite(HIGH) or LOW Commands to the chip operating at this low of a current?
And I guess if this is the case 3.3V droped by that level converter did fry the diode. (silent but deadly) haha
Hope someone can get back to me. Much appreciated.
I think you are confusing inputs with outputs. Outputs sink current, that is how much current they will pull down to ground. You were asking before about level converters they convert a 5V signal FROM the arduino to the 3V3 signal into your ASIC. This has nothing to do with current sinking.
It looks like the ASIC provides an OUTPUT on the data and strobe lines, this output can be directly connected into an ardunio INPUT. If you have a pull up resistor on the input going to 3v3 then that will give you current that your ASIC can sink. That pull up has to be very low to exceed 20mA. Do the sums 3.3 / 0.02 = 165R.
If you have the pull up to 5V then you are in danger of frying the outputs of your ASIC.
"the ASIC can only guarantee 0.4V when sinking up to 2mA. "
I've been working on interfacing for a while now, and the only thing i can figure is the problem is this part with the sinking which im not understanding.
You are still getting confused with inputs and outputs. That sentence means when the ASIC is acting as an output and is sinking 2mA then the output voltage will only be 0.4V as opposed to the zero volts that a logic zero is supposed to delver.
1A) Yes
1B) Yes
But you only need the 1.8K resistor, this is because you have a protection diode in the ASIC which can take up to 20mA. So with a 1.8K resistor dropping 5 - 3.9 = 1.4 / 1800 = 0.8mA = Safe for this application.
The LVC is NOT a level translator. It is a buffer with 5V tolerant inputs. That means it will output what ever voltage is is powered with BUT you won't blow it up if you put an input of 5V into it.
Along with other people lately you are just drip feeding information in stead of coming out and saying what you are using. You haven't even linked the data sheet of this device you are trying to use. Without all the information the advice you receive will be less than perfect.
I really appreciate your help, normally when I'm having troubles I will post a datsheet, in this specific case though I don't have permission to post in a public forum. By all means I can send an email with the disclosure statement, but not in public.
I have talked to a few people about it and a couple engineers and I'm hoping this is why the chip isn't operating. Origonally I was sent two different datasheets for chips with the same identification codes. But it was a mistake on there end and they are fixing it. Now that I have the correct sheet I'm starting to see some differences especially the current consumptions and the inputs are all different.
Again thanks for all your time, and once finished, the project will be publicly available.
Its not actually publicly available. It does actually come with a disclaimer, the code I'm provided with I can't distribute at all. I'm allowed to show my code though. I think its to limit and control who has the information.
The mix up was on there end with two identical parts but three revisions of the same ic and still providing the different versions for backward compatability.
