ESP-01 ESP8266 connection error: "Failed to connect to ESP8266: Timed out waiting for packet header"
Hello Guys,
I am trying to connect ESP-01 ESP8266 to Arduino UNO and all the wiring is connected correctly. When I upload the code to the WiFi module (ESP-01 ESP8266) it throws back the below mentioned error:
"A fatal esptool.py error occurred: Failed to connect to ESP8266: Timed out waiting for packet header"
Currently just for testing the connection I am trying to run the Blink example in IDE.
The goal of my project is to connect to the Wi-Fi module ESP-01 via phone and turn the servo motor accordingly.
Specs:
WiFi Module: ESP-01 ESP8266
Board Manager Version: 3.1.2
Arduino Board: Arduino Uno
that means that the communication pins are unstable, i had the same problem, i connect TX RX directly to arduino pins and for some reason it wont upload unless i reset while the ----.....----- loading shows up, TX connected to TX and RX to RX
Sounds like you encountered the same issue I was, here is the thread where it was fixed:
Good luck!
