Hi! I´m trying to do an arduino SmartLock, with a Servo and a Bluetooth Model (hc-05), but keep getting error. How can i fix it?
Thank you
#include <SoftwareSerial.h>
#include <Servo.h>
#include <EEPROM.h>
Servo servoMotor; // Declaramos la variable para controlar el servo
SoftwareSerial BT1(10, 11); // RX | TX
Servo servo;
char state;
{ pinMode(8, OUTPUT); // Al poner en HIGH forzaremos el modo AT
pinMode(9, OUTPUT); // cuando se alimente de aqui
digitalWrite(9, HIGH);
delay (500) ; // Espera antes de encender el modulo
Serial.begin(9600); // Iniciamos el monitor serie para mostrar el resultado
Serial.println("Levantando el modulo HC-06");
digitalWrite (8, HIGH); //Enciende el modulo
Serial.println("Esperando comandos AT:");
BT1.begin(9600);
servoMotor.attach(7); // Iniciamos el servo para que empiece a trabajar con el pin 7
// codigo del chino
if (EEPROM.read(0) == 1) // Reads the EEPROM value stored to know what state the door lock was in before it was last turned off
{ // An EEPROM value of 1 means UNLOCKED and a value of 2 means LOCKED
servo.write(70); // Rotates the servo to the unlocked position
delay(200);
else if (EEPROM.read(0) == 2)
servo.write(120); // Rotates the servo to the locked position
delay(200);
// arriba termina el codigo de tostada francesa sexy
void loop(){
if (Serial.available() > 0)
char data;
data = Serial.read(); // The variable data is used to store the value sent by the Android app
switch (data)
case '1':
if (EEPROM.read(0) == 1) //An EEPROM value of 1 means it is currently unlocked
EEPROM.write(0, 2); // Writes the number 2 to address 0 on the Arduino's EEPROM. This value will be used by the Arduino to remember the last state the door lock was in
Serial.print("3"); // Sends the number 3 to the Android app. To see what this does, please see the Android Studio Project file
for (int a = 70; a <= 120; a++) // Rotates the servo to the locked position
servo.write(a);
delay(15);
Serial.println(servo.read());
else if (EEPROM.read(0) == 2) //An EEPROM value of 2 means it i currently locked
EEPROM.write(0, 1); // Writes the number 1 to address 0 on the Arduino's EEPROM. This value will be used by the Arduino to remember the last state the door lock was in
Serial.print("4"); // Sends the number 4 to the Android app. The number sent will be used by the app to update the locked/unlocked icon
for (int x = 120; x >= 70; x--) // Rotates the servo to the unlocked position
servo.write(x);
delay(15);
case '3':
// This part of the switch case statement is used everytime the Arduino is turned on
// Basically, the Android app sends a command asking the Arduino to send the current state of the lock in order to accordingly update the locked/unlocked icon in the app
Serial.print("4");
Serial.print("3");
