"Hi i need your help with my code I don't know what i did wrong, but for some reason i am getting an error message saying a function-definition is not allowed here before '{' token this code is suppose to run rc car through pc using arduino mega 2560, please can you help me anyone, i have tried everything. ![]()
int forward = 30; // Pin 12 - Forward
int reverse = 40; // Pin 11 - Reverse
int left = 51; // Pin 10 - Left
int right = 39; // Pin 9 - Right
char val; // Variable to receive data from the serial port
// initialize the digital pins as output
pinMode(forward, OUTPUT);
pinMode(reverse, OUTPUT);
pinMode(left, OUTPUT);
pinMode(right, OUTPUT); Serial.begin(9600); // Start serial communication at 9600bps
// Fordward action
void go_forward() {
digitalWrite(forward, HIGH);
digitalWrite(reverse, LOW);
// Reverse action
void go_reverse() {
digitalWrite(reverse, HIGH);
digitalWrite(forward, LOW);
// Left action
void go_left() {
digitalWrite(left, HIGH);
digitalWrite(right, LOW);
// Right action
void go_right() {
digitalWrite(right, HIGH);
digitalWrite(left, LOW);
// Stop turn action
void stop_turn() {
// Stop car
void stop_car() {
// Read serial port and perform command
void performCommand() {
if (Serial.available()) { val = Serial.read();
} if (val == 'w') { // Forward go_forward(); } else if (val == 's') { // Backward go_reverse(); } else if (val == 'd') { // Right go_right(); } else if (val == 'a') { // Left go_left(); } else if (val == 'l') { // Stop Turn stop_turn(); } else if (val == 'k') { // Stop stop_car(); }
performCommand();
Arduino Software Error messages:
sketch_sep05a.ino: In function 'void performCommand () ' :
sketch_sep05a: 64: error: a function-definition is not allowed
here before ' { ' token
sketch_sep05a:66: error: expected ' } ' at end of input
a function-definition is not allowed here before ' { ' token
