A few Arduino Uno error messages i dont understand
Okay so i just started this Arduino Uno project a week ago and its pretty fun, im on Task 3, the Love-O-Meter and i finished writing the code, although when i verify and upload, i get 3 error messages:
Arduino: 1.7.10 (Windows 8.1), Board: "Arduino Uno"
L0M_Arduino_Task_3.ino:2:1: error: expected unqualified-id before numeric constant
L0M_Arduino_Task_3.ino:1:24: error: 'AO' was not declared in this scope
L0M_Arduino_Task_3.ino:54:1: error: expected ',' or ';' at end of input
Error compiling.
And im not sure how to get past it--
Heres my code ive written--
const int sensorPin = AO
const float baselineTemp = 20.0
Serial.begin(9600); // open a serial port
for(int pinNumber = 2; pinNumber<5; pinNumber++) {
pinMode(pinNumber, OUTPUT);
digitalWrite(pinNumber, LOW);
int sensorVal = analogRead(sensorPin);
Serial.print("Sensor Value: ");
Serial.print(sensorVal);
//convert the ADC reading to voltage
float voltage = (sensorVal;/1024.0) * 5.0;
Serial.print(", Volts: ");
Serial.print(voltage);
Serial.print(", degrees C: ");
//convert the voltage to tempeartire in degrees
float temperature = (voltaeg - .5) * 100;
Serial.println(temperature);
if(temperature < baselineTemp){
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
}else if(temperature >= baselineTemp+2) &&
temperature < baselineTemp+4){
digitalWrite(2, HIGH);
}else if(temperature >= baselineTemp+4) &&
temperature < baselineTemp+6){
digitalWrite(3, HIGH);
}else if(temperature >= baselineTemp+6){
digitalWrite(4, HIGH);
delay(1);
Any and all help is appreciated
Both missing semicolon
Spelling
Also it's A "zero", not A"Oh"
Comma after sensorVal, not semicolon.
now i get this---
L0M_Arduino_Task_3.ino: In function 'void loop()':
L0M_Arduino_Task_3.ino:19:30: error: expected primary-expression before '/' token
L0M_Arduino_Task_3.ino:33:32: error: invalid operands of types 'void*' and 'float' to binary 'operator<'
L0M_Arduino_Task_3.ino:33:33: error: expected ';' before ')' token
L0M_Arduino_Task_3.ino:39:32: error: invalid operands of types 'void*' and 'float' to binary 'operator<'
L0M_Arduino_Task_3.ino:39:33: error: expected ';' before ')' token
L0M_Arduino_Task_3.ino:33:5: error: label 'temperature' used but not defined
L0M_Arduino_Task_3.ino: At global scope:
L0M_Arduino_Task_3.ino:54:1: error: expected declaration before '}' token
Error compiling.
Can't see your code.
Use code tags this time, please.
what are code tags?
const int sensorPin = A0;
const float baselineTemp = 20.0;
// convert the ADC reading to voltage
float voltage = (sensorVal,/1024.0) * 5.0;
// convert the voltage to tempeartire in degrees
float temperature = (voltage - .5) * 100;
delay(1);
Oops sorry, not comma after sensorVal.
Code tags are explained in the readme at the top of the forum.
I don't have the source book you have - is there something wrong with it?
what is a source book
should be
 else if (temperature >= baselineTemp + 2 && temperature < baselineTemp + 4) {
The thing that you got your code from.
I figured it was a physical book, because if it was electronic, you would just cut and paste, and you wouldn't have all these transcription errors.
um yes i am using the book that came with the kit, "Arduino Uno Projects Book"
Oh, this is from the Arduino Starter Kit!
ArdUnoLerner:
Ah yes, the Starter Kit. I have that as well. Double check the code. I know for a fact what you have isn't what the book says.
okay guys here are the error messages i have now--
Error compiling.
code---
}else if(temperature >= baselineTemp+2 &&
}else if(temperature >= baselineTemp+4 &&
delay(1);
Lose the comma. See reply #7
Use code tags. Use the five minutes before you can post again to read about them.
now--
Error compiling.
Again.
sorry my bad
delay(1);
What happened to the code tags?float voltage = (sensorVal,/1024.0) * 5.0
Lose the comma (again) and stick a semicolon on the end.
Is the print in the book unclear or really small?
