A fatal esptool.py error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
Hello there... I am trying to upload the below code to my ESP 01 via Arduino Uno but I keep on getting the esptool.py error. This is the connection that I am using
RX---------->RX
TX---------->TX
CH---------->3.3V
GND ------->GND
VCC---------->3.3V
I have also tried connecting RX to TX and TX to RX but the error is still consistent.
This are thing I have tried so far...
  1. Downgraded ESP8266 libraries
  2. uninstalled and re-installed port drivers from the device manager
  3. Uninstalled and re-installed Arduino IDE
  4. I have also tried using a different laptop
  5. I have also reduced my baud to 9600
    I have tried almost everything available on the internet but none seems successful and my serial monitor commands are not working at all. This is the code i am trying to upload to my esp01
// Libraries
#include <ESP8266WiFi.h>
// WiFi network
const char* ssid     = "SpaceX";
const char* password = "Rock@321";
  // Start serial
  delay(10);
  // Connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
kindly assist
from ESP8266_01_pin_magic
GPIO0 and GPIO2 need to have pull-up resistors connected to ensure the module starts up correctly. The ESP-01S has 12K resistors on the board for GPIO0, RST and CH_PD
I find the ESP-01 Helper V3 a useful tool for programming the device
Welcome
Some people might know what that means, others might not :wink: Please post the complete error message as text using code tags (see How to get the best out of this forum)
I'm not familiar with ESPs so can't help further.
For uploading GPIO 0 should be connected to GND at boot and GPIO 1 (TX) & GPIO 2 should not be connected to GND (pulled up or free-floating) also since the UNO is a 5v device and the esp is a 3.3v device you should use a voltage divider on the ESP's RX line to reduce the 5v logic levels that the UNO provides, like this :
UNO RX -> 1k -> ESP RX -> 1k ->1k -> GND
For the rest your connections look ok. Make sure that there is no sketch on the UNO that uses Serial or pin 0 & 1 in any other way (blink is fine !)
So add the GPIO 0 -> GND and the voltage divider.
(note, do not use high value resistors, 1K (3 times) works best.)
After upload the program will run, but if you reset the ESP and want the program to run you should disconnect GPIO 0 from GND (or it will go into flash mode again) and if you want to upload again you will need to reset it with GPIO 0 to GND.
. Variables and constants in RAM (global, static), used 28680 / 80192 bytes (35%)
║ SEGMENT BYTES DESCRIPTION
╠══ DATA 1496 initialized variables
╠══ RODATA 1032 constants
╚══ BSS 26152 zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 61895 / 65536 bytes (94%)
╠══ ICACHE 32768 reserved space for flash instruction cache
╚══ IRAM 29127 code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 240648 / 1048576 bytes (22%)
╚══ IROM 240648 code in flash
esptool.py v3.0
Serial port COM3
Connecting......................................_____
sorry for that this is the whole error
if you run the windows device manager and you unplug/plugin the ESP8266 USB cable does COM3 appear/disappear
if so it sounds like you don't have GPIO0 low and GPIO2 high to program the device
it does not disappear when i unplug from the device it just fades when i plug in it is bold..
i have tried it but still there is no progress
it is still not working ..
try a different USB cable and plugging it in a different port
