I have a 2 x 16 LCD screen with 16 pins. I included the LiquidCrystal Library and set up a test site and connected everything as suggested. It worked fine and displayed "Hello World" as expected.
Then I tried to add it to my project, which unfortunately used the same pins as my working 433Mhz receiver, so I attempted to reassign pin 11 and pin 12 to pins 9 and 10 respectively, and move the data pins from 2 - 5 to pins 4 - 7. changed following lines to reflect the change.
const int rs = 10, en = 9, d4 = 7, d5 = 6, d6 = 5, d7 = 4;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
This is part of the LiquieCrystal.cpp file Do I have to change anything in here to resolve this?
// Note, however, that resetting the Arduino doesn't reset the LCD, so we
// can't assume that its in that state when a sketch starts (and the
// LiquidCrystal constructor is called).
LiquidCrystal::LiquidCrystal(uint8_t rs, uint8_t rw, uint8_t enable,
uint8_t d0, uint8_t d1, uint8_t d2, uint8_t d3,
uint8_t d4, uint8_t d5, uint8_t d6, uint8_t d7)
init(0, rs, rw, enable, d0, d1, d2, d3, d4, d5, d6, d7);
LiquidCrystal::LiquidCrystal(uint8_t rs, uint8_t enable,
init(0, rs, 255, enable, d0, d1, d2, d3, d4, d5, d6, d7);
uint8_t d0, uint8_t d1, uint8_t d2, uint8_t d3)
init(1, rs, rw, enable, d0, d1, d2, d3, 0, 0, 0, 0);
init(1, rs, 255, enable, d0, d1, d2, d3, 0, 0, 0, 0);
void LiquidCrystal::init(uint8_t fourbitmode, uint8_t rs, uint8_t rw, uint8_t enable,
_rs_pin = rs;
_rw_pin = rw;
_enable_pin = enable;
_data_pins[0] = d0;
_data_pins[1] = d1;
_data_pins[2] = d2;
_data_pins[3] = d3;
_data_pins[4] = d4;
_data_pins[5] = d5;
_data_pins[6] = d6;
_data_pins[7] = d7;
if (fourbitmode)
_displayfunction = LCD_4BITMODE | LCD_1LINE | LCD_5x8DOTS;
_displayfunction = LCD_8BITMODE | LCD_1LINE | LCD_5x8DOTS;
begin(16, 1);
