Hi
I am trying to make a counter(0-99) with 2 digit 7-segment display(common cathode) and the two pushbuttons, one for increment by 1 and one for decrement by 1.
I found this code on the internet but I didnt find a way to use it with my 7-seg display so I decided to use a single shift register driving the segments (anodes) and 2 digital i/o pins each driving a NPN transistor to switch in each cathode one at a time.
Now I have to modify the code to drive these transistors that will switch in each cathode at a certain time.
I am still learning programming and I am not so sure how to do this properly so any help is welcome
This is the code I have:
const byte latchPin = 5; // Pin connected to Pin 12 of 74HC595 (Latch)
const byte dataPin = 6; // Pin connected to Pin 14 of 74HC595 (Data)
const byte clockPin = 7; // Pin connected to Pin 11 of 74HC595 (Clock)
const byte upPin = 2; // pushbutton attached to pin 2
const byte downPin = 3; // pushbutton attached to pin 3
int prevUpState = 0;
int prevDownState = 0;
int currUpState = 1;
int currDownState = 1;
int counter = 0; // initialise counter as zero
byte numberOfDigits = 2;
const byte numbers[10] = // Describe each digit in terms of display segments 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
B11111100, //0
B01100000, //1
B11011010, //2
B11110010, //3
B01100110, //4
B10110110, //5
B10111110, //6
B11100000, //7
B11111110, //8
B11110110, //9
pinMode(latchPin, OUTPUT); // set SR pins to output
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(upPin, INPUT); // sets pin 12 as pushbutton INPUT
pinMode(downPin, INPUT); // sets pin 13 as pushbutton INPUT
//counter part
currUpState = digitalRead(upPin);
if (prevUpState != currUpState) // has the state changed from HIGH to LOW or vice versa
prevUpState = !prevUpState; //invert
if (currUpState == HIGH && counter < 99) // If the button was pressed AND not reached 99
counter++; // increment the counter by one
if(counter == 99) counter = 0;
currDownState = digitalRead(downPin);
if (prevDownState != currDownState) // has the state changed from HIGH to LOW or vice versa
prevDownState = currDownState;
if (currDownState == HIGH && counter > 0) // If the button was pressed AND not reached 0
counter--; // decrement the counter by one
showNumber(counter); // display the current digit
void showNumber(int number)
digitalWrite(latchPin, LOW); // Set latchPin LOW while clocking bits in to the register
for(byte i = 0; i < numberOfDigits; i++)
shiftOut(dataPin, clockPin, LSBFIRST, numbers[number % 10]);
number /= 10;
digitalWrite(latchPin, HIGH); //set latchPin to high to lock and send data
You can see pictures down bellow with the datasheet of my 7-seg display as well as the schematic I made for this counter.
Yes but have you seen my pinout for display?
It has 2 digits and each segment from A to G is connected together from each digit...
So I cant use that schematic, because I will end up displaying two same digits, and for that reason I need to modify the code so I can light up certain digit at certain time trough transistors.
You know what I mean?
Here is the picture of the pinout to make it clearer for you:
That is a completely standard display construction. All the anodes (segments A-G + DP) are wired in parallel. The cathodes are separate. This means you have to multiplex the display, which simply means that you display digit one for a short period then display digit two for a short period, then repeat endlessly.
If tried to fix your function showNumber() so it should work with the 2 digit display. My modifications are not pretty, but have been designed for the minimum disturbance of the existing code.
Ideally, the function would be called by a timer say every 1 mS, and would directly access the global variable counter.
You'll also have to set pinMode() for the transistor pins in setup().
I've not tested it.
// digits are : (LH - pin 8) and (RH - pin 9)
digitalWrite( 9 , LOW ) ; // switch off digit RH
digitalWrite( 8 , LOW ) ; // switch off digit LH
number /= 10;
if ( i == 0 ) {
digitalWrite( 9 , HIGH ) ; // switch on digit LH
} else if ( i == 1 ) {
digitalWrite( 8 , HIGH ) ; // switch on digit RH
delay( 500 ) ; // for debugging so you see the multiplexing
You need to attach your pictures rather than load them offsite, there are some platforms that make it difficult to view offsite pictures.
The Ops circuit.
TomGeorge:
In general, of course you are right. In this specific case, however, where the OP has used Fritzing to create the image, the picture doesn't help much. This is because, as is usual with Fritzing, most of the essential detail (pin numbers etc.) is blurred or covered with other features leaving only a pretty looking picture, which has anyway to be loaded into an image viewer where you can magnify many times it to see this otherwise barely visible detail.
I put a dropbox link of the pictures and I attached them too so you can see them where ever you like.
Anyway, thank you @6v6gt for helping me with the code.
I have tried it and it works...but I am having some weird problem. My D segment doesnt ligt up on the right digit. Why is this happening?
Besides that, I found that all other segments(that shouldnt be turned on)are not completely turned off.
Here´s the picture(i dont know if you can see that segments ). It shows number 15, you can see segment D on the right digit doesnt light up.
6v6gt:
I know its fritzy, but it has been logically drawn and its better then nothing.
Tom...
But it works fine on the left side ?
If you swap the connection to pins 8 and 9 on the Arduino, does the problem of the failed Segment D move to the other side ?
If so, did you also have that problem when the delay was set to 500 mS ?
If not, then it is almost certainly a display hardware failure which you could verify by applying 5 volts via a 220R resistor to the appropriate pins on the display.
It was a hardware display failure...I changed the display andit works now :).
Now I just need to find a way to stop lighting up those segments which are not completely turned off(and should be)
Any ideas?
Is there anything I can do to stop these unwanted segments being turned on.
On the right digit it is less noticeable but on the left I found out that it displays the number from right digit too but in much less brightness(and still visible).
const byte UpPin = 12; // pushbutton connected to pin 12 for increment by 1
const byte DownPin = 13; // pushbutton connected to pin 13 for decrement by 1
const byte reset = A0;
const byte Digit1 = 8; // transistor for ones digit connected to pin 8
const byte Digit2 = 9; // transistor for tens digit connected to pin 9
int res = 0;
B11111100, //0
B01100000, //1
B11011010, //2
B11110010, //3
B01100110, //4
B10110110, //5
B10111110, //6
B11100000, //7
B11111110, //8
B11110110, //9
pinMode(UpPin, INPUT); // sets pin 12 as pushbutton INPUT
pinMode(DownPin, INPUT); // sets pin 13 as pushbutton INPUT
pinMode(reset, INPUT);
pinMode(Digit1, OUTPUT);
pinMode(Digit2, OUTPUT);
//counter part
currUpState = digitalRead(UpPin);
if (currUpState == HIGH && counter <= 99) // If the button was pressed AND not reached 99
if(counter > 99) counter = 0; //if counter is greater than 99, set it to 0
currDownState = digitalRead(DownPin);
if (currDownState == HIGH && counter >= 0) // If the button was pressed AND not reached 0
if(counter < 0) counter = 99; // counting backward from 99 to 0
res = digitalRead(reset);
if(res == HIGH) counter = 0;
// digits are : (Digit1 - pin 8) and (Digit2 - pin 9)
digitalWrite(Digit1, LOW ) ; // switch off Digit1(ones)
digitalWrite(Digit2, LOW ) ; // switch off Digit2(tens)
number /= 10;
if ( i == 0 )
digitalWrite(Digit1, HIGH ) ; // switch on Digit1
else if ( i == 1 )
digitalWrite(Digit2, HIGH ) ; // switch on Digit2
delay(5);
Does this effect appear to be ghosting from one side to the other ?
From an earlier picture of 15, the only truly dark segement (segment A) was not shared between either the 1 or the 5.
You could alternately disconnect pin 8 and then later pin 9 to see if effect is still there.
You could also try modifying showNumber() . . .
number /= 10;
digitalWrite(Digit1, ( i == 0 ) ) ; // switch on/off Digit1
digitalWrite(Digit2, ( i == 1 ) ) ; // switch on/off Digit2
delay(5);
If that does not work, you can then experiment with the NOT OE (pin 13) on the shift register to suppress output until everything is stable.
One question:
Is it possibe to connect one or two more 2 digit 7seg displays on the same shift register but to control them with other pushbuttons so they count from 0 to 99 too?
Connect pins A through to G on the new display directly to the equivalent pins on the existing display (no additional resistors)
Connect the cathodes of the new display via transistors to two new arduino pins.
modify function showNumber to handle 4 digits.
You'll then create an additional button controlled counter 0-99.
Simply add the existing counter to 100 times the new counter and call showNumber with this combined value.
6v6gt:
I didnt understand you very well about this.
Do I need to make a new counter?
You want to create a 4 digit display.
If you want two independent counters, each of which display numbers between 00-99. Say the value of counter on the right hand pair digits and the value of counter2 on the left pair of digits, then, yes you need 2 counters.
If, on the other hand, you simply want your existing counter to now display 0000 - 9999 , you don't need another counter.
