Bonjour,
J'ai une question à 5.. cents sur cet excellent tuto (Row-columm Scanning to control an 8x8 LED Matrix) !!?! que je tâche de comprendre à fond ...
https://www.arduino.cc/en/Tutorial/RowColumnScanning
Note 1 : J'ai changé un chouga la config, je me passe de potentiomètre pour l'instant
analog pins 2 through 5 used as digital 16 through 19
analog pins 0 through 3 used as digital 14 through 17
Note 2 : Je teste ces positions pixels[5][3] et pixels[1][7] = LOW;
void setupScreen(){
for (int x = 0; x < 8; x++) {
for (int y = 0; y < 8; y++) {
pixels[x][y] = HIGH;
//OFF current pos
//pixels[posX][posY] = LOW;
pixels[5][3] = LOW;
pixels[1][7] = LOW;
Voici mon code, je teste donc le "comment allumer une led de mon choix "
// 2-dimensional array of row pin numbers:
const int row[8] = {
2, 7, 17, 5, 13, 16, 12, 14
// 2-dimensional array of column pin numbers:
const int col[8] = {
6, 11, 10, 3, 15, 4, 8, 9
// 2-dimensional array of pixels:
int pixels[8][8];
int posX = 7;
int posY = 7;
int count = 1000;
int thisPixel;
int thisPixel2;
// initialize the I/O pins as outputs
// iterate over the pins:
for (int thisPin = 0; thisPin < 8; thisPin++) {
// initialize the output pins:
pinMode(col[thisPin], OUTPUT);
pinMode(row[thisPin], OUTPUT);
// take the col pins (i.e. the cathodes) high to ensure that
// the LEDS are off:
digitalWrite(col[thisPin], HIGH);
setupScreen();
// draw the screen:
refreshScreen();
if(count-- == 0){
count = 40;
if(posX--==0){
posX = 7;
if(posY--==0){
posY = 7;
setupScreen();
void setupScreen(){
//OFF current pos
pixels[5][3] = LOW;
pixels[1][7] = LOW;
void refreshScreen() {
thisPixel = pixels[5][3];
digitalWrite(row[5], HIGH);
digitalWrite(col[3], thisPixel);
digitalWrite(col[3], HIGH);
thisPixel2 = pixels[1][7];
digitalWrite(row[1], HIGH);
digitalWrite(col[7], thisPixel2);
Voici le résultat http://www.messinmaisoui.org/Arduino/_DSC0184.JPG
Note 3 : Bon je teste 2 leds, mais j'en ai allumé 4, ça s'explique sans doute
*par les croisements lignes/colonnes, ça c'est pas un soucis ... *
Ma question du jour ... c'est pourquoi ceci m'affiche une led brillante
Alors que ceci me fait baisser la luminosité de la led en question !?
Ce qui est d'ailleurs pour moi (compte tenu de mon programme) équivalent à
digitalWrite(col[3], LOW);
Et la led devrait s'éteindre mais ça n'est pas le cas :o ...
Merci pour votre aide précieuse
