I'm trying to compare the pinouts of 74HC595 and TPIC6B595 from their datasheets.
Please can someone confirm whether I have the following pins matched correctly?
(Sorry I couldn't find a way to make the table more readable.)
Did you use the same manufacturer’s data sheet for both devices? TI refers to pin 9 of the sn74hc595 as QH’ , at least in the one I found.
And you had no problem with the /G or /OE (output enable) ?
It is just that I've just been through this myself recently when considering both chips for a project.
Different manufacturers add to the confusion with their own names for the pins of standard specification devices. Another name you sometimes see is strobe (meaning register clock and other similar terms). I just mentioned output enable (/OE /G etc.) because it is another name with multiple variants and you can't just leave it floating.
I also discovered an error during this exercise on the TPIC6B595 datasheet which I reported to TI. There is a mismatch between the pinout diagram and a the pin table for the pin labeled SRCK.
6v6gt:
Was there any reason you didn't want to share your conclusions? ;D :-X
6v6gt:
I spotted that too: pin 15 apears twice in the table and no pin 13.
idrisdraig:
I have no problem sharing the conclusion, but it was for a very specific project which, incidentally, is here: Six Digit Nixie Clock - Exhibition / Gallery - Arduino Forum where the issue was possibly saving two high voltage transistors to drive neon lamps by relying on the clamp diodes in the TPIC6B959, so the conclusion is probably not generally useful. Anyway, if you look at the description, you'll see what I did.
