.96 OLED display freezing, system starting again & again, display pixels going black
Working with Arduino UNO that has a Bylund Automotive shield mounted on it. System is to operate a Bosch 4.9 LSU wideband oxygen sensor and display Air Fuel Ratios and Lambda. There are two of the same units that are electrically isolated from each other in terms of power. Ground is shared. Power to the Arduino comes from 12v ignition ON circuit and feeds a 12-to-5v step down (5v leading on to the Arduino.) Same circuit continues on to a 12v relay. That relay switches an always-live 12v circuit ON/OFF to power the Bylund shield. There's a snubber attached to the in and output sides of the switched relay circuit. To the .96" OLED display, there are 4 wires soldered to the Bylund shield leading to and soldered to the .96 OLED with a 4 pin junction between. Total wiring length is 15". This length is a bench test config that is at least showing data for up to 30 seconds. Then there's a freeze in the data displayed. Sometimes the system restarts. Sometimes it stays frozen. Sometimes the frozen pixels go to black in progression so eventually the display is blank. I cannot see a pattern in any of this.
At actual operating length, the 4-wire/cable is 7'. There is no data displayed with this length cable. I have tested 22awg and 24awg wiring with the same result. The cable from the Bosch 4.9 LSU sensors is shielded and grounded. Display wires (cable) is not shielded.
Not sure it matters but to cover the background for this, this Arduino system is in a 1985 Porsche 911 3.2. I have no idea if this car / engine is "noisy" electrically speaking or not.
Further, Bylund is unresponsive and so my looking for assistance here. Sketch applied is below. There are no errors when compiling this. I'd appreciate help with sorting out what the problem is and what needs to be done to make this hard/software work.
Sketch:
    Example code compatible with the Lambda Shield 2 for Arduino and GUI frontend.
    Copyright (C) 2020 Bylund Automotive AB
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
    Contact information of author:
    http://www.bylund-automotive.com/
    info@bylund-automotive.com
    Version history:
    2020-04-13        v1.0.0        First release.
    2020-08-30        v1.1.0        Added display support.
//Define included headers.
#include <SPI.h>
#include <U8g2lib.h>
//Define CJ125 registers used.
#define           CJ125_IDENT_REG_REQUEST             0x4800        /* Identify request, gives revision of the chip. */
#define           CJ125_DIAG_REG_REQUEST              0x7800        /* Dignostic request, gives the current status. */
#define           CJ125_INIT_REG1_REQUEST             0x6C00        /* Requests the first init register. */
#define           CJ125_INIT_REG2_REQUEST             0x7E00        /* Requests the second init register. */
#define           CJ125_INIT_REG1_MODE_CALIBRATE      0x569D        /* Sets the first init register in calibration mode. */
#define           CJ125_INIT_REG1_MODE_NORMAL_V8      0x5688        /* Sets the first init register in operation mode. V=8 amplification. */
#define           CJ125_INIT_REG1_MODE_NORMAL_V17     0x5689        /* Sets the first init register in operation mode. V=17 amplification. */
#define           CJ125_DIAG_REG_STATUS_OK            0x28FF        /* The response of the diagnostic register when everything is ok. */
#define           CJ125_DIAG_REG_STATUS_NOPOWER       0x2855        /* The response of the diagnostic register when power is low. */
#define           CJ125_DIAG_REG_STATUS_NOSENSOR      0x287F        /* The response of the diagnostic register when no sensor is connected. */
#define           CJ125_INIT_REG1_STATUS_0            0x2888        /* The response of the init register when V=8 amplification is in use. */
#define           CJ125_INIT_REG1_STATUS_1            0x2889        /* The response of the init register when V=17 amplification is in use. */
//Define pin assignments.
#define           CJ125_NSS_PIN                       10            /* Pin used for chip select in SPI communication. */
#define           LED_STATUS_POWER                    7             /* Pin used for power the status LED, indicating we have power. */
#define           LED_STATUS_HEATER                   6             /* Pin used for the heater status LED, indicating heater activity. */
#define           HEATER_OUTPUT_PIN                   5             /* Pin used for the PWM output to the heater circuit. */
#define           UB_ANALOG_INPUT_PIN                 2             /* Analog input for power supply.*/
#define           UR_ANALOG_INPUT_PIN                 1             /* Analog input for temperature.*/
#define           UA_ANALOG_INPUT_PIN                 0             /* Analog input for lambda.*/
//Define adjustable parameters.
#define           SERIAL_RATE                         10            /* Serial refresh rate in HZ (1-100)*/
#define           UBAT_MIN                            150           /* Minimum voltage (ADC value) on Ubat to operate */
#define           hardwareId                          0x01          /* The hardwareId defines which hardware you are using. */
//Global variables.
int adcValue_UA = 0;                                                /* ADC value read from the CJ125 UA output pin */
int adcValue_UR = 0;                                                /* ADC value read from the CJ125 UR output pin */
int adcValue_UB = 0;                                                /* ADC value read from the voltage divider caluclating Ubat */
int adcValue_UA_Optimal = 0;                                        /* UA ADC value stored when CJ125 is in calibration mode, λ=1 */
int adcValue_UR_Optimal = 0;                                        /* UR ADC value stored when CJ125 is in calibration mode, optimal temperature */
int HeaterOutput = 0;                                               /* Current PWM output value (0-255) of the heater output pin */
int CJ125_Status = 0;                                               /* Latest stored DIAG registry response from the CJ125 */
int serial_counter = 0;                                             /* Counter used to calculate refresh rate on the serial output */
int HeaterStatus = 0;                                               /* Defines the heater status for the GUI front-end */
//PID regulation variables.
int dState;                                                         /* Last position input. */
int iState;                                                         /* Integrator state. */
const int iMax = 250;                                               /* Maximum allowable integrator state. */
const int iMin = -250;                                              /* Minimum allowable integrator state. */
const float pGain = 120;                                            /* Proportional gain. Default = 120*/
const float iGain = 0.8;                                            /* Integral gain. Default = 0.8*/
const float dGain = 10;                                             /* Derivative gain. Default = 10*/
//Define display.
U8G2_SH1106_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, U8X8_PIN_NONE);
//Company logo bitmap.
PROGMEM const unsigned char Logo[] = {
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0xff, 0xf8, 0x07, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf0, 0x7f, 0xf8,
   0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
   0x00, 0xf8, 0x7f, 0xfc, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0x3f, 0xfc, 0x01, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfc, 0x3f, 0xfe,
   0x00, 0xfc, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x7f,
   0x7f, 0x80, 0xfb, 0x07, 0xf8, 0x87, 0x3f, 0xff, 0x01, 0xe7, 0xff, 0x7f,
   0x00, 0xfc, 0x8f, 0x3f, 0xff, 0xc0, 0xf1, 0x07, 0xf8, 0xc7, 0x3f, 0xfe,
   0x81, 0xc7, 0xff, 0x7f, 0x00, 0xff, 0xc7, 0x3f, 0xff, 0xf0, 0xf8, 0x03,
   0xf8, 0xc3, 0x1f, 0xfe, 0x81, 0xc3, 0x1f, 0xff, 0x80, 0xff, 0xc3, 0x1f,
   0xfe, 0x78, 0xf8, 0x03, 0xf8, 0xe3, 0x1f, 0xff, 0xc1, 0xe3, 0x0f, 0x7f,
   0xc0, 0xff, 0xe3, 0x1f, 0xfe, 0x1c, 0xfc, 0x01, 0xfc, 0xe1, 0x8f, 0xff,
   0xc1, 0xe1, 0x8f, 0x7f, 0xc0, 0xff, 0xe1, 0x0f, 0xfe, 0x0e, 0xfc, 0x01,
   0xfc, 0xf1, 0x87, 0xff, 0xe3, 0xf1, 0x87, 0x3f, 0xe0, 0xff, 0xf1, 0x07,
   0xfe, 0x07, 0xfe, 0x00, 0xfe, 0xf0, 0xc7, 0xff, 0xe3, 0xf0, 0xc7, 0x3f,
   0x00, 0x00, 0xf0, 0x07, 0xfe, 0x03, 0xff, 0x00, 0xff, 0xf8, 0xc3, 0xf9,
   0xf3, 0xf8, 0xc3, 0x1f, 0x00, 0x00, 0xf8, 0x03, 0xfe, 0x01, 0x7f, 0x00,
   0x7f, 0xf8, 0xe3, 0xf9, 0x73, 0xfc, 0xe3, 0x0f, 0x00, 0x00, 0xfc, 0x03,
   0xfe, 0x80, 0x7f, 0x80, 0x7f, 0xfc, 0xe1, 0xf8, 0x3b, 0xfc, 0xe1, 0x0f,
   0xf0, 0x7f, 0xfc, 0x01, 0xff, 0x80, 0x3f, 0x80, 0x3f, 0xfe, 0xf1, 0xf8,
   0x3f, 0xfe, 0xf1, 0x07, 0xf8, 0x3f, 0xfe, 0x01, 0x7f, 0xc0, 0x3f, 0xc0,
   0x3f, 0xfe, 0x70, 0xf8, 0x1f, 0xfe, 0xf8, 0x07, 0xfc, 0x3f, 0xfe, 0x80,
   0x3f, 0xc0, 0x1f, 0xc0, 0x1f, 0xff, 0x38, 0xf8, 0x1f, 0xff, 0xf8, 0x03,
   0xfc, 0x1f, 0xff, 0x80, 0x3f, 0xe0, 0x1f, 0xe0, 0x0f, 0x7f, 0x38, 0xf8,
   0x0f, 0x7f, 0xfc, 0x03, 0xfe, 0xff, 0x7f, 0xc0, 0x1f, 0xe0, 0xff, 0xef,
   0xff, 0x3f, 0x1c, 0xf8, 0x8f, 0xff, 0xff, 0x01, 0xff, 0xff, 0x1f, 0xc0,
   0x1f, 0xf0, 0xff, 0xcf, 0xff, 0x1f, 0x1e, 0xf0, 0x87, 0xff, 0x7f, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0xf6, 0xff, 0x9b, 0xfb,
   0xfe, 0x9f, 0x3e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c,
   0x1b, 0xb3, 0x9d, 0xdb, 0x8c, 0x59, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x3a, 0x9b, 0xf9, 0xfd, 0x6d, 0xcc, 0x59, 0x1f, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf, 0x8d, 0xd9, 0xfa, 0x6d,
   0xc6, 0xb8, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xb1,
   0xc7, 0x78, 0xd0, 0x3c, 0x66, 0xb8, 0x0f, 0x00 };
//Sensor symbol bitmap.
PROGMEM const unsigned char LambdaSensorSymbol[] = {
   0xfc, 0x3f, 0xfe, 0x7f, 0x3f, 0xfc, 0x3f, 0xfc, 0x3f, 0xfc, 0x3f, 0xfc,
   0x3f, 0xfc, 0x3f, 0xfc, 0x1f, 0xf8, 0x1f, 0xf8, 0x1f, 0xf8, 0x3f, 0xfc,
   0x3f, 0xfc, 0x7f, 0xfe, 0xfe, 0x7f, 0xfc, 0x3f };
//Battery symbol bitmap.
PROGMEM const unsigned char BatterySymbol[] = {
   0xfc, 0x3f, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xcf, 0xf3, 0x07, 0xe0,
   0x07, 0xe0, 0x07, 0xe0, 0x07, 0xe0, 0x07, 0xe0, 0x07, 0xe0, 0xff, 0xff,
   0xff, 0xff, 0xff, 0xff, 0xfe, 0x7f, 0xfc, 0x3f };
//Heater symbol bitmap.
PROGMEM const unsigned char HeaterSymbol[] = {
   0xfc, 0x3f, 0xfe, 0x7f, 0xff, 0xff, 0xdf, 0xf6, 0x4f, 0xf2, 0x6f, 0xfb,
   0x6f, 0xfb, 0x4f, 0xf2, 0xdf, 0xf6, 0xff, 0xff, 0x07, 0xe0, 0xff, 0xff,
//Lambda Conversion Lookup Table. (ADC 39-791).
const PROGMEM float Lambda_Conversion[753] {
  0.750, 0.751, 0.752, 0.752, 0.753, 0.754, 0.755, 0.755, 0.756, 0.757, 0.758, 0.758, 0.759, 0.760, 0.761, 0.761, 0.762, 0.763, 0.764, 0.764,
  0.765, 0.766, 0.766, 0.767, 0.768, 0.769, 0.769, 0.770, 0.771, 0.772, 0.772, 0.773, 0.774, 0.774, 0.775, 0.776, 0.777, 0.777, 0.778, 0.779,
  0.780, 0.780, 0.781, 0.782, 0.782, 0.783, 0.784, 0.785, 0.785, 0.786, 0.787, 0.787, 0.788, 0.789, 0.790, 0.790, 0.791, 0.792, 0.793, 0.793,
  0.794, 0.795, 0.796, 0.796, 0.797, 0.798, 0.799, 0.799, 0.800, 0.801, 0.802, 0.802, 0.803, 0.804, 0.805, 0.805, 0.806, 0.807, 0.808, 0.808,
  0.809, 0.810, 0.811, 0.811, 0.812, 0.813, 0.814, 0.815, 0.815, 0.816, 0.817, 0.818, 0.819, 0.820, 0.820, 0.821, 0.822, 0.823, 0.824, 0.825,
  0.825, 0.826, 0.827, 0.828, 0.829, 0.830, 0.830, 0.831, 0.832, 0.833, 0.834, 0.835, 0.836, 0.837, 0.837, 0.838, 0.839, 0.840, 0.841, 0.842,
  0.843, 0.844, 0.845, 0.846, 0.846, 0.847, 0.848, 0.849, 0.850, 0.851, 0.852, 0.853, 0.854, 0.855, 0.855, 0.856, 0.857, 0.858, 0.859, 0.860,
  0.861, 0.862, 0.863, 0.864, 0.865, 0.865, 0.866, 0.867, 0.868, 0.869, 0.870, 0.871, 0.872, 0.873, 0.874, 0.875, 0.876, 0.877, 0.878, 0.878,
  0.879, 0.880, 0.881, 0.882, 0.883, 0.884, 0.885, 0.886, 0.887, 0.888, 0.889, 0.890, 0.891, 0.892, 0.893, 0.894, 0.895, 0.896, 0.897, 0.898,
  0.899, 0.900, 0.901, 0.902, 0.903, 0.904, 0.905, 0.906, 0.907, 0.908, 0.909, 0.910, 0.911, 0.912, 0.913, 0.915, 0.916, 0.917, 0.918, 0.919,
  0.920, 0.921, 0.922, 0.923, 0.924, 0.925, 0.926, 0.927, 0.928, 0.929, 0.931, 0.932, 0.933, 0.934, 0.935, 0.936, 0.937, 0.938, 0.939, 0.940,
  0.941, 0.942, 0.944, 0.945, 0.946, 0.947, 0.948, 0.949, 0.950, 0.951, 0.952, 0.953, 0.954, 0.955, 0.957, 0.958, 0.959, 0.960, 0.961, 0.962,
  0.963, 0.965, 0.966, 0.967, 0.969, 0.970, 0.971, 0.973, 0.974, 0.976, 0.977, 0.979, 0.980, 0.982, 0.983, 0.985, 0.986, 0.987, 0.989, 0.990,
  0.991, 0.992, 0.994, 0.995, 0.996, 0.998, 0.999, 1.001, 1.003, 1.005, 1.008, 1.010, 1.012, 1.015, 1.017, 1.019, 1.022, 1.024, 1.026, 1.028,
  1.030, 1.032, 1.035, 1.037, 1.039, 1.041, 1.043, 1.045, 1.048, 1.050, 1.052, 1.055, 1.057, 1.060, 1.062, 1.064, 1.067, 1.069, 1.072, 1.075,
  1.077, 1.080, 1.082, 1.085, 1.087, 1.090, 1.092, 1.095, 1.098, 1.100, 1.102, 1.105, 1.107, 1.110, 1.112, 1.115, 1.117, 1.120, 1.122, 1.124,
  1.127, 1.129, 1.132, 1.135, 1.137, 1.140, 1.142, 1.145, 1.148, 1.151, 1.153, 1.156, 1.159, 1.162, 1.165, 1.167, 1.170, 1.173, 1.176, 1.179,
  1.182, 1.185, 1.188, 1.191, 1.194, 1.197, 1.200, 1.203, 1.206, 1.209, 1.212, 1.215, 1.218, 1.221, 1.224, 1.227, 1.230, 1.234, 1.237, 1.240,
  1.243, 1.246, 1.250, 1.253, 1.256, 1.259, 1.262, 1.266, 1.269, 1.272, 1.276, 1.279, 1.282, 1.286, 1.289, 1.292, 1.296, 1.299, 1.303, 1.306,
  1.310, 1.313, 1.317, 1.320, 1.324, 1.327, 1.331, 1.334, 1.338, 1.342, 1.345, 1.349, 1.352, 1.356, 1.360, 1.364, 1.367, 1.371, 1.375, 1.379,
  1.382, 1.386, 1.390, 1.394, 1.398, 1.401, 1.405, 1.409, 1.413, 1.417, 1.421, 1.425, 1.429, 1.433, 1.437, 1.441, 1.445, 1.449, 1.453, 1.457,
  1.462, 1.466, 1.470, 1.474, 1.478, 1.483, 1.487, 1.491, 1.495, 1.500, 1.504, 1.508, 1.513, 1.517, 1.522, 1.526, 1.531, 1.535, 1.540, 1.544,
  1.549, 1.554, 1.558, 1.563, 1.568, 1.572, 1.577, 1.582, 1.587, 1.592, 1.597, 1.601, 1.606, 1.611, 1.616, 1.621, 1.627, 1.632, 1.637, 1.642,
  1.647, 1.652, 1.658, 1.663, 1.668, 1.674, 1.679, 1.684, 1.690, 1.695, 1.701, 1.707, 1.712, 1.718, 1.724, 1.729, 1.735, 1.741, 1.747, 1.753,
  1.759, 1.764, 1.770, 1.776, 1.783, 1.789, 1.795, 1.801, 1.807, 1.813, 1.820, 1.826, 1.832, 1.839, 1.845, 1.852, 1.858, 1.865, 1.872, 1.878,
  1.885, 1.892, 1.898, 1.905, 1.912, 1.919, 1.926, 1.933, 1.940, 1.947, 1.954, 1.961, 1.968, 1.975, 1.983, 1.990, 1.997, 2.005, 2.012, 2.020,
  2.027, 2.035, 2.042, 2.050, 2.058, 2.065, 2.073, 2.081, 2.089, 2.097, 2.105, 2.113, 2.121, 2.129, 2.137, 2.145, 2.154, 2.162, 2.171, 2.179,
  2.188, 2.196, 2.205, 2.214, 2.222, 2.231, 2.240, 2.249, 2.258, 2.268, 2.277, 2.286, 2.295, 2.305, 2.314, 2.324, 2.333, 2.343, 2.353, 2.363,
  2.373, 2.383, 2.393, 2.403, 2.413, 2.424, 2.434, 2.444, 2.455, 2.466, 2.476, 2.487, 2.498, 2.509, 2.520, 2.532, 2.543, 2.554, 2.566, 2.577,
  2.589, 2.601, 2.613, 2.625, 2.637, 2.649, 2.662, 2.674, 2.687, 2.699, 2.712, 2.725, 2.738, 2.751, 2.764, 2.778, 2.791, 2.805, 2.819, 2.833,
  2.847, 2.861, 2.875, 2.890, 2.904, 2.919, 2.934, 2.949, 2.964, 2.979, 2.995, 3.010, 3.026, 3.042, 3.058, 3.074, 3.091, 3.107, 3.124, 3.141,
  3.158, 3.175, 3.192, 3.209, 3.227, 3.245, 3.263, 3.281, 3.299, 3.318, 3.337, 3.355, 3.374, 3.394, 3.413, 3.433, 3.452, 3.472, 3.492, 3.513,
  3.533, 3.554, 3.575, 3.597, 3.618, 3.640, 3.662, 3.684, 3.707, 3.730, 3.753, 3.776, 3.800, 3.824, 3.849, 3.873, 3.898, 3.924, 3.950, 3.976,
  4.002, 4.029, 4.056, 4.084, 4.112, 4.140, 4.169, 4.198, 4.228, 4.258, 4.288, 4.319, 4.350, 4.382, 4.414, 4.447, 4.480, 4.514, 4.548, 4.583,
  4.618, 4.654, 4.690, 4.726, 4.764, 4.801, 4.840, 4.879, 4.918, 4.958, 4.999, 5.040, 5.082, 5.124, 5.167, 5.211, 5.255, 5.299, 5.345, 5.391,
  5.438, 5.485, 5.533, 5.582, 5.632, 5.683 ,5.735, 5.788, 5.841, 5.896, 5.953, 6.010, 6.069, 6.129, 6.190, 6.253, 6.318, 6.384, 6.452, 6.521,
  6.592, 6.665, 6.740, 6.817, 6.896, 6.976, 7.059, 7.144, 7.231, 7.320, 7.412, 7.506, 7.602, 7.701, 7.803, 7.906, 8.013, 8.122, 8.234, 8.349,
  8.466, 8.587, 8.710, 8.837, 8.966, 9.099, 9.235, 9.374, 9.516, 9.662, 9.811, 9.963, 10.119 };
//Function for transfering SPI data to the CJ125.
uint16_t COM_SPI(uint16_t TX_data) {
  //Set chip select pin low, chip in use.
  digitalWrite(CJ125_NSS_PIN, LOW);
  //Transmit and receive.
  byte highByte = SPI.transfer(TX_data >> 8);
  byte lowByte = SPI.transfer(TX_data & 0xff);
  //Set chip select pin high, chip not in use.
  digitalWrite(CJ125_NSS_PIN, HIGH);
  //Assemble response in to a 16bit integer and return the value.
  uint16_t Response = (highByte << 8) + lowByte;
  return Response;
//Lookup Lambda Value.
float Lookup_Lambda(int Input_ADC) {
    //Declare and set default return value.
    float LAMBDA_VALUE = 0;
    //Validate ADC range for lookup table.
    if (Input_ADC >= 39 && Input_ADC <= 791) {
      LAMBDA_VALUE = pgm_read_float_near(Lambda_Conversion + (Input_ADC-39));
    if (Input_ADC > 791) {
      LAMBDA_VALUE = 10.119;
    if (Input_ADC < 39) {
      LAMBDA_VALUE = 0.750;
    //Return value.
    return LAMBDA_VALUE;
//Temperature regulating software (PID).
int CalculateHeaterOutput(int input) {
  //Calculate error term.
  int error = adcValue_UR_Optimal - input;
  //Set current position.
  int position = input;
  //Calculate proportional term.
  float pTerm = -pGain * error;
  //Calculate the integral state with appropriate limiting.
  iState += error;
  if (iState > iMax) iState = iMax;
  if (iState < iMin) iState = iMin;
  //Calculate the integral term.
  float iTerm = -iGain * iState;
  //Calculate the derivative term.
  float dTerm = -dGain * (dState - position);
  dState = position;
  //Calculate regulation (PI).
  int RegulationOutput = pTerm + iTerm + dTerm;
  //Set maximum heater output (full power).
  if (RegulationOutput > 255) RegulationOutput = 255;
  //Set minimum heater value (cooling).
  if (RegulationOutput < 0.0) RegulationOutput = 0;
  //Return calculated PWM output.
  return RegulationOutput;
//Function to transfer current values to front end.
void UpdateSerialOutput() {
  //Calculate checksum.
  uint16_t checksum = HeaterStatus + hardwareId + CJ125_Status + adcValue_UA + adcValue_UR + adcValue_UB;
  //Assembled data.
  String txString = (String)HeaterStatus;
  txString += ",";
  txString += (String)hardwareId;
  txString += ",";
  txString += (String)CJ125_Status;
  txString += ",";
  txString += (String)adcValue_UA;
  txString += ",";
  txString += (String)adcValue_UR;
  txString += ",";
  txString += (String)adcValue_UB;
  txString += ",";
  txString += (String)checksum;
  //Output values.
  Serial.println(txString);
//Function to read inputs and update values.
void UpdateInputs() {
  //Update CJ125 diagnostic register from SPI.
  CJ125_Status = COM_SPI(CJ125_DIAG_REG_REQUEST);
  //Update analog inputs.
  adcValue_UA = analogRead(UA_ANALOG_INPUT_PIN);
  adcValue_UR = analogRead(UR_ANALOG_INPUT_PIN);
  adcValue_UB = analogRead(UB_ANALOG_INPUT_PIN);
//Function to update user interfaces and output.
void UpdateUI() {
  //Local variables.
  const float AirFuelRatioOctane = 14.70;
  //Sensor is not active.
  if (HeaterStatus == 0) {
    //Output LED's.
    digitalWrite(LED_STATUS_POWER, LOW);
    digitalWrite(LED_STATUS_HEATER, LOW);
    //Output serial data.
    UpdateSerialOutput();
    //Output logo to display.
    u8g2.firstPage();
    do {
      u8g2.drawXBMP(0, 16, 128, 32, Logo);
    } while ( u8g2.nextPage() );
  //Sensor is heating up.
  if (HeaterStatus == 1) {
    //Output LED's.
    digitalWrite(LED_STATUS_POWER, HIGH);
    digitalWrite(LED_STATUS_HEATER, HIGH);
    //Output display data.
    u8g2.firstPage();
    do {
      u8g2.drawXBMP(108, 4, 16, 16, LambdaSensorSymbol);
      u8g2.drawXBMP(108, 24, 16, 16, BatterySymbol);
      u8g2.drawXBMP(108, 44, 16, 16, HeaterSymbol);
    //Delay for flashing LED's.
    u8g2.firstPage();
    do {
    //Output LED's.
  //Sensor is measuring.
  if (HeaterStatus == 2) {
    //Output LED's.
    u8g2.firstPage();
    do {
      u8g2.setFont(u8g2_font_helvB24_tf);
      u8g2.setCursor(5,29);
      u8g2.print(Lookup_Lambda(adcValue_UA) * AirFuelRatioOctane, 2);
      u8g2.setCursor(5,59);
      u8g2.print(Lookup_Lambda(adcValue_UA), 2);
//Function to set up device for operation.
  //Set up serial communication.
  //Set up SPI.
  SPI.begin();  /* Note, SPI will disable the bult in LED*/
  SPI.setClockDivider(SPI_CLOCK_DIV128);
  SPI.setBitOrder(MSBFIRST);
  SPI.setDataMode(SPI_MODE1);
  //Set up digital output pins.
  pinMode(CJ125_NSS_PIN, OUTPUT);
  pinMode(LED_STATUS_POWER, OUTPUT);
  pinMode(LED_STATUS_HEATER, OUTPUT);
  pinMode(HEATER_OUTPUT_PIN, OUTPUT);
  //Initialize display.
  u8g2.begin();
  //Start main function.
  start();
void start() {
  //Reset initial values.
  analogWrite(HEATER_OUTPUT_PIN, 0);
  //Start of operation. (Test LED's).
  delay(200);
  //Update heater status to off.
  HeaterStatus = 0;
  //Wait until everything is ready. Read CJ125 multiple times with delay in between to let it initialize. Otherwise responds OK.
  while (adcValue_UB < UBAT_MIN || CJ125_Status != CJ125_DIAG_REG_STATUS_OK) {
    //Update Values.
    UpdateInputs();
    //Update frontends.
    UpdateUI();
    //Delay.
    delay(100);
  //Set CJ125 in calibration mode.
  COM_SPI(CJ125_INIT_REG1_MODE_CALIBRATE);
  //Let values settle.
  //Store optimal values before leaving calibration mode.
  adcValue_UA_Optimal = analogRead(UA_ANALOG_INPUT_PIN);
  adcValue_UR_Optimal = analogRead(UR_ANALOG_INPUT_PIN);
  //Set CJ125 in normal operation mode.
  //COM_SPI(CJ125_INIT_REG1_MODE_NORMAL_V8);  /* V=0 */
  COM_SPI(CJ125_INIT_REG1_MODE_NORMAL_V17);  /* V=1 */
  /* Heat up sensor. This is described in detail in the datasheet of the LSU 4.9 sensor with a
   * condensation phase and a ramp up face before going in to PID control. */
  //Update heater status to heating.
  HeaterStatus = 1;
  //Calculate supply voltage.
  float SupplyVoltage = (((float)adcValue_UB / 1023 * 5) /10000) * 110000;
  //Condensation phase, 2V for 5s.
  int CondensationPWM = (2 / SupplyVoltage) * 255;
  analogWrite(HEATER_OUTPUT_PIN, CondensationPWM);
  int t = 0;
  while (t < 5 && adcValue_UB > UBAT_MIN) {
    //Update Values.
    UpdateInputs();
    //Update frontends.
    UpdateUI();
    t += 1;
  //Ramp up phase, +0.4V / s until 100% PWM from 8.5V.
  float UHeater = 8.5;
  while (UHeater < 13.0 && adcValue_UB > UBAT_MIN && adcValue_UR > adcValue_UR_Optimal) {
    //Update Values.
    UpdateInputs();
    //Update frontends.
    UpdateUI();
    //Set heater output during ramp up.
    CondensationPWM = (UHeater / SupplyVoltage) * 255;
    if (CondensationPWM > 255) CondensationPWM = 255; /*If supply voltage is less than 13V, maximum is 100% duty cycle*/
    //Increment Voltage.
    UHeater += 0.4;
  //Update heater status to regulating.
  HeaterStatus = 2;
//Infinite loop.
  //Update Values.
  UpdateInputs();
  //Display on serial port at defined rate. Comma separate values, readable by frontends.
  if ( (100 / SERIAL_RATE) ==  serial_counter) {
    //Reset counter.
    serial_counter = 0;
    //Update frontends.
    UpdateUI();
  //Adjust PWM output by calculated PID regulation.
  if (adcValue_UR < 500 && adcValue_UB > UBAT_MIN) {
    //Calculate and set new heater output.
    HeaterOutput = CalculateHeaterOutput(adcValue_UR);
    analogWrite(HEATER_OUTPUT_PIN, HeaterOutput);
    //Re-start() and wait for power.
    start();
  //Increment serial output counter and delay for next cycle. The PID requires to be responsive but we don't need to flood the serial port.
  serial_counter++;
  delay(10);
Thanks for your help.
Best ~~~
Karl / Nordseven
Probably you have a memory issue. Get rid logos and related code from the sketch and try without it.
Thank you b707. Doing it.
Deleted as much as I could make out was Logo related. Got an error when compiling. I do not know sketch structure enough to manage this with much skill. So put Logo data (what I think is the Logo's image code) back in to a very limited degree only to keep the "Logo" existing. Saved 1% memory (went from 80% space used to 79%.) That modified sketch verified and I just tested it in-car. Only part of the top line of text displayed and there was no motion in the numbers as there should be. Original sketch is being uploaded.
Idea of a memory issue to solve was applied via reducing display fonts from 24pt to 12pt. Used space went from 80% to 70% with this mod. Display stability improved noticeably but not perfect. Was sufficient to drive around and see what the Air Fuel Ratio (AFR) / Lambda was doing. Reason for this Arduino adventure is I rebuilt the engine and went from a prior-rebuild 18 mpg city to 10 mpg. (27 highway.) This Arduino wideband is intended to provide insight to when the fuel system is going out of bounds. Running the engine under all loads just now... the display bobbled a single decimal point AFR and Lambda never budged from 0.99. There should have been some decisive swings in the numbers and there wasn't. Tomorrow the snubbers come out and will see what comes of that.
Few tests just completed:
Changed Arduino & shield for a second set. Display froze.
Changed 4.9 Bosch sensor for new Bosch sensor purchased from same company the Arduino and shield came from (Bylund Automotive out of Sweden.) No data to display.
Disconnected snubber from relay that serves 12v to Bylund shield. With same new Bosch sensor... no data.
After all that has transpired, all that has not worked, minimal to zero support, I wasted my time & money with what appears to be a useless product/company.
The license does not allow the use of Arduino in the automotive environment. This is due to the fact that Arduino boards do not have protection against voltage surges and interference, which always occur when the engine and other units are running.
The fact that your board hangs is absolutely not surprising. In order to reduce the likelihood of freezing, it is advisable to use the most stable power supply (preferably independent from the car network), use the shortest possible wires, and protect all input ports with capacitors.
Thank you b707 for those notes. It is unknown to me that Arduino's are not suitable---without protection---in automotive environs.
Were Bylund Automotive as professionally engaged in automotive component design as the company promotes, they would certainly have advised the Arduino protection b707 notes... and... designed their shield for the auto environment it is for.
Anyone looking into Bylund Automotive products should consider what I failed to look at. Their forum.... it's an empty shell. All their YouTube vids... comments are blocked. And there is no YouTube vids with end-users of the Bylund wideband system promoting how well or not it works. Forum support from Christian Bylund was offered me at first. Later, I couldn't get into the forum. Then I re registered to get in and got no assistance. Add everything together and nothing speaks of a professional company offering valued solutions. On the surface, Bylund Automotive puts on a good show. Below, the company doesn't add up. I'm done investing time & money trying to get their system to work.
Bottom line... for anyone thinking about Bylund Automotive products, think twice.
Thank you for your input b707. And to anyone who has spent their time thinking over the problems I faced with this matter.
