Hey guys, looks look i'm the only one not messing with LED matrices in here. Anyway, I'm new like I said and I'm trying to get 6 multiplexers to cycle through 96 analog signals (pots). Right now I'm just trying to get 2 working. I think I'm close, maybe. I took this http://bildr.org/2011/02/cd74hc4067-arduino/ guys code and changed it a little:
//Mux control pins
int s0 = 40;
int s1 = 41;
int s2 = 42;
int s3 = 43;
int s4 = 34;
int s5 = 35;
int s6 = 36;
int s7 = 37;
//Mux in "SIG" pins
int SIG_pin1 = 0;
int SIG_pin2 = 1;
void setup(){
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
pinMode(s4, OUTPUT);
pinMode(s5, OUTPUT);
pinMode(s6, OUTPUT);
pinMode(s7, OUTPUT);
digitalWrite(s0, LOW);
digitalWrite(s1, LOW);
digitalWrite(s2, LOW);
digitalWrite(s3, LOW);
digitalWrite(s4, LOW);
digitalWrite(s5, LOW);
digitalWrite(s6, LOW);
digitalWrite(s7, LOW);
void loop(){
//Loop through and read all 16 values
//Reports back Value at channel 6 is: 346
for(int i = 0; i < 16; i ++){
Serial.print("Value at channel ");
Serial.print(i);
Serial.print("is : ");
Serial.println(readMux1(i));
int readMux1(int channel1){
int controlPin1[] = {s0, s1, s2, s3};
int muxChannel1[16][4]={
{0,0,0,0}, //channel 2
{1,0,0,0}, //channel 3
{0,1,0,0}, //channel 4
{1,1,0,0}, //channel 5
{0,0,1,0}, //channel x
{1,0,1,0}, //channel c
{0,1,1,0}, //channel 6
{1,1,1,0}, //channel 7
{0,0,0,1}, //channel 8
{1,0,0,1}, //channel 9
{0,1,0,1}, //channel 10
{1,1,0,1}, //channel 11
{0,0,1,1}, //channel 12
{1,0,1,1}, //channel 13
{0,1,1,1}, //channel 14
{1,1,1,1} //channel 15
//loop through the 4 sig
for(int i = 0; i < 4; i ++){
digitalWrite(controlPin1[i], muxChannel1[channel1][i]);
//read the value at the SIG pin
int val = analogRead(SIG_pin1);
Serial.print(i);
Serial.println(readMux2(i));
int readMux2(int channel2){
int controlPin2[] = {s4, s5, s6, s7};
int muxChannel2[16][4]={
digitalWrite(controlPin2[i], muxChannel2[channel2][i]);
int val = analogRead(SIG_pin2);
//return the value
return val;
I am assuming there is a problem because when I look at the monitor it isn't scrolling through all 32 channels.
I appreciate any help as always.
thanks
tony
