My hardware wiring settings are posted in the file itself.
A photo of a bunch of wired up stuff is probably not helpful.
I have followed all the advice, USB micro B jack into the plug near the 5 Volt plug in,
wired inputs from the SPI plug in the middle of the Arduino Due board.
The Arduino board itself is likely OK, because I went back and attached it
to the 1306 oled, the smaller one, and the 1306 oled worked fine.
My oled stays dark, which is the normal backgrounding for the display.
So something is not being excited.
I have tried grounding all the inputs that the 1.91 inch oled does not use,
and that did not change anything.
Previously, I went through another wiring, and when I lifted up the ground and put it back in again, I got the screen to paste several colors across itself: green, red, and mixed.
So it is likely the 1.91 inch oled is alive.
Tried several power inputs.
Code for the test file is here.
Thanks in advance for your support.
type or paste code here
```// Section 1, fetching libraries, and setting pre-compiler attributes
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1351.h>
#include <SPI.h>
// Screen dimensions
#define SCREEN_WIDTH 176
#define SCREEN_HEIGHT 176
// oled address
#define SCREEN_SPI_ADDRESS 0x3C
// Color definitions
const unsigned short BLACK = 0x0000;
const unsigned short BLUE = 0x001F;
const unsigned short GREEN = 0x07E0;
const unsigned short RED = 0xF800;
const unsigned short WHITE = 0xFFFF;
const unsigned short VIOLET = 0x781F;
const unsigned short YELLOW = 0xFFE0;
Arduino SPI communication uses
a) 4 wires—SCK (Clock),
b) MOSI (Master Out),
c) MISO (Master In),
d) and CS/SS (Chip Select)—to exchange data at high speeds.
The SPI.h library manages communication, requiring
a) SPI.beginTransaction() for settings (not shown),
b) digitalWrite() to manage the CS pin (multiple times),
c) and SPI.transfer() to send/receive bytes (not shown).
// SPI Pin connections
#define OLED_RST 8 // Arduino Due pin D8 to oled pin 16
#define OLED_DC 9 // Arduino Due pin D9 to oled pin 4
#define OLED_CS 10 // Arduino Due pin D10 to oled pin 17
#define OLED_MOSI 77 // Arduino Due SPI header pin 77 (known as SPI-4) to oled pin 8
#define OLED_CLK 76 // Arduino Due SPI header pin 76 (known as SPI-3) to oled pin 7
// Recommended for SPI-4 Wire: BS1 (pin 19) is VCC, BS0, BS2 (pins 18, 20) are GND
/* configuration of six pin SPI header
RST-78 (pin 5)---SCLK 76 (pin 3)---MISO--74 (pin1)
GND-79 (pin 6)---MOSI-77 (pin 4)-----5V-75 (pin 2)
MISO is not used in this configuraton
5V is not used in this configuraton
// Initialize display
Adafruit_SSD1351 oled = Adafruit_SSD1351(SCREEN_WIDTH, SCREEN_HEIGHT,&SPI,OLED_DC,OLED_RST,OLED_CS);
// Section 2, prepping oled and attributes to get ready for display
pinMode(OLED_CS,OUTPUT);
pinMode(OLED_DC,OUTPUT);
pinMode(OLED_RST,OUTPUT);
SPI.begin(OLED_CS);
SPI.beginTransaction(SPISettings(8000000, MSBFIRST,SPI_MODE0));
// the reset pulse is needed to initiate the display for inputs,
// below is the recommended timing, 10 us as low (3 to 10 us,
// 100 us still OK, 20 ms as high (15 to 20 ms)
digitalWrite(OLED_RST, LOW);
delay(.01);
digitalWrite(OLED_RST, HIGH);
delay(20);
// below commands protect setup commands as given
digitalWrite(OLED_DC,LOW);
digitalWrite(OLED_CS, LOW);
SPI.transfer(0xFD);
digitalWrite(OLED_CS, HIGH);
digitalWrite(OLED_DC,HIGH);
SPI.transfer(0x12);
// SPI.transfer(0x12); frees commands to be open to display changes
// SPI.transfer(0xFD); command Lock, step one to lock in setup commands
// SPI.transfer(0x16); locks command to prevent display changes,step two
// to keep setup commands locked,see below
// SPI.transfer(0xAE); display OFF
// Set remaining oled attributes
// Clock divider,0x09 is default, sets spanning rate
SPI.transfer(0xB3);
SPI.transfer(0x09);
// Contrast, 256 levels of contrast
SPI.transfer(0xC1);
SPI.transfer(0x3F);
// Current, 0x0F is optimum, 0x01 to 0x07 is low for night mode,
//0x07 to 0x10 for maximum
SPI.transfer(0xC7);
SPI.transfer(0x01);
// Communication voltage, 0x05 is .82*VCC
SPI.transfer(0xBE);
SPI.transfer(0x20);
// Multiplex ratio,this determines how many rows are
//scanned at a time, 0xAF is a 1:176 ratio, or
//one row per scan, the default
SPI.transfer(0xCA);
SPI.transfer(0xAF);
// Phase length, pre-charge period,and pre-charge voltage
// are implemented with defaults as shown below
// for the display controller (SSD1333)
SPI.transfer(0xB1);
SPI.transfer(0x84);
// Pre-charge period, 0x08 is 8 display clocks
SPI.transfer(0xB6);
SPI.transfer(0x08);
// Pre-charge voltage, default is 0x17,or.40*VCC
SPI.transfer(0xBB);
SPI.transfer(0x17);
// Re-map enables the map to be flipped:
// 0x64 is normal, 0x14 or 0x06 allows 180 degree flip
// Re-map color depth,selects between two color modes,
// 16 bit (65K options) and 18 bit (enhanced color, 262K options)
// 0x50 is default
SPI.transfer(0xA0);
SPI.transfer(0x64);
SPI.transfer(0xA0);
SPI.transfer(0x50);
// Set Column Address, 0x00 start, 0xAF end, per spec
SPI.transfer(0x15);
SPI.transfer(0xAF);
SPI.transfer(0x15);
SPI.transfer(0x00);
// Set Row Address, 0x00 start, 0xAF end, per spec
SPI.transfer(0x75);
SPI.transfer(0xAF);
SPI.transfer(0x75);
SPI.transfer(0x00);
clock divider ratio: B3 with the following, according to NH doc
A[3:0] => Display Clock Divider
A[7:4] => Oscillator Frequency
column address: 15
command lock: FD based on NH doc
contrast (set): 81, C1 based on NH doc
display offset: A2
display (on/off): AE to AF
display start line (set): A1
memory addressing mode: 20
multiplex ratio: A8, CA based on NH doc
oscillator frequency: B3
pre-charge: VCOMH: BE
pre-charge period: B1, B6 according to NH doc
ram (display): A4 to A7
remap: A0
row address: 75
scroll (stop): 2E
scroll (vertical/horizontal): 26 to 27, A1 and A2 according to NH doc
// Turn on display, this is recommended to be the last step in the setup process
SPI.transfer(0xAF);
SPI.transfer(0xA5);
0xAF = Display ON command
Set Display Mode
Default => 0xA6
0xA4 => Entire Display Off, All Pixels Turn Off,
used to return display to original mode
0xA5 => Entire Display On, All Pixels Turn On at GS Level 63,
maximum brightness, used to check for dead pixels
0xA6 => Normal Display
0xA7 => Inverse Display
// Section four, looping program to draw line
// SPI.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
// set column address, low and high
digitalWrite(OLED_DC, LOW);
SPI.transfer(0x15);
SPI.transfer(0x00);
SPI.transfer(0xAF);
// set row address, low and high
SPI.transfer(0x75);
SPI.transfer(0x00);
SPI.transfer(0xAF);
// send color data to RAM
SPI.transfer(OLED_CS, 0xD3, SPI_CONTINUE); // Set Display Offset
SPI.transfer(OLED_CS, 0x00, SPI_CONTINUE); // Set Offset Value
SPI.transfer(0x5C);
// sending data to RAM, send high byte, then low byte
digitalWrite(OLED_DC, HIGH);
for (int i = 0; i < 176*176; i++){
SPI.transfer(GREEN >> 8);
SPI.transfer(GREEN & 0xFF);
YT, Joshua H. Sparber
