A change in value from a color sensor
Hey all,
I'm struggling a bit with my code..
The idea is that when the color sensor picks up a different value, it will then read the value and activate a relais.
So I need to save the first value it reads then as soon as it picks up another value the if statement will begin. I've already tried somethings, but I only have error codes.
Here's my code:
#define s0 8
#define s1 9
#define s2 10
#define s3 11
#define out 12
 //GetColors();
int Red=0, Blue=0, Green=0;
//setup colorsensor
pinMode(s0,OUTPUT);
pinMode(s1,OUTPUT);
pinMode(s2,OUTPUT);
pinMode(s3,OUTPUT);
pinMode(out,INPUT);
//setup relais
pinMode(6, OUTPUT);
pinMode(5,OUTPUT);
pinMode(4,OUTPUT);
digitalWrite(s0,HIGH);
digitalWrite(s1,HIGH);
sensor   = pulseIn;
LastReading = ThisReading ;
ThisReading = pulseIn ;
  if (ThisReading != pulseIn) When a different value is detected
 if (Red <=15 && Green <=15 && Blue <=15)   //now it will detect colors, this is white
 colorcountERROR++;
else if (Red<Blue && Red<=Green && Red<23)
      colorcountRed++;
  else if (Blue<Green && Blue<Red && Blue<20)
      colorcountBlue++;
  else if (Green<Red && Green-Blue<= 8)
      colorcountGreen++;
  else    //No color found
     colorcountERROR++;
  if (colorcountERROR >=9)
    Serial.println ("Unknown");
  else if (colorcountRed >=5)
    Serial.println ("Red");
    digitalWrite (6,HIGH);
  else if (colorcountBlue >=5)
    Serial.println ("Blue");
    digitalWrite (5,HIGH);
  else if (colorcountGreen >=5)
    Serial.println ("Green");
    digitalWrite (4,HIGH);
    Serial.println ("wait..");
  else  //No difference in value
  Serial.println ("Rad in stilstand");
void GetColors()
  digitalWrite(s2, LOW);
  digitalWrite(s3, LOW);
  Red = pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
  delay(20);
  digitalWrite(s3, HIGH);
  Blue = pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
  delay(20);
  digitalWrite(s2, HIGH);
  Green = pulseIn(out, digitalRead(out) == HIGH ? LOW : HIGH);
  delay(20);
Please post a link to the sensor product page or data sheet, and cut and paste the error codes (with quote or code tags).
It would be helpful to readers if you deleted most of the blank lines in your code, and re-post it.
Hey,
I've changed deleted the blank lines it should be better now.
The color sensor I'm using is the TCS3200.
Here's a link to a data sheet: TCS3200 datasheet(1/14 Pages) TAOS | COLOR LIGHT-TO-FREQUENCY CONVERTER
As for error codes; "Use of undeclared identifier 'sensor'clang(undeclared_var_use)","Use of undeclared identifier 'LastReading'clang(undeclared_var_use)", "Use of undeclared identifier 'ThisReading'clang(undeclared_var_use)".
these are found when comparing the previous value to the current value. this makes sense since I have yet to declare it, but I don't know how to do it properly.
Do you know how to declare it so it works?
Many thanks
All variables have to be appropriately declared. For example, if you intend to store the result of the pulseIn() function, then you look up the reference page for pulseIn()
to learn that it requires as arguments the correct digital pin number and a value (HIGH or LOW), and returns an unsigned long result.
So your code might look like this:
unsigned long sensor_value;
sensor_value = pulseIn(pin, HIGH);
BTW: Where did this code come from? It never could have worked, with lines like this:
sensor = pulseIn;
None of these variables are declared. Did you copy random lines from some other code with no understanding of them? 'cause that just won't work!
To pick up the first value, you can read from the sensor in setup() and save those readings in global variables. Then, in loop(), you can read new values and compare them to those saved earlier.
Can you clarify what you mean by that? Do you mean a change in the colour or hue of the light, ignoring any change in the brightness level? Or should a change in the brightness also trigger the relay?
I'm pretty certain you don't want any change to trigger the relay. Even if the object in front of the sensor does not move and the light levels don't change, the readings from the sensor won't be exactly the same each time. There will always be some small random variations from reading to reading. You will need to spend some time observing the readings before you know how much of a change is a real change and not just a random fluctuation.
Hello thanks for your reply,
I want it to trigger when the color changes.
I have three colors I work with, Red, green and blue. when the color changes from what it picked up the moment the program runs, the if statement starts.
The three colors are on a 'wheel of fortune' so the starting value(color) might be different every time. and when the wheel stops spinning a relais must be activated. I've already coded that
Ok, I understand a little more about your project now.
Did you understand anything of what I have said?
First, learn how to use pulseIn() properly, to read the sensor output. Any output.
You need only a few lines of code for that. But you could start from this tutorial, as long as you copy the code correctly.
https://techatronic.com/tcs3200-color-sensor-with-arduino-detailed-tutorial/
Yes, this is what I now have:
in my void setup():
int sensor_Value = pulseIn(s3,HIGH);
in my void loop():
if (sensor_Value != pulseIn(s3,HIGH))
I have yet to test it out tho..
That's almost certain to be true, always.
So how is it properly done?
It's quite difficult do do because pulseIn(s2/s3,HIGH/LOW) gives different colors...
thanks
Put the result of the pulseIn into a variable and compare that to a range of values
Please always post your complete code.
The sensor outputs are square waves, so it should not matter if you choose HIGH or LOW because in theory the result should be the same. In practice, as I said, there will always be fluctuations in the readings.
Why would you use s2 or s3 with pulseIn() ? You declared these pins as OUTPUT.
The readings you will get for each colour on the wheel will vary depending on the ambient lighting, unless you can completely exclude ambient light from entering the sensor. Different types of ambient lighting will give different readings: sunlight different to overcast daylight different to florescent lighting different to led lighting...
Hey,
this is the part of the code
int previousvalue = pulsIn;
  if (previousvalue =/= pulseIn)
is the correct way to define it: pulseIn(OUTPUT,HIGH);?
kind regards
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
  • Your OS and version can be valuable information, please include it along with extra security you are using.
  • Always list the version of the IDE you are using and the board version if applicable.
  • Use quote or add error messages as an attachment NOT a picture.
  • How to insert an image into your post. ( Thanks @sterretje )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
  • Ensure you have FULLY inserted the USB cables.
  • Check you have a COMMON GROUND where required. ( Thanks @Perry)
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
  • There may be a problem with the board check or remove your wiring first.
  • Remove any items connected to pins 0 and 1.
COMPUTER RELATED
  • Close any other serial programs before opening the IDE.
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
  • CH340/341 based clones do not report useful information to the “get board info” button.
  • NANO (Old Types) some require you to use the OLD BOOTLOADER option.
  • NANO (ALL Types) See the specific sections lower in the forum.
  • NANO (NEW Types) Install your board CORE’s.
  • Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
  • Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
  • On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
  • On Linux ~/ArduinoCreateAgent-1.1/config.ini
  • On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
To get started on this project, see post #9 and go through the linked material carefully.
