A previous astronomy project (5 Yrs ago) called Spotnik
Hi all, I have been having a nightmare with uploading the following sketch to an Uno R3 and also tried Arduino Mega; this a link to this massive sketch......SpotNik/spotnik.ino at main · surfer-max/SpotNik · GitHub
I've asked the original program writer for help but he was no longer involved with these projects. What would be great is if someone out there with the arduino know-how could try uploading the sketch themselves and see if they can? I'd be very pleased to fix this issue and unfortunately I cannot fix myself as I'm totally entry level arduino guy....with NO programming knowledge or ability. I am hopeful!!!
Welcome to the forum
What problems do you have when trying to upload the sketch ?
Please post your full sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
It is also helpful to post full error messages in code tags as it makes it easier to scroll through them and copy them for examination
To post the error message, click the "COPY ERROR MESSAGES" button in the IDE, paste the copied messages in a reply here, select all of it and click the < CODE > icon above the reply editor to add the code tags and then save the reply
Welcome!
That could be many things, I have a blue, what do I have? we need more information, such as the code and the problems you are having. If it is errors from the upload capture them and upload using code tags.
At this point I can only guess and say check your cable and be sure it is ok, try uploading one of the example sketches. Is your power source stable?
The code compiles and uploads without problems.
You have installed the LiquidCrystal library, right?
Interesting piece of code.
It is unclear what the problems are you are encountering?
Can you elaborate?
Hi Maximo, yes , I checked the list of things in the library and LCD is definitely there.
What exactly is the problem you are having?
Note that if you have a bluetooth module connected to the Rx and Tx pins of the arduino, you will need to disconnect the bluetooth module while uploading a sketch.
[code]
SpotNik - by Max Reinecke
Created: May 2021
SpotNik is software for a stepto system for telescopes
 This program is free software: you can redistribute it and/or modify
 it under the terms of the GNU General Public License as published by
 the Free Software Foundation, either version 3 of the License, or
 (at your option) any later version.
 This program is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 GNU General Public License for more details.
 You should have received a copy of the GNU General Public License
 along with this program.  If not, see <http://www.gnu.org/licenses/>.
#define VERSION 2.0
// to be changed by user according to EQ mount - see instructions
// total numbers of impulse of the rotary encoder of RA axis when turned 24h
#define IMPULSE24HRA 2772 // 6h - 690 Impulse --> 24h - 4 * 693 = 2772 / ~ 1:138
// total numbers of impulse of the rotary encoder of DEC axis when turned 360° // +/- for correct direction
#define IMPULSE360DEGDEC 1784 // 90° - 446 Impulse --> 360° - 4 * 446 = 1784 / ~ 1:88
#include <LiquidCrystal.h> // I2C LCD arbeitet nicht vernünftig mit Rotary Encoder zusammen,daher normales nehmen
#include <EEPROM.h>
//#include <MemoryFree.h> // only used for testing
// LCD
#define LCD_CONTRAST_PIN 11 // LCD contrast - V0 // use high frequency PWM to avoid flickering (Leonardo,Micro,Yún 3 and 11: 980 Hz // Mega pins 4 and 13: 980 Hz)
#define LCD_BACKLIGHT_PIN 10 // LCD backlight - LCD A
// EEPROM
#define EEPROM_SIGNATURE 117 // value 0-255 (byte) - signature/mark to recognize if the value fits to this sketch
#define EEPROM_VALUE_ADDR_SIGNATURE 0
// rotary enoder HMI
#define ROTARY_SW 3 // use interrupt pin - digital pins for interrupts on Micro,Leonardo and other 32u4 based 0,1,2,3,7
#define ROTARY_DT 4
#define ROTARY_CLK 5
// Sensor RA
#define SENS_RA_DT A0 // analog pins used as UNO has not that many digital pins
#define SENS_RA_CLK A1
// Sensor DEC
#define SENS_DEC_DT A2
#define SENS_DEC_CLK A3
// LX200 connection
#define BT_SWITCH 2
// lookup table with names of deep sky objects
struct DSONameStruct
char objectName[9];
const struct DSONameStruct DSO_NAME_PROGMEM[202] PROGMEM =
{"3C273"},
{"B"},
{"IC"},
{"M"},
{"NGC"},
{"#a"},
{"#aA"},
{"#aB"},
{"#b"},
{"#c"},
{"#d"},
{"#e"},
{"#e1"},
{"#e2"},
{"#g"},
{"#h"},
{"#i"},
{"#j"},
{"#k"},
{"#l"},
{"#m"},
{"#n"},
{"#o"},
{"#p"},
{"#q"},
{"#r"},
{"#s"},
{"#t"},
{"#u"},
{"#w"},
{"#x"},
{"#z"},
{"AC"},
{"Achernar"},
{"Acrab"},
{"Acrux"},
{"Adhara"},
{"Agena"},
{"Alamak"},
{"Aldebara"},
{"Alderami"},
{"AlDhanab"},
{"Algenib"},
{"Algieba"},
{"Algol"},
{"Alhena"},
{"Alioth"},
{"Alkaid"},
{"AlNair"},
{"Alnilam"},
{"Alnitak"},
{"Alphard"},
{"Alphecca"},
{"Alpherat"},
{"Alsuhail"},
{"Altair"},
{"Aludra"},
{"Ankaa"},
{"Antares"},
{"AQ"},
{"Arcturus"},
{"Arneb"},
{"Aspidisk"},
{"Atria"},
{"Avior"},
{"AW"},
{"AX"},
{"BD"},
{"Becrux"},
{"Bellatri"},
{"Betelgeu"},
{"BF"},
{"BG"},
{"BL"},
{"BM"},
{"BX"},
{"Canopus"},
{"Capella"},
{"Caph"},
{"Castor"},
{"Cih"},
{"CY"},
{"Deneb"},
{"DenebKai"},
{"Denebola"},
{"Diphda"},
{"DR"},
{"Dschubba"},
{"Dubhe"},
{"EL"},
{"ElNath"},
{"Eltanin"},
{"Enif"},
{"FO"},
{"Fomalhau"},
{"FU"},
{"Gacrux"},
{"Gemma"},
{"Gienah"},
{"Girtab"},
{"GK"},
{"GY"},
{"H"},
{"Hadar"},
{"Hamal"},
{"Han"},
{"HD"},
{"HJ"},
{"HK"},
{"HN"},
{"Izar"},
{"JC"},
{"KausAust"},
{"Kochab"},
{"KooShe"},
{"Markab"},
{"Menkalin"},
{"Menkar"},
{"Menkent"},
{"Merak"},
{"Miaplaci"},
{"Mimosa"},
{"Mintaka"},
{"Mirach"},
{"Mirfak"},
{"Mirzam"},
{"Mizar"},
{"Naos"},
{"NQ"},
{"NSV"},
{"Nunki"},
{"O#F"},
{"Peacock"},
{"Phecda"},
{"Polaris"},
{"Pollux"},
{"Procyon"},
{"PZ6"},
{"R"},
{"RasAlhag"},
{"Regulus"},
{"Rigel"},
{"RigilKen"},
{"RR"},
{"RS"},
{"RT"},
{"RU"},
{"RV"},
{"RX"},
{"RY"},
{"RZ"},
{"S"},
{"S605"},
{"Sabik"},
{"Sadr"},
{"Saiph"},
{"SAO"},
{"Sargas"},
{"Scheat"},
{"Schedar"},
{"Shaula"},
{"SHJ"},
{"Sirius"},
{"Spica"},
{"SS"},
{"ST"},
{"SU"},
{"SV"},
{"SY"},
{"SZ"},
{"T"},
{"TT"},
{"TU"},
{"Tureis"},
{"TW"},
{"TX"},
{"U"},
{"UU"},
{"UV"},
{"UX"},
{"UY"},
{"V"},
{"Vega"},
{"VW"},
{"VX"},
{"VY"},
{"W"},
{"Wei"},
{"Wezen"},
{"WO"},
{"WW"},
{"WX"},
{"WZ"},
{"X"},
{"XS"},
{"XX"},
{"Y"},
{"Z"},
{"Zozma"},
{"β648"},
{"#F"},
{"extern"}
// data of deep sky objects
struct DSOstruct
byte objectPreFixNameNo; // number of name for lookup table
unsigned int objectNumber; // if name contains a number
byte objectTypeMagnitude; // object type & magnitude coded in one byte
byte objectConst; // constellation of object
unsigned int objectRA; //HHMM(SS/6)
int objectDEC; //sHHMM
DSOstruct myTarget; // object to store data of selected target
DSOstruct myReference; // object to store data of selected target
const unsigned int DSO_PROGMEM_size = 1204;
const struct DSOstruct DSO_PROGMEM[DSO_PROGMEM_size] PROGMEM =
{1, 0, 27, 86, 12291, 203},
{2, 33, 42, 60, 5409, -228},
{2, 65, 42, 77, 18027, -2750},
{2, 86, 42, 59, 17196, -2642},
{3, 342, 54, 11, 3468, 6806},
{3, 405, 66, 8, 5165, 3421},
{3, 410, 64, 8, 5227, 3325},
{3, 434, 67, 60, 5410, -227},
{3, 1396, 74, 16, 21391, 5730},
{3, 4406, 95, 50, 14224, -4409},
{3, 5067, 64, 31, 20508, 4421},
{3, 5146, 80, 31, 21534, 4716},
{4, 1, 106, 78, 5345, 2201},
{4, 2, 119, 5, 21335, -49},
{4, 3, 118, 30, 13422, 2823},
{4, 4, 117, 72, 16236, -2632},
{4, 5, 118, 74, 15186, 205},
{4, 6, 130, 72, 17403, -3215},
{4, 7, 129, 72, 17539, -3448},
{4, 8, 75, 77, 18037, -2423},
{4, 9, 120, 59, 17192, -1831},
{4, 10, 119, 59, 16571, -406},
{4, 11, 132, 73, 18511, -616},
{4, 12, 118, 59, 16472, -157},
{4, 13, 118, 40, 16417, 3628},
{4, 14, 120, 59, 17376, -315},
{4, 15, 118, 62, 21300, 1210},
{4, 16, 76, 74, 18188, -1347},
{4, 17, 76, 77, 18208, -1611},
{4, 18, 133, 77, 18199, -1708},
{4, 19, 119, 59, 17026, -2616},
{4, 20, 76, 77, 18027, -2258},
{4, 21, 132, 77, 18042, -2229},
{4, 22, 117, 77, 18364, -2354},
{4, 23, 132, 77, 17571, -1859},
{4, 24, 129, 77, 18266, -1823},
{4, 25, 131, 77, 18318, -1907},
{4, 26, 134, 73, 18452, -924},
{4, 27, 91, 88, 19596, 2243},
{4, 28, 119, 77, 18245, -2452},
{4, 29, 133, 31, 20239, 3832},
{4, 30, 119, 12, 21404, -2311},
{4, 31, 45, 1, 427, 4116},
{4, 32, 50, 1, 427, 4052},
{4, 33, 48, 81, 1339, 3039},
{4, 34, 131, 63, 2421, 4247},
{4, 35, 131, 38, 6089, 2421},
{4, 36, 132, 8, 5363, 3408},
{4, 37, 132, 8, 5523, 3233},
{4, 38, 132, 8, 5287, 3551},
{4, 39, 131, 31, 21322, 4826},
{4, 40, 149, 83, 12219, 5806},
{4, 41, 131, 20, 6460, -2045},
{4, 42, 74, 60, 5353, -523},
{4, 43, 63, 60, 5355, -516},
{4, 44, 129, 22, 8400, 1940},
{4, 45, 71, 78, 3470, 2407},
{4, 46, 132, 68, 7418, -1449},
{4, 47, 130, 68, 7366, -1429},
{4, 48, 132, 42, 8137, -545},
{4, 49, 50, 86, 12298, 800},
{4, 50, 132, 55, 7025, -823},
{4, 51, 50, 30, 13299, 4712},
{4, 52, 133, 14, 23242, 6135},
{4, 53, 120, 24, 13129, 1810},
{4, 54, 120, 77, 18551, -3029},
{4, 55, 118, 77, 19400, -3058},
{4, 56, 120, 52, 19166, 3011},
{4, 57, 93, 52, 18536, 3302},
{4, 58, 52, 86, 12377, 1149},
{4, 59, 52, 86, 12420, 1139},
{4, 60, 51, 86, 12437, 1133},
{4, 61, 52, 86, 12219, 428},
{4, 62, 118, 59, 17012, -3007},
{4, 63, 51, 30, 13158, 4202},
{4, 64, 51, 24, 12567, 2141},
{4, 65, 51, 46, 11189, 1305},
{4, 66, 51, 46, 11202, 1300},
{4, 67, 133, 22, 8508, 1149},
{4, 68, 119, 42, 12395, -2645},
{4, 69, 120, 77, 18314, -3221},
{4, 70, 120, 77, 18432, -3218},
{4, 71, 120, 76, 19538, 1847},
{4, 72, 121, 5, 20535, -1232},
{4, 73, 136, 5, 20590, -1238},
{4, 74, 51, 67, 1367, 1547},
{4, 75, 121, 77, 20061, -2155},
{4, 76, 94, 63, 1423, 5135},
{4, 77, 51, 17, 2427, -1},
{4, 78, 64, 60, 5468, 5},
{4, 79, 120, 47, 5242, -2431},
{4, 80, 119, 72, 16170, -2259},
{4, 81, 49, 83, 9556, 6904},
{4, 82, 50, 83, 9559, 6941},
{4, 83, 50, 42, 13370, -2952},
{4, 84, 51, 86, 12251, 1253},
{4, 85, 51, 24, 12254, 1811},
{4, 86, 51, 86, 12262, 1257},
{4, 87, 51, 86, 12308, 1223},
{4, 88, 52, 24, 12320, 1425},
{4, 89, 52, 86, 12357, 1233},
{4, 90, 52, 86, 12368, 1310},
{4, 91, 52, 24, 12354, 1430},
{4, 92, 119, 40, 17171, 4308},
{4, 93, 132, 68, 7445, -2351},
{4, 94, 50, 30, 12509, 4107},
{4, 95, 52, 46, 10440, 1142},
{4, 96, 51, 46, 10468, 1149},
{4, 97, 95, 83, 11148, 5501},
{4, 98, 52, 24, 12138, 1454},
{4, 99, 52, 24, 12188, 1425},
{4, 100, 51, 24, 12229, 1549},
{4, 101, 50, 83, 14032, 5421},
{4, 102, 52, 34, 15065, 5546},
{4, 103, 133, 14, 1334, 6039},
{4, 104, 50, 86, 12400, -1137},
{4, 105, 51, 46, 10478, 1235},
{4, 106, 50, 30, 12190, 4718},
{4, 107, 120, 59, 16325, -1303},
{4, 108, 52, 83, 11115, 5540},
{4, 109, 52, 83, 11576, 5322},
{4, 110, 50, 1, 404, 4141},
{5, 40, 94, 16, 130, 7231},
{5, 55, 50, 71, 149, -3911},
{5, 129, 133, 14, 300, 6013},
{5, 136, 137, 14, 315, 6131},
{5, 147, 52, 14, 332, 4830},
{5, 157, 52, 17, 348, -824},
{5, 185, 51, 14, 390, 4820},
{5, 188, 134, 16, 475, 8514},
{5, 210, 52, 17, 406, -1352},
{5, 225, 133, 14, 436, 6146},
{5, 246, 94, 17, 471, -1152},
{5, 247, 51, 17, 471, -2046},
{5, 253, 49, 71, 476, -2518},
{5, 278, 52, 14, 521, 4733},
{5, 281, 77, 14, 530, 5637},
{5, 288, 120, 71, 528, -2635},
{5, 300, 50, 71, 549, -3741},
{5, 381, 135, 14, 1084, 6135},
{5, 404, 52, 1, 1094, 3543},
{5, 436, 135, 14, 1160, 5849},
{5, 457, 132, 14, 1195, 5817},
{5, 488, 52, 67, 1218, 515},
{5, 524, 52, 67, 1248, 932},
{5, 559, 136, 14, 1295, 6319},
{5, 584, 52, 17, 1313, -652},
{5, 596, 52, 17, 1329, -702},
{5, 613, 52, 71, 1343, -2925},
{5, 615, 53, 17, 1351, -720},
{5, 637, 134, 14, 1431, 6402},
{5, 654, 133, 14, 1440, 6153},
{5, 659, 134, 14, 1444, 6040},
{5, 663, 133, 14, 1460, 6115},
{5, 672, 52, 81, 1479, 2726},
{5, 720, 52, 17, 1530, -1344},
{5, 752, 132, 1, 1577, 3740},
{5, 772, 52, 7, 1593, 1900},
{5, 779, 53, 17, 1597, -558},
{5, 869, 131, 63, 2191, 5708},
{5, 884, 132, 63, 2225, 5709},
{5, 891, 52, 1, 2226, 4221},
{5, 908, 52, 17, 2231, -2114},
{5, 925, 52, 81, 2273, 3335},
{5, 936, 52, 17, 2276, -109},
{5, 986, 52, 37, 2336, -3903},
{5, 1022, 53, 17, 2385, -641},
{5, 1023, 51, 63, 2404, 3904},
{5, 1027, 133, 14, 2426, 6136},
{5, 1052, 52, 17, 2411, -815},
{5, 1055, 52, 17, 2418, 27},
{5, 1084, 52, 36, 2460, -735},
{5, 1097, 52, 37, 2463, -3017},
{5, 1232, 52, 36, 3098, -2035},
{5, 1245, 134, 63, 3147, 4714},
{5, 1261, 120, 41, 3123, -5513},
{5, 1275, 53, 63, 3198, 4131},
{5, 1291, 51, 36, 3173, -4106},
{5, 1300, 52, 36, 3197, -1925},
{5, 1316, 51, 37, 3227, -3713},
{5, 1325, 53, 36, 3244, -2133},
{5, 1332, 52, 36, 3263, -2120},
{5, 1342, 133, 63, 3317, 3722},
{5, 1360, 93, 37, 3332, -2552},
{5, 1365, 52, 37, 3336, -3608},
{5, 1374, 53, 37, 3353, -3514},
{5, 1380, 54, 37, 3368, -3444},
{5, 1398, 52, 37, 3389, -2620},
{5, 1399, 52, 37, 3385, -3527},
{5, 1407, 52, 36, 3402, -1835},
{5, 1433, 52, 41, 3420, -4713},
{5, 1444, 133, 63, 3494, 5240},
{5, 1491, 70, 63, 4032, 5119},
{5, 1499, 61, 63, 4032, 3622},
{5, 1501, 96, 11, 4070, 6055},
{5, 1502, 133, 11, 4078, 6220},
{5, 1513, 134, 63, 4099, 4931},
{5, 1514, 94, 78, 4093, 3047},
{5, 1528, 132, 63, 4153, 5113},
{5, 1532, 52, 36, 4121, -3252},
{5, 1535, 93, 36, 4143, -1244},
{5, 1545, 132, 63, 4209, 5015},
{5, 1549, 52, 33, 4158, -5536},
{5, 1566, 52, 33, 4200, -5456},
{5, 1647, 132, 78, 4459, 1906},
{5, 1664, 134, 8, 4511, 4341},
{5, 1672, 52, 33, 4457, -5915},
{5, 1788, 70, 60, 5069, -320},
{5, 1792, 52, 23, 5052, -3759},
{5, 1808, 52, 23, 5077, -3731},
{5, 1817, 134, 78, 5124, 1641},
{5, 1851, 119, 23, 5141, -4003},
{5, 1857, 133, 8, 5201, 3921},
{5, 1907, 134, 8, 5281, 3520},
{5, 1909, 70, 36, 5045, -716},
{5, 1931, 80, 8, 5314, 3415},
{5, 1961, 53, 11, 5421, 6923},
{5, 1964, 52, 47, 5334, -2157},
{5, 1973, 63, 60, 5351, -444},
{5, 1980, 73, 60, 5354, -555},
{5, 1999, 70, 60, 5364, -643},
{5, 2022, 95, 60, 5421, 905},
{5, 2024, 70, 60, 5417, -151},
{5, 2126, 136, 8, 6025, 4952},
{5, 2129, 133, 38, 6007, 2319},
{5, 2158, 135, 38, 6074, 2406},
{5, 2169, 132, 60, 6084, 1358},
{5, 2175, 77, 60, 6096, 2029},
{5, 2185, 70, 55, 6110, -614},
{5, 2186, 135, 60, 6121, 528},
{5, 2194, 135, 60, 6138, 1248},
{5, 2204, 135, 20, 6155, -1840},
{5, 2207, 52, 20, 6164, -2122},
{5, 2215, 134, 55, 6208, -717},
{5, 2232, 130, 55, 6280, -451},
{5, 2237, 76, 55, 6309, 503},
{5, 2238, 62, 55, 6307, 501},
{5, 2239, 131, 55, 6319, 457},
{5, 2245, 70, 55, 6327, 1009},
{5, 2251, 133, 55, 6346, 822},
{5, 2261, 70, 55, 6392, 845},
{5, 2264, 74, 55, 6410, 954},
{5, 2266, 136, 38, 6433, 2658},
{5, 2281, 131, 8, 6483, 4105},
{5, 2286, 134, 55, 6477, -309},
{5, 2300, 53, 16, 7323, 8543},
{5, 2301, 132, 55, 6518, 28},
{5, 2304, 136, 38, 6552, 1759},
{5, 2311, 136, 55, 6578, -437},
{5, 2324, 134, 55, 7041, 103},
{5, 2335, 133, 55, 7068, -1002},
{5, 2343, 133, 55, 7081, -1037},
{5, 2346, 96, 55, 7094, -48},
{5, 2353, 133, 55, 7145, -1016},
{5, 2354, 133, 20, 7143, -2542},
{5, 2355, 136, 38, 7170, 1345},
{5, 2359, 70, 20, 7185, -1314},
{5, 2360, 133, 20, 7177, -1538},
{5, 2362, 130, 20, 7187, -2457},
{5, 2371, 95, 38, 7256, 2929},
{5, 2372, 95, 38, 7256, 2930},
{5, 2383, 134, 20, 7247, -2057},
{5, 2384, 133, 20, 7252, -2101},
{5, 2392, 93, 38, 7292, 2055},
{5, 2395, 134, 38, 7272, 1337},
{5, 2403, 51, 11, 7368, 6536},
{5, 2419, 122, 51, 7381, 3853},
{5, 2420, 134, 38, 7384, 2134},
{5, 2421, 134, 68, 7362, -2037},
{5, 2423, 133, 68, 7371, -1352},
{5, 2438, 95, 68, 7418, -1444},
{5, 2439, 133, 68, 7408, -3142},
{5, 2440, 95, 68, 7419, -1813},
{5, 2467, 77, 68, 7525, -2626},
{5, 2477, 132, 68, 7522, -3832},
{5, 2479, 136, 68, 7551, -1742},
{5, 2482, 133, 68, 7552, -2415},
{5, 2489, 134, 68, 7563, -3004},
{5, 2506, 134, 55, 8000, -1046},
{5, 2509, 135, 68, 8008, -1903},
{5, 2527, 133, 68, 8050, -2809},
{5, 2539, 133, 68, 8106, -1249},
{5, 2547, 131, 85, 8102, -4912},
{5, 2567, 133, 68, 8185, -3039},
{5, 2571, 133, 68, 8189, -2945},
{5, 2613, 52, 69, 8334, -2258},
{5, 2627, 134, 69, 8372, -2957},
{5, 2655, 52, 11, 8556, 7813},
{5, 2681, 52, 83, 8535, 5119},
{5, 2683, 52, 51, 8527, 3325},
{5, 2742, 53, 83, 9076, 6029},
{5, 2768, 52, 83, 9116, 6002},
{5, 2775, 52, 22, 9103, 702},
{5, 2782, 53, 51, 9141, 4007},
{5, 2784, 52, 42, 9123, -2410},
{5, 2787, 52, 83, 9193, 6912},
{5, 2811, 53, 42, 9162, -1619},
{5, 2835, 52, 42, 9179, -2221},
{5, 2841, 51, 83, 9220, 5059},
{5, 2859, 52, 49, 9243, 3431},
{5, 2867, 94, 13, 9214, -5819},
{5, 2903, 51, 46, 9322, 2130},
{5, 2950, 52, 83, 9426, 5851},
{5, 2964, 53, 46, 9429, 3151},
{5, 2974, 52, 75, 9426, -342},
{5, 2976, 52, 83, 9472, 6755},
{5, 2985, 52, 83, 9504, 7217},
{5, 2997, 51, 2, 9456, -3111},
{5, 3077, 52, 83, 10033, 6844},
{5, 3079, 52, 83, 10020, 5541},
{5, 3109, 52, 42, 10031, -2610},
{5, 3115, 51, 75, 10052, -743},
{5, 3132, 92, 85, 10070, -4026},
{5, 3147, 52, 34, 10169, 7324},
{5, 3166, 52, 75, 10138, 326},
{5, 3169, 52, 75, 10142, 328},
{5, 3184, 52, 83, 10183, 4125},
{5, 3190, 53, 46, 10181, 2150},
{5, 3193, 52, 46, 10184, 2154},
{5, 3198, 52, 83, 10199, 4533},
{5, 3201, 119, 85, 10176, -4625},
{5, 3226, 53, 46, 10234, 1954},
{5, 3227, 52, 46, 10235, 1952},
{5, 3242, 93, 42, 10248, -1839},
{5, 3245, 52, 49, 10273, 2830},
{5, 3277, 53, 49, 10329, 2831},
{5, 3294, 53, 49, 10363, 3719},
{5, 3310, 52, 83, 10388, 5330},
{5, 3344, 52, 49, 10435, 2455},
{5, 3359, 52, 83, 10466, 6313},
{5, 3372, 59, 13, 10451, -5952},
{5, 3377, 52, 46, 10477, 1359},
{5, 3384, 52, 46, 10483, 1238},
{5, 3395, 54, 49, 10498, 3259},
{5, 3412, 52, 46, 10509, 1325},
{5, 3414, 53, 49, 10513, 2758},
{5, 3432, 53, 49, 10525, 3637},
{5, 3486, 52, 49, 11004, 2859},
{5, 3489, 52, 46, 11003, 1354},
{5, 3504, 53, 49, 11032, 2758},
{5, 3521, 51, 46, 11058, -2},
{5, 3532, 129, 13, 11052, -5844},
{5, 3593, 52, 46, 11146, 1249},
{5, 3607, 52, 46, 11169, 1803},
{5, 3608, 52, 46, 11170, 1809},
{5, 3610, 52, 83, 11184, 5847},
{5, 3613, 52, 83, 11186, 5800},
{5, 3619, 53, 83, 11194, 5745},
{5, 3621, 52, 42, 11183, -3249},
{5, 3626, 53, 46, 11201, 1821},
{5, 3628, 52, 46, 11203, 1335},
{5, 3631, 52, 83, 11210, 5310},
{5, 3640, 52, 46, 11211, 314},
{5, 3655, 53, 46, 11229, 1635},
{5, 3665, 52, 83, 11247, 3846},
{5, 3675, 52, 83, 11261, 4335},
{5, 3686, 53, 46, 11277, 1713},
{5, 3717, 53, 42, 11315, -3019},
{5, 3718, 52, 83, 11326, 5304},
{5, 3726, 52, 83, 11333, 4702},
{5, 3729, 53, 83, 11338, 5308},
{5, 3810, 52, 46, 11410, 1128},
{5, 3813, 53, 83, 11413, 3633},
{5, 3877, 53, 83, 11461, 4730},
{5, 3893, 52, 83, 11486, 4843},
{5, 3898, 52, 83, 11493, 5605},
{5, 3900, 53, 46, 11492, 2701},
{5, 3912, 54, 46, 11501, 2629},
{5, 3918, 92, 15, 11503, -5711},
{5, 3923, 52, 42, 11510, -2848},
{5, 3938, 52, 83, 11528, 4407},
{5, 3941, 52, 83, 11529, 3659},
{5, 3945, 52, 83, 11532, 6040},
{5, 3949, 53, 83, 11537, 4752},
{5, 3953, 52, 83, 11538, 5219},
{5, 3962, 52, 27, 11547, -1359},
{5, 3982, 53, 83, 11565, 5507},
{5, 3998, 52, 83, 11579, 5527},
{5, 4013, 53, 83, 11585, 4357},
{5, 4026, 52, 83, 11594, 5058},
{5, 4027, 53, 29, 11595, -1916},
{5, 4030, 52, 86, 12004, -106},
{5, 4036, 52, 83, 12015, 6154},
{5, 4038, 52, 29, 12019, -1852},
{5, 4039, 52, 29, 12019, -1853},
{5, 4041, 53, 83, 12022, 6208},
{5, 4051, 52, 83, 12032, 4432},
{5, 4085, 54, 83, 12054, 5021},
{5, 4088, 52, 83, 12056, 5032},
{5, 4096, 52, 83, 12060, 4729},
{5, 4102, 53, 83, 12064, 5243},
{5, 4105, 52, 42, 12067, -2946},
{5, 4111, 52, 30, 12070, 4304},
{5, 4125, 52, 34, 12081, 6510},
{5, 4143, 52, 30, 12096, 4232},
{5, 4147, 122, 24, 12101, 1833},
{5, 4150, 53, 24, 12106, 3024},
{5, 4151, 52, 30, 12105, 3924},
{5, 4179, 53, 86, 12129, 118},
{5, 4203, 52, 24, 12151, 3312},
{5, 4214, 52, 30, 12156, 3620},
{5, 4216, 52, 86, 12159, 1309},
{5, 4236, 52, 34, 12167, 6928},
{5, 4244, 52, 30, 12175, 3748},
{5, 4245, 53, 24, 12176, 2936},
{5, 4251, 52, 24, 12181, 2810},
{5, 4261, 52, 86, 12194, 549},
{5, 4273, 53, 86, 12199, 521},
{5, 4274, 52, 24, 12198, 2937},
{5, 4278, 52, 24, 12201, 2917},
{5, 4281, 53, 86, 12204, 523},
{5, 4293, 52, 24, 12212, 1823},
{5, 4314, 52, 24, 12225, 2954},
{5, 4346, 53, 30, 12235, 4700},
{5, 4350, 53, 24, 12240, 1642},
{5, 4361, 94, 29, 12245, -1847},
{5, 4365, 52, 86, 12245, 719},
{5, 4371, 52, 86, 12249, 1142},
{5, 4388, 53, 86, 12258, 1240},
{5, 4394, 52, 24, 12259, 1813},
{5, 4395, 52, 30, 12258, 3333},
{5, 4414, 52, 24, 12265, 3113},
{5, 4419, 53, 24, 12269, 1503},
{5, 4429, 52, 86, 12274, 1106},
{5, 4435, 52, 86, 12277, 1305},
{5, 4438, 52, 86, 12278, 1300},
{5, 4442, 52, 86, 12281, 948},
{5, 4448, 53, 24, 12283, 2837},
{5, 4449, 52, 30, 12282, 4406},
{5, 4450, 52, 24, 12285, 1705},
{5, 4459, 52, 24, 12290, 1359},
{5, 4473, 52, 24, 12298, 1326},
{5, 4477, 52, 24, 12300, 1338},
{5, 4478, 53, 86, 12303, 1220},
{5, 4485, 53, 30, 12305, 4142},
{5, 4490, 52, 30, 12306, 4139},
{5, 4494, 52, 24, 12314, 2546},
{5, 4517, 52, 86, 12328, 7},
{5, 4526, 52, 86, 12340, 742},
{5, 4527, 52, 86, 12341, 239},
{5, 4535, 52, 86, 12343, 812},
{5, 4536, 52, 86, 12344, 211},
{5, 4546, 52, 86, 12355, -348},
{5, 4550, 53, 86, 12355, 1213},
{5, 4559, 52, 24, 12360, 2758},
{5, 4565, 52, 24, 12363, 2559},
{5, 4567, 53, 86, 12365, 1115},
{5, 4568, 52, 86, 12366, 1114},
{5, 4570, 52, 86, 12369, 715},
{5, 4596, 52, 86, 12399, 1011},
{5, 4605, 52, 83, 12400, 6136},
{5, 4618, 52, 30, 12416, 4109},
{5, 4631, 51, 30, 12421, 3232},
{5, 4636, 52, 86, 12428, 241},
{5, 4643, 52, 86, 12433, 159},
{5, 4654, 52, 86, 12439, 1308},
{5, 4656, 52, 30, 12440, 3210},
{5, 4660, 53, 86, 12445, 1111},
{5, 4665, 52, 86, 12451, 303},
{5, 4666, 52, 86, 12451, -28},
{5, 4689, 52, 24, 12478, 1346},
{5, 4697, 51, 86, 12486, -548},
{5, 4698, 52, 86, 12484, 829},
{5, 4699, 52, 86, 12490, -840},
{5, 4725, 51, 24, 12504, 2530},
{5, 4753, 52, 86, 12524, -112},
{5, 4754, 52, 86, 12523, 1119},
{5, 4762, 52, 86, 12529, 1114},
{5, 4781, 53, 86, 12544, -1032},
{5, 4800, 53, 30, 12546, 4632},
{5, 4845, 53, 86, 12580, 135},
{5, 4856, 52, 86, 12594, -1503},
{5, 4866, 53, 86, 12595, 1410},
{5, 4889, 53, 24, 13001, 2759},
{5, 4900, 53, 86, 13007, 230},
{5, 4902, 52, 86, 13010, -1431},
{5, 4945, 51, 15, 13054, -4928},
{5, 4958, 52, 86, 13058, -801},
{5, 4995, 53, 86, 13097, -750},
{5, 5005, 52, 30, 13109, 3703},
{5, 5033, 52, 30, 13135, 3636},
{5, 5053, 122, 24, 13165, 1742},
{5, 5054, 52, 86, 13170, -1638},
{5, 5068, 52, 86, 13189, -2102},
{5, 5078, 53, 42, 13198, -2725},
{5, 5102, 52, 15, 13220, -3638},
{5, 5128, 49, 15, 13255, -4301},
{5, 5139, 116, 15, 13268, -4729},
{5, 5247, 52, 86, 13380, -1753},
{5, 5248, 52, 9, 13375, 853},
{5, 5273, 53, 30, 13421, 3539},
{5, 5286, 119, 15, 13464, -5122},
{5, 5322, 52, 83, 13492, 6011},
{5, 5350, 53, 30, 13534, 4022},
{5, 5353, 53, 30, 13534, 4017},
{5, 5354, 53, 30, 13534, 4018},
{5, 5363, 52, 86, 13561, 515},
{5, 5364, 52, 86, 13562, 501},
{5, 5371, 52, 30, 13557, 4028},
{5, 5427, 53, 86, 14034, -602},
{5, 5466, 121, 9, 14055, 2832},
{5, 5473, 53, 83, 14047, 5454},
{5, 5474, 52, 83, 14050, 5340},
{5, 5557, 53, 9, 14184, 3630},
{5, 5566, 52, 86, 14203, 356},
{5, 5576, 53, 86, 14211, 316},
{5, 5631, 53, 83, 14266, 5635},
{5, 5634, 122, 86, 14296, -559},
{5, 5643, 52, 50, 14327, -4411},
{5, 5676, 53, 9, 14328, 4927},
{5, 5689, 53, 9, 14355, 4844},
{5, 5694, 122, 42, 14396, -2632},
{5, 5746, 52, 86, 14449, 157},
{5, 5813, 52, 86, 15012, 142},
{5, 5822, 133, 50, 15044, -5424},
{5, 5823, 134, 19, 15055, -5536},
{5, 5824, 121, 50, 15040, -3304},
{5, 5846, 52, 86, 15065, 136},
{5, 5850, 52, 86, 15071, 133},
{5, 5897, 120, 48, 15174, -2101},
{5, 5907, 52, 34, 15159, 5620},
{5, 5927, 120, 50, 15280, -5040},
{5, 5946, 120, 57, 15355, -5040},
{5, 5982, 53, 34, 15387, 5921},
{5, 5986, 120, 50, 15461, -3747},
{5, 6067, 132, 57, 16132, -5413},
{5, 6118, 53, 74, 16218, -217},
{5, 6124, 132, 72, 16253, -4039},
{5, 6134, 133, 57, 16278, -4909},
{5, 6144, 121, 72, 16272, -2601},
{5, 6192, 135, 72, 16404, -4322},
{5, 6193, 131, 6, 16413, -4846},
{5, 6204, 134, 6, 16462, -4701},
{5, 6207, 53, 40, 16431, 3650},
{5, 6210, 94, 40, 16445, 2348},
{5, 6217, 53, 84, 16326, 7812},
{5, 6222, 136, 72, 16494, -4444},
{5, 6229, 121, 40, 16470, 4732},
{5, 6231, 129, 72, 16542, -4149},
{5, 6235, 121, 59, 16534, -2211},
{5, 6242, 132, 72, 16556, -3928},
{5, 6259, 134, 72, 17008, -4439},
{5, 6281, 131, 72, 17047, -3759},
{5, 6284, 121, 59, 17045, -2446},
{5, 6287, 121, 59, 17052, -2242},
{5, 6293, 120, 59, 17102, -2635},
{5, 6302, 96, 72, 17137, -3706},
{5, 6304, 120, 59, 17145, -2928},
{5, 6309, 95, 59, 17141, -1255},
{5, 6316, 120, 59, 17166, -2808},
{5, 6334, 70, 72, 17208, -3606},
{5, 6342, 122, 59, 17212, -1935},
{5, 6352, 120, 6, 17255, -4825},
{5, 6355, 121, 59, 17240, -2621},
{5, 6356, 120, 59, 17236, -1749},
{5, 6366, 122, 59, 17277, -505},
{5, 6369, 95, 59, 17293, -2346},
{5, 6388, 119, 72, 17363, -4444},
{5, 6397, 117, 6, 17407, -5340},
{5, 6401, 119, 59, 17386, -2355},
{5, 6426, 122, 59, 17449, 310},
{5, 6440, 121, 77, 17489, -2022},
{5, 6441, 119, 72, 17502, -3703},
{5, 6445, 97, 77, 17493, -2001},
{5, 6451, 134, 72, 17507, -3013},
{5, 6453, 122, 72, 17509, -3436},
{5, 6503, 52, 34, 17495, 7009},
{5, 6517, 122, 59, 18018, -858},
{5, 6520, 134, 77, 18034, -2753},
{5, 6522, 122, 77, 18036, -3002},
{5, 6528, 122, 77, 18048, -3003},
{5, 6535, 121, 74, 18038, -18},
{5, 6539, 121, 74, 18048, -735},
{5, 6541, 118, 25, 18080, -4342},
{5, 6543, 92, 34, 17586, 6638},
{5, 6544, 120, 77, 18073, -2500},
{5, 6553, 120, 77, 18093, -2554},
{5, 6568, 135, 77, 18128, -2135},
{5, 6569, 120, 77, 18136, -3150},
{5, 6572, 92, 59, 18121, 651},
{5, 6583, 136, 77, 18158, -2208},
{5, 6603, 137, 77, 18184, -1824},
{5, 6624, 120, 77, 18237, -3022},
{5, 6629, 94, 77, 18257, -2312},
{5, 6633, 131, 59, 18273, 631},
{5, 6638, 121, 77, 18309, -2530},
{5, 6642, 121, 77, 18319, -2329},
{5, 6645, 135, 77, 18320, -1653},
{5, 6649, 135, 73, 18335, -1024},
{5, 6652, 121, 77, 18358, -3259},
{5, 6664, 134, 73, 18366, -749},
{5, 6712, 120, 73, 18531, -842},
{5, 6723, 119, 77, 18596, -3638},
{5, 6726, 70, 25, 19017, -3653},
{5, 6727, 70, 25, 19017, -3653},
{5, 6729, 70, 25, 19019, -3657},
{5, 6752, 117, 61, 19109, -5959},
{5, 6755, 134, 4, 19078, 416},
{5, 6756, 136, 4, 19087, 442},
{5, 6760, 121, 4, 19112, 102},
{5, 6781, 95, 4, 19185, 632},
{5, 6791, 136, 52, 19207, 3751},
{5, 6802, 135, 88, 19306, 2016},
{5, 6818, 94, 77, 19440, -1409},
{5, 6819, 133, 31, 19413, 4011},
{5, 6822, 51, 77, 19449, -1448},
{5, 6823, 133, 88, 19432, 2318},
{5, 6826, 93, 31, 19448, 5032},
{5, 6830, 134, 88, 19510, 2306},
{5, 6834, 134, 31, 19522, 2924},
{5, 6857, 67, 31, 20028, 3331},
{5, 6866, 134, 31, 20039, 4410},
{5, 6885, 134, 88, 20119, 2629},
{5, 6888, 66, 31, 20128, 3819},
{5, 6905, 96, 32, 20224, 2006},
{5, 6907, 53, 12, 20251, -2449},
{5, 6910, 133, 31, 20232, 4047},
{5, 6934, 121, 32, 20342, 724},
{5, 6939, 134, 16, 20315, 6040},
{5, 6940, 132, 88, 20344, 2817},
{5, 6946, 51, 16, 20349, 6009},
{5, 6960, 105, 31, 20457, 3043},
{5, 6974, 112, 31, 20511, 3150},
{5, 6979, 70, 31, 20510, 3208},
{5, 6992, 105, 31, 20564, 3143},
{5, 6995, 105, 31, 20571, 3113},
{5, 7000, 60, 31, 21018, 4412},
{5, 7006, 122, 32, 21015, 1611},
{5, 7008, 96, 31, 21005, 5433},
{5, 7009, 92, 5, 21042, -1122},
{5, 7023, 77, 16, 21005, 6810},
{5, 7026, 96, 31, 21063, 4751},
{5, 7027, 94, 31, 21070, 4214},
{5, 7044, 138, 31, 21129, 4229},
{5, 7062, 134, 31, 21235, 4623},
{5, 7086, 134, 31, 21305, 5136},
{5, 7090, 52, 44, 21365, -5433},
{5, 7128, 136, 31, 21440, 5343},
{5, 7129, 81, 16, 21430, 6607},
{5, 7142, 135, 16, 21452, 6546},
{5, 7160, 132, 16, 21537, 6236},
{5, 7184, 52, 5, 22027, -2049},
{5, 7209, 134, 45, 22051, 4629},
{5, 7217, 52, 62, 22079, 3122},
{5, 7243, 132, 45, 22151, 4954},
{5, 7293, 90, 5, 22296, -2050},
{5, 7296, 136, 45, 22282, 5217},
{5, 7320, 54, 62, 22361, 3357},
{5, 7331, 52, 62, 22371, 3425},
{5, 7380, 133, 16, 22473, 5808},
{5, 7424, 52, 39, 22573, -4104},
{5, 7448, 53, 62, 23001, 1559},
{5, 7479, 52, 62, 23049, 1219},
{5, 7510, 134, 16, 23115, 6034},
{5, 7582, 52, 39, 23184, -4222},
{5, 7606, 52, 5, 23191, -829},
{5, 7619, 53, 62, 23202, 812},
{5, 7635, 67, 14, 23202, 6111},
{5, 7662, 93, 1, 23259, 4232},
{5, 7686, 132, 1, 23301, 4908},
{5, 7723, 53, 5, 23390, -1258},
{5, 7727, 52, 5, 23399, -1218},
{5, 7789, 133, 14, 23574, 5643},
{5, 7790, 135, 14, 23584, 6113},
{5, 7793, 51, 71, 23578, -3236},
{5, 7814, 52, 62, 32, 1609},
{0, 36, 146, 1, 550, +2338},
{15, 0, 142, 1, 2039, +4220},
{201, 228, 147, 1, 2140, +4729},
{201, 3050, 146, 1, 23595, +3343},
{0, 56, 146, 1, 1562, +3715},
{0, 59, 146, 1, 2109, +3902},
{24, 0, 146, 4, 19487, +1149},
{201, 2404, 147, 4, 18508, +1059},
{201, 2532, 146, 4, 19302, 254},
{0, 5, 146, 4, 18465, -58},
{0, 11, 145, 4, 18591, +1338},
{0, 15, 146, 4, 19050, -402},
{0, 57, 146, 4, 19546, -814},
{201, 2838, 146, 5, 21546, -318},
{32, 0, 144, 5, 22288, -1},
{0, 12, 146, 5, 21041, -549},
{0, 41, 146, 5, 22143, -2104},
{0, 53, 146, 5, 22266, -1645},
{0, 94, 145, 5, 23191, -1328},
{0, 107, 146, 5, 23460, -1841},
{12, 0, 145, 7, 2592, +2120},
{15, 0, 145, 7, 1535, +1918},
{20, 0, 145, 7, 1579, +2336},
{24, 0, 145, 7, 2493, +1728},
{201, 394, 147, 7, 3280, +2028},
{0, 1, 146, 7, 1501, +2217},
{0, 30, 147, 7, 2370, +2439},
{0, 33, 145, 7, 2407, +2704},
{16, 0, 143, 8, 5597, +3713},
{201, 644, 147, 8, 5103, +3718},
{201, 698, 147, 8, 5252, +3451},
{201, 872, 147, 8, 6156, +3609},
{29, 0, 145, 8, 4593, +3753},
{30, 0, 145, 8, 6467, +4335},
{0, 14, 145, 8, 5154, +3241},
{0, 26, 145, 8, 5386, +3030},
{0, 41, 146, 8, 6116, +4843},
{132, 147, 147, 8, 6343, +3805},
{11, 0, 144, 9, 15155, +3319},
{12, 0, 143, 9, 14450, +2704},
{17, 0, 145, 9, 14162, +5122},
{19, 0, 145, 9, 14135, +5147},
{21, 0, 144, 9, 15245, +3723},
{24, 0, 145, 9, 14407, +1625},
{201, 1825, 146, 9, 14165, +2007},
{201, 1835, 145, 9, 14234, +827},
{201, 1884, 147, 9, 14484, +2422},
{31, 0, 145, 9, 14514, +1906},
{32, 0, 144, 9, 14411, +1344},
{0, 39, 146, 9, 14497, +4843},
{0, 44, 145, 9, 15038, +4739},
{162, 191, 147, 9, 14596, +5352},
{201, 1694, 145, 11, 12492, +8325},
{201, 400, 147, 11, 3350, +6002},
{201, 485, 147, 11, 4078, +6220},
{0, 1, 146, 11, 4320, +5355},
{0, 11, 145, 11, 5061, +5858},
{6, 0, 144, 12, 20176, -1230},
{23, 0, 146, 12, 20299, -1835},
{24, 0, 145, 12, 20273, -1813},
{26, 0, 145, 12, 20289, -1749},
{27, 0, 145, 12, 20194, -1907},
{17, 0, 145, 14, 2291, +6724},
{18, 0, 144, 14, 491, +5749},
{27, 0, 145, 14, 23590, +5545},
{201, 163, 147, 14, 1513, +6451},
{201, 3053, 146, 14, 26, +6606},
{201, 3062, 146, 14, 63, +5826},
{0, 3, 145, 15, 13518, -3300},
{9, 0, 143, 16, 21287, +7034},
{11, 0, 144, 16, 22292, +5825},
{19, 0, 144, 16, 20089, +7743},
{201, 2780, 147, 16, 21118, +5959},
{201, 2816, 146, 16, 21390, +5729},
{201, 2840, 146, 16, 21520, +5548},
{201, 460, 146, 16, 4100, +8042},
{31, 0, 144, 16, 22038, +6438},
{132, 461, 147, 16, 22039, +5949},
{10, 0, 145, 17, 1496, -1041},
{15, 0, 144, 17, 2433, +314},
{201, 186, 147, 17, 1559, +151},
{0, 66, 146, 17, 2128, -224},
{6, 0, 140, 20, 6451, -1643},
{12, 0, 142, 20, 6586, -2858},
{21, 0, 145, 20, 6561, -1403},
{108, 3945, 145, 20, 7166, -2319},
{17, 0, 144, 22, 8467, +2846},
{25, 0, 146, 22, 8268, +2656},
{201, 1177, 147, 22, 8056, +2732},
{201, 1245, 146, 22, 8358, 637},
{201, 1254, 147, 22, 8404, +1940},
{201, 1311, 147, 22, 9074, +2259},
{32, 0, 145, 22, 8122, +1739},
{0, 57, 146, 22, 8542, +3035},
{0, 66, 146, 22, 9014, +3215},
{201, 1633, 147, 24, 12207, +2703},
{201, 1639, 147, 24, 12244, +2535},
{0, 2, 146, 24, 12043, +2128},
{0, 24, 145, 24, 12351, +1823},
{0, 35, 145, 24, 12533, +2115},
{15, 0, 145, 25, 19064, -3704},
{19, 0, 146, 25, 18334, -3844},
{15, 0, 144, 26, 15427, +2618},
{18, 0, 146, 26, 15232, +3017},
{27, 0, 146, 26, 16147, +3352},
{32, 0, 145, 26, 15394, +3638},
{132, 128, 146, 26, 16117, +3321},
{11, 0, 143, 29, 12299, -1631},
{201, 1604, 147, 29, 12095, -1151},
{6, 0, 143, 30, 12560, +3819},
{0, 2, 146, 30, 12161, +4040},
{9, 0, 143, 31, 19307, +2758},
{11, 0, 143, 31, 19450, +4508},
{20, 0, 145, 31, 20474, +3629},
{21, 0, 145, 31, 21441, +2845},
{201, 2486, 147, 31, 19121, +4951},
{30, 0, 145, 31, 19556, +5226},
{0, 16, 146, 31, 19418, +5032},
{0, 31, 144, 31, 20136, +4644},
{0, 49, 146, 31, 20410, +3218},
{0, 61, 145, 31, 21069, +3845},
{132, 130, 146, 31, 21208, +3227},
{103, 5137, 146, 31, 19459, +3501},
{15, 0, 144, 32, 20467, +1607},
{12, 0, 144, 34, 19482, +7016},
{21, 0, 146, 34, 17053, +5428},
{22, 0, 145, 34, 17322, +5511},
{23, 0, 145, 34, 18512, +5923},
{201, 2155, 147, 34, 17161, +6043},
{201, 2348, 146, 34, 18339, +5221},
{30, 0, 145, 34, 17419, +7209},
{0, 17, 145, 34, 16362, +5255},
{0, 41, 146, 34, 18002, +8000},
{132, 123, 147, 34, 13271, +6444},
{12, 0, 145, 35, 20591, +418},
{201, 2742, 147, 35, 21022, +711},
{16, 0, 143, 36, 2583, -4018},
{11, 5, 146, 36, 1398, -5612},
{0, 55, 147, 36, 4436, -848},
{108, 3556, 146, 36, 3124, -4425},
{29, 0, 145, 37, 2338, -2814},
{6, 0, 142, 38, 7346, +3153},
{11, 0, 144, 38, 7201, +2159},
{19, 0, 144, 38, 7444, +2424},
{201, 1083, 147, 38, 7256, +2030},
{201, 1108, 147, 38, 7328, +2253},
{0, 38, 145, 38, 6546, +1311},
{162, 70, 147, 38, 6278, +2047},
{6, 0, 143, 40, 17146, +1423},
{11, 0, 143, 40, 17150, +2450},
{19, 0, 145, 40, 16081, +1703},
{26, 0, 145, 40, 17237, +3709},
{201, 2052, 147, 40, 16289, +1825},
{201, 2063, 146, 40, 16318, +4536},
{201, 2315, 147, 40, 18250, +2724},
{201, 2411, 147, 40, 18523, +1432},
{0, 37, 146, 40, 16406, +413},
{0, 56, 146, 40, 16550, +2544},
{0, 95, 145, 40, 18015, +2136},
{0, 100, 146, 40, 18078, +2606},
{132, 129, 147, 40, 18359, +1659},
{12, 0, 143, 42, 8468, +625},
{201, 1348, 148, 42, 9245, +621},
{201, 1355, 147, 42, 9273, +614},
{201, 1365, 147, 42, 9315, +128},
{28, 0, 145, 42, 9291, -246},
{103, 396, 146, 42, 11323, -2916},
{201, 2894, 146, 45, 22189, +3746},
{0, 8, 146, 45, 22359, +3938},
{6, 0, 141, 46, 10084, +1158},
{15, 0, 142, 46, 10200, +1950},
{28, 0, 145, 46, 11279, +251},
{0, 6, 145, 46, 9320, +943},
{0, 49, 146, 46, 10350, +839},
{0, 54, 144, 46, 10556, +2445},
{0, 81, 146, 46, 11256, +1627},
{0, 83, 147, 46, 11268, +301},
{0, 90, 146, 46, 11347, +1648},
{132, 215, 147, 46, 10163, +1744},
{15, 0, 144, 47, 5445, -2227},
{108, 3750, 145, 47, 5204, -2114},
{21, 0, 145, 48, 14493, -1409},
{23, 0, 146, 48, 15210, -1533},
{201, 1962, 146, 48, 15387, -847},
{31, 0, 145, 50, 15569, -3358},
{201, 1282, 147, 51, 8508, +3504},
{201, 1333, 147, 51, 9184, +3522},
{201, 1338, 147, 51, 9210, +3811},
{201, 1369, 147, 51, 9354, +3958},
{201, 958, 146, 51, 6482, +5542},
{0, 12, 145, 51, 6462, +5927},
{0, 19, 146, 51, 7229, +5517},
{0, 38, 144, 51, 9188, +3648},
{9, 0, 144, 52, 18501, +3322},
{13, 0, 145, 52, 18443, +3940},
{14, 0, 145, 52, 18443, +3940},
{18, 0, 144, 52, 19138, +3909},
{201, 2474, 147, 52, 19091, +3436},
{32, 0, 144, 52, 18448, +3736},
{200, 0, 145, 52, 18570, +3254},
{162, 282, 146, 52, 18549, +3358},
{108, 5218, 147, 54, 20454, -3029},
{9, 0, 145, 55, 6288, -702},
{12, 0, 144, 55, 6238, +436},
{20, 0, 144, 59, 16309, +159},
{23, 0, 145, 59, 17180, -2417},
{26, 0, 145, 59, 16256, -2327},
{201, 2276, 147, 59, 18057, +1200},
{28, 0, 145, 59, 18031, -811},
{0, 36, 145, 59, 17153, -2636},
{0, 61, 146, 59, 17446, +235},
{0, 70, 144, 59, 18055, +230},
{9, 0, 140, 60, 5145, -812},
{11, 0, 142, 60, 5320, -18},
{16, 0, 145, 60, 5353, -523},
{17, 0, 143, 60, 5354, -555},
{18, 0, 144, 60, 5245, -224},
{20, 0, 144, 60, 5351, +956},
{26, 0, 145, 60, 5133, +252},
{27, 0, 144, 60, 5387, -236},
{201, 747, 145, 60, 5350, -600},
{201, 790, 146, 60, 5460, -416},
{32, 0, 142, 60, 5407, -157},
{0, 14, 146, 60, 5079, +830},
{0, 23, 145, 60, 5228, +333},
{0, 32, 144, 60, 5308, 557},
{0, 33, 146, 60, 5312, +318},
{0, 52, 146, 60, 5480, +627},
{12, 0, 143, 62, 21442, +953},
{201, 2841, 146, 62, 21543, +1943},
{201, 3007, 147, 62, 23228, +2034},
{0, 1, 144, 62, 21221, +1948},
{18, 0, 144, 63, 2507, +5554},
{201, 162, 146, 63, 1493, +4754},
{201, 331, 145, 63, 3009, +5221},
{201, 336, 147, 63, 3015, +3225},
{201, 369, 147, 63, 3171, +4029},
{0, 56, 146, 63, 4246, +3358},
{11, 24, 146, 66, 22366, -3140},
{6, 0, 144, 67, 2020, +246},
{201, 22, 147, 67, 174, +853},
{201, 3009, 147, 67, 23243, +343},
{30, 0, 145, 67, 1057, +2128},
{32, 0, 145, 67, 1137, +735},
{0, 35, 144, 67, 150, +849},
{0, 55, 146, 67, 399, +2126},
{0, 65, 146, 67, 499, +2743},
{0, 66, 146, 67, 546, +1911},
{0, 77, 146, 67, 1058, +455},
{112, 0, 145, 68, 7183, -3644},
{110, 19, 146, 68, 7343, -2328},
{103, 327, 144, 68, 7388, -2648},
{6, 0, 141, 72, 16294, -2626},
{9, 0, 143, 72, 16054, -1948},
{22, 0, 144, 72, 16120, -1928},
{31, 0, 145, 72, 16044, -1122},
{11, 0, 144, 74, 15348, +1032},
{16, 0, 145, 74, 18562, +412},
{201, 1919, 147, 74, 15127, +1917},
{0, 59, 145, 74, 18272, +12},
{132, 127, 146, 74, 15402, +1203},
{15, 0, 145, 75, 9525, -806},
{153, 0, 147, 75, 9541, +457},
{0, 35, 146, 75, 10433, +445},
{0, 40, 147, 75, 10493, -401},
{32, 0, 145, 76, 19490, +1909},
{110, 84, 146, 76, 19394, +1634},
{138, 0, 145, 77, 17591, -3015},
{0, 54, 145, 77, 19407, -1618},
{108, 5082, 146, 77, 19031, -1915},
{10, 0, 145, 78, 4226, +2538},
{25, 0, 145, 78, 4204, +2721},
{201, 422, 146, 78, 3368, +35},
{201, 495, 146, 78, 4077, +1510},
{201, 572, 147, 78, 4385, +2656},
{0, 7, 147, 78, 3344, +2428},
{0, 62, 146, 78, 4240, +2418},
{0, 118, 146, 78, 5293, +2509},
{201, 239, 147, 81, 2174, +2845},
{0, 6, 145, 81, 2124, +3018},
{27, 0, 145, 83, 9104, +6708},
{201, 1520, 147, 83, 11161, +5246},
{201, 1523, 144, 83, 11182, +3132},
{201, 1695, 146, 83, 12563, +5406},
{32, 0, 142, 83, 13239, +5456},
{132, 126, 146, 83, 11323, +6105},
{6, 0, 142, 84, 2318, +8916},
{201, 1972, 147, 84, 15292, +8027},
{108, 2682, 147, 84, 13407, +7651},
{11, 70, 145, 85, 8295, -4443},
{108, 4191, 145, 85, 9144, -4314},
{15, 0, 143, 86, 12417, -127},
{28, 0, 144, 86, 14016, +133},
{0, 17, 147, 86, 12225, +518},
{60, 0, 161, 1, 275, 3535},
{166, 0, 162, 1, 23388, 3546},
{167, 0, 162, 1, 46, 4333},
{181, 0, 161, 1, 2384, 3910},
{185, 0, 162, 1, 199, 4443},
{107, 5223, 162, 1, 542, 2404},
{130, 15196, 162, 1, 542, 2404},
{179, 0, 162, 4, 18585, 1422},
{182, 0, 161, 4, 19044, -541},
{182, 1469, 162, 4, 20011, 931},
{130, 11960, 161, 4, 19232, -1042},
{147, 0, 163, 5, 23244, -1719},
{182, 0, 162, 7, 2150, 1214},
{90, 0, 163, 8, 5034, 5038},
{96, 0, 162, 8, 5481, 3038},
{148, 0, 164, 8, 6348, 4230},
{152, 0, 162, 8, 5271, 3409},
{176, 0, 163, 8, 5091, 3900},
{178, 0, 159, 8, 6365, 3827},
{179, 0, 161, 8, 5218, 3231},
{182, 0, 163, 8, 6240, 4742},
{182, 346, 163, 8, 4526, 3830},
{149, 0, 163, 9, 14242, 2542},
{147, 0, 162, 11, 7217, 6940},
{152, 0, 162, 11, 5410, 6848},
{166, 0, 161, 11, 4512, 6810},
{177, 0, 161, 11, 3418, 6239},
{179, 0, 162, 11, 4059, 6148},
{196, 0, 161, 11, 4086, 5322},
{146, 0, 161, 12, 20171, -2119},
{129, 0, 164, 14, 246, 5417},
{166, 0, 165, 14, 175, 1714},
{187, 0, 162, 14, 549, 5834},
{191, 0, 163, 14, 1336, 5745},
{193, 0, 161, 14, 13, 6021},
{182, 623, 161, 14, 3114, 5754},
{21, 0, 162, 16, 21435, 5848},
{152, 0, 161, 16, 21352, 7837},
{107, 16115, 162, 17, 2351, -927},
{157, 129989, 162, 17, 2351, -9264},
{187, 0, 160, 20, 7081, -1155},
{139, 0, 161, 21, 7087, 1001},
{171, 0, 162, 22, 8567, 1931},
{194, 0, 160, 22, 8554, 1714},
{139, 0, 160, 26, 15486, 2809},
{182, 0, 161, 26, 15495, 3934},
{172, 0, 162, 30, 12594, 3749},
{197, 0, 159, 30, 12451, 4526},
{66, 0, 161, 31, 19288, 4603},
{67, 0, 162, 31, 19572, 4416},
{82, 0, 162, 31, 20468, 4603},
{145, 0, 161, 31, 20134, 3844},
{148, 0, 161, 31, 21433, 3801},
{150, 0, 163, 31, 20104, 3557},
{168, 0, 163, 31, 20095, 4752},
{172, 0, 161, 31, 19409, 3237},
{177, 0, 160, 31, 20196, 4754},
{182, 0, 162, 31, 20413, 4808},
{192, 0, 163, 31, 20186, 3727},
{182, 460, 160, 31, 21420, 3531},
{107, 189256, 162, 31, 19572, 4418},
{157, 106516, 162, 32, 20486, 1750},
{150, 0, 160, 34, 12564, 6560},
{171, 0, 161, 34, 17564, 5813},
{180, 0, 160, 34, 19216, 7634},
{169, 0, 162, 36, 5098, -531},
{75, 0, 162, 38, 7209, 2460},
{129, 0, 161, 38, 7319, 2430},
{173, 0, 161, 38, 6109, 2601},
{184, 0, 162, 38, 6421, 3127},
{33, 0, 161, 40, 18303, 2152},
{144, 0, 162, 40, 16042, 5030},
{157, 46574, 161, 40, 17135, 4206},
{177, 0, 159, 42, 10376, -1323},
{182, 0, 161, 42, 10516, -2115},
{197, 0, 161, 42, 9511, -2301},
{139, 0, 160, 46, 9476, 1124},
{139, 0, 160, 47, 4596, -1448},
{197, 0, 161, 51, 7282, 460},
{109, 0, 162, 52, 18428, 3658},
{171, 0, 162, 52, 18323, 3660},
{177, 0, 162, 52, 19202, 3753},
{73, 0, 163, 55, 6564, 76},
{96, 0, 163, 55, 6224, 325},
{102, 0, 162, 55, 6532, -435},
{148, 0, 161, 55, 6584, 610},
{150, 0, 162, 55, 7069, -733},
{182, 614, 161, 55, 7010, -315},
{175, 0, 161, 59, 17297, -1928},
{182, 0, 161, 59, 16267, -1226},
{74, 0, 160, 60, 6255, 1443},
{101, 0, 164, 60, 6177, 831},
{146, 0, 162, 60, 5332, 709},
{190, 0, 160, 60, 5054, 111},
{149, 0, 162, 62, 21564, 2248},
{33, 0, 163, 63, 3451, 4447},
{149, 0, 162, 63, 21564, 2252},
{151, 0, 162, 63, 22059, 3330},
{197, 0, 162, 63, 3277, 4411},
{182, 466, 162, 63, 3415, 5130},
{176, 0, 159, 67, 23464, 329},
{198, 0, 161, 67, 1161, 2546},
{107, 26, 162, 67, 54, 847},
{157, 109003, 162, 67, 54, 847},
{157, 128396, 163, 67, 23491, 623},
{147, 0, 162, 68, 8075, -2255},
{148, 0, 163, 73, 18474, -1313},
{149, 0, 162, 73, 18370, -736},
{165, 0, 160, 73, 18583, -754},
{171, 0, 162, 73, 18554, -86},
{87, 0, 162, 74, 18474, 530},
{94, 0, 163, 74, 18194, -1537},
{72, 0, 163, 76, 20024, 2105},
{76, 0, 162, 76, 20024, 2036},
{195, 0, 161, 76, 20051, 2039},
{60, 0, 161, 77, 19343, -1622},
{170, 0, 162, 77, 17449, -1839},
{182, 1942, 161, 77, 19192, -1555},
{167, 0, 163, 78, 5491, 1904},
{172, 0, 162, 78, 4515, 2832},
{173, 0, 160, 78, 5452, 2425},
{197, 0, 161, 78, 5457, 2042},
{146, 0, 163, 83, 9184, 5124},
{186, 0, 160, 83, 10451, 6725},
{147, 0, 162, 86, 12473, 409},
{165, 0, 160, 86, 12252, 46},
{107, 113801, 163, 86, 13064, -2004},
{157, 157721, 163, 86, 13064, -2004},
{68, 0, 162, 88, 20373, 2630},
{130, 13571, 162, 88, 21099, 2637},
{34, 0, 169, 36, 1377, -5714},
{35, 0, 171, 72, 16054, -1948},
{36, 0, 169, 28, 12266, -6306},
{37, 0, 170, 20, 6586, -2858},
{38, 0, 169, 15, 14038, -6022},
{39, 0, 170, 1, 2039, 4220},
{40, 0, 169, 78, 4359, 1631},
{41, 0, 170, 16, 21186, 6235},
{42, 0, 170, 39, 22427, -4653},
{43, 0, 170, 63, 3243, 4952},
{44, 0, 170, 46, 10200, 1950},
{45, 0, 170, 63, 3082, 4057},
{46, 0, 170, 38, 6377, 1624},
{47, 0, 170, 83, 12540, 5558},
{48, 0, 170, 83, 13475, 4919},
{49, 0, 170, 39, 22082, -4658},
{50, 0, 170, 60, 5362, -112},
{51, 0, 170, 60, 5408, -157},
{52, 0, 170, 42, 9276, -840},
{53, 0, 170, 26, 15347, 2643},
{54, 0, 170, 1, 84, 2905},
{55, 0, 170, 85, 8095, -4720},
{56, 0, 169, 4, 19508, 852},
{57, 0, 170, 20, 7241, -2918},
{58, 0, 170, 64, 263, -4218},
{59, 0, 169, 72, 16294, -2626},
{61, 0, 168, 9, 14157, 1911},
{62, 0, 171, 47, 5327, -1749},
{63, 0, 170, 13, 9171, -5917},
{64, 0, 170, 80, 16487, -6902},
{65, 0, 170, 13, 8225, -5931},
{69, 0, 169, 28, 12477, -5941},
{70, 0, 170, 60, 5251, 621},
{71, 0, 169, 60, 5552, 724},
{77, 0, 168, 13, 6240, -5242},
{78, 0, 168, 8, 5167, 4560},
{79, 0, 170, 14, 92, 5909},
{80, 0, 170, 38, 7346, 3153},
{81, 0, 170, 14, 567, 6043},
{83, 0, 169, 31, 20414, 4517},
{84, 0, 170, 17, 436, -1759},
{85, 0, 170, 46, 11491, 1434},
{86, 0, 170, 17, 436, -1759},
{88, 0, 170, 72, 16003, -2237},
{89, 0, 170, 83, 11037, 6145},
{91, 0, 170, 78, 5263, 2836},
{92, 0, 170, 34, 17566, 5129},
{93, 0, 170, 62, 21442, 953},
{95, 0, 169, 66, 22577, -2937},
{97, 0, 170, 28, 12312, -5707},
{98, 0, 170, 26, 15347, 2643},
{99, 0, 171, 31, 20462, 3358},
{100, 0, 170, 72, 17425, -3902},
{104, 0, 169, 15, 14038, -6022},
{105, 0, 170, 7, 2072, 2328},
{106, 0, 171, 59, 16372, -1034},
{111, 0, 170, 9, 14450, 2704},
{113, 0, 170, 77, 18242, -3423},
{114, 0, 170, 84, 14507, 7409},
{115, 0, 170, 85, 8447, -5443},
{116, 0, 170, 62, 23048, 1512},
{117, 0, 170, 8, 5595, 4457},
{118, 0, 171, 17, 3023, 405},
{119, 0, 170, 15, 14067, -3622},
{120, 0, 170, 83, 11018, 5623},
{121, 0, 170, 13, 9132, -6943},
{122, 0, 169, 28, 12477, -5941},
{123, 0, 170, 60, 5320, -18},
{124, 0, 170, 1, 1097, 3537},
{125, 0, 170, 63, 3243, 4952},
{126, 0, 170, 20, 6227, -1757},
{127, 0, 170, 83, 13239, 5456},
{128, 0, 170, 68, 8036, -4000},
{131, 0, 170, 77, 18553, -2618},
{133, 0, 170, 61, 20256, -5644},
{134, 0, 170, 83, 11538, 5342},
{135, 0, 170, 84, 2318, 8916},
{136, 0, 169, 38, 7453, 2802},
{137, 0, 168, 21, 7393, 514},
{140, 0, 170, 59, 17349, 1234},
{141, 0, 169, 46, 10084, 1158},
{142, 0, 168, 60, 5145, -812},
{143, 0, 168, 15, 14396, -6050},
{154, 0, 170, 59, 17104, -1543},
{155, 0, 170, 31, 20222, 4015},
{156, 0, 170, 60, 5478, -940},
{158, 0, 170, 72, 17373, -4260},
{159, 0, 170, 62, 23038, 2805},
{160, 0, 170, 14, 405, 5632},
{161, 0, 170, 72, 17336, -3706},
{163, 0, 168, 20, 6451, -1643},
{164, 0, 169, 86, 13252, -1110},
{174, 0, 170, 13, 9171, -5917},
{183, 0, 168, 52, 18369, 3847},
{188, 0, 170, 72, 16502, -3418},
{189, 0, 170, 20, 7084, -2624},
{199, 0, 171, 46, 11141, 2031},
{7, 0, 168, 15, 14396, -6050},
{8, 0, 169, 15, 14396, -6050},
{6, 0, 170, 50, 14419, -4723},
{9, 0, 170, 39, 22427, -4653},
{15, 0, 170, 14, 567, 6043},
{15, 0, 170, 15, 12415, -4858},
{11, 0, 171, 15, 12084, -5043},
{11, 0, 170, 85, 8447, -5443},
{12, 0, 170, 15, 13399, -5328},
{32, 0, 171, 15, 13555, -4717},
{32, 0, 171, 59, 16372, -1034},
{18, 0, 170, 15, 14355, -4209},
{19, 0, 170, 85, 9221, -5501},
{20, 0, 170, 85, 9080, -4326}
// variables for button - instead of bounce lib - save flash memory
const int DEBOUNCE_DELAY = 50; // the debounce time; increase if the output flickers
int lastSteadyState = LOW; // the previous steady state from the input pin
int lastFlickerableState = LOW; // the previous flickerable state from the input pin
int currentState; // the current reading from the input pin
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long lastPressedTime = 0;
// LCD - VSS - GND // VCC - 5V // RW - GND // K - GND
const byte rs = 12;
const byte en = 13;
const byte d4 = 9;
const byte d5 = 8;
const byte d6 = 7;
const byte d7 = 6;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
byte myLCDbacklight = 255;
byte myLCDcontrast = 100;
// variables to steer menu
byte myDisplayMode = 0;
const char *const menuTopic[] = {"DEC", "Align", "Target", "Region", "Const", "Brightness", "Contrast", "Sensors", "LX200"};
const byte menuTopic_size = sizeof(menuTopic) / sizeof(menuTopic[0]);
byte myMenuTopicNo = 0;
// definition of special / greek characters - for LCD 1602 chinese version - adapt to your LCD if needed
// used lcd is like this https://www.waveshare.com/datasheet/LCD_en_PDF/LCD1602.pdf (see 14. font table)
const char ch_deg = (char)(223); // degree symbol
const char ch_sigma = (char)(246); // uppercase Sigma
// greek alphabet 1-24 = α β γ δ ε ζ η θ ι κ λ μ ν ξ ο π ρ σ τ υ φ χ ψ ω
// maximum 8 custom characters
// γ
char ch_def_1 = 'g'; // for identificatrion & replacement
byte ch_custom_1[] = {
B00000,
B10011,
B10010,
B10010,
B01110,
B00100,
B00100,
B00100
// δ
char ch_def_2 = 'd';
byte ch_custom_2[] = {
B00110,
B01001,
B00100,
B01110,
B10001,
B10001,
B01110,
B00000
// ζ
char ch_def_3 = 'z';
byte ch_custom_3[] = {
B01111,
B00010,
B00100,
B01000,
B01000,
B01111,
B00001,
B00110
// λ
char ch_def_4 = 'l';
byte ch_custom_4[] = {
B01100,
B00100,
B00100,
B01010,
B01010,
B10001,
B10001,
B00000
// ξ
char ch_def_5 = 'x';
byte ch_custom_5[] = {
B11111,
B00100,
B01000,
B00111,
B01000,
B10000,
B11111,
B00010
// φ
char ch_def_6 = 'p';
byte ch_custom_6[] = {
B00000,
B10111,
B10101,
B10101,
B10101,
B01110,
B00100,
B00100
// ψ
char ch_def_7 = 's';
byte ch_custom_7[] = {
B00000,
B00100,
B10101,
B10101,
B10101,
B01110,
B00100,
B00100
// Δ
char ch_def_8 = 'D';
byte ch_custom_8[] = {
B00000,
B00100,
B01010,
B01010,
B10001,
B10001,
B11111,
B00000
// lookup table placeholder chars with greek symbols
struct greekSymbols {
char originalChar;
char replaceChar;
const unsigned int greekSymbols_size = 26;
const struct greekSymbols greekSymbols[greekSymbols_size] =
{'a', (char)(224)}, // α
{'b', (char)(226)}, // β
{'g', 'g'}, // γ custom character
{'d', 'd'}, // δ custom character
{'e', (char)(227)}, // ε
{'z', 'z'}, // ζ custom character
{'j', 'n'}, // η
{'h', (char)(242)}, // θ
{'i', 'l'}, // ι
{'k', 'k'}, // κ
{'l', 'l'}, // λ custom character
{'m', (char)(228)}, // μ
{'n', 'v'}, // ν
{'x', 'x'}, // ξ custom character
{'o', 'o'}, // ο
{'p', (char)(247)}, // π
{'r', (char)(230)}, // ρ
{'s', (char)(229)}, // σ
{'t', 't'}, // τ
{'y', (char)(232)}, // υ
{'q', 'p'}, // φ custom character
{'c', 'x'}, // χ
{'w', 's'}, // ψ custom character
{'u', 'w'},
{'F', (char)(246)}, // Σ
{'D', '/'} // Δ
// definition of constellation names
struct constStruct {
char constName[4];
constStruct myConstellation;
const unsigned int constStruct_size = 89;
const struct constStruct const_PROGMEM[constStruct_size] PROGMEM = {
{"all"}, {"And"}, {"Ant"}, {"Aps"}, {"Aql"}, {"Aqr"}, {"Ara"}, {"Ari"}, {"Aur"}, {"Boo"}, {"Cae"}, {"Cam"}, {"Cap"}, {"Car"}, {"Cas"}, {"Cen"}, {"Cep"}, {"Cet"}, {"Cha"}, {"Cir"},
{"CMa"}, {"CMi"}, {"Cnc"}, {"Col"}, {"Com"}, {"CrA"}, {"CrB"}, {"Crt"}, {"Cru"}, {"Crv"}, {"CVn"}, {"Cyg"}, {"Del"}, {"Dor"}, {"Dra"}, {"Equ"}, {"Eri"}, {"For"}, {"Gem"}, {"Gru"},
{"Her"}, {"Hor"}, {"Hya"}, {"Hyi"}, {"Ind"}, {"Lac"}, {"Leo"}, {"Lep"}, {"Lib"}, {"LMi"}, {"Lup"}, {"Lyn"}, {"Lyr"}, {"Men"}, {"Mic"}, {"Mon"}, {"Mus"}, {"Nor"}, {"Oct"}, {"Oph"},
{"Ori"}, {"Pav"}, {"Peg"}, {"Per"}, {"Phe"}, {"Pic"}, {"PsA"}, {"Psc"}, {"Pup"}, {"Pyx"}, {"Ret"}, {"Scl"}, {"Sco"}, {"Sct"}, {"Ser"}, {"Sex"}, {"Sge"}, {"Sgr"}, {"Tau"}, {"Tel"},
{"TrA"}, {"Tri"}, {"Tuc"}, {"UMa"}, {"UMi"}, {"Vel"}, {"Vir"}, {"Vol"}, {"Vul"}
byte myConstellationNo = 0;
String myConstellationName = "";
// object type name and variables for deep sky objects
const char* myObjectTypeName[] = {"Quasar", "Dark Nebula", "Galaxy", "Bright Neb", "Clust + Neb", "Planet Neb", "SN Rem", "Glob Cluster", "Open Cluster", "Double Star", "Red Star", "Reference", "any"};
unsigned int myRefNo = 0; // number of selected reference star
unsigned int myTargetNo = 0; // number of selected target
// definition of cellestial regions = constellations of seasons defined in groups (as in Deep Sky Atlas) to filter targets and reference stars
// constellation for which deep sky objects exist in the list 0 = all
const byte myAllCONST[] = {0, 1, 2, 4, 5, 6, 7, 8, 9, 11, 12, 13, 14, 15, 16, 17, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 44, 45, 46, 47, 48, 49, 50, 51, 52, 54, 55, 57, 59, 60, 61, 62, 63, 64, 66, 67, 68, 69, 71, 72, 73, 74, 75, 76, 77, 78, 80, 81, 83, 84, 85, 86, 88};
const byte myAllCONST_size = sizeof(myAllCONST) / sizeof(myAllCONST[0]);
// North - UMI,UMA,DRA,CEP,CAS,CAM
const byte myNorthCONST[] = {84, 83, 34, 16, 14, 11};
const byte myNorthCONST_size = sizeof(myNorthCONST) / sizeof(myNorthCONST[0]);
// Spring - LEO,LMI,SEX,HYA,CVN,COM,VIR,CRT,CRV,BOO,CRB,SER
const byte mySpringCONST[] = {46, 49, 75, 42, 30, 24, 86, 27, 29, 9, 26, 74};
const byte mySpringCONST_size = sizeof(mySpringCONST) / sizeof(mySpringCONST[0]);
// Summer - HER,LYR,OPH,SCO,CYG,VUL,SGE,DEL,EQU,AQL,SCT,SER,SGR,CAP
const byte mySummerCONST[] = {40, 52, 59, 72, 31, 88, 76, 32, 35, 4, 73, 74, 77, 12};
const byte mySummerCONST_size = sizeof(mySummerCONST) / sizeof(mySummerCONST[0]);
// Autumn - LAC,PEG,AQR,PSA,AND,TRI,PER,ARI,PSC,CET,SCL,FOR,ERI
const byte myAutumnCONST[] = {45, 62, 5, 66, 1, 81, 63, 7, 67, 17, 71, 37, 36};
const byte myAutumnCONST_size = sizeof(myAutumnCONST) / sizeof(myAutumnCONST[0]);
// Winter - AUR,TAU,ORI,LEP,LYN,GEM,CMI,MON,CMA,PUP,CNC
const byte myWinterCONST[] = {8, 78, 60, 47, 51, 38, 21, 55, 20, 68, 22};
const byte myWinterCONST_size = sizeof(myWinterCONST) / sizeof(myWinterCONST[0]);
// South - ANT,VEL,CAR,VOL,CHA,MUS,CRU,CEN,CRU,TRA,LUP,NOR,ARA,SCO,SGR,CRA,TEL,MIC,IND,PAV,GRU,PHE,SCL,FOR,ERI,HOR,RET,HYI,TUC,DOR,CAE,COL,PUP,PYX,PIC,MEN,APS,OCT
const byte mySouthCONST[] = {2, 85, 13, 28, 15, 28, 80, 50, 57, 6, 72, 77, 25, 54, 44, 61, 39, 64, 71, 37, 36, 41, 33, 23, 68, 69, 65};
const byte mySouthCONST_size = sizeof(mySouthCONST) / sizeof(mySouthCONST[0]);
const char* myregionNAME[] = {"all", "North", "Spring", "Summer", "Autumn", "Winter", "South"}; // no south to save flash
const byte regionArraySize = sizeof(myregionNAME) / sizeof(myregionNAME[0]); // Anzahl der Einträge
byte myRegionNo = 0; // all - 0; North - 1; .... ; South - 6
String myregionName = "";
// variables for calculation of position // all positions are calculated in seconds
long myRefStartTimeSec = 0; // Startzeit beim Setzen des Referenzsterns in Sekunden
long myCurrentRAsec = 0; // meine aktuelle Rektaszension in Sekunden
long myCurrentDECsec = 0; // meine aktuelle Deklination in Sekunden
long myLastRAsec = 0; // meine letzte Rektaszension in Sekunden
long myLastDECsec = 0; // meine letzte Deklination in Sekunden
long myReferenceRAsec = 0; // meine Rektaszensionsreferenz in Sekunden
long myReferenceDECsec = 0; // meine Deklinationsreferenz in Sekunden
long mySensorRAsec = 0; // Sensorwert der Rektaszension in Sekunden
long mySensorDECsec = 0; // Sensorwert der Deklination in Sekunden
long myTargetRAsec = 0; // Rektaszension des Ziels in Sekunden
long myTargetDECsec = 0; // Deklination des Ziels in Sekunden
const int secPerStepRA = 86400L / IMPULSE24HRA; // defines how many seconds RA is changed per rotary step // (24h * 3600sec = 86400sec) / (1:139 * 20 impulse = 2780) --> 31,079 sec / i
const int secPerStepDEC = 1296000L / IMPULSE360DEGDEC; // defines how many seconds DEC is changed per rotary step // (360° * 3600sec = 1296000sec) / (1:96 * 20 impulse = 1920) / --> 675 sec / i
int myDirectionDEC = 1; // saves the value of the direction of the DEC axis, important if the telescope is turned over
// for rotary encoders
static uint8_t prevNextCode_ROT = 0;
static uint16_t store_ROT = 0;
static uint8_t prevNextCode_RA = 0;
static uint16_t store_RA = 0;
static uint8_t prevNextCode_DEC = 0;
static uint16_t store_DEC = 0;
static int8_t val_ROT, val_RA, val_DEC;
int myImpulseRA = 0, myImpulseDEC = 0;
int myLastImpulseRA = 0, myLastImpulseDEC = 0;
const int8_t enc_table[] = {0, 1, 1, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 1, 1, 0};
// variables for LX200
byte statusLX200 = 0; // 0 - BT switched off / 1 - BT switched on / 2 - connected via BT & LX200 (frequent connect to LX200)
byte statusLX200old = 0;
byte btStatus = 0; // 0 - off / 1 - on
unsigned long lastLX200Message = 0;
DSOstruct externalObject; // instance LX200 object
// setup
// for LX200 protocol & debugging
Serial.begin (9600);
// while(!Serial); // attention - only for debugging when in use with IDE!
// Serial.println(F("started"));
getSettingsFromEeprom(); // load settings (brightness,contrast,...)
setReference(); // set reference object to saved values
setTarget(); // set target object to saved values
setupLCD();
createCustomCharacters();
setupRotaryEncoders();
initExternalObject();
// software reset Two Ways to Reset Arduino in Software (with Pictures) - Instructables
void(* resetFunc) (void) = 0;//declare reset function at address 0
void setupLCD()
lcd.begin(16, 2);
updateLCD();
pinMode(LCD_BACKLIGHT_PIN, OUTPUT);
analogWrite(LCD_CONTRAST_PIN, myLCDcontrast); //set contrast
//Creating custom characters in CG-RAM
void createCustomCharacters()
lcd.createChar(1 , ch_custom_1);
lcd.createChar(2 , ch_custom_2);
lcd.createChar(3 , ch_custom_3);
lcd.createChar(4 , ch_custom_4);
lcd.createChar(5 , ch_custom_5);
lcd.createChar(6 , ch_custom_6);
lcd.createChar(7 , ch_custom_7);
lcd.createChar(8 , ch_custom_8);
void setupRotaryEncoders()
// HMI rotary encoder button
pinMode(ROTARY_SW, INPUT_PULLUP);
pinMode(ROTARY_CLK, INPUT);
pinMode(ROTARY_DT, INPUT);
// it is better to use the integrated pull-ups of KY-040 (this requires "+" to be connected to 5V) - https://forum.arduino.cc/index.php?topic=242356.0
// as analog pins are used for rotary encoders - internal pull-ups are additionally used to avoid akward behaviour if not connected to sensors
// RA rotary encoder
pinMode(SENS_RA_CLK, INPUT_PULLUP);
pinMode(SENS_RA_DT, INPUT_PULLUP);
// DEC rotary encoder
pinMode(SENS_DEC_CLK, INPUT_PULLUP);
pinMode(SENS_DEC_DT, INPUT_PULLUP);
// switch for BT module
pinMode(BT_SWITCH, OUTPUT);
// initialise external object struct for receiving via LX200
void initExternalObject()
externalObject.objectPreFixNameNo = 202; // is "external" in DSO PROGMEM
externalObject.objectNumber = 0; // empty - no number in name
externalObject.objectTypeMagnitude = 0;
externalObject.objectConst = 0; // "all" in constellations
externalObject.objectRA = 0;
externalObject.objectDEC = 0;
// \setup
// loop
analogWrite(LCD_BACKLIGHT_PIN, myLCDbacklight); // LCD backlight analogWrite: values from 0 to 255
updateRotaryEncoderButton();
updateRotaryEncoders();
calcCurrentPosition();
if (myDisplayMode == 9) displaySensorValue();
if (myDisplayMode == 11) displayCurrPos();
if (myDisplayMode == 12) displayTargetPos();
if (myDisplayMode == 13) displayDiffTargetCurrPos();
// LX200 status
updateLX200Status();
readSendLX200();
// \loop
// read sensor values
// reads rotary encoders
void updateRotaryEncoders()
if (val_ROT = read_rotary_ROT()) switchSelection(val_ROT);
if (val_RA = read_rotary_RA())
  mySensorRAsec = mySensorRAsec + val_RA * secPerStepRA;
  myImpulseRA = myImpulseRA + val_RA; // for sensor test
if (val_DEC = read_rotary_DEC())
  mySensorDECsec = mySensorDECsec + val_DEC * secPerStepDEC * myDirectionDEC;
  myImpulseDEC = myImpulseDEC + val_DEC * myDirectionDEC; // for sensor test
// reads rotary encoder button
void updateRotaryEncoderButton()
// copy from Arduino - Button - Debounce | Arduino Tutorial
currentState = digitalRead(ROTARY_SW);
if (currentState != lastFlickerableState)
  lastDebounceTime = millis();
  lastFlickerableState = currentState;
if ((millis() - lastDebounceTime) > DEBOUNCE_DELAY)
  if (lastSteadyState == HIGH && currentState == LOW)
    switchMode();
    updateLCD();
    lastPressedTime = millis();
  else if (lastSteadyState == LOW && currentState == HIGH)
    // if button pressed > 5 seconds -> reset
    if (millis() - lastPressedTime > 5000) resetFunc(); // call reset
  lastSteadyState = currentState;
// read rotary encoder for HMI
// robust rotary encoder reading Rotary Encoder: Immediately Tame your Noisy Encoder!
// A vald CW or CCW move returns 1,invalid returns 0.
int8_t read_rotary_ROT()
prevNextCode_ROT <<= 2;
if (digitalRead(ROTARY_DT)) prevNextCode_ROT |= 0x02;
if (digitalRead(ROTARY_CLK)) prevNextCode_ROT |= 0x01;
prevNextCode_ROT &= 0x0f;
// If valid then store as 16 bit data.
if  (enc_table[prevNextCode_ROT] )
  store_ROT <<= 4;
  store_ROT |= prevNextCode_ROT;
  if ((store_ROT & 0xff) == 0x2b) return -1;
  if ((store_ROT & 0xff) == 0x17) return 1;
return 0;
// read rotary encoder for RA
int8_t read_rotary_RA()
prevNextCode_RA <<= 2;
if (digitalRead(SENS_RA_DT)) prevNextCode_RA |= 0x02;
if (digitalRead(SENS_RA_CLK)) prevNextCode_RA |= 0x01;
prevNextCode_RA &= 0x0f;
if  (enc_table[prevNextCode_RA] )
  store_RA <<= 4;
  store_RA |= prevNextCode_RA;
  if ((store_RA & 0xff) == 0x2b) return -1;
  if ((store_RA & 0xff) == 0x17) return 1;
return 0;
// read rotary encoder for DEC
int8_t read_rotary_DEC()
prevNextCode_DEC <<= 2;
if (digitalRead(SENS_DEC_DT)) prevNextCode_DEC |= 0x02;
if (digitalRead(SENS_DEC_CLK)) prevNextCode_DEC |= 0x01;
prevNextCode_DEC &= 0x0f;
if  (enc_table[prevNextCode_DEC] )
  store_DEC <<= 4;
  store_DEC |= prevNextCode_DEC;
  if ((store_DEC & 0xff) == 0x2b) return -1;
  if ((store_DEC & 0xff) == 0x17) return 1;
return 0;
// get & set of object data
// returns the type as number of a deep sky object
byte getObjectType(byte typeMagnitude)
return (typeMagnitude / 14); // decoding of object type from typeMagnitude
// returns the type as string of a deep sky object
String getObjectTypeName(byte typeMagnitude)
return myObjectTypeName[(typeMagnitude / 14) - 1];
// returns the magnitude of a deep sky object
String getMagnitude(byte typeMagnitude) // calcs the right magnitude - here modulo 14 as coded
String strFlMag = (String)(typeMagnitude % 14) + "m";
return strFlMag;
// returns the name of a constellation as string from a lookup tabel according to its number
String getConstName(int no)
constStruct oneConstellation;
// copy constellations data from PROGMEM into oneConstellation according to no
memcpy_P (&oneConstellation, &const_PROGMEM[no], sizeof oneConstellation);
return (String)oneConstellation.constName;
// returns the current constellation for filtering
String getCurrentConstName()
String constellationName;
constellationName = getConstName(myConstellationNo);
return constellationName;
// returns the current cellestial region
String getSetregionName()
return myregionNAME[myRegionNo];
// set reference star
void setReference()
// copy reference data from PROGMEM into myReference according to myRefNo
memcpy_P (&myReference, &DSO_PROGMEM[myRefNo], sizeof myReference);
setReferenceRA_DEC();
// RA and DEC of selected target are set
void setReferenceRA_DEC()
// transfer RA / DEC into internal format (seconds)
myReferenceRAsec = calcRAsecFromRA(myReference.objectRA);
myReferenceDECsec = calcDECsecFromDEC(myReference.objectDEC);
// set target
void setTarget()
// copy reference data from PROGMEM into myTarget according to myTargetNo
memcpy_P (&myTarget, &DSO_PROGMEM[myTargetNo], sizeof myTarget);
setTargetRA_DEC();
void setTargetRA_DEC()
myTargetRAsec = calcRAsecFromRA(myTarget.objectRA);
myTargetDECsec = calcDECsecFromDEC(myTarget.objectDEC);
// \get & set of object data
// calculations and settings of positions
// calculation of RA seconds
unsigned int calcRAsecFromRA(unsigned int ra)
int h = ra / 1000;
int m = (ra - h * 1000) / 10;
int s = (ra - h * 1000 - m * 10) * 6;
unsigned int raSec = h * 3600L + m * 60 + s;
return raSec;
// calculation of DEC seconds
long calcDECsecFromDEC(int dec)
int deg = dec / 100;
int m = (dec - deg * 100);
long decSec = deg * 3600L + m * 60;
return decSec;
// calculation of current telescope position
void calcCurrentPosition()
myCurrentRAsec = myReferenceRAsec + myRefStartTimeSec + mySensorRAsec - millis() / 1000;
myCurrentDECsec = myReferenceDECsec + mySensorDECsec;
// sets the sensor values to zero - needed for alignment with reference star
void resetSensorTime()
myRefStartTimeSec = millis() / 1000;
// \calculations and settings of positions
// display information
// display the current position
void displayCurrPos()
if (myLastRAsec != myCurrentRAsec || myLastDECsec != myCurrentDECsec)
myLastRAsec = myCurrentRAsec;
myLastDECsec = myCurrentDECsec;
displayRA_DEC("Curr ", "Coord", myCurrentRAsec, myCurrentDECsec);
// display position of selected target
void displayTargetPos()
displayRA_DEC(getObjectName(myTarget.objectPreFixNameNo, myTarget.objectNumber, myTarget.objectConst), "Coord", myTargetRAsec, myTargetDECsec);
// calulation & display of difference between current position & target position
void displayDiffTargetCurrPos()
long diffRAsec = myTargetRAsec - myCurrentRAsec;
long diffDECsec = myTargetDECsec - myCurrentDECsec;
if (myLastRAsec != myCurrentRAsec ||  myLastDECsec != myCurrentDECsec) // only if position has changed
  displayRA_DEC(getObjectName(myTarget.objectPreFixNameNo, myTarget.objectNumber, myTarget.objectConst), "Diff ", diffRAsec , diffDECsec);
// display of RA and DEC - generic use for reference stars & target
void displayRA_DEC(String text1, String text2, long rekSec, long dekSec)
// Rektaszension //
int sign = 1.0;
if (rekSec < 0) sign = -1.0;
byte s = (abs(rekSec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator // vorher int
byte m = (abs(rekSec / 60)) % 60;
byte h = (abs(rekSec / 3600)) % 24;
lcd.setCursor(0, 0);
printObjectName(text1);
lcd.setCursor(8, 0);
if (sign < 0) lcd.print(F("-"));
else lcd.print(F("+"));
if (h < 10) lcd.print(F(" "));
lcd.print(h);
lcd.print(F(":"));
if (m < 10) lcd.print(F("0"));
lcd.print(m);
lcd.print(F(","));
lcd.print(s / 6);
// DEC // +90° - -90°
sign = 1.0;
if (dekSec < 0) sign = -1.0;
s = (abs(dekSec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator
m = (abs(dekSec / 60)) % 60;
h = (abs(dekSec / 3600)) % 180;
lcd.setCursor(0, 1);
lcd.print(text2);
lcd.setCursor(8, 1);
lcd.print(h);
lcd.print(ch_deg);
lcd.print(m);
lcd.print(F("'"));
// display current sensor values
void displaySensorValue()
if (myImpulseRA != myLastImpulseRA || myImpulseDEC != myLastImpulseDEC)
lcd.clear();
lcd.print(F("Imp RA"));
lcd.print(F("Imp DEC"));
lcd.setCursor(10, 0);
lcd.print(myImpulseRA);
lcd.setCursor(10, 1);
lcd.print(myImpulseDEC);
myLastImpulseRA = myImpulseRA;
myLastImpulseDEC = myImpulseDEC;
// update LCD according to selected display mode
void updateLCD()
lcd.clear();
if (myDisplayMode == 0)
  lcd.print(F("SpotNik   v")); // DO NOT REMOVE
  lcd.print(VERSION);
  lcd.print(F("developed by MR")); // DO NOT REMOVE
if (myDisplayMode == 1) // main menu
  lcd.print(F(">"));
  lcd.setCursor(1, 0);
  lcd.print(menuTopic[myMenuTopicNo]); // {" reverse", "Ref","Target","region","Const","Bright","Contr","Test"};
  switch (myMenuTopicNo) {
    case 0:
      if (myDirectionDEC == 1) lcd.print(F("normal"));
      else lcd.print(F("reverse"));
    case 1:
      printObjectName(getObjectName(myReference.objectPreFixNameNo, myReference.objectNumber, myReference.objectConst));
    case 2:
      printObjectName(getObjectName(myTarget.objectPreFixNameNo, myTarget.objectNumber, myTarget.objectConst));
      //if (statusLX200 != 2) printObjectName(getObjectName(myTarget.objectPreFixNameNo,myTarget.objectNumber,myTarget.objectConst));
      //else lcd.print(F("external")); // if connection to LX200 source - no usage of internal star database
    case 3:
      lcd.print(getSetregionName());
      // if (statusLX200 != 2) lcd.print(getSetregionName());
      // else lcd.print(F("external"));
    case 4:
      lcd.print(getCurrentConstName());
      // if (statusLX200 != 2) lcd.print(getCurrentConstName());
    case 8:
      if (statusLX200 == 0) lcd.print(F("BT off"));
      if (statusLX200 == 1) lcd.print(F("BT on"));
      if (statusLX200 == 2) lcd.print(F("conn"));
  lcd.setCursor(1, 1);
  if (myMenuTopicNo + 1 < menuTopic_size)
    lcd.print(menuTopic[myMenuTopicNo + 1]);
    lcd.print(menuTopic[0]);
if (myDisplayMode == 2)
  lcd.print(F("Direction of DEC"));
  lcd.print(F(">"));
if (myDisplayMode == 3)
  lcd.setCursor(13, 0);
  lcd.print(getConstName(myReference.objectConst));
  lcd.print(getObjectTypeName(myReference.objectTypeMagnitude));
  lcd.setCursor(13, 1);
  lcd.print(getMagnitude(myReference.objectTypeMagnitude));
if (myDisplayMode == 4)
  lcd.print(getConstName(myTarget.objectConst));
  lcd.print(getObjectTypeName(myTarget.objectTypeMagnitude));
  lcd.print(getMagnitude(myTarget.objectTypeMagnitude));
if (myDisplayMode == 5)
  lcd.print(F("Celestial Region"));
  lcd.print(F(">"));
if (myDisplayMode == 6)
  lcd.print(F("Constellation"));
  lcd.setCursor(11, 1);
  lcd.print(F(">"));
if (myDisplayMode == 7)
  lcd.print(F("LCD Brightness"));
  lcd.print(F(">"));
  lcd.print(myLCDbacklight);
if (myDisplayMode == 8)
  lcd.print(F("LCD Contrast"));
  lcd.print(F(">"));
  lcd.print(myLCDcontrast);
  lcd.print(F("For test"));
  lcd.print(F("turn DEC / RA"));
  myImpulseRA = 0;
  myImpulseDEC = 0;
  myLastImpulseRA = 0;
if (myDisplayMode == 10)
  lcd.print(F("LX200 Connection"));
  lcd.print(F(">"));
  if (statusLX200 == 0) lcd.print(F("Bluetooth off"));
  if (statusLX200 == 1) lcd.print(F("Bluetooth on"));
  if (statusLX200 == 2) lcd.print(F("LX200 connected"));
// returns name of deep sky object based on coded name its number and its constellation
String getObjectName(byte objectprefixNameNo, unsigned int objectNumber, byte objectConst)
String objectName = "";
int indexOfHash = -1;
DSONameStruct oneDSONameStruct;
if (objectprefixNameNo > 0)
  // get name accordng to name number from lookup table
  memcpy_P (&oneDSONameStruct, &DSO_NAME_PROGMEM[objectprefixNameNo - 1], sizeof oneDSONameStruct);
  objectName = oneDSONameStruct.objectName;
  indexOfHash = objectName.indexOf('#');
  if (indexOfHash > -1)
    // replace char with greek char
    String charToReplace = objectName.substring(indexOfHash + 1, indexOfHash + 2);
    objectName = objectName.substring(0, indexOfHash) + objectName.substring(indexOfHash + 2); // delete # and next char from string
    // loop over the greek symbols
    for (int i; i < greekSymbols_size; i++)
      if ((String)charToReplace == (String)greekSymbols[i].originalChar)
        charToReplace = greekSymbols[i].replaceChar;
        objectName = objectName + charToReplace;
if (objectNumber > 0)
  objectName = objectName + (String)objectNumber;
// if object is only number,greek Symbol or max. two characters,accept 'M' - add constellation for identification
if (objectName.charAt(1) == NULL || objectprefixNameNo == 0 || (objectName.charAt(2) == NULL && objectNumber == 0)) // oder nur Zahlen!!!
  objectName = objectName + ' ' + getConstName(objectConst);
return objectName;
// some greek symbols are custom, print function needed
void printObjectName(String objectName)
byte customChar = 0;
char charAt0 = objectName.charAt(0);
if (charAt0 == ch_def_1) customChar = 1;
else if (charAt0 == ch_def_2) customChar = 2;
else if (charAt0 == ch_def_3) customChar = 3;
else if (charAt0 == ch_def_4) customChar = 4;
else if (charAt0 == ch_def_5) customChar = 5;
else if (charAt0 == ch_def_6) customChar = 6;
else if (charAt0 == ch_def_7) customChar = 7;
if (customChar > 0) lcd.write(customChar);
  lcd.print(objectName);
  return;
lcd.print(F(" "));
lcd.print(objectName.substring(2, 8));
// \display information
// switching
// myDisplayMode - rotary encoder for change
// 0 = welcome, 1 = top menu, 2 = change direction, 3 = set reference, 4 = set target, 5 = set region, 6 = set constellation, 7 = set LCD brightness, 8 = set LCD contrast
// 9 = sensor test, 10 = set bluetooth, 11 = show current position, 12 = show target position, 13 = show difference target - current position
void switchMode()
saveSettingsToEeprom(); // save settings to eeprom each time the button is pressed
if (myDisplayMode == 0) // welcome
  myDisplayMode = 1; // top menue
else if (myDisplayMode == 1)
  myDisplayMode = myMenuTopicNo + 2;
else if (myDisplayMode == 3) // set reference
  resetSensorTime();
  myLastDECsec = 0; // set once to zero to update display
  myDisplayMode = 11; // show current position
else if (myDisplayMode == 4) // set target
  setTargetRA_DEC();
  myDisplayMode = 13; // show diff position
// set direction // region // constellation // set brightness  // set contrast // sensor test // show current position // show diff position
else if (myDisplayMode == 2 || myDisplayMode >= 5)
  myDisplayMode = 1; // return to top level menu
lcd.clear();
// function of rotary encoder changes acording to current display mode
void switchSelection(int dir)
myDisplayMode = 1;
updateLCD();
else if (myDisplayMode == 1) changeMenu(dir);
if (myDisplayMode == 2) changeDirectionDEC(dir);
if (myDisplayMode == 3) changeReference(dir);
if (myDisplayMode == 4) changeTarget(dir);
if (myDisplayMode == 5) changeregion(dir);
if (myDisplayMode == 6) changeConstellation(dir);
if (myDisplayMode == 7) changeLCDBacklight(dir);
if (myDisplayMode == 8) changeLCDcontrast(dir);
if (myDisplayMode == 10) changeBTconnection(dir);
if (myDisplayMode == 11 || myDisplayMode == 12 || myDisplayMode == 13) changeView(dir);
updateLCD();
// change menu topics
void changeMenu(int dir)
if (dir == 1)
if ((myMenuTopicNo + 1) < menuTopic_size)
myMenuTopicNo = myMenuTopicNo + 1;
myMenuTopicNo = 0;
else if (dir == -1)
if (myMenuTopicNo > 0)
myMenuTopicNo = myMenuTopicNo - 1;
myMenuTopicNo = menuTopic_size - 1;
// according to the direction of the DEC axis the value of the DEC sensor has to be reverted
void changeDirectionDEC(int dir)
if (dir == 1 || dir == -1)
if (myDirectionDEC == 1) myDirectionDEC = -1;
else myDirectionDEC = 1;
// calls changeObject for object type reference
void changeReference (int dir)
changeObject(dir, 'r');
// calls changeObject for object type target
void changeTarget(int dir)
changeObject(dir, 't');
// change referenc star including filter according to selected sky region
void changeObject (int dir, char objectType)
bool constFound = false;
DSOstruct oneObject; // instance of reference for search & filter
unsigned int objectNo;
unsigned int numberOfLoops = 0;
if (objectType == 'r')
  objectNo = myRefNo; // set start no of object
  objectNo = myTargetNo;
while (constFound == false)
  if (dir == 1)
    if ((objectNo + 1) < DSO_PROGMEM_size)
      objectNo = objectNo + 1;
      objectNo = 0;
  if (dir == -1) // before else if - but what if no fitting star at beginning before rotary turning?
    if (objectNo > 0)
      objectNo = objectNo - 1;
      objectNo = DSO_PROGMEM_size - 1;
  memcpy_P (&oneObject, &DSO_PROGMEM[objectNo], sizeof oneObject); // get next DSO object from struct and copy it into oneObject
  // filter on a constellation
  // if a constellation is selected,object is a target and constellation of object fits to selected constellation
  if (objectType == 't' && myConstellationNo > 0 && getObjectType(oneObject.objectTypeMagnitude) > 0  && getObjectType(oneObject.objectTypeMagnitude) < 12 && oneObject.objectConst == myConstellationNo)
    constFound = true;
  // filter on regions
  else if ( (objectType == 'r' && getObjectType(oneObject.objectTypeMagnitude) == 12) || // reference stars     // filter on objects of type "reference" = no 12
            (myConstellationNo == 0 && objectType == 't' && getObjectType(oneObject.objectTypeMagnitude) > 0  && getObjectType(oneObject.objectTypeMagnitude) < 12)) // target objects
    // filter targets by constellations of the selected region
    // myregionNAME[]={"All","North","Spring","Summer","Autumn","Winter","South"};
    if (myRegionNo == 1) // region = north
      for (int i = 0; i < myNorthCONST_size; i++)
        if (oneObject.objectConst == myNorthCONST[i])
          constFound = true;
    else if (myRegionNo == 2) // region = spring
      for (int i = 0; i < mySpringCONST_size; i++)
        if (oneObject.objectConst == mySpringCONST[i])
          constFound = true;
    else if (myRegionNo == 3) // region = summer
      for (int i = 0; i < mySummerCONST_size; i++)
        if (oneObject.objectConst == mySummerCONST[i])
          constFound = true;
    else if (myRegionNo == 4) // region = autumn
      for (int i = 0; i < myAutumnCONST_size; i++)
        if (oneObject.objectConst == myAutumnCONST[i])
          constFound = true;
    else if (myRegionNo == 5) // region = winter
      for (int i = 0; i < myWinterCONST_size; i++)
        if (oneObject.objectConst == myWinterCONST[i])
          constFound = true;
    else if (myRegionNo == 6) // region = south
      for (int i = 0; i < mySouthCONST_size; i++)
        if (oneObject.objectConst == mySouthCONST[i])
          constFound = true;
    else // all constellations
      constFound = true;
}// end while
  myRefNo = objectNo;
  myReference = oneObject; // copy selected reference object in my reference object
  myTargetNo = objectNo;
  myTarget = oneObject; // copy selected target object in my target object
  setTargetRA_DEC();
updateLCD();
// change region
void changeregion(int dir)
if (dir == 1)
if ((myRegionNo + 1) < regionArraySize) {
myRegionNo = myRegionNo + 1;
else {
myRegionNo = 0;
else if (dir == -1)
if (myRegionNo > 0) {
myRegionNo = myRegionNo - 1;
else {
myRegionNo = regionArraySize - 1;
myTargetNo = 0; // reset target,when aera has changed
myConstellationNo = 0; // reset constellation,when aera has changed
updateLCD();
// set constellation
void changeConstellation(int dir)
if (dir == 1)
if ((myConstellationNo) < constStruct_size - 1) {
myConstellationNo = myConstellationNo + 1;
else {
else if (dir == -1)
if (myConstellationNo > 0) {
myConstellationNo = myConstellationNo - 1;
else {
myConstellationNo = constStruct_size - 1;
      if (myConstellationNo == myNorthCONST[i])
        constFound = true;
      if (myConstellationNo == mySpringCONST[i])
        constFound = true;
      if (myConstellationNo == mySummerCONST[i])
        constFound = true;
      if (myConstellationNo == myAutumnCONST[i])
        constFound = true;
      if (myConstellationNo == myWinterCONST[i])
        constFound = true;
      if (myConstellationNo == mySouthCONST[i])
        constFound = true;
    for (int i = 0; i < myAllCONST_size; i++)
      if (myConstellationNo == myAllCONST[i])
        constFound = true;
myTargetNo = 0; // reset target every time when constellation was changed
updateLCD();
// switch view between current position, diff position & target coordinates
void changeView(int dir)
lcd.clear();
myDisplayMode = myDisplayMode + dir;
if (myDisplayMode > 13) myDisplayMode = 11;
if (myDisplayMode < 11) myDisplayMode = 13;
// set LCD brightness
void changeLCDBacklight(int dir)
myLCDbacklight = myLCDbacklight + dir * 8;
if (myLCDbacklight > 255) myLCDbacklight = 0;
if (myLCDbacklight < 0) myLCDbacklight = 255;
// set LCD contrast
void changeLCDcontrast(int dir)
myLCDcontrast = myLCDcontrast + dir * 5;
if (myLCDcontrast > 255) myLCDcontrast = 0;
if (myLCDcontrast < 0) myLCDcontrast = 255;
void changeBTconnection(int dir)
if (btStatus == 0) // switch BT on if off
btStatus = 1;
statusLX200 = 1;
digitalWrite(BT_SWITCH, HIGH);
else if (btStatus != 0) // switch BT off
btStatus = 0;
statusLX200 = 0;
digitalWrite(BT_SWITCH, LOW);
updateLCD();
// \switching
// LX200 communication
// set the status of LX200 to control LCD etc
void updateLX200Status()
if (btStatus == 1)
// if frequent feedback from LX200 - last request > 4 sek
if ((millis() - lastLX200Message) > 4000)
statusLX200 = 1; // BT on - but no LX200 connection
statusLX200 = 2; // LX200 connected
// LX200 status changend - update lcd in relevant views (main menu & BT)
if (statusLX200 != statusLX200old && (myDisplayMode == 10 || myDisplayMode == 1))
  updateLCD();
  statusLX200old = statusLX200;
// called if a LX200 message was received
void receivedLX200message() // received
lastLX200Message = millis();
// read the bluetooth message and trigger functions according to message type
void readSendLX200()
if (Serial.available())
char message[14] = "";
byte i = 0;
while (Serial.available() > 0)
char a = Serial.read(); // Stores current byte
message[i] += a; // Append current byte to message String
delay(10);
i++;
  // all LX200 info from https://www.meade.com/support/TelescopeProtocol_2010-10.pdf
  // LX200 message :GR#
  // Get Telescope RA
  // Returns: HH:MM.T#  or  HH:MM:SS#Depending which precision is set for the telescope
  if (message[0] == ':' && message[1] == 'G' && message[2] == 'R' && message[3] == '#')
    receivedLX200message();
    sendLX200RA();
  // LX200 message :GD# or :RS#:GD# or :RM#:GD#
  // Get Telescope Declination.
  // Returns: sDD*MM# or sDD*MM’SS#Depending upon the current precision setting for the telescope.
  if (message[0] == ':' && message[1] == 'G' && message[2] == 'D' && message[3] == '#' ||
      message[4] == ':' && message[5] == 'G' && message[6] == 'D' && message[7] == '#')
    sendLX200DEC();
  // LX200 message :CM#
  // Synchronizes the telescope's position with the currently selected database object's coordinates.
  // Returns:LX200's - a "#" terminated string with the name of the object that was synced
  if (message[0] == ':' && message[1] == 'C' && message[2] == 'M')
    Serial.print("#");
  // LX200 message :SrHH:MM.T# or :SrHH:MM:SS#
  // Set target object RA to HH:MM.T or HH:MM:SS depending on the current precision setting.
  // Returns:0 – Invalid1 - Valid
  // output HHMM(S/6)
  if (message[0] == ':' && message[1] == 'S' && message[2] == 'r')
    setRAtoLX200message(message);
  // LX200 message :SdsDD*MM#
  // Set target object declination to sDD*MM or sDD*MM:SS depending on the current precision setting
  // Returns:1 - Dec Accepted0 – Dec invalid
  // output sHHMM
  if (message[0] == ':' && message[1] == 'S' && message[2] == 'd')
    setDECtoLX200message(message);
  //  Serial.print("BT message "); // for debugging
  //  Serial.println(message);
// set RA coordinates of placeholder externalobject to received LX200 message
void setRAtoLX200message(char message[10])
long(atoi(message + 3)) * 1000 + // HH // access at array different when using atoi - use address
long(atoi(message + 6)) * 10; // MM - Minuten passen noch nicht bei zweistelligen gibt es Fehler
if (message[8] == ':') // : or .
  externalObject.objectRA = externalObject.objectRA +
                            long(atoi(message + 9)) / 6; // SS/6
else if (message[8] == '.')
  externalObject.objectRA = externalObject.objectRA + atoi(message + 9); // T
Serial.println(); // leave this command, as otherwise no update on goto from LX200 source
// set DEC coordinates of placeholder externalobject to received LX200 message & update the (reference or target) object
void setDECtoLX200message(char message[9])
int sign;
if (message[3] == '-') sign = -1;
else sign = 1;
  sign * ( // s
    long(atoi(message + 4)) * 100 + // DD
    long(atoi(message + 7))); // MM
// assumption - first RA then DEC - then set target to external object
if (myDisplayMode == 3 || myDisplayMode == 11) // if view shows reference selection or current position then copy external object into reference object
  externalObject.objectTypeMagnitude = 168;
  myReference = externalObject; // copy external object to my reference object
  resetSensorTime();
else // in all other cases copy to target
  externalObject.objectTypeMagnitude = 182;
  myTarget = externalObject; // copy external object to my target object
  setTargetRA_DEC();
updateLCD();
// send current RA coordinate of telescope from SpotNik to LX200 server (e.g. Sky Safari)
void sendLX200RA()
byte s = (abs(myCurrentRAsec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator
byte m = (abs(myCurrentRAsec / 60)) % 60;
byte h = (abs(myCurrentRAsec / 3600)) % 24;
String posString = "";
if (h < 10) posString = "0";
posString = posString + String(h);
posString = posString + ":";
if (m < 10) posString = posString + "0";
posString = posString + String(m);
if (s < 10) posString = posString + "0";
posString = posString + String(s);
posString = posString + "#";
Serial.print(posString);
// send current DEC coordinate of telescope from SpotNik to LX200 server (e.g. Sky Safari)
void sendLX200DEC()
byte s = (abs(myCurrentDECsec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator
byte m = (abs(myCurrentDECsec / 60)) % 60;
byte h = (abs(myCurrentDECsec / 3600)) % 180;
if (myCurrentDECsec > 0) posString = "+";
else posString = "-";
posString = posString + "*";
// \LX200 communication
// EEPROM
// save relevant data for next startup (e.g. target no,LCD brightness)
void saveSettingsToEeprom()
// Serial.print(F("freeMemory()=")); //only used for testing
// Serial.println(freeMemory());
byte addr = EEPROM_VALUE_ADDR_SIGNATURE;
byte myTargetNoLowByte = lowByte(myTargetNo); // myTargetNo is of type int - transfer into two bytes
byte myTargetNoHighByte = highByte(myTargetNo);
byte myReferenceNoLowByte = lowByte(myRefNo); // myTargetNo is of type int - transfer into two bytes
byte myReferenceNoHighByte = highByte(myRefNo);
EEPROM.update(addr, EEPROM_SIGNATURE); // use update for longer eeprom life
addr += sizeof(EEPROM_SIGNATURE);
EEPROM.update(addr, myReferenceNoLowByte);
addr += sizeof(myReferenceNoLowByte);
EEPROM.update(addr, myReferenceNoHighByte);
addr += sizeof(myReferenceNoHighByte);
EEPROM.update(addr, myTargetNoLowByte);
addr += sizeof(myTargetNoLowByte);
EEPROM.update(addr, myTargetNoHighByte);
addr += sizeof(myTargetNoHighByte);
EEPROM.update(addr, myRegionNo);
addr += sizeof(myRegionNo);
EEPROM.update(addr, myConstellationNo);
addr += sizeof(myConstellationNo);
EEPROM.update(addr, myLCDbacklight);
addr += sizeof(myLCDbacklight);
EEPROM.update(addr, myLCDcontrast);
// load relevant data at startup (e.g. target no, LCD brightness)
void getSettingsFromEeprom()
byte addr = EEPROM_VALUE_ADDR_SIGNATURE, signature = 0, value, myReferenceNoLowByte, myReferenceNoHighByte, myTargetNoLowByte, myTargetNoHighByte; // myTargetNo is of type int,need to concatenated from two bytes
EEPROM.get(addr, signature);
if (signature != EEPROM_SIGNATURE) return; // maybe data from another sketch
EEPROM.get(addr, value);
myReferenceNoLowByte = value;
myReferenceNoHighByte = value;
if (value >= 0 && value <= 32767) myRefNo = word(myReferenceNoHighByte, myReferenceNoLowByte);
myTargetNoLowByte = value;
myTargetNoHighByte = value;
if (value >= 0 && value <= 32767) myTargetNo = word(myTargetNoHighByte, myTargetNoLowByte);
if (value >= 0 && value <= 255) myRegionNo = value;
if (value >= 0 && value <= 255) myConstellationNo = value;
if (value >= 0 && value <= 255) myLCDbacklight = value;
if (value >= 0 && value <= 255) myLCDcontrast = value;
// \EEPROM
}Use code tags to format code for the forum
/code]
here's the error code bar.........Arduino: 1.8.20 Hourly Build 2021/12/20 07:33 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09b\sketch_jul09b.ino:30:0:
\\admin-che\c$\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h: In function 'void setup()':
\\admin-che\c$\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:130:5: error: invalid declaration of member template in local class
     template< typename T > T &get( int idx, T &t ){
\\admin-che\c$\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:137:5: error: invalid declaration of member template in local class
     template< typename T > const T &put( int idx, const T &t ){
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09b\sketch_jul09b.ino:1496:3: warning: narrowing conversion of '129989' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09b\sketch_jul09b.ino:1496:3: warning: large integer implicitly truncated to unsigned type [-Woverflow]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09b\sketch_jul09b.ino:1496:3: warning: narrowing conversion of '189256' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09b\sketch_jul09b.ino:1496:3: warning: narrowing conversion of '106516' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09b\sketch_jul09b.ino:1496:3: warning: narrowing conversion of '109003' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09b\sketch_jul09b.ino:1496:3: warning: narrowing conversion of '128396' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09b\sketch_jul09b.ino:1496:3: warning: narrowing conversion of '113801' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09b\sketch_jul09b.ino:1496:3: warning: narrowing conversion of '157721' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
sketch_jul09b:1781:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:1800:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:1809:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:1821:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:1844:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:1860:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:1885:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:1903:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:1934:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:1953:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:1972:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:1998:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2004:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2010:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2017:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2026:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2034:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2040:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2048:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2056:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2064:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2079:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2089:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2098:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2105:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2120:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2131:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2137:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2151:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2194:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2213:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2357:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2405:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2437:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2469:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2491:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2518:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2528:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2534:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2540:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2684:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2710:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2819:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2828:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2836:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2845:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2870:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2895:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2901:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2967:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:2986:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:3015:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:3035:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:3061:3: error: a function-definition is not allowed here before '{' token
sketch_jul09b:3092:3: error: a function-definition is not allowed here before '{' token
In file included from C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09b\sketch_jul09b.ino:29:0:
\\admin-che\c$\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h: At global scope:
\\admin-che\c$\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:55:3: warning: 'setup()::LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)' used but never defined
   LiquidCrystal(uint8_t rs, uint8_t enable,
exit status 1
option enabled in File -> Preferences.
type or paste code here
`type or paste code here`
```Use code tags to format code for the forum
Hi Uk Helibob, I hope this is sufficient for you to have a look at? Thanks.Use code tags to format code for the forum
Looks like this got added to the sketch at the very beginning, almost like you pasted the sketch into the middle of an empty sketch.
< edit >
There is also this that has been added to the end of the sketch:
This is what it should look like:
  SpotNik - by Max Reinecke
  Created: May 2021
  SpotNik is software for a stepto system for telescopes
   This program is free software: you can redistribute it and/or modify
   it under the terms of the GNU General Public License as published by
   the Free Software Foundation, either version 3 of the License, or
   (at your option) any later version.
   This program is distributed in the hope that it will be useful,
   but WITHOUT ANY WARRANTY; without even the implied warranty of
   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
   GNU General Public License for more details.
   You should have received a copy of the GNU General Public License
   along with this program.  If not, see <http://www.gnu.org/licenses/>.
#define VERSION 2.0
// to be changed by user according to EQ mount - see instructions
// total numbers of impulse of the rotary encoder of RA axis when turned 24h
#define IMPULSE24HRA 2772 // 6h - 690 Impulse --> 24h - 4 * 693 = 2772 / ~ 1:138
//  total numbers of impulse of the rotary encoder of DEC axis when turned 360° // +/- for correct direction
#define IMPULSE360DEGDEC 1784  // 90° - 446 Impulse --> 360° - 4 * 446 = 1784 / ~ 1:88
#include <LiquidCrystal.h> // I2C LCD arbeitet nicht vernünftig mit Rotary Encoder zusammen,daher normales nehmen
#include <EEPROM.h>
//#include <MemoryFree.h> // only used for testing
// LCD
#define LCD_CONTRAST_PIN 11 //  LCD contrast - V0 // use high frequency PWM to avoid flickering (Leonardo,Micro,Yún 3 and 11: 980 Hz // Mega pins 4 and 13: 980 Hz)
#define LCD_BACKLIGHT_PIN 10 // LCD backlight - LCD A
// EEPROM
#define EEPROM_SIGNATURE 117 // value 0-255 (byte) - signature/mark to recognize if the value fits to this sketch
#define EEPROM_VALUE_ADDR_SIGNATURE 0
// rotary enoder HMI
#define ROTARY_SW 3 // use interrupt pin - digital pins for interrupts on Micro,Leonardo and other 32u4 based 0,1,2,3,7
#define ROTARY_DT 4
#define ROTARY_CLK 5
// Sensor RA
#define SENS_RA_DT A0 // analog pins used as UNO has not that many digital pins
#define SENS_RA_CLK A1
// Sensor DEC
#define SENS_DEC_DT A2
#define SENS_DEC_CLK A3
// LX200 connection
#define BT_SWITCH 2
// lookup table with names of deep sky objects
struct DSONameStruct
  char objectName[9];
const struct DSONameStruct DSO_NAME_PROGMEM[202] PROGMEM =
  {"3C273"},
  {"B"},
  {"IC"},
  {"M"},
  {"NGC"},
  {"#a"},
  {"#aA"},
  {"#aB"},
  {"#b"},
  {"#c"},
  {"#d"},
  {"#e"},
  {"#e1"},
  {"#e2"},
  {"#g"},
  {"#h"},
  {"#i"},
  {"#j"},
  {"#k"},
  {"#l"},
  {"#m"},
  {"#n"},
  {"#o"},
  {"#p"},
  {"#q"},
  {"#r"},
  {"#s"},
  {"#t"},
  {"#u"},
  {"#w"},
  {"#x"},
  {"#z"},
  {"AC"},
  {"Achernar"},
  {"Acrab"},
  {"Acrux"},
  {"Adhara"},
  {"Agena"},
  {"Alamak"},
  {"Aldebara"},
  {"Alderami"},
  {"AlDhanab"},
  {"Algenib"},
  {"Algieba"},
  {"Algol"},
  {"Alhena"},
  {"Alioth"},
  {"Alkaid"},
  {"AlNair"},
  {"Alnilam"},
  {"Alnitak"},
  {"Alphard"},
  {"Alphecca"},
  {"Alpherat"},
  {"Alsuhail"},
  {"Altair"},
  {"Aludra"},
  {"Ankaa"},
  {"Antares"},
  {"AQ"},
  {"Arcturus"},
  {"Arneb"},
  {"Aspidisk"},
  {"Atria"},
  {"Avior"},
  {"AW"},
  {"AX"},
  {"BD"},
  {"Becrux"},
  {"Bellatri"},
  {"Betelgeu"},
  {"BF"},
  {"BG"},
  {"BL"},
  {"BM"},
  {"BX"},
  {"Canopus"},
  {"Capella"},
  {"Caph"},
  {"Castor"},
  {"Cih"},
  {"CY"},
  {"Deneb"},
  {"DenebKai"},
  {"Denebola"},
  {"Diphda"},
  {"DR"},
  {"Dschubba"},
  {"Dubhe"},
  {"EL"},
  {"ElNath"},
  {"Eltanin"},
  {"Enif"},
  {"FO"},
  {"Fomalhau"},
  {"FU"},
  {"Gacrux"},
  {"Gemma"},
  {"Gienah"},
  {"Girtab"},
  {"GK"},
  {"GY"},
  {"H"},
  {"Hadar"},
  {"Hamal"},
  {"Han"},
  {"HD"},
  {"HJ"},
  {"HK"},
  {"HN"},
  {"Izar"},
  {"JC"},
  {"KausAust"},
  {"Kochab"},
  {"KooShe"},
  {"Markab"},
  {"Menkalin"},
  {"Menkar"},
  {"Menkent"},
  {"Merak"},
  {"Miaplaci"},
  {"Mimosa"},
  {"Mintaka"},
  {"Mirach"},
  {"Mirfak"},
  {"Mirzam"},
  {"Mizar"},
  {"Naos"},
  {"NQ"},
  {"NSV"},
  {"Nunki"},
  {"O#F"},
  {"Peacock"},
  {"Phecda"},
  {"Polaris"},
  {"Pollux"},
  {"Procyon"},
  {"PZ6"},
  {"R"},
  {"RasAlhag"},
  {"Regulus"},
  {"Rigel"},
  {"RigilKen"},
  {"RR"},
  {"RS"},
  {"RT"},
  {"RU"},
  {"RV"},
  {"RX"},
  {"RY"},
  {"RZ"},
  {"S"},
  {"S605"},
  {"Sabik"},
  {"Sadr"},
  {"Saiph"},
  {"SAO"},
  {"Sargas"},
  {"Scheat"},
  {"Schedar"},
  {"Shaula"},
  {"SHJ"},
  {"Sirius"},
  {"Spica"},
  {"SS"},
  {"ST"},
  {"SU"},
  {"SV"},
  {"SY"},
  {"SZ"},
  {"T"},
  {"TT"},
  {"TU"},
  {"Tureis"},
  {"TW"},
  {"TX"},
  {"U"},
  {"UU"},
  {"UV"},
  {"UX"},
  {"UY"},
  {"V"},
  {"Vega"},
  {"VW"},
  {"VX"},
  {"VY"},
  {"W"},
  {"Wei"},
  {"Wezen"},
  {"WO"},
  {"WW"},
  {"WX"},
  {"WZ"},
  {"X"},
  {"XS"},
  {"XX"},
  {"Y"},
  {"Z"},
  {"Zozma"},
  {"β648"},
  {"#F"},
  {"extern"}
// data of deep sky objects
struct DSOstruct
  byte objectPreFixNameNo; // number of name for lookup table
  unsigned int objectNumber; // if name contains a number
  byte objectTypeMagnitude; // object type & magnitude coded in one byte
  byte objectConst; // constellation of object
  unsigned int objectRA; //HHMM(SS/6)
  int objectDEC; //sHHMM
DSOstruct myTarget; // object to store data of selected target
DSOstruct myReference; // object to store data of selected target
const unsigned int DSO_PROGMEM_size = 1204;
const struct DSOstruct DSO_PROGMEM[DSO_PROGMEM_size] PROGMEM =
  {1, 0, 27, 86, 12291, 203},
  {2, 33, 42, 60, 5409, -228},
  {2, 65, 42, 77, 18027, -2750},
  {2, 86, 42, 59, 17196, -2642},
  {3, 342, 54, 11, 3468, 6806},
  {3, 405, 66, 8, 5165, 3421},
  {3, 410, 64, 8, 5227, 3325},
  {3, 434, 67, 60, 5410, -227},
  {3, 1396, 74, 16, 21391, 5730},
  {3, 4406, 95, 50, 14224, -4409},
  {3, 5067, 64, 31, 20508, 4421},
  {3, 5146, 80, 31, 21534, 4716},
  {4, 1, 106, 78, 5345, 2201},
  {4, 2, 119, 5, 21335, -49},
  {4, 3, 118, 30, 13422, 2823},
  {4, 4, 117, 72, 16236, -2632},
  {4, 5, 118, 74, 15186, 205},
  {4, 6, 130, 72, 17403, -3215},
  {4, 7, 129, 72, 17539, -3448},
  {4, 8, 75, 77, 18037, -2423},
  {4, 9, 120, 59, 17192, -1831},
  {4, 10, 119, 59, 16571, -406},
  {4, 11, 132, 73, 18511, -616},
  {4, 12, 118, 59, 16472, -157},
  {4, 13, 118, 40, 16417, 3628},
  {4, 14, 120, 59, 17376, -315},
  {4, 15, 118, 62, 21300, 1210},
  {4, 16, 76, 74, 18188, -1347},
  {4, 17, 76, 77, 18208, -1611},
  {4, 18, 133, 77, 18199, -1708},
  {4, 19, 119, 59, 17026, -2616},
  {4, 20, 76, 77, 18027, -2258},
  {4, 21, 132, 77, 18042, -2229},
  {4, 22, 117, 77, 18364, -2354},
  {4, 23, 132, 77, 17571, -1859},
  {4, 24, 129, 77, 18266, -1823},
  {4, 25, 131, 77, 18318, -1907},
  {4, 26, 134, 73, 18452, -924},
  {4, 27, 91, 88, 19596, 2243},
  {4, 28, 119, 77, 18245, -2452},
  {4, 29, 133, 31, 20239, 3832},
  {4, 30, 119, 12, 21404, -2311},
  {4, 31, 45, 1, 427, 4116},
  {4, 32, 50, 1, 427, 4052},
  {4, 33, 48, 81, 1339, 3039},
  {4, 34, 131, 63, 2421, 4247},
  {4, 35, 131, 38, 6089, 2421},
  {4, 36, 132, 8, 5363, 3408},
  {4, 37, 132, 8, 5523, 3233},
  {4, 38, 132, 8, 5287, 3551},
  {4, 39, 131, 31, 21322, 4826},
  {4, 40, 149, 83, 12219, 5806},
  {4, 41, 131, 20, 6460, -2045},
  {4, 42, 74, 60, 5353, -523},
  {4, 43, 63, 60, 5355, -516},
  {4, 44, 129, 22, 8400, 1940},
  {4, 45, 71, 78, 3470, 2407},
  {4, 46, 132, 68, 7418, -1449},
  {4, 47, 130, 68, 7366, -1429},
  {4, 48, 132, 42, 8137, -545},
  {4, 49, 50, 86, 12298, 800},
  {4, 50, 132, 55, 7025, -823},
  {4, 51, 50, 30, 13299, 4712},
  {4, 52, 133, 14, 23242, 6135},
  {4, 53, 120, 24, 13129, 1810},
  {4, 54, 120, 77, 18551, -3029},
  {4, 55, 118, 77, 19400, -3058},
  {4, 56, 120, 52, 19166, 3011},
  {4, 57, 93, 52, 18536, 3302},
  {4, 58, 52, 86, 12377, 1149},
  {4, 59, 52, 86, 12420, 1139},
  {4, 60, 51, 86, 12437, 1133},
  {4, 61, 52, 86, 12219, 428},
  {4, 62, 118, 59, 17012, -3007},
  {4, 63, 51, 30, 13158, 4202},
  {4, 64, 51, 24, 12567, 2141},
  {4, 65, 51, 46, 11189, 1305},
  {4, 66, 51, 46, 11202, 1300},
  {4, 67, 133, 22, 8508, 1149},
  {4, 68, 119, 42, 12395, -2645},
  {4, 69, 120, 77, 18314, -3221},
  {4, 70, 120, 77, 18432, -3218},
  {4, 71, 120, 76, 19538, 1847},
  {4, 72, 121, 5, 20535, -1232},
  {4, 73, 136, 5, 20590, -1238},
  {4, 74, 51, 67, 1367, 1547},
  {4, 75, 121, 77, 20061, -2155},
  {4, 76, 94, 63, 1423, 5135},
  {4, 77, 51, 17, 2427, -1},
  {4, 78, 64, 60, 5468, 5},
  {4, 79, 120, 47, 5242, -2431},
  {4, 80, 119, 72, 16170, -2259},
  {4, 81, 49, 83, 9556, 6904},
  {4, 82, 50, 83, 9559, 6941},
  {4, 83, 50, 42, 13370, -2952},
  {4, 84, 51, 86, 12251, 1253},
  {4, 85, 51, 24, 12254, 1811},
  {4, 86, 51, 86, 12262, 1257},
  {4, 87, 51, 86, 12308, 1223},
  {4, 88, 52, 24, 12320, 1425},
  {4, 89, 52, 86, 12357, 1233},
  {4, 90, 52, 86, 12368, 1310},
  {4, 91, 52, 24, 12354, 1430},
  {4, 92, 119, 40, 17171, 4308},
  {4, 93, 132, 68, 7445, -2351},
  {4, 94, 50, 30, 12509, 4107},
  {4, 95, 52, 46, 10440, 1142},
  {4, 96, 51, 46, 10468, 1149},
  {4, 97, 95, 83, 11148, 5501},
  {4, 98, 52, 24, 12138, 1454},
  {4, 99, 52, 24, 12188, 1425},
  {4, 100, 51, 24, 12229, 1549},
  {4, 101, 50, 83, 14032, 5421},
  {4, 102, 52, 34, 15065, 5546},
  {4, 103, 133, 14, 1334, 6039},
  {4, 104, 50, 86, 12400, -1137},
  {4, 105, 51, 46, 10478, 1235},
  {4, 106, 50, 30, 12190, 4718},
  {4, 107, 120, 59, 16325, -1303},
  {4, 108, 52, 83, 11115, 5540},
  {4, 109, 52, 83, 11576, 5322},
  {4, 110, 50, 1, 404, 4141},
  {5, 40, 94, 16, 130, 7231},
  {5, 55, 50, 71, 149, -3911},
  {5, 129, 133, 14, 300, 6013},
  {5, 136, 137, 14, 315, 6131},
  {5, 147, 52, 14, 332, 4830},
  {5, 157, 52, 17, 348, -824},
  {5, 185, 51, 14, 390, 4820},
  {5, 188, 134, 16, 475, 8514},
  {5, 210, 52, 17, 406, -1352},
  {5, 225, 133, 14, 436, 6146},
  {5, 246, 94, 17, 471, -1152},
  {5, 247, 51, 17, 471, -2046},
  {5, 253, 49, 71, 476, -2518},
  {5, 278, 52, 14, 521, 4733},
  {5, 281, 77, 14, 530, 5637},
  {5, 288, 120, 71, 528, -2635},
  {5, 300, 50, 71, 549, -3741},
  {5, 381, 135, 14, 1084, 6135},
  {5, 404, 52, 1, 1094, 3543},
  {5, 436, 135, 14, 1160, 5849},
  {5, 457, 132, 14, 1195, 5817},
  {5, 488, 52, 67, 1218, 515},
  {5, 524, 52, 67, 1248, 932},
  {5, 559, 136, 14, 1295, 6319},
  {5, 584, 52, 17, 1313, -652},
  {5, 596, 52, 17, 1329, -702},
  {5, 613, 52, 71, 1343, -2925},
  {5, 615, 53, 17, 1351, -720},
  {5, 637, 134, 14, 1431, 6402},
  {5, 654, 133, 14, 1440, 6153},
  {5, 659, 134, 14, 1444, 6040},
  {5, 663, 133, 14, 1460, 6115},
  {5, 672, 52, 81, 1479, 2726},
  {5, 720, 52, 17, 1530, -1344},
  {5, 752, 132, 1, 1577, 3740},
  {5, 772, 52, 7, 1593, 1900},
  {5, 779, 53, 17, 1597, -558},
  {5, 869, 131, 63, 2191, 5708},
  {5, 884, 132, 63, 2225, 5709},
  {5, 891, 52, 1, 2226, 4221},
  {5, 908, 52, 17, 2231, -2114},
  {5, 925, 52, 81, 2273, 3335},
  {5, 936, 52, 17, 2276, -109},
  {5, 986, 52, 37, 2336, -3903},
  {5, 1022, 53, 17, 2385, -641},
  {5, 1023, 51, 63, 2404, 3904},
  {5, 1027, 133, 14, 2426, 6136},
  {5, 1052, 52, 17, 2411, -815},
  {5, 1055, 52, 17, 2418, 27},
  {5, 1084, 52, 36, 2460, -735},
  {5, 1097, 52, 37, 2463, -3017},
  {5, 1232, 52, 36, 3098, -2035},
  {5, 1245, 134, 63, 3147, 4714},
  {5, 1261, 120, 41, 3123, -5513},
  {5, 1275, 53, 63, 3198, 4131},
  {5, 1291, 51, 36, 3173, -4106},
  {5, 1300, 52, 36, 3197, -1925},
  {5, 1316, 51, 37, 3227, -3713},
  {5, 1325, 53, 36, 3244, -2133},
  {5, 1332, 52, 36, 3263, -2120},
  {5, 1342, 133, 63, 3317, 3722},
  {5, 1360, 93, 37, 3332, -2552},
  {5, 1365, 52, 37, 3336, -3608},
  {5, 1374, 53, 37, 3353, -3514},
  {5, 1380, 54, 37, 3368, -3444},
  {5, 1398, 52, 37, 3389, -2620},
  {5, 1399, 52, 37, 3385, -3527},
  {5, 1407, 52, 36, 3402, -1835},
  {5, 1433, 52, 41, 3420, -4713},
  {5, 1444, 133, 63, 3494, 5240},
  {5, 1491, 70, 63, 4032, 5119},
  {5, 1499, 61, 63, 4032, 3622},
  {5, 1501, 96, 11, 4070, 6055},
  {5, 1502, 133, 11, 4078, 6220},
  {5, 1513, 134, 63, 4099, 4931},
  {5, 1514, 94, 78, 4093, 3047},
  {5, 1528, 132, 63, 4153, 5113},
  {5, 1532, 52, 36, 4121, -3252},
  {5, 1535, 93, 36, 4143, -1244},
  {5, 1545, 132, 63, 4209, 5015},
  {5, 1549, 52, 33, 4158, -5536},
  {5, 1566, 52, 33, 4200, -5456},
  {5, 1647, 132, 78, 4459, 1906},
  {5, 1664, 134, 8, 4511, 4341},
  {5, 1672, 52, 33, 4457, -5915},
  {5, 1788, 70, 60, 5069, -320},
  {5, 1792, 52, 23, 5052, -3759},
  {5, 1808, 52, 23, 5077, -3731},
  {5, 1817, 134, 78, 5124, 1641},
  {5, 1851, 119, 23, 5141, -4003},
  {5, 1857, 133, 8, 5201, 3921},
  {5, 1907, 134, 8, 5281, 3520},
  {5, 1909, 70, 36, 5045, -716},
  {5, 1931, 80, 8, 5314, 3415},
  {5, 1961, 53, 11, 5421, 6923},
  {5, 1964, 52, 47, 5334, -2157},
  {5, 1973, 63, 60, 5351, -444},
  {5, 1980, 73, 60, 5354, -555},
  {5, 1999, 70, 60, 5364, -643},
  {5, 2022, 95, 60, 5421, 905},
  {5, 2024, 70, 60, 5417, -151},
  {5, 2126, 136, 8, 6025, 4952},
  {5, 2129, 133, 38, 6007, 2319},
  {5, 2158, 135, 38, 6074, 2406},
  {5, 2169, 132, 60, 6084, 1358},
  {5, 2175, 77, 60, 6096, 2029},
  {5, 2185, 70, 55, 6110, -614},
  {5, 2186, 135, 60, 6121, 528},
  {5, 2194, 135, 60, 6138, 1248},
  {5, 2204, 135, 20, 6155, -1840},
  {5, 2207, 52, 20, 6164, -2122},
  {5, 2215, 134, 55, 6208, -717},
  {5, 2232, 130, 55, 6280, -451},
  {5, 2237, 76, 55, 6309, 503},
  {5, 2238, 62, 55, 6307, 501},
  {5, 2239, 131, 55, 6319, 457},
  {5, 2245, 70, 55, 6327, 1009},
  {5, 2251, 133, 55, 6346, 822},
  {5, 2261, 70, 55, 6392, 845},
  {5, 2264, 74, 55, 6410, 954},
  {5, 2266, 136, 38, 6433, 2658},
  {5, 2281, 131, 8, 6483, 4105},
  {5, 2286, 134, 55, 6477, -309},
  {5, 2300, 53, 16, 7323, 8543},
  {5, 2301, 132, 55, 6518, 28},
  {5, 2304, 136, 38, 6552, 1759},
  {5, 2311, 136, 55, 6578, -437},
  {5, 2324, 134, 55, 7041, 103},
  {5, 2335, 133, 55, 7068, -1002},
  {5, 2343, 133, 55, 7081, -1037},
  {5, 2346, 96, 55, 7094, -48},
  {5, 2353, 133, 55, 7145, -1016},
  {5, 2354, 133, 20, 7143, -2542},
  {5, 2355, 136, 38, 7170, 1345},
  {5, 2359, 70, 20, 7185, -1314},
  {5, 2360, 133, 20, 7177, -1538},
  {5, 2362, 130, 20, 7187, -2457},
  {5, 2371, 95, 38, 7256, 2929},
  {5, 2372, 95, 38, 7256, 2930},
  {5, 2383, 134, 20, 7247, -2057},
  {5, 2384, 133, 20, 7252, -2101},
  {5, 2392, 93, 38, 7292, 2055},
  {5, 2395, 134, 38, 7272, 1337},
  {5, 2403, 51, 11, 7368, 6536},
  {5, 2419, 122, 51, 7381, 3853},
  {5, 2420, 134, 38, 7384, 2134},
  {5, 2421, 134, 68, 7362, -2037},
  {5, 2423, 133, 68, 7371, -1352},
  {5, 2438, 95, 68, 7418, -1444},
  {5, 2439, 133, 68, 7408, -3142},
  {5, 2440, 95, 68, 7419, -1813},
  {5, 2467, 77, 68, 7525, -2626},
  {5, 2477, 132, 68, 7522, -3832},
  {5, 2479, 136, 68, 7551, -1742},
  {5, 2482, 133, 68, 7552, -2415},
  {5, 2489, 134, 68, 7563, -3004},
  {5, 2506, 134, 55, 8000, -1046},
  {5, 2509, 135, 68, 8008, -1903},
  {5, 2527, 133, 68, 8050, -2809},
  {5, 2539, 133, 68, 8106, -1249},
  {5, 2547, 131, 85, 8102, -4912},
  {5, 2567, 133, 68, 8185, -3039},
  {5, 2571, 133, 68, 8189, -2945},
  {5, 2613, 52, 69, 8334, -2258},
  {5, 2627, 134, 69, 8372, -2957},
  {5, 2655, 52, 11, 8556, 7813},
  {5, 2681, 52, 83, 8535, 5119},
  {5, 2683, 52, 51, 8527, 3325},
  {5, 2742, 53, 83, 9076, 6029},
  {5, 2768, 52, 83, 9116, 6002},
  {5, 2775, 52, 22, 9103, 702},
  {5, 2782, 53, 51, 9141, 4007},
  {5, 2784, 52, 42, 9123, -2410},
  {5, 2787, 52, 83, 9193, 6912},
  {5, 2811, 53, 42, 9162, -1619},
  {5, 2835, 52, 42, 9179, -2221},
  {5, 2841, 51, 83, 9220, 5059},
  {5, 2859, 52, 49, 9243, 3431},
  {5, 2867, 94, 13, 9214, -5819},
  {5, 2903, 51, 46, 9322, 2130},
  {5, 2950, 52, 83, 9426, 5851},
  {5, 2964, 53, 46, 9429, 3151},
  {5, 2974, 52, 75, 9426, -342},
  {5, 2976, 52, 83, 9472, 6755},
  {5, 2985, 52, 83, 9504, 7217},
  {5, 2997, 51, 2, 9456, -3111},
  {5, 3077, 52, 83, 10033, 6844},
  {5, 3079, 52, 83, 10020, 5541},
  {5, 3109, 52, 42, 10031, -2610},
  {5, 3115, 51, 75, 10052, -743},
  {5, 3132, 92, 85, 10070, -4026},
  {5, 3147, 52, 34, 10169, 7324},
  {5, 3166, 52, 75, 10138, 326},
  {5, 3169, 52, 75, 10142, 328},
  {5, 3184, 52, 83, 10183, 4125},
  {5, 3190, 53, 46, 10181, 2150},
  {5, 3193, 52, 46, 10184, 2154},
  {5, 3198, 52, 83, 10199, 4533},
  {5, 3201, 119, 85, 10176, -4625},
  {5, 3226, 53, 46, 10234, 1954},
  {5, 3227, 52, 46, 10235, 1952},
  {5, 3242, 93, 42, 10248, -1839},
  {5, 3245, 52, 49, 10273, 2830},
  {5, 3277, 53, 49, 10329, 2831},
  {5, 3294, 53, 49, 10363, 3719},
  {5, 3310, 52, 83, 10388, 5330},
  {5, 3344, 52, 49, 10435, 2455},
  {5, 3359, 52, 83, 10466, 6313},
  {5, 3372, 59, 13, 10451, -5952},
  {5, 3377, 52, 46, 10477, 1359},
  {5, 3384, 52, 46, 10483, 1238},
  {5, 3395, 54, 49, 10498, 3259},
  {5, 3412, 52, 46, 10509, 1325},
  {5, 3414, 53, 49, 10513, 2758},
  {5, 3432, 53, 49, 10525, 3637},
  {5, 3486, 52, 49, 11004, 2859},
  {5, 3489, 52, 46, 11003, 1354},
  {5, 3504, 53, 49, 11032, 2758},
  {5, 3521, 51, 46, 11058, -2},
  {5, 3532, 129, 13, 11052, -5844},
  {5, 3593, 52, 46, 11146, 1249},
  {5, 3607, 52, 46, 11169, 1803},
  {5, 3608, 52, 46, 11170, 1809},
  {5, 3610, 52, 83, 11184, 5847},
  {5, 3613, 52, 83, 11186, 5800},
  {5, 3619, 53, 83, 11194, 5745},
  {5, 3621, 52, 42, 11183, -3249},
  {5, 3626, 53, 46, 11201, 1821},
  {5, 3628, 52, 46, 11203, 1335},
  {5, 3631, 52, 83, 11210, 5310},
  {5, 3640, 52, 46, 11211, 314},
  {5, 3655, 53, 46, 11229, 1635},
  {5, 3665, 52, 83, 11247, 3846},
  {5, 3675, 52, 83, 11261, 4335},
  {5, 3686, 53, 46, 11277, 1713},
  {5, 3717, 53, 42, 11315, -3019},
  {5, 3718, 52, 83, 11326, 5304},
  {5, 3726, 52, 83, 11333, 4702},
  {5, 3729, 53, 83, 11338, 5308},
  {5, 3810, 52, 46, 11410, 1128},
  {5, 3813, 53, 83, 11413, 3633},
  {5, 3877, 53, 83, 11461, 4730},
  {5, 3893, 52, 83, 11486, 4843},
  {5, 3898, 52, 83, 11493, 5605},
  {5, 3900, 53, 46, 11492, 2701},
  {5, 3912, 54, 46, 11501, 2629},
  {5, 3918, 92, 15, 11503, -5711},
  {5, 3923, 52, 42, 11510, -2848},
  {5, 3938, 52, 83, 11528, 4407},
  {5, 3941, 52, 83, 11529, 3659},
  {5, 3945, 52, 83, 11532, 6040},
  {5, 3949, 53, 83, 11537, 4752},
  {5, 3953, 52, 83, 11538, 5219},
  {5, 3962, 52, 27, 11547, -1359},
  {5, 3982, 53, 83, 11565, 5507},
  {5, 3998, 52, 83, 11579, 5527},
  {5, 4013, 53, 83, 11585, 4357},
  {5, 4026, 52, 83, 11594, 5058},
  {5, 4027, 53, 29, 11595, -1916},
  {5, 4030, 52, 86, 12004, -106},
  {5, 4036, 52, 83, 12015, 6154},
  {5, 4038, 52, 29, 12019, -1852},
  {5, 4039, 52, 29, 12019, -1853},
  {5, 4041, 53, 83, 12022, 6208},
  {5, 4051, 52, 83, 12032, 4432},
  {5, 4085, 54, 83, 12054, 5021},
  {5, 4088, 52, 83, 12056, 5032},
  {5, 4096, 52, 83, 12060, 4729},
  {5, 4102, 53, 83, 12064, 5243},
  {5, 4105, 52, 42, 12067, -2946},
  {5, 4111, 52, 30, 12070, 4304},
  {5, 4125, 52, 34, 12081, 6510},
  {5, 4143, 52, 30, 12096, 4232},
  {5, 4147, 122, 24, 12101, 1833},
  {5, 4150, 53, 24, 12106, 3024},
  {5, 4151, 52, 30, 12105, 3924},
  {5, 4179, 53, 86, 12129, 118},
  {5, 4203, 52, 24, 12151, 3312},
  {5, 4214, 52, 30, 12156, 3620},
  {5, 4216, 52, 86, 12159, 1309},
  {5, 4236, 52, 34, 12167, 6928},
  {5, 4244, 52, 30, 12175, 3748},
  {5, 4245, 53, 24, 12176, 2936},
  {5, 4251, 52, 24, 12181, 2810},
  {5, 4261, 52, 86, 12194, 549},
  {5, 4273, 53, 86, 12199, 521},
  {5, 4274, 52, 24, 12198, 2937},
  {5, 4278, 52, 24, 12201, 2917},
  {5, 4281, 53, 86, 12204, 523},
  {5, 4293, 52, 24, 12212, 1823},
  {5, 4314, 52, 24, 12225, 2954},
  {5, 4346, 53, 30, 12235, 4700},
  {5, 4350, 53, 24, 12240, 1642},
  {5, 4361, 94, 29, 12245, -1847},
  {5, 4365, 52, 86, 12245, 719},
  {5, 4371, 52, 86, 12249, 1142},
  {5, 4388, 53, 86, 12258, 1240},
  {5, 4394, 52, 24, 12259, 1813},
  {5, 4395, 52, 30, 12258, 3333},
  {5, 4414, 52, 24, 12265, 3113},
  {5, 4419, 53, 24, 12269, 1503},
  {5, 4429, 52, 86, 12274, 1106},
  {5, 4435, 52, 86, 12277, 1305},
  {5, 4438, 52, 86, 12278, 1300},
  {5, 4442, 52, 86, 12281, 948},
  {5, 4448, 53, 24, 12283, 2837},
  {5, 4449, 52, 30, 12282, 4406},
  {5, 4450, 52, 24, 12285, 1705},
  {5, 4459, 52, 24, 12290, 1359},
  {5, 4473, 52, 24, 12298, 1326},
  {5, 4477, 52, 24, 12300, 1338},
  {5, 4478, 53, 86, 12303, 1220},
  {5, 4485, 53, 30, 12305, 4142},
  {5, 4490, 52, 30, 12306, 4139},
  {5, 4494, 52, 24, 12314, 2546},
  {5, 4517, 52, 86, 12328, 7},
  {5, 4526, 52, 86, 12340, 742},
  {5, 4527, 52, 86, 12341, 239},
  {5, 4535, 52, 86, 12343, 812},
  {5, 4536, 52, 86, 12344, 211},
  {5, 4546, 52, 86, 12355, -348},
  {5, 4550, 53, 86, 12355, 1213},
  {5, 4559, 52, 24, 12360, 2758},
  {5, 4565, 52, 24, 12363, 2559},
  {5, 4567, 53, 86, 12365, 1115},
  {5, 4568, 52, 86, 12366, 1114},
  {5, 4570, 52, 86, 12369, 715},
  {5, 4596, 52, 86, 12399, 1011},
  {5, 4605, 52, 83, 12400, 6136},
  {5, 4618, 52, 30, 12416, 4109},
  {5, 4631, 51, 30, 12421, 3232},
  {5, 4636, 52, 86, 12428, 241},
  {5, 4643, 52, 86, 12433, 159},
  {5, 4654, 52, 86, 12439, 1308},
  {5, 4656, 52, 30, 12440, 3210},
  {5, 4660, 53, 86, 12445, 1111},
  {5, 4665, 52, 86, 12451, 303},
  {5, 4666, 52, 86, 12451, -28},
  {5, 4689, 52, 24, 12478, 1346},
  {5, 4697, 51, 86, 12486, -548},
  {5, 4698, 52, 86, 12484, 829},
  {5, 4699, 52, 86, 12490, -840},
  {5, 4725, 51, 24, 12504, 2530},
  {5, 4753, 52, 86, 12524, -112},
  {5, 4754, 52, 86, 12523, 1119},
  {5, 4762, 52, 86, 12529, 1114},
  {5, 4781, 53, 86, 12544, -1032},
  {5, 4800, 53, 30, 12546, 4632},
  {5, 4845, 53, 86, 12580, 135},
  {5, 4856, 52, 86, 12594, -1503},
  {5, 4866, 53, 86, 12595, 1410},
  {5, 4889, 53, 24, 13001, 2759},
  {5, 4900, 53, 86, 13007, 230},
  {5, 4902, 52, 86, 13010, -1431},
  {5, 4945, 51, 15, 13054, -4928},
  {5, 4958, 52, 86, 13058, -801},
  {5, 4995, 53, 86, 13097, -750},
  {5, 5005, 52, 30, 13109, 3703},
  {5, 5033, 52, 30, 13135, 3636},
  {5, 5053, 122, 24, 13165, 1742},
  {5, 5054, 52, 86, 13170, -1638},
  {5, 5068, 52, 86, 13189, -2102},
  {5, 5078, 53, 42, 13198, -2725},
  {5, 5102, 52, 15, 13220, -3638},
  {5, 5128, 49, 15, 13255, -4301},
  {5, 5139, 116, 15, 13268, -4729},
  {5, 5247, 52, 86, 13380, -1753},
  {5, 5248, 52, 9, 13375, 853},
  {5, 5273, 53, 30, 13421, 3539},
  {5, 5286, 119, 15, 13464, -5122},
  {5, 5322, 52, 83, 13492, 6011},
  {5, 5350, 53, 30, 13534, 4022},
  {5, 5353, 53, 30, 13534, 4017},
  {5, 5354, 53, 30, 13534, 4018},
  {5, 5363, 52, 86, 13561, 515},
  {5, 5364, 52, 86, 13562, 501},
  {5, 5371, 52, 30, 13557, 4028},
  {5, 5427, 53, 86, 14034, -602},
  {5, 5466, 121, 9, 14055, 2832},
  {5, 5473, 53, 83, 14047, 5454},
  {5, 5474, 52, 83, 14050, 5340},
  {5, 5557, 53, 9, 14184, 3630},
  {5, 5566, 52, 86, 14203, 356},
  {5, 5576, 53, 86, 14211, 316},
  {5, 5631, 53, 83, 14266, 5635},
  {5, 5634, 122, 86, 14296, -559},
  {5, 5643, 52, 50, 14327, -4411},
  {5, 5676, 53, 9, 14328, 4927},
  {5, 5689, 53, 9, 14355, 4844},
  {5, 5694, 122, 42, 14396, -2632},
  {5, 5746, 52, 86, 14449, 157},
  {5, 5813, 52, 86, 15012, 142},
  {5, 5822, 133, 50, 15044, -5424},
  {5, 5823, 134, 19, 15055, -5536},
  {5, 5824, 121, 50, 15040, -3304},
  {5, 5846, 52, 86, 15065, 136},
  {5, 5850, 52, 86, 15071, 133},
  {5, 5897, 120, 48, 15174, -2101},
  {5, 5907, 52, 34, 15159, 5620},
  {5, 5927, 120, 50, 15280, -5040},
  {5, 5946, 120, 57, 15355, -5040},
  {5, 5982, 53, 34, 15387, 5921},
  {5, 5986, 120, 50, 15461, -3747},
  {5, 6067, 132, 57, 16132, -5413},
  {5, 6118, 53, 74, 16218, -217},
  {5, 6124, 132, 72, 16253, -4039},
  {5, 6134, 133, 57, 16278, -4909},
  {5, 6144, 121, 72, 16272, -2601},
  {5, 6192, 135, 72, 16404, -4322},
  {5, 6193, 131, 6, 16413, -4846},
  {5, 6204, 134, 6, 16462, -4701},
  {5, 6207, 53, 40, 16431, 3650},
  {5, 6210, 94, 40, 16445, 2348},
  {5, 6217, 53, 84, 16326, 7812},
  {5, 6222, 136, 72, 16494, -4444},
  {5, 6229, 121, 40, 16470, 4732},
  {5, 6231, 129, 72, 16542, -4149},
  {5, 6235, 121, 59, 16534, -2211},
  {5, 6242, 132, 72, 16556, -3928},
  {5, 6259, 134, 72, 17008, -4439},
  {5, 6281, 131, 72, 17047, -3759},
  {5, 6284, 121, 59, 17045, -2446},
  {5, 6287, 121, 59, 17052, -2242},
  {5, 6293, 120, 59, 17102, -2635},
  {5, 6302, 96, 72, 17137, -3706},
  {5, 6304, 120, 59, 17145, -2928},
  {5, 6309, 95, 59, 17141, -1255},
  {5, 6316, 120, 59, 17166, -2808},
  {5, 6334, 70, 72, 17208, -3606},
  {5, 6342, 122, 59, 17212, -1935},
  {5, 6352, 120, 6, 17255, -4825},
  {5, 6355, 121, 59, 17240, -2621},
  {5, 6356, 120, 59, 17236, -1749},
  {5, 6366, 122, 59, 17277, -505},
  {5, 6369, 95, 59, 17293, -2346},
  {5, 6388, 119, 72, 17363, -4444},
  {5, 6397, 117, 6, 17407, -5340},
  {5, 6401, 119, 59, 17386, -2355},
  {5, 6426, 122, 59, 17449, 310},
  {5, 6440, 121, 77, 17489, -2022},
  {5, 6441, 119, 72, 17502, -3703},
  {5, 6445, 97, 77, 17493, -2001},
  {5, 6451, 134, 72, 17507, -3013},
  {5, 6453, 122, 72, 17509, -3436},
  {5, 6503, 52, 34, 17495, 7009},
  {5, 6517, 122, 59, 18018, -858},
  {5, 6520, 134, 77, 18034, -2753},
  {5, 6522, 122, 77, 18036, -3002},
  {5, 6528, 122, 77, 18048, -3003},
  {5, 6535, 121, 74, 18038, -18},
  {5, 6539, 121, 74, 18048, -735},
  {5, 6541, 118, 25, 18080, -4342},
  {5, 6543, 92, 34, 17586, 6638},
  {5, 6544, 120, 77, 18073, -2500},
  {5, 6553, 120, 77, 18093, -2554},
  {5, 6568, 135, 77, 18128, -2135},
  {5, 6569, 120, 77, 18136, -3150},
  {5, 6572, 92, 59, 18121, 651},
  {5, 6583, 136, 77, 18158, -2208},
  {5, 6603, 137, 77, 18184, -1824},
  {5, 6624, 120, 77, 18237, -3022},
  {5, 6629, 94, 77, 18257, -2312},
  {5, 6633, 131, 59, 18273, 631},
  {5, 6638, 121, 77, 18309, -2530},
  {5, 6642, 121, 77, 18319, -2329},
  {5, 6645, 135, 77, 18320, -1653},
  {5, 6649, 135, 73, 18335, -1024},
  {5, 6652, 121, 77, 18358, -3259},
  {5, 6664, 134, 73, 18366, -749},
  {5, 6712, 120, 73, 18531, -842},
  {5, 6723, 119, 77, 18596, -3638},
  {5, 6726, 70, 25, 19017, -3653},
  {5, 6727, 70, 25, 19017, -3653},
  {5, 6729, 70, 25, 19019, -3657},
  {5, 6752, 117, 61, 19109, -5959},
  {5, 6755, 134, 4, 19078, 416},
  {5, 6756, 136, 4, 19087, 442},
  {5, 6760, 121, 4, 19112, 102},
  {5, 6781, 95, 4, 19185, 632},
  {5, 6791, 136, 52, 19207, 3751},
  {5, 6802, 135, 88, 19306, 2016},
  {5, 6818, 94, 77, 19440, -1409},
  {5, 6819, 133, 31, 19413, 4011},
  {5, 6822, 51, 77, 19449, -1448},
  {5, 6823, 133, 88, 19432, 2318},
  {5, 6826, 93, 31, 19448, 5032},
  {5, 6830, 134, 88, 19510, 2306},
  {5, 6834, 134, 31, 19522, 2924},
  {5, 6857, 67, 31, 20028, 3331},
  {5, 6866, 134, 31, 20039, 4410},
  {5, 6885, 134, 88, 20119, 2629},
  {5, 6888, 66, 31, 20128, 3819},
  {5, 6905, 96, 32, 20224, 2006},
  {5, 6907, 53, 12, 20251, -2449},
  {5, 6910, 133, 31, 20232, 4047},
  {5, 6934, 121, 32, 20342, 724},
  {5, 6939, 134, 16, 20315, 6040},
  {5, 6940, 132, 88, 20344, 2817},
  {5, 6946, 51, 16, 20349, 6009},
  {5, 6960, 105, 31, 20457, 3043},
  {5, 6974, 112, 31, 20511, 3150},
  {5, 6979, 70, 31, 20510, 3208},
  {5, 6992, 105, 31, 20564, 3143},
  {5, 6995, 105, 31, 20571, 3113},
  {5, 7000, 60, 31, 21018, 4412},
  {5, 7006, 122, 32, 21015, 1611},
  {5, 7008, 96, 31, 21005, 5433},
  {5, 7009, 92, 5, 21042, -1122},
  {5, 7023, 77, 16, 21005, 6810},
  {5, 7026, 96, 31, 21063, 4751},
  {5, 7027, 94, 31, 21070, 4214},
  {5, 7044, 138, 31, 21129, 4229},
  {5, 7062, 134, 31, 21235, 4623},
  {5, 7086, 134, 31, 21305, 5136},
  {5, 7090, 52, 44, 21365, -5433},
  {5, 7128, 136, 31, 21440, 5343},
  {5, 7129, 81, 16, 21430, 6607},
  {5, 7142, 135, 16, 21452, 6546},
  {5, 7160, 132, 16, 21537, 6236},
  {5, 7184, 52, 5, 22027, -2049},
  {5, 7209, 134, 45, 22051, 4629},
  {5, 7217, 52, 62, 22079, 3122},
  {5, 7243, 132, 45, 22151, 4954},
  {5, 7293, 90, 5, 22296, -2050},
  {5, 7296, 136, 45, 22282, 5217},
  {5, 7320, 54, 62, 22361, 3357},
  {5, 7331, 52, 62, 22371, 3425},
  {5, 7380, 133, 16, 22473, 5808},
  {5, 7424, 52, 39, 22573, -4104},
  {5, 7448, 53, 62, 23001, 1559},
  {5, 7479, 52, 62, 23049, 1219},
  {5, 7510, 134, 16, 23115, 6034},
  {5, 7582, 52, 39, 23184, -4222},
  {5, 7606, 52, 5, 23191, -829},
  {5, 7619, 53, 62, 23202, 812},
  {5, 7635, 67, 14, 23202, 6111},
  {5, 7662, 93, 1, 23259, 4232},
  {5, 7686, 132, 1, 23301, 4908},
  {5, 7723, 53, 5, 23390, -1258},
  {5, 7727, 52, 5, 23399, -1218},
  {5, 7789, 133, 14, 23574, 5643},
  {5, 7790, 135, 14, 23584, 6113},
  {5, 7793, 51, 71, 23578, -3236},
  {5, 7814, 52, 62, 32, 1609},
  {0, 36, 146, 1, 550, +2338},
  {15, 0, 142, 1, 2039, +4220},
  {201, 228, 147, 1, 2140, +4729},
  {201, 3050, 146, 1, 23595, +3343},
  {0, 56, 146, 1, 1562, +3715},
  {0, 59, 146, 1, 2109, +3902},
  {24, 0, 146, 4, 19487, +1149},
  {201, 2404, 147, 4, 18508, +1059},
  {201, 2532, 146, 4, 19302, 254},
  {0, 5, 146, 4, 18465, -58},
  {0, 11, 145, 4, 18591, +1338},
  {0, 15, 146, 4, 19050, -402},
  {0, 57, 146, 4, 19546, -814},
  {201, 2838, 146, 5, 21546, -318},
  {32, 0, 144, 5, 22288, -1},
  {0, 12, 146, 5, 21041, -549},
  {0, 41, 146, 5, 22143, -2104},
  {0, 53, 146, 5, 22266, -1645},
  {0, 94, 145, 5, 23191, -1328},
  {0, 107, 146, 5, 23460, -1841},
  {12, 0, 145, 7, 2592, +2120},
  {15, 0, 145, 7, 1535, +1918},
  {20, 0, 145, 7, 1579, +2336},
  {24, 0, 145, 7, 2493, +1728},
  {201, 394, 147, 7, 3280, +2028},
  {0, 1, 146, 7, 1501, +2217},
  {0, 30, 147, 7, 2370, +2439},
  {0, 33, 145, 7, 2407, +2704},
  {16, 0, 143, 8, 5597, +3713},
  {201, 644, 147, 8, 5103, +3718},
  {201, 698, 147, 8, 5252, +3451},
  {201, 872, 147, 8, 6156, +3609},
  {29, 0, 145, 8, 4593, +3753},
  {30, 0, 145, 8, 6467, +4335},
  {0, 14, 145, 8, 5154, +3241},
  {0, 26, 145, 8, 5386, +3030},
  {0, 41, 146, 8, 6116, +4843},
  {132, 147, 147, 8, 6343, +3805},
  {11, 0, 144, 9, 15155, +3319},
  {12, 0, 143, 9, 14450, +2704},
  {17, 0, 145, 9, 14162, +5122},
  {19, 0, 145, 9, 14135, +5147},
  {21, 0, 144, 9, 15245, +3723},
  {24, 0, 145, 9, 14407, +1625},
  {201, 1825, 146, 9, 14165, +2007},
  {201, 1835, 145, 9, 14234, +827},
  {201, 1884, 147, 9, 14484, +2422},
  {31, 0, 145, 9, 14514, +1906},
  {32, 0, 144, 9, 14411, +1344},
  {0, 39, 146, 9, 14497, +4843},
  {0, 44, 145, 9, 15038, +4739},
  {162, 191, 147, 9, 14596, +5352},
  {201, 1694, 145, 11, 12492, +8325},
  {201, 400, 147, 11, 3350, +6002},
  {201, 485, 147, 11, 4078, +6220},
  {0, 1, 146, 11, 4320, +5355},
  {0, 11, 145, 11, 5061, +5858},
  {6, 0, 144, 12, 20176, -1230},
  {23, 0, 146, 12, 20299, -1835},
  {24, 0, 145, 12, 20273, -1813},
  {26, 0, 145, 12, 20289, -1749},
  {27, 0, 145, 12, 20194, -1907},
  {17, 0, 145, 14, 2291, +6724},
  {18, 0, 144, 14, 491, +5749},
  {27, 0, 145, 14, 23590, +5545},
  {201, 163, 147, 14, 1513, +6451},
  {201, 3053, 146, 14, 26, +6606},
  {201, 3062, 146, 14, 63, +5826},
  {0, 3, 145, 15, 13518, -3300},
  {9, 0, 143, 16, 21287, +7034},
  {11, 0, 144, 16, 22292, +5825},
  {19, 0, 144, 16, 20089, +7743},
  {201, 2780, 147, 16, 21118, +5959},
  {201, 2816, 146, 16, 21390, +5729},
  {201, 2840, 146, 16, 21520, +5548},
  {201, 460, 146, 16, 4100, +8042},
  {31, 0, 144, 16, 22038, +6438},
  {132, 461, 147, 16, 22039, +5949},
  {10, 0, 145, 17, 1496, -1041},
  {15, 0, 144, 17, 2433, +314},
  {201, 186, 147, 17, 1559, +151},
  {0, 66, 146, 17, 2128, -224},
  {6, 0, 140, 20, 6451, -1643},
  {12, 0, 142, 20, 6586, -2858},
  {21, 0, 145, 20, 6561, -1403},
  {108, 3945, 145, 20, 7166, -2319},
  {17, 0, 144, 22, 8467, +2846},
  {25, 0, 146, 22, 8268, +2656},
  {201, 1177, 147, 22, 8056, +2732},
  {201, 1245, 146, 22, 8358, 637},
  {201, 1254, 147, 22, 8404, +1940},
  {201, 1311, 147, 22, 9074, +2259},
  {32, 0, 145, 22, 8122, +1739},
  {0, 57, 146, 22, 8542, +3035},
  {0, 66, 146, 22, 9014, +3215},
  {201, 1633, 147, 24, 12207, +2703},
  {201, 1639, 147, 24, 12244, +2535},
  {0, 2, 146, 24, 12043, +2128},
  {0, 24, 145, 24, 12351, +1823},
  {0, 35, 145, 24, 12533, +2115},
  {15, 0, 145, 25, 19064, -3704},
  {19, 0, 146, 25, 18334, -3844},
  {15, 0, 144, 26, 15427, +2618},
  {18, 0, 146, 26, 15232, +3017},
  {27, 0, 146, 26, 16147, +3352},
  {32, 0, 145, 26, 15394, +3638},
  {132, 128, 146, 26, 16117, +3321},
  {11, 0, 143, 29, 12299, -1631},
  {201, 1604, 147, 29, 12095, -1151},
  {6, 0, 143, 30, 12560, +3819},
  {0, 2, 146, 30, 12161, +4040},
  {9, 0, 143, 31, 19307, +2758},
  {11, 0, 143, 31, 19450, +4508},
  {20, 0, 145, 31, 20474, +3629},
  {21, 0, 145, 31, 21441, +2845},
  {201, 2486, 147, 31, 19121, +4951},
  {30, 0, 145, 31, 19556, +5226},
  {0, 16, 146, 31, 19418, +5032},
  {0, 31, 144, 31, 20136, +4644},
  {0, 49, 146, 31, 20410, +3218},
  {0, 61, 145, 31, 21069, +3845},
  {132, 130, 146, 31, 21208, +3227},
  {103, 5137, 146, 31, 19459, +3501},
  {15, 0, 144, 32, 20467, +1607},
  {12, 0, 144, 34, 19482, +7016},
  {21, 0, 146, 34, 17053, +5428},
  {22, 0, 145, 34, 17322, +5511},
  {23, 0, 145, 34, 18512, +5923},
  {201, 2155, 147, 34, 17161, +6043},
  {201, 2348, 146, 34, 18339, +5221},
  {30, 0, 145, 34, 17419, +7209},
  {0, 17, 145, 34, 16362, +5255},
  {0, 41, 146, 34, 18002, +8000},
  {132, 123, 147, 34, 13271, +6444},
  {12, 0, 145, 35, 20591, +418},
  {201, 2742, 147, 35, 21022, +711},
  {16, 0, 143, 36, 2583, -4018},
  {11, 5, 146, 36, 1398, -5612},
  {0, 55, 147, 36, 4436, -848},
  {108, 3556, 146, 36, 3124, -4425},
  {29, 0, 145, 37, 2338, -2814},
  {6, 0, 142, 38, 7346, +3153},
  {11, 0, 144, 38, 7201, +2159},
  {19, 0, 144, 38, 7444, +2424},
  {201, 1083, 147, 38, 7256, +2030},
  {201, 1108, 147, 38, 7328, +2253},
  {0, 38, 145, 38, 6546, +1311},
  {162, 70, 147, 38, 6278, +2047},
  {6, 0, 143, 40, 17146, +1423},
  {11, 0, 143, 40, 17150, +2450},
  {19, 0, 145, 40, 16081, +1703},
  {26, 0, 145, 40, 17237, +3709},
  {201, 2052, 147, 40, 16289, +1825},
  {201, 2063, 146, 40, 16318, +4536},
  {201, 2315, 147, 40, 18250, +2724},
  {201, 2411, 147, 40, 18523, +1432},
  {0, 37, 146, 40, 16406, +413},
  {0, 56, 146, 40, 16550, +2544},
  {0, 95, 145, 40, 18015, +2136},
  {0, 100, 146, 40, 18078, +2606},
  {132, 129, 147, 40, 18359, +1659},
  {12, 0, 143, 42, 8468, +625},
  {201, 1348, 148, 42, 9245, +621},
  {201, 1355, 147, 42, 9273, +614},
  {201, 1365, 147, 42, 9315, +128},
  {28, 0, 145, 42, 9291, -246},
  {103, 396, 146, 42, 11323, -2916},
  {201, 2894, 146, 45, 22189, +3746},
  {0, 8, 146, 45, 22359, +3938},
  {6, 0, 141, 46, 10084, +1158},
  {15, 0, 142, 46, 10200, +1950},
  {28, 0, 145, 46, 11279, +251},
  {0, 6, 145, 46, 9320, +943},
  {0, 49, 146, 46, 10350, +839},
  {0, 54, 144, 46, 10556, +2445},
  {0, 81, 146, 46, 11256, +1627},
  {0, 83, 147, 46, 11268, +301},
  {0, 90, 146, 46, 11347, +1648},
  {132, 215, 147, 46, 10163, +1744},
  {15, 0, 144, 47, 5445, -2227},
  {108, 3750, 145, 47, 5204, -2114},
  {21, 0, 145, 48, 14493, -1409},
  {23, 0, 146, 48, 15210, -1533},
  {201, 1962, 146, 48, 15387, -847},
  {31, 0, 145, 50, 15569, -3358},
  {201, 1282, 147, 51, 8508, +3504},
  {201, 1333, 147, 51, 9184, +3522},
  {201, 1338, 147, 51, 9210, +3811},
  {201, 1369, 147, 51, 9354, +3958},
  {201, 958, 146, 51, 6482, +5542},
  {0, 12, 145, 51, 6462, +5927},
  {0, 19, 146, 51, 7229, +5517},
  {0, 38, 144, 51, 9188, +3648},
  {9, 0, 144, 52, 18501, +3322},
  {13, 0, 145, 52, 18443, +3940},
  {14, 0, 145, 52, 18443, +3940},
  {18, 0, 144, 52, 19138, +3909},
  {201, 2474, 147, 52, 19091, +3436},
  {32, 0, 144, 52, 18448, +3736},
  {200, 0, 145, 52, 18570, +3254},
  {162, 282, 146, 52, 18549, +3358},
  {108, 5218, 147, 54, 20454, -3029},
  {9, 0, 145, 55, 6288, -702},
  {12, 0, 144, 55, 6238, +436},
  {20, 0, 144, 59, 16309, +159},
  {23, 0, 145, 59, 17180, -2417},
  {26, 0, 145, 59, 16256, -2327},
  {201, 2276, 147, 59, 18057, +1200},
  {28, 0, 145, 59, 18031, -811},
  {0, 36, 145, 59, 17153, -2636},
  {0, 61, 146, 59, 17446, +235},
  {0, 70, 144, 59, 18055, +230},
  {9, 0, 140, 60, 5145, -812},
  {11, 0, 142, 60, 5320, -18},
  {16, 0, 145, 60, 5353, -523},
  {17, 0, 143, 60, 5354, -555},
  {18, 0, 144, 60, 5245, -224},
  {20, 0, 144, 60, 5351, +956},
  {26, 0, 145, 60, 5133, +252},
  {27, 0, 144, 60, 5387, -236},
  {201, 747, 145, 60, 5350, -600},
  {201, 790, 146, 60, 5460, -416},
  {32, 0, 142, 60, 5407, -157},
  {0, 14, 146, 60, 5079, +830},
  {0, 23, 145, 60, 5228, +333},
  {0, 32, 144, 60, 5308, 557},
  {0, 33, 146, 60, 5312, +318},
  {0, 52, 146, 60, 5480, +627},
  {12, 0, 143, 62, 21442, +953},
  {201, 2841, 146, 62, 21543, +1943},
  {201, 3007, 147, 62, 23228, +2034},
  {0, 1, 144, 62, 21221, +1948},
  {18, 0, 144, 63, 2507, +5554},
  {201, 162, 146, 63, 1493, +4754},
  {201, 331, 145, 63, 3009, +5221},
  {201, 336, 147, 63, 3015, +3225},
  {201, 369, 147, 63, 3171, +4029},
  {0, 56, 146, 63, 4246, +3358},
  {11, 24, 146, 66, 22366, -3140},
  {6, 0, 144, 67, 2020, +246},
  {201, 22, 147, 67, 174, +853},
  {201, 3009, 147, 67, 23243, +343},
  {30, 0, 145, 67, 1057, +2128},
  {32, 0, 145, 67, 1137, +735},
  {0, 35, 144, 67, 150, +849},
  {0, 55, 146, 67, 399, +2126},
  {0, 65, 146, 67, 499, +2743},
  {0, 66, 146, 67, 546, +1911},
  {0, 77, 146, 67, 1058, +455},
  {112, 0, 145, 68, 7183, -3644},
  {110, 19, 146, 68, 7343, -2328},
  {103, 327, 144, 68, 7388, -2648},
  {6, 0, 141, 72, 16294, -2626},
  {9, 0, 143, 72, 16054, -1948},
  {22, 0, 144, 72, 16120, -1928},
  {31, 0, 145, 72, 16044, -1122},
  {11, 0, 144, 74, 15348, +1032},
  {16, 0, 145, 74, 18562, +412},
  {201, 1919, 147, 74, 15127, +1917},
  {0, 59, 145, 74, 18272, +12},
  {132, 127, 146, 74, 15402, +1203},
  {15, 0, 145, 75, 9525, -806},
  {153, 0, 147, 75, 9541, +457},
  {0, 35, 146, 75, 10433, +445},
  {0, 40, 147, 75, 10493, -401},
  {32, 0, 145, 76, 19490, +1909},
  {110, 84, 146, 76, 19394, +1634},
  {138, 0, 145, 77, 17591, -3015},
  {0, 54, 145, 77, 19407, -1618},
  {108, 5082, 146, 77, 19031, -1915},
  {10, 0, 145, 78, 4226, +2538},
  {25, 0, 145, 78, 4204, +2721},
  {201, 422, 146, 78, 3368, +35},
  {201, 495, 146, 78, 4077, +1510},
  {201, 572, 147, 78, 4385, +2656},
  {0, 7, 147, 78, 3344, +2428},
  {0, 62, 146, 78, 4240, +2418},
  {0, 118, 146, 78, 5293, +2509},
  {201, 239, 147, 81, 2174, +2845},
  {0, 6, 145, 81, 2124, +3018},
  {27, 0, 145, 83, 9104, +6708},
  {201, 1520, 147, 83, 11161, +5246},
  {201, 1523, 144, 83, 11182, +3132},
  {201, 1695, 146, 83, 12563, +5406},
  {32, 0, 142, 83, 13239, +5456},
  {132, 126, 146, 83, 11323, +6105},
  {6, 0, 142, 84, 2318, +8916},
  {201, 1972, 147, 84, 15292, +8027},
  {108, 2682, 147, 84, 13407, +7651},
  {11, 70, 145, 85, 8295, -4443},
  {108, 4191, 145, 85, 9144, -4314},
  {15, 0, 143, 86, 12417, -127},
  {28, 0, 144, 86, 14016, +133},
  {0, 17, 147, 86, 12225, +518},
  {60, 0, 161, 1, 275, 3535},
  {166, 0, 162, 1, 23388, 3546},
  {167, 0, 162, 1, 46, 4333},
  {181, 0, 161, 1, 2384, 3910},
  {185, 0, 162, 1, 199, 4443},
  {107, 5223, 162, 1, 542, 2404},
  {130, 15196, 162, 1, 542, 2404},
  {179, 0, 162, 4, 18585, 1422},
  {182, 0, 161, 4, 19044, -541},
  {182, 1469, 162, 4, 20011, 931},
  {130, 11960, 161, 4, 19232, -1042},
  {147, 0, 163, 5, 23244, -1719},
  {182, 0, 162, 7, 2150, 1214},
  {90, 0, 163, 8, 5034, 5038},
  {96, 0, 162, 8, 5481, 3038},
  {148, 0, 164, 8, 6348, 4230},
  {152, 0, 162, 8, 5271, 3409},
  {176, 0, 163, 8, 5091, 3900},
  {178, 0, 159, 8, 6365, 3827},
  {179, 0, 161, 8, 5218, 3231},
  {182, 0, 163, 8, 6240, 4742},
  {182, 346, 163, 8, 4526, 3830},
  {149, 0, 163, 9, 14242, 2542},
  {147, 0, 162, 11, 7217, 6940},
  {152, 0, 162, 11, 5410, 6848},
  {166, 0, 161, 11, 4512, 6810},
  {177, 0, 161, 11, 3418, 6239},
  {179, 0, 162, 11, 4059, 6148},
  {196, 0, 161, 11, 4086, 5322},
  {146, 0, 161, 12, 20171, -2119},
  {129, 0, 164, 14, 246, 5417},
  {166, 0, 165, 14, 175, 1714},
  {187, 0, 162, 14, 549, 5834},
  {191, 0, 163, 14, 1336, 5745},
  {193, 0, 161, 14, 13, 6021},
  {182, 623, 161, 14, 3114, 5754},
  {21, 0, 162, 16, 21435, 5848},
  {152, 0, 161, 16, 21352, 7837},
  {107, 16115, 162, 17, 2351, -927},
  {157, 129989, 162, 17, 2351, -9264},
  {187, 0, 160, 20, 7081, -1155},
  {139, 0, 161, 21, 7087, 1001},
  {171, 0, 162, 22, 8567, 1931},
  {194, 0, 160, 22, 8554, 1714},
  {139, 0, 160, 26, 15486, 2809},
  {182, 0, 161, 26, 15495, 3934},
  {172, 0, 162, 30, 12594, 3749},
  {197, 0, 159, 30, 12451, 4526},
  {66, 0, 161, 31, 19288, 4603},
  {67, 0, 162, 31, 19572, 4416},
  {82, 0, 162, 31, 20468, 4603},
  {145, 0, 161, 31, 20134, 3844},
  {148, 0, 161, 31, 21433, 3801},
  {150, 0, 163, 31, 20104, 3557},
  {168, 0, 163, 31, 20095, 4752},
  {172, 0, 161, 31, 19409, 3237},
  {177, 0, 160, 31, 20196, 4754},
  {182, 0, 162, 31, 20413, 4808},
  {192, 0, 163, 31, 20186, 3727},
  {182, 460, 160, 31, 21420, 3531},
  {107, 189256, 162, 31, 19572, 4418},
  {157, 106516, 162, 32, 20486, 1750},
  {150, 0, 160, 34, 12564, 6560},
  {171, 0, 161, 34, 17564, 5813},
  {180, 0, 160, 34, 19216, 7634},
  {169, 0, 162, 36, 5098, -531},
  {75, 0, 162, 38, 7209, 2460},
  {129, 0, 161, 38, 7319, 2430},
  {173, 0, 161, 38, 6109, 2601},
  {184, 0, 162, 38, 6421, 3127},
  {33, 0, 161, 40, 18303, 2152},
  {144, 0, 162, 40, 16042, 5030},
  {157, 46574, 161, 40, 17135, 4206},
  {177, 0, 159, 42, 10376, -1323},
  {182, 0, 161, 42, 10516, -2115},
  {197, 0, 161, 42, 9511, -2301},
  {139, 0, 160, 46, 9476, 1124},
  {139, 0, 160, 47, 4596, -1448},
  {197, 0, 161, 51, 7282, 460},
  {109, 0, 162, 52, 18428, 3658},
  {171, 0, 162, 52, 18323, 3660},
  {177, 0, 162, 52, 19202, 3753},
  {73, 0, 163, 55, 6564, 76},
  {96, 0, 163, 55, 6224, 325},
  {102, 0, 162, 55, 6532, -435},
  {148, 0, 161, 55, 6584, 610},
  {150, 0, 162, 55, 7069, -733},
  {182, 614, 161, 55, 7010, -315},
  {175, 0, 161, 59, 17297, -1928},
  {182, 0, 161, 59, 16267, -1226},
  {74, 0, 160, 60, 6255, 1443},
  {101, 0, 164, 60, 6177, 831},
  {146, 0, 162, 60, 5332, 709},
  {190, 0, 160, 60, 5054, 111},
  {149, 0, 162, 62, 21564, 2248},
  {33, 0, 163, 63, 3451, 4447},
  {149, 0, 162, 63, 21564, 2252},
  {151, 0, 162, 63, 22059, 3330},
  {197, 0, 162, 63, 3277, 4411},
  {182, 466, 162, 63, 3415, 5130},
  {176, 0, 159, 67, 23464, 329},
  {198, 0, 161, 67, 1161, 2546},
  {107, 26, 162, 67, 54, 847},
  {157, 109003, 162, 67, 54, 847},
  {157, 128396, 163, 67, 23491, 623},
  {147, 0, 162, 68, 8075, -2255},
  {148, 0, 163, 73, 18474, -1313},
  {149, 0, 162, 73, 18370, -736},
  {165, 0, 160, 73, 18583, -754},
  {171, 0, 162, 73, 18554, -86},
  {87, 0, 162, 74, 18474, 530},
  {94, 0, 163, 74, 18194, -1537},
  {72, 0, 163, 76, 20024, 2105},
  {76, 0, 162, 76, 20024, 2036},
  {195, 0, 161, 76, 20051, 2039},
  {60, 0, 161, 77, 19343, -1622},
  {170, 0, 162, 77, 17449, -1839},
  {182, 1942, 161, 77, 19192, -1555},
  {167, 0, 163, 78, 5491, 1904},
  {172, 0, 162, 78, 4515, 2832},
  {173, 0, 160, 78, 5452, 2425},
  {197, 0, 161, 78, 5457, 2042},
  {146, 0, 163, 83, 9184, 5124},
  {186, 0, 160, 83, 10451, 6725},
  {147, 0, 162, 86, 12473, 409},
  {165, 0, 160, 86, 12252, 46},
  {107, 113801, 163, 86, 13064, -2004},
  {157, 157721, 163, 86, 13064, -2004},
  {68, 0, 162, 88, 20373, 2630},
  {130, 13571, 162, 88, 21099, 2637},
  {34, 0, 169, 36, 1377, -5714},
  {35, 0, 171, 72, 16054, -1948},
  {36, 0, 169, 28, 12266, -6306},
  {37, 0, 170, 20, 6586, -2858},
  {38, 0, 169, 15, 14038, -6022},
  {39, 0, 170, 1, 2039, 4220},
  {40, 0, 169, 78, 4359, 1631},
  {41, 0, 170, 16, 21186, 6235},
  {42, 0, 170, 39, 22427, -4653},
  {43, 0, 170, 63, 3243, 4952},
  {44, 0, 170, 46, 10200, 1950},
  {45, 0, 170, 63, 3082, 4057},
  {46, 0, 170, 38, 6377, 1624},
  {47, 0, 170, 83, 12540, 5558},
  {48, 0, 170, 83, 13475, 4919},
  {49, 0, 170, 39, 22082, -4658},
  {50, 0, 170, 60, 5362, -112},
  {51, 0, 170, 60, 5408, -157},
  {52, 0, 170, 42, 9276, -840},
  {53, 0, 170, 26, 15347, 2643},
  {54, 0, 170, 1, 84, 2905},
  {55, 0, 170, 85, 8095, -4720},
  {56, 0, 169, 4, 19508, 852},
  {57, 0, 170, 20, 7241, -2918},
  {58, 0, 170, 64, 263, -4218},
  {59, 0, 169, 72, 16294, -2626},
  {61, 0, 168, 9, 14157, 1911},
  {62, 0, 171, 47, 5327, -1749},
  {63, 0, 170, 13, 9171, -5917},
  {64, 0, 170, 80, 16487, -6902},
  {65, 0, 170, 13, 8225, -5931},
  {69, 0, 169, 28, 12477, -5941},
  {70, 0, 170, 60, 5251, 621},
  {71, 0, 169, 60, 5552, 724},
  {77, 0, 168, 13, 6240, -5242},
  {78, 0, 168, 8, 5167, 4560},
  {79, 0, 170, 14, 92, 5909},
  {80, 0, 170, 38, 7346, 3153},
  {81, 0, 170, 14, 567, 6043},
  {83, 0, 169, 31, 20414, 4517},
  {84, 0, 170, 17, 436, -1759},
  {85, 0, 170, 46, 11491, 1434},
  {86, 0, 170, 17, 436, -1759},
  {88, 0, 170, 72, 16003, -2237},
  {89, 0, 170, 83, 11037, 6145},
  {91, 0, 170, 78, 5263, 2836},
  {92, 0, 170, 34, 17566, 5129},
  {93, 0, 170, 62, 21442, 953},
  {95, 0, 169, 66, 22577, -2937},
  {97, 0, 170, 28, 12312, -5707},
  {98, 0, 170, 26, 15347, 2643},
  {99, 0, 171, 31, 20462, 3358},
  {100, 0, 170, 72, 17425, -3902},
  {104, 0, 169, 15, 14038, -6022},
  {105, 0, 170, 7, 2072, 2328},
  {106, 0, 171, 59, 16372, -1034},
  {111, 0, 170, 9, 14450, 2704},
  {113, 0, 170, 77, 18242, -3423},
  {114, 0, 170, 84, 14507, 7409},
  {115, 0, 170, 85, 8447, -5443},
  {116, 0, 170, 62, 23048, 1512},
  {117, 0, 170, 8, 5595, 4457},
  {118, 0, 171, 17, 3023, 405},
  {119, 0, 170, 15, 14067, -3622},
  {120, 0, 170, 83, 11018, 5623},
  {121, 0, 170, 13, 9132, -6943},
  {122, 0, 169, 28, 12477, -5941},
  {123, 0, 170, 60, 5320, -18},
  {124, 0, 170, 1, 1097, 3537},
  {125, 0, 170, 63, 3243, 4952},
  {126, 0, 170, 20, 6227, -1757},
  {127, 0, 170, 83, 13239, 5456},
  {128, 0, 170, 68, 8036, -4000},
  {131, 0, 170, 77, 18553, -2618},
  {133, 0, 170, 61, 20256, -5644},
  {134, 0, 170, 83, 11538, 5342},
  {135, 0, 170, 84, 2318, 8916},
  {136, 0, 169, 38, 7453, 2802},
  {137, 0, 168, 21, 7393, 514},
  {140, 0, 170, 59, 17349, 1234},
  {141, 0, 169, 46, 10084, 1158},
  {142, 0, 168, 60, 5145, -812},
  {143, 0, 168, 15, 14396, -6050},
  {154, 0, 170, 59, 17104, -1543},
  {155, 0, 170, 31, 20222, 4015},
  {156, 0, 170, 60, 5478, -940},
  {158, 0, 170, 72, 17373, -4260},
  {159, 0, 170, 62, 23038, 2805},
  {160, 0, 170, 14, 405, 5632},
  {161, 0, 170, 72, 17336, -3706},
  {163, 0, 168, 20, 6451, -1643},
  {164, 0, 169, 86, 13252, -1110},
  {174, 0, 170, 13, 9171, -5917},
  {183, 0, 168, 52, 18369, 3847},
  {188, 0, 170, 72, 16502, -3418},
  {189, 0, 170, 20, 7084, -2624},
  {199, 0, 171, 46, 11141, 2031},
  {7, 0, 168, 15, 14396, -6050},
  {8, 0, 169, 15, 14396, -6050},
  {6, 0, 170, 50, 14419, -4723},
  {9, 0, 170, 39, 22427, -4653},
  {15, 0, 170, 14, 567, 6043},
  {15, 0, 170, 15, 12415, -4858},
  {11, 0, 171, 15, 12084, -5043},
  {11, 0, 170, 85, 8447, -5443},
  {12, 0, 170, 15, 13399, -5328},
  {32, 0, 171, 15, 13555, -4717},
  {32, 0, 171, 59, 16372, -1034},
  {18, 0, 170, 15, 14355, -4209},
  {19, 0, 170, 85, 9221, -5501},
  {20, 0, 170, 85, 9080, -4326}
// variables for button - instead of bounce lib - save flash memory
const int DEBOUNCE_DELAY = 50;   // the debounce time; increase if the output flickers
int lastSteadyState = LOW;       // the previous steady state from the input pin
int lastFlickerableState = LOW;  // the previous flickerable state from the input pin
int currentState;                // the current reading from the input pin
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long lastPressedTime = 0;
// LCD - VSS - GND // VCC - 5V // RW - GND // K - GND
const byte rs = 12;
const byte en = 13;
const byte d4 = 9;
const byte d5 = 8;
const byte d6 = 7;
const byte d7 = 6;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
byte myLCDbacklight = 255;
byte myLCDcontrast = 100;
// variables to steer menu
byte myDisplayMode = 0;
const char *const menuTopic[] = {"DEC", "Align", "Target", "Region", "Const", "Brightness", "Contrast", "Sensors", "LX200"};
const byte menuTopic_size = sizeof(menuTopic) / sizeof(menuTopic[0]);
byte myMenuTopicNo = 0;
// definition of special / greek characters - for LCD 1602 chinese version - adapt to your LCD if needed
// used lcd is like this https://www.waveshare.com/datasheet/LCD_en_PDF/LCD1602.pdf (see 14. font table)
const char ch_deg = (char)(223); // degree symbol
const char ch_sigma = (char)(246); // uppercase Sigma
// greek alphabet 1-24 = α β γ δ ε ζ η θ ι κ λ μ ν ξ ο π ρ σ τ υ φ χ ψ ω
// maximum 8 custom characters
// γ
char ch_def_1 = 'g'; // for identificatrion & replacement
byte ch_custom_1[] = {
  B00000,
  B10011,
  B10010,
  B10010,
  B01110,
  B00100,
  B00100,
  B00100
// δ
char ch_def_2 = 'd';
byte ch_custom_2[] = {
  B00110,
  B01001,
  B00100,
  B01110,
  B10001,
  B10001,
  B01110,
  B00000
// ζ
char ch_def_3 = 'z';
byte ch_custom_3[] = {
  B01111,
  B00010,
  B00100,
  B01000,
  B01000,
  B01111,
  B00001,
  B00110
// λ
char ch_def_4 = 'l';
byte ch_custom_4[] = {
  B01100,
  B00100,
  B00100,
  B01010,
  B01010,
  B10001,
  B10001,
  B00000
// ξ
char ch_def_5 = 'x';
byte ch_custom_5[] = {
  B11111,
  B00100,
  B01000,
  B00111,
  B01000,
  B10000,
  B11111,
  B00010
// φ
char ch_def_6 = 'p';
byte ch_custom_6[] = {
  B00000,
  B10111,
  B10101,
  B10101,
  B10101,
  B01110,
  B00100,
  B00100
// ψ
char ch_def_7 = 's';
byte ch_custom_7[] = {
  B00000,
  B00100,
  B10101,
  B10101,
  B10101,
  B01110,
  B00100,
  B00100
// Δ
char ch_def_8 = 'D';
byte ch_custom_8[] = {
  B00000,
  B00100,
  B01010,
  B01010,
  B10001,
  B10001,
  B11111,
  B00000
// lookup table placeholder chars with greek symbols
struct greekSymbols {
  char originalChar;
  char replaceChar;
const unsigned int greekSymbols_size = 26;
const struct greekSymbols greekSymbols[greekSymbols_size]  =
  {'a', (char)(224)}, // α
  {'b', (char)(226)}, // β
  {'g', 'g'}, // γ custom character
  {'d', 'd'}, // δ custom character
  {'e', (char)(227)}, // ε
  {'z', 'z'}, // ζ custom character
  {'j', 'n'}, // η
  {'h', (char)(242)}, // θ
  {'i', 'l'}, // ι
  {'k', 'k'}, // κ
  {'l', 'l'}, // λ custom character
  {'m', (char)(228)}, // μ
  {'n', 'v'}, // ν
  {'x', 'x'}, // ξ custom character
  {'o', 'o'}, // ο
  {'p', (char)(247)}, // π
  {'r', (char)(230)}, // ρ
  {'s', (char)(229)}, // σ
  {'t', 't'}, // τ
  {'y', (char)(232)}, // υ
  {'q', 'p'}, // φ custom character
  {'c', 'x'}, // χ
  {'w', 's'}, // ψ custom character
  {'u', 'w'},
  {'F', (char)(246)}, // Σ
  {'D', '/'} // Δ
// definition of constellation names
struct constStruct {
  char constName[4];
constStruct myConstellation;
const unsigned int constStruct_size = 89;
const struct constStruct const_PROGMEM[constStruct_size] PROGMEM = {
  {"all"}, {"And"}, {"Ant"}, {"Aps"}, {"Aql"}, {"Aqr"}, {"Ara"}, {"Ari"}, {"Aur"}, {"Boo"}, {"Cae"}, {"Cam"}, {"Cap"}, {"Car"}, {"Cas"}, {"Cen"}, {"Cep"}, {"Cet"}, {"Cha"}, {"Cir"},
  {"CMa"}, {"CMi"}, {"Cnc"}, {"Col"}, {"Com"}, {"CrA"}, {"CrB"}, {"Crt"}, {"Cru"}, {"Crv"}, {"CVn"}, {"Cyg"}, {"Del"}, {"Dor"}, {"Dra"}, {"Equ"}, {"Eri"}, {"For"}, {"Gem"}, {"Gru"},
  {"Her"}, {"Hor"}, {"Hya"}, {"Hyi"}, {"Ind"}, {"Lac"}, {"Leo"}, {"Lep"}, {"Lib"}, {"LMi"}, {"Lup"}, {"Lyn"}, {"Lyr"}, {"Men"}, {"Mic"}, {"Mon"}, {"Mus"}, {"Nor"}, {"Oct"}, {"Oph"},
  {"Ori"}, {"Pav"}, {"Peg"}, {"Per"}, {"Phe"}, {"Pic"}, {"PsA"}, {"Psc"}, {"Pup"}, {"Pyx"}, {"Ret"}, {"Scl"}, {"Sco"}, {"Sct"}, {"Ser"}, {"Sex"}, {"Sge"}, {"Sgr"}, {"Tau"}, {"Tel"},
  {"TrA"}, {"Tri"}, {"Tuc"}, {"UMa"}, {"UMi"}, {"Vel"}, {"Vir"}, {"Vol"}, {"Vul"}
byte myConstellationNo = 0;
String myConstellationName = "";
// object type name and variables for deep sky objects
const char* myObjectTypeName[] = {"Quasar", "Dark Nebula", "Galaxy", "Bright Neb", "Clust + Neb", "Planet Neb", "SN Rem", "Glob Cluster", "Open Cluster", "Double Star", "Red Star", "Reference", "any"};
unsigned int myRefNo = 0; // number of selected reference star
unsigned int  myTargetNo = 0; // number of selected target
// definition of cellestial regions = constellations of seasons defined in groups (as in Deep Sky Atlas) to filter targets and reference stars
// constellation for which deep sky objects exist in the list 0 = all
const byte myAllCONST[] = {0, 1, 2, 4, 5, 6, 7, 8, 9, 11, 12, 13, 14, 15, 16, 17, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 44, 45, 46, 47, 48, 49, 50, 51, 52, 54, 55, 57, 59, 60, 61, 62, 63, 64, 66, 67, 68, 69, 71, 72, 73, 74, 75, 76, 77, 78, 80, 81, 83, 84, 85, 86, 88};
const byte myAllCONST_size = sizeof(myAllCONST) / sizeof(myAllCONST[0]);
// North - UMI,UMA,DRA,CEP,CAS,CAM
const byte myNorthCONST[] = {84, 83, 34, 16, 14, 11};
const byte myNorthCONST_size = sizeof(myNorthCONST) / sizeof(myNorthCONST[0]);
// Spring - LEO,LMI,SEX,HYA,CVN,COM,VIR,CRT,CRV,BOO,CRB,SER
const byte mySpringCONST[] = {46, 49, 75, 42, 30, 24, 86, 27, 29, 9, 26, 74};
const byte mySpringCONST_size = sizeof(mySpringCONST) / sizeof(mySpringCONST[0]);
// Summer - HER,LYR,OPH,SCO,CYG,VUL,SGE,DEL,EQU,AQL,SCT,SER,SGR,CAP
const byte mySummerCONST[] = {40, 52, 59, 72, 31, 88, 76, 32, 35, 4, 73, 74, 77, 12};
const byte mySummerCONST_size = sizeof(mySummerCONST) / sizeof(mySummerCONST[0]);
// Autumn - LAC,PEG,AQR,PSA,AND,TRI,PER,ARI,PSC,CET,SCL,FOR,ERI
const byte myAutumnCONST[] = {45, 62, 5, 66, 1, 81, 63, 7, 67, 17, 71, 37, 36};
const byte myAutumnCONST_size = sizeof(myAutumnCONST) / sizeof(myAutumnCONST[0]);
// Winter - AUR,TAU,ORI,LEP,LYN,GEM,CMI,MON,CMA,PUP,CNC
const byte myWinterCONST[] = {8, 78, 60, 47, 51, 38, 21, 55, 20, 68, 22};
const byte myWinterCONST_size = sizeof(myWinterCONST) / sizeof(myWinterCONST[0]);
// South - ANT,VEL,CAR,VOL,CHA,MUS,CRU,CEN,CRU,TRA,LUP,NOR,ARA,SCO,SGR,CRA,TEL,MIC,IND,PAV,GRU,PHE,SCL,FOR,ERI,HOR,RET,HYI,TUC,DOR,CAE,COL,PUP,PYX,PIC,MEN,APS,OCT
const byte mySouthCONST[] = {2, 85, 13, 28, 15, 28, 80, 50, 57, 6, 72, 77, 25, 54, 44, 61, 39, 64, 71, 37, 36, 41, 33, 23, 68, 69, 65};
const byte mySouthCONST_size = sizeof(mySouthCONST) / sizeof(mySouthCONST[0]);
const char* myregionNAME[] = {"all", "North", "Spring", "Summer", "Autumn", "Winter", "South"}; // no south to save flash
const byte regionArraySize = sizeof(myregionNAME) / sizeof(myregionNAME[0]); // Anzahl der Einträge
byte myRegionNo = 0; // all - 0; North - 1; .... ; South - 6
String myregionName = "";
// variables for calculation of position // all positions are calculated in seconds
long myRefStartTimeSec = 0; // Startzeit beim Setzen des Referenzsterns in Sekunden
long myCurrentRAsec = 0; // meine aktuelle Rektaszension in Sekunden
long myCurrentDECsec = 0; // meine aktuelle Deklination in Sekunden
long myLastRAsec = 0; // meine letzte Rektaszension in Sekunden
long myLastDECsec = 0; // meine letzte Deklination in Sekunden
long myReferenceRAsec = 0; // meine Rektaszensionsreferenz in Sekunden
long myReferenceDECsec = 0; // meine Deklinationsreferenz in Sekunden
long mySensorRAsec = 0; // Sensorwert der Rektaszension in Sekunden
long mySensorDECsec = 0; // Sensorwert der Deklination in Sekunden
long myTargetRAsec = 0; // Rektaszension des Ziels in Sekunden
long myTargetDECsec = 0; // Deklination des Ziels in Sekunden
const int secPerStepRA = 86400L / IMPULSE24HRA; // defines how many seconds RA is changed per rotary step //  (24h * 3600sec = 86400sec) / (1:139 * 20 impulse = 2780) --> 31,079 sec / i
const int secPerStepDEC = 1296000L / IMPULSE360DEGDEC; // defines how many seconds DEC is changed per rotary step //  (360° * 3600sec = 1296000sec) / (1:96 * 20 impulse = 1920) / --> 675 sec / i
int myDirectionDEC = 1; // saves the value of the direction of the DEC axis, important if the telescope is turned over
// for rotary encoders
static uint8_t prevNextCode_ROT = 0;
static uint16_t store_ROT = 0;
static uint8_t prevNextCode_RA = 0;
static uint16_t store_RA = 0;
static uint8_t prevNextCode_DEC = 0;
static uint16_t store_DEC = 0;
static int8_t val_ROT, val_RA, val_DEC;
int myImpulseRA = 0, myImpulseDEC = 0;
int myLastImpulseRA = 0, myLastImpulseDEC = 0;
const int8_t enc_table[] = {0, 1, 1, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 1, 1, 0};
// variables for LX200
byte statusLX200 = 0; // 0 - BT switched off / 1 - BT switched on / 2 - connected via BT & LX200 (frequent connect to LX200)
byte statusLX200old = 0;
byte btStatus = 0; // 0 - off / 1 - on
unsigned long lastLX200Message = 0;
DSOstruct externalObject; // instance LX200 object
// setup
  // for LX200 protocol & debugging
  Serial.begin (9600);
  // while(!Serial); // attention - only for debugging when in use with IDE!
  // Serial.println(F("started"));
  getSettingsFromEeprom(); // load settings (brightness,contrast,...)
  setReference(); // set reference object to saved values
  setTarget(); // set target object to saved values
  setupLCD();
  createCustomCharacters();
  setupRotaryEncoders();
  initExternalObject();
// software reset https://www.instructables.com/two-ways-to-reset-arduino-in-software/
void(* resetFunc) (void) = 0;//declare reset function at address 0
void setupLCD()
  lcd.begin(16, 2);
  updateLCD();
  pinMode(LCD_BACKLIGHT_PIN, OUTPUT);
  analogWrite(LCD_CONTRAST_PIN, myLCDcontrast); //set contrast
//Creating custom characters in CG-RAM
void createCustomCharacters()
  lcd.createChar(1 , ch_custom_1);
  lcd.createChar(2 , ch_custom_2);
  lcd.createChar(3 , ch_custom_3);
  lcd.createChar(4 , ch_custom_4);
  lcd.createChar(5 , ch_custom_5);
  lcd.createChar(6 , ch_custom_6);
  lcd.createChar(7 , ch_custom_7);
  lcd.createChar(8 , ch_custom_8);
void setupRotaryEncoders()
  // HMI rotary encoder button
  pinMode(ROTARY_SW, INPUT_PULLUP);
  pinMode(ROTARY_CLK, INPUT);
  pinMode(ROTARY_DT, INPUT);
  // it is better to use the integrated pull-ups of KY-040 (this requires "+" to be connected to 5V) - https://forum.arduino.cc/index.php?topic=242356.0
  // as analog pins are used for rotary encoders - internal pull-ups are additionally used to avoid akward behaviour if not connected to sensors
  // RA rotary encoder
  pinMode(SENS_RA_CLK, INPUT_PULLUP);
  pinMode(SENS_RA_DT, INPUT_PULLUP);
  // DEC rotary encoder
  pinMode(SENS_DEC_CLK, INPUT_PULLUP);
  pinMode(SENS_DEC_DT, INPUT_PULLUP);
  // switch for BT module
  pinMode(BT_SWITCH, OUTPUT);
// initialise external object struct for receiving via LX200
void initExternalObject()
  externalObject.objectPreFixNameNo = 202; // is "external" in DSO PROGMEM
  externalObject.objectNumber = 0; // empty - no number in name
  externalObject.objectTypeMagnitude = 0;
  externalObject.objectConst = 0; // "all" in constellations
  externalObject.objectRA = 0;
  externalObject.objectDEC = 0;
// \setup
// loop
  analogWrite(LCD_BACKLIGHT_PIN, myLCDbacklight);  // LCD backlight analogWrite: values from 0 to 255
  updateRotaryEncoderButton();
  updateRotaryEncoders();
  calcCurrentPosition();
  if (myDisplayMode == 9) displaySensorValue();
  if (myDisplayMode == 11) displayCurrPos();
  if (myDisplayMode == 12) displayTargetPos();
  if (myDisplayMode == 13) displayDiffTargetCurrPos();
  // LX200 status
  updateLX200Status();
  readSendLX200();
// \loop
// read sensor values
// reads rotary encoders
void updateRotaryEncoders()
  if (val_ROT = read_rotary_ROT()) switchSelection(val_ROT);
  if (val_RA = read_rotary_RA())
    mySensorRAsec = mySensorRAsec + val_RA * secPerStepRA;
    myImpulseRA = myImpulseRA + val_RA; // for sensor test
  if (val_DEC = read_rotary_DEC())
    mySensorDECsec = mySensorDECsec + val_DEC * secPerStepDEC * myDirectionDEC;
    myImpulseDEC = myImpulseDEC + val_DEC * myDirectionDEC; // for sensor test
// reads rotary encoder button
void updateRotaryEncoderButton()
  // copy from https://arduinogetstarted.com/tutorials/arduino-button-debounce
  currentState = digitalRead(ROTARY_SW);
  if (currentState != lastFlickerableState)
    lastDebounceTime = millis();
    lastFlickerableState = currentState;
  if ((millis() - lastDebounceTime) > DEBOUNCE_DELAY)
    if (lastSteadyState == HIGH && currentState == LOW)
      switchMode();
      updateLCD();
      lastPressedTime = millis();
    else if (lastSteadyState == LOW && currentState == HIGH)
      // if button pressed > 5 seconds -> reset
      if (millis() - lastPressedTime > 5000) resetFunc(); // call reset
    lastSteadyState = currentState;
// read rotary encoder for HMI
// robust rotary encoder reading https://www.best-microcontroller-projects.com/rotary-encoder.html
// A vald CW or  CCW move returns 1,invalid returns 0.
int8_t read_rotary_ROT()
  prevNextCode_ROT <<= 2;
  if (digitalRead(ROTARY_DT)) prevNextCode_ROT |= 0x02;
  if (digitalRead(ROTARY_CLK)) prevNextCode_ROT |= 0x01;
  prevNextCode_ROT &= 0x0f;
  // If valid then store as 16 bit data.
  if  (enc_table[prevNextCode_ROT] )
    store_ROT <<= 4;
    store_ROT |= prevNextCode_ROT;
    if ((store_ROT & 0xff) == 0x2b) return -1;
    if ((store_ROT & 0xff) == 0x17) return 1;
  return 0;
// read rotary encoder for RA
int8_t read_rotary_RA()
  prevNextCode_RA <<= 2;
  if (digitalRead(SENS_RA_DT)) prevNextCode_RA |= 0x02;
  if (digitalRead(SENS_RA_CLK)) prevNextCode_RA |= 0x01;
  prevNextCode_RA &= 0x0f;
  if  (enc_table[prevNextCode_RA] )
    store_RA <<= 4;
    store_RA |= prevNextCode_RA;
    if ((store_RA & 0xff) == 0x2b) return -1;
    if ((store_RA & 0xff) == 0x17) return 1;
  return 0;
// read rotary encoder for DEC
int8_t read_rotary_DEC()
  prevNextCode_DEC <<= 2;
  if (digitalRead(SENS_DEC_DT)) prevNextCode_DEC |= 0x02;
  if (digitalRead(SENS_DEC_CLK)) prevNextCode_DEC |= 0x01;
  prevNextCode_DEC &= 0x0f;
  if  (enc_table[prevNextCode_DEC] )
    store_DEC <<= 4;
    store_DEC |= prevNextCode_DEC;
    if ((store_DEC & 0xff) == 0x2b) return -1;
    if ((store_DEC & 0xff) == 0x17) return 1;
  return 0;
// get & set of object data
// returns the type as number of a deep sky object
byte getObjectType(byte typeMagnitude)
  return (typeMagnitude / 14); // decoding of object type from typeMagnitude
// returns the type as string of a deep sky object
String getObjectTypeName(byte typeMagnitude)
  return myObjectTypeName[(typeMagnitude / 14) - 1];
// returns the magnitude of a deep sky object
String getMagnitude(byte typeMagnitude)  // calcs the right magnitude - here modulo 14 as coded
  String strFlMag = (String)(typeMagnitude % 14) +  "m";
  return strFlMag;
// returns the name of a constellation as string from a lookup tabel according to its number
String getConstName(int no)
  constStruct oneConstellation;
  // copy constellations data from PROGMEM into oneConstellation according to no
  memcpy_P (&oneConstellation, &const_PROGMEM[no], sizeof oneConstellation);
  return (String)oneConstellation.constName;
// returns the current constellation for filtering
String getCurrentConstName()
  String constellationName;
  constellationName = getConstName(myConstellationNo);
  return constellationName;
// returns the current cellestial region
String getSetregionName()
  return myregionNAME[myRegionNo];
// set reference star
void setReference()
  // copy reference data from PROGMEM into myReference according to myRefNo
  memcpy_P (&myReference, &DSO_PROGMEM[myRefNo], sizeof myReference);
  setReferenceRA_DEC();
// RA and DEC of selected target are set
void setReferenceRA_DEC()
  // transfer RA / DEC into internal format (seconds)
  myReferenceRAsec = calcRAsecFromRA(myReference.objectRA);
  myReferenceDECsec = calcDECsecFromDEC(myReference.objectDEC);
// set target
void setTarget()
  // copy reference data from PROGMEM into myTarget according to myTargetNo
  memcpy_P (&myTarget, &DSO_PROGMEM[myTargetNo], sizeof myTarget);
  setTargetRA_DEC();
void setTargetRA_DEC()
  myTargetRAsec = calcRAsecFromRA(myTarget.objectRA);
  myTargetDECsec = calcDECsecFromDEC(myTarget.objectDEC);
// \get & set of object data
// calculations and settings of positions
// calculation of RA seconds
unsigned int calcRAsecFromRA(unsigned int ra)
  int h = ra / 1000;
  int m = (ra - h * 1000) / 10;
  int s = (ra - h * 1000 - m * 10) * 6;
  unsigned int raSec = h * 3600L + m * 60 + s;
  return raSec;
// calculation of DEC seconds
long calcDECsecFromDEC(int dec)
  int deg = dec / 100;
  int m = (dec - deg * 100);
  long decSec = deg * 3600L + m * 60;
  return decSec;
// calculation of current telescope position
void calcCurrentPosition()
  myCurrentRAsec = myReferenceRAsec + myRefStartTimeSec + mySensorRAsec - millis() / 1000;
  myCurrentDECsec = myReferenceDECsec + mySensorDECsec;
// sets the sensor values to zero - needed for alignment with reference star
void resetSensorTime()
  myRefStartTimeSec = millis() / 1000;
// \calculations and settings of positions
// display information
// display the current position
void displayCurrPos()
  if (myLastRAsec != myCurrentRAsec || myLastDECsec != myCurrentDECsec)
    myLastRAsec = myCurrentRAsec;
    myLastDECsec = myCurrentDECsec;
    displayRA_DEC("Curr   ", "Coord", myCurrentRAsec, myCurrentDECsec);
// display position of selected target
void displayTargetPos()
  displayRA_DEC(getObjectName(myTarget.objectPreFixNameNo, myTarget.objectNumber, myTarget.objectConst), "Coord", myTargetRAsec, myTargetDECsec);
// calulation & display of difference between current position & target position
void displayDiffTargetCurrPos()
  long diffRAsec = myTargetRAsec - myCurrentRAsec;
  long diffDECsec = myTargetDECsec - myCurrentDECsec;
  if (myLastRAsec != myCurrentRAsec ||  myLastDECsec != myCurrentDECsec) // only if position has changed
    displayRA_DEC(getObjectName(myTarget.objectPreFixNameNo, myTarget.objectNumber, myTarget.objectConst), "Diff ", diffRAsec , diffDECsec);
// display of RA and DEC - generic use for reference stars & target
void displayRA_DEC(String text1, String text2, long rekSec, long dekSec)
  // Rektaszension //
  int sign = 1.0;
  if (rekSec < 0) sign = -1.0;
  byte s = (abs(rekSec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator // vorher int
  byte m  = (abs(rekSec / 60)) % 60;
  byte h  = (abs(rekSec / 3600)) % 24;
  lcd.setCursor(0, 0);
  printObjectName(text1);
  lcd.setCursor(8, 0);
  if (sign < 0) lcd.print(F("-"));
  else lcd.print(F("+"));
  if (h < 10) lcd.print(F(" "));
  lcd.print(h);
  lcd.print(F(":"));
  if (m < 10) lcd.print(F("0"));
  lcd.print(m);
  lcd.print(F(","));
  lcd.print(s / 6);
  // DEC // +90° - -90°
  sign = 1.0;
  if (dekSec < 0) sign = -1.0;
  s = (abs(dekSec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator
  m = (abs(dekSec / 60)) % 60;
  h = (abs(dekSec / 3600)) % 180;
  lcd.setCursor(0, 1);
  lcd.print(text2);
  lcd.setCursor(8, 1);
  lcd.print(h);
  lcd.print(ch_deg);
  lcd.print(m);
  lcd.print(F("'"));
// display current sensor values
void displaySensorValue()
  if (myImpulseRA != myLastImpulseRA || myImpulseDEC != myLastImpulseDEC)
    lcd.clear();
    lcd.print(F("Imp RA"));
    lcd.print(F("Imp DEC"));
    lcd.setCursor(10, 0);
    lcd.print(myImpulseRA);
    lcd.setCursor(10, 1);
    lcd.print(myImpulseDEC);
    myLastImpulseRA = myImpulseRA;
    myLastImpulseDEC = myImpulseDEC;
// update LCD according to selected display mode
void updateLCD()
  lcd.clear();
  if (myDisplayMode == 0)
    lcd.print(F("SpotNik   v")); // DO NOT REMOVE
    lcd.print(VERSION);
    lcd.print(F("developed by MR")); // DO NOT REMOVE
  if (myDisplayMode == 1) // main menu
    lcd.print(F(">"));
    lcd.setCursor(1, 0);
    lcd.print(menuTopic[myMenuTopicNo]); // {" reverse", "Ref","Target","region","Const","Bright","Contr","Test"};
    switch (myMenuTopicNo) {
      case 0:
        if (myDirectionDEC == 1) lcd.print(F("normal"));
        else lcd.print(F("reverse"));
      case 1:
        printObjectName(getObjectName(myReference.objectPreFixNameNo, myReference.objectNumber, myReference.objectConst));
      case 2:
        printObjectName(getObjectName(myTarget.objectPreFixNameNo, myTarget.objectNumber, myTarget.objectConst));
        //if (statusLX200 != 2) printObjectName(getObjectName(myTarget.objectPreFixNameNo,myTarget.objectNumber,myTarget.objectConst));
        //else lcd.print(F("external")); // if connection to LX200 source - no usage of internal star database
      case 3:
        lcd.print(getSetregionName());
        // if (statusLX200 != 2) lcd.print(getSetregionName());
        // else lcd.print(F("external"));
      case 4:
        lcd.print(getCurrentConstName());
        // if (statusLX200 != 2) lcd.print(getCurrentConstName());
      case 8:
        if (statusLX200 == 0) lcd.print(F("BT off"));
        if (statusLX200 == 1) lcd.print(F("BT on"));
        if (statusLX200 == 2) lcd.print(F("conn"));
    lcd.setCursor(1, 1);
    if (myMenuTopicNo + 1 < menuTopic_size)
      lcd.print(menuTopic[myMenuTopicNo + 1]);
      lcd.print(menuTopic[0]);
  if (myDisplayMode == 2)
    lcd.print(F("Direction of DEC"));
    lcd.print(F(">"));
  if (myDisplayMode == 3)
    lcd.setCursor(13, 0);
    lcd.print(getConstName(myReference.objectConst));
    lcd.print(getObjectTypeName(myReference.objectTypeMagnitude));
    lcd.setCursor(13, 1);
    lcd.print(getMagnitude(myReference.objectTypeMagnitude));
  if (myDisplayMode == 4)
    lcd.print(getConstName(myTarget.objectConst));
    lcd.print(getObjectTypeName(myTarget.objectTypeMagnitude));
    lcd.print(getMagnitude(myTarget.objectTypeMagnitude));
  if (myDisplayMode == 5)
    lcd.print(F("Celestial Region"));
    lcd.print(F(">"));
  if (myDisplayMode == 6)
    lcd.print(F("Constellation"));
    lcd.setCursor(11, 1);
    lcd.print(F(">"));
  if (myDisplayMode == 7)
    lcd.print(F("LCD Brightness"));
    lcd.print(F(">"));
    lcd.print(myLCDbacklight);
  if (myDisplayMode == 8)
    lcd.print(F("LCD Contrast"));
    lcd.print(F(">"));
    lcd.print(myLCDcontrast);
    lcd.print(F("For test"));
    lcd.print(F("turn DEC / RA"));
    myImpulseRA = 0;
    myImpulseDEC = 0;
    myLastImpulseRA = 0;
  if (myDisplayMode == 10)
    lcd.print(F("LX200 Connection"));
    lcd.print(F(">"));
    if (statusLX200 == 0) lcd.print(F("Bluetooth off"));
    if (statusLX200 == 1) lcd.print(F("Bluetooth on"));
    if (statusLX200 == 2) lcd.print(F("LX200 connected"));
// returns name of deep sky object based on coded name its number and its constellation
String getObjectName(byte objectprefixNameNo, unsigned int objectNumber, byte objectConst)
  String objectName = "";
  int indexOfHash = -1;
  DSONameStruct oneDSONameStruct;
  if (objectprefixNameNo > 0)
    // get name accordng to name number from lookup table
    memcpy_P (&oneDSONameStruct, &DSO_NAME_PROGMEM[objectprefixNameNo - 1], sizeof oneDSONameStruct);
    objectName = oneDSONameStruct.objectName;
    indexOfHash = objectName.indexOf('#');
    if (indexOfHash > -1)
      // replace char with greek char
      String charToReplace = objectName.substring(indexOfHash + 1, indexOfHash + 2);
      objectName = objectName.substring(0, indexOfHash) + objectName.substring(indexOfHash + 2); // delete # and next char from string
      // loop over the greek symbols
      for (int i; i < greekSymbols_size; i++)
        if ((String)charToReplace == (String)greekSymbols[i].originalChar)
          charToReplace = greekSymbols[i].replaceChar;
          objectName = objectName + charToReplace;
  if (objectNumber > 0)
    objectName = objectName + (String)objectNumber;
  // if object is only number,greek Symbol or max. two characters,accept 'M' - add constellation for identification
  if (objectName.charAt(1) == NULL || objectprefixNameNo == 0 || (objectName.charAt(2) == NULL && objectNumber == 0)) // oder nur Zahlen!!!
    objectName = objectName + ' ' + getConstName(objectConst);
  return objectName;
// some greek symbols are custom, print function needed
void printObjectName(String objectName)
  byte customChar = 0;
  char charAt0 = objectName.charAt(0);
  if (charAt0 == ch_def_1) customChar = 1;
  else if (charAt0 == ch_def_2) customChar = 2;
  else if (charAt0 == ch_def_3) customChar = 3;
  else if (charAt0 == ch_def_4) customChar = 4;
  else if (charAt0 == ch_def_5) customChar = 5;
  else if (charAt0 == ch_def_6) customChar = 6;
  else if (charAt0 == ch_def_7) customChar = 7;
  if (customChar > 0) lcd.write(customChar);
    lcd.print(objectName);
    return;
  lcd.print(F(" "));
  lcd.print(objectName.substring(2, 8));
// \display information
// switching
// myDisplayMode - rotary encoder for change
// 0 = welcome, 1 = top menu, 2 = change direction, 3 = set reference, 4 = set target, 5 = set region, 6 = set constellation, 7 = set LCD brightness, 8 = set LCD contrast
// 9 = sensor test, 10 = set bluetooth, 11 = show current position, 12 = show target position, 13 = show difference target - current position
void switchMode()
  saveSettingsToEeprom(); // save settings to eeprom each time the button is pressed
  if (myDisplayMode == 0) // welcome
    myDisplayMode = 1; // top menue
  else if (myDisplayMode == 1)
    myDisplayMode = myMenuTopicNo + 2;
  else if (myDisplayMode == 3) // set reference
    resetSensorTime();
    myLastDECsec = 0; // set once to zero to update display
    myDisplayMode = 11; // show current position
  else if (myDisplayMode == 4) // set target
    setTargetRA_DEC();
    myDisplayMode = 13; // show diff position
  // set direction // region // constellation // set brightness  // set contrast // sensor test // show current position // show diff position
  else if (myDisplayMode == 2 || myDisplayMode >= 5)
    myDisplayMode = 1; // return to top level menu
  lcd.clear();
// function of rotary encoder changes acording to current display mode
void switchSelection(int dir)
    myDisplayMode = 1;
    updateLCD();
  else if (myDisplayMode == 1) changeMenu(dir);
  if (myDisplayMode == 2) changeDirectionDEC(dir);
  if (myDisplayMode == 3) changeReference(dir);
  if (myDisplayMode == 4) changeTarget(dir);
  if (myDisplayMode == 5) changeregion(dir);
  if (myDisplayMode == 6) changeConstellation(dir);
  if (myDisplayMode == 7) changeLCDBacklight(dir);
  if (myDisplayMode == 8) changeLCDcontrast(dir);
  if (myDisplayMode == 10) changeBTconnection(dir);
  if (myDisplayMode == 11 || myDisplayMode == 12 || myDisplayMode == 13) changeView(dir);
  updateLCD();
// change menu topics
void changeMenu(int dir)
  if (dir == 1)
    if ((myMenuTopicNo + 1) < menuTopic_size)
      myMenuTopicNo = myMenuTopicNo + 1;
      myMenuTopicNo = 0;
  else if (dir == -1)
    if (myMenuTopicNo > 0)
      myMenuTopicNo = myMenuTopicNo - 1;
      myMenuTopicNo = menuTopic_size - 1;
// according to the direction of the DEC axis the value of the DEC sensor has to be reverted
void changeDirectionDEC(int dir)
  if (dir == 1 || dir == -1)
    if (myDirectionDEC == 1) myDirectionDEC = -1;
    else myDirectionDEC = 1;
// calls changeObject for object type reference
void changeReference (int dir)
  changeObject(dir, 'r');
// calls changeObject for object type target
void changeTarget(int dir)
  changeObject(dir, 't');
// change referenc star including filter according to selected sky region
void changeObject (int dir, char objectType)
  bool constFound = false;
  DSOstruct oneObject; // instance of reference for search & filter
  unsigned int objectNo;
  unsigned int numberOfLoops = 0;
  if (objectType == 'r')
    objectNo = myRefNo; // set start no of object
    objectNo = myTargetNo;
  while (constFound == false)
    if (dir == 1)
      if ((objectNo + 1) < DSO_PROGMEM_size)
        objectNo = objectNo + 1;
        objectNo = 0;
    if (dir == -1) // before else if - but what if no fitting star at beginning before rotary turning?
      if (objectNo > 0)
        objectNo = objectNo - 1;
        objectNo = DSO_PROGMEM_size - 1;
    memcpy_P (&oneObject, &DSO_PROGMEM[objectNo], sizeof oneObject); // get next DSO object from struct and copy it into oneObject
    // filter on a constellation
    // if a constellation is selected,object is a target and constellation of object fits to selected constellation
    if (objectType == 't' && myConstellationNo > 0 && getObjectType(oneObject.objectTypeMagnitude) > 0  && getObjectType(oneObject.objectTypeMagnitude) < 12 && oneObject.objectConst == myConstellationNo)
      constFound = true;
    // filter on regions
    else if ( (objectType == 'r' && getObjectType(oneObject.objectTypeMagnitude) == 12) || // reference stars     // filter on objects of type "reference" = no 12
              (myConstellationNo == 0 && objectType == 't' && getObjectType(oneObject.objectTypeMagnitude) > 0  && getObjectType(oneObject.objectTypeMagnitude) < 12)) // target objects
      // filter targets by constellations of the selected region
      // myregionNAME[]={"All","North","Spring","Summer","Autumn","Winter","South"};
      if (myRegionNo == 1) // region = north
        for (int i = 0; i < myNorthCONST_size; i++)
          if (oneObject.objectConst == myNorthCONST[i])
            constFound = true;
      else if (myRegionNo == 2) // region = spring
        for (int i = 0; i < mySpringCONST_size; i++)
          if (oneObject.objectConst == mySpringCONST[i])
            constFound = true;
      else if (myRegionNo == 3) // region = summer
        for (int i = 0; i < mySummerCONST_size; i++)
          if (oneObject.objectConst == mySummerCONST[i])
            constFound = true;
      else if (myRegionNo == 4) // region = autumn
        for (int i = 0; i < myAutumnCONST_size; i++)
          if (oneObject.objectConst == myAutumnCONST[i])
            constFound = true;
      else if (myRegionNo == 5) // region = winter
        for (int i = 0; i < myWinterCONST_size; i++)
          if (oneObject.objectConst == myWinterCONST[i])
            constFound = true;
      else if (myRegionNo == 6) // region = south
        for (int i = 0; i < mySouthCONST_size; i++)
          if (oneObject.objectConst == mySouthCONST[i])
            constFound = true;
      else // all constellations
        constFound = true;
  }// end while
    myRefNo = objectNo;
    myReference = oneObject; // copy selected reference object in my reference object
    myTargetNo = objectNo;
    myTarget = oneObject; // copy selected target object in my target object
    setTargetRA_DEC();
  updateLCD();
// change region
void changeregion(int dir)
  if (dir == 1)
    if ((myRegionNo + 1) < regionArraySize) {
      myRegionNo = myRegionNo + 1;
    else {
      myRegionNo = 0;
  else if (dir == -1)
    if (myRegionNo > 0) {
      myRegionNo = myRegionNo - 1;
    else {
      myRegionNo = regionArraySize - 1;
  myTargetNo = 0; // reset target,when aera has changed
  myConstellationNo = 0; // reset constellation,when aera has changed
  updateLCD();
// set constellation
void changeConstellation(int dir)
    if (dir == 1)
      if ((myConstellationNo) < constStruct_size - 1) {
        myConstellationNo = myConstellationNo + 1;
      else {
    else if (dir == -1)
      if (myConstellationNo > 0) {
        myConstellationNo = myConstellationNo - 1;
      else {
        myConstellationNo = constStruct_size - 1;
        if (myConstellationNo == myNorthCONST[i])
          constFound = true;
        if (myConstellationNo == mySpringCONST[i])
          constFound = true;
        if (myConstellationNo == mySummerCONST[i])
          constFound = true;
        if (myConstellationNo == myAutumnCONST[i])
          constFound = true;
        if (myConstellationNo == myWinterCONST[i])
          constFound = true;
        if (myConstellationNo == mySouthCONST[i])
          constFound = true;
      for (int i = 0; i < myAllCONST_size; i++)
        if (myConstellationNo == myAllCONST[i])
          constFound = true;
  myTargetNo = 0; // reset target every time when constellation was changed
  updateLCD();
// switch view between current position, diff position & target coordinates
void changeView(int dir)
  lcd.clear();
  myDisplayMode = myDisplayMode + dir;
  if (myDisplayMode > 13) myDisplayMode = 11;
  if (myDisplayMode < 11) myDisplayMode = 13;
// set LCD brightness
void changeLCDBacklight(int dir)
  myLCDbacklight = myLCDbacklight + dir * 8;
  if (myLCDbacklight > 255) myLCDbacklight = 0;
  if (myLCDbacklight < 0) myLCDbacklight = 255;
// set LCD contrast
void changeLCDcontrast(int dir)
  myLCDcontrast = myLCDcontrast + dir * 5;
  if (myLCDcontrast > 255) myLCDcontrast = 0;
  if (myLCDcontrast < 0) myLCDcontrast = 255;
void changeBTconnection(int dir)
  if (btStatus == 0) // switch BT on if off
    btStatus = 1;
    statusLX200 = 1;
    digitalWrite(BT_SWITCH, HIGH);
  else if (btStatus != 0) // switch BT off
    btStatus = 0;
    statusLX200 = 0;
    digitalWrite(BT_SWITCH, LOW);
  updateLCD();
// \switching
// LX200 communication
// set the status of LX200 to control LCD etc
void updateLX200Status()
  if (btStatus == 1)
    // if frequent feedback from LX200 - last request > 4 sek
    if ((millis() - lastLX200Message) > 4000)
      statusLX200 = 1; // BT on - but no LX200 connection
      statusLX200 = 2; // LX200 connected
  // LX200 status changend - update lcd in relevant views (main menu & BT)
  if (statusLX200 != statusLX200old && (myDisplayMode == 10 || myDisplayMode == 1))
    updateLCD();
    statusLX200old = statusLX200;
// called if a LX200 message was received
void receivedLX200message() // received
  lastLX200Message = millis();
// read the bluetooth message and trigger functions according to message type
void readSendLX200()
  if (Serial.available())
    char message[14] = "";
    byte i = 0;
    while (Serial.available() > 0)
      char a = Serial.read(); // Stores current byte
      message[i] += a;      // Append current byte to message String
      delay(10);
      i++;
    // all LX200 info from https://www.meade.com/support/TelescopeProtocol_2010-10.pdf
    // LX200 message :GR#
    // Get Telescope RA
    // Returns: HH:MM.T#  or  HH:MM:SS#Depending which precision is set for the telescope
    if (message[0] == ':' && message[1] == 'G' && message[2] == 'R' && message[3] == '#')
      receivedLX200message();
      sendLX200RA();
    // LX200 message :GD# or :RS#:GD# or :RM#:GD#
    // Get Telescope Declination.
    // Returns: sDD*MM# or sDD*MM’SS#Depending upon the current precision setting for the telescope.
    if (message[0] == ':' && message[1] == 'G' && message[2] == 'D' && message[3] == '#' ||
        message[4] == ':' && message[5] == 'G' && message[6] == 'D' && message[7] == '#')
      sendLX200DEC();
    // LX200 message :CM#
    // Synchronizes the telescope's position with the currently selected database object's coordinates.
    // Returns:LX200's - a "#" terminated string with the name of the object that was synced
    if (message[0] == ':' && message[1] == 'C' && message[2] == 'M')
      Serial.print("#");
    // LX200 message :SrHH:MM.T# or :SrHH:MM:SS#
    // Set target object RA to HH:MM.T or HH:MM:SS depending on the current precision setting.
    // Returns:0 – Invalid1 - Valid
    // output HHMM(S/6)
    if (message[0] == ':' && message[1] == 'S' && message[2] == 'r')
      setRAtoLX200message(message);
    // LX200 message :SdsDD*MM#
    // Set target object declination to sDD*MM or sDD*MM:SS depending on the current precision setting
    // Returns:1 - Dec Accepted0 – Dec invalid
    // output sHHMM
    if (message[0] == ':' && message[1] == 'S' && message[2] == 'd')
      setDECtoLX200message(message);
    //  Serial.print("BT message "); // for debugging
    //  Serial.println(message);
// set RA coordinates of placeholder externalobject to received LX200 message
void setRAtoLX200message(char message[10])
    long(atoi(message + 3)) * 1000 + // HH // access at array different when using atoi - use address
    long(atoi(message + 6)) * 10; // MM - Minuten passen noch nicht bei zweistelligen gibt es Fehler
  if (message[8] == ':') // : or .
    externalObject.objectRA = externalObject.objectRA +
                              long(atoi(message + 9)) / 6; // SS/6
  else if (message[8] == '.')
    externalObject.objectRA = externalObject.objectRA + atoi(message + 9); // T
  Serial.println(); // leave this command, as otherwise no update on goto from LX200 source
// set DEC coordinates of placeholder externalobject to received LX200 message & update the (reference or target) object
void setDECtoLX200message(char message[9])
  int sign;
  if (message[3] == '-') sign = -1;
  else sign = 1;
    sign * ( // s
      long(atoi(message + 4)) * 100 + // DD
      long(atoi(message + 7))); // MM
  // assumption - first RA then DEC - then set target to external object
  if (myDisplayMode == 3 || myDisplayMode == 11) // if view shows reference selection or current position then copy external object into reference object
    externalObject.objectTypeMagnitude = 168;
    myReference = externalObject; // copy external object to my reference object
    resetSensorTime();
  else // in all other cases copy to target
    externalObject.objectTypeMagnitude = 182;
    myTarget = externalObject; // copy external object to my target object
    setTargetRA_DEC();
  updateLCD();
// send current RA coordinate of telescope from SpotNik to LX200 server (e.g. Sky Safari)
void sendLX200RA()
  byte s = (abs(myCurrentRAsec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator
  byte m  = (abs(myCurrentRAsec / 60)) % 60;
  byte h  = (abs(myCurrentRAsec / 3600)) % 24;
  String posString = "";
  if (h < 10) posString = "0";
  posString = posString + String(h);
  posString = posString + ":";
  if (m < 10) posString = posString + "0";
  posString = posString + String(m);
  if (s < 10) posString = posString + "0";
  posString = posString + String(s);
  posString = posString + "#";
  Serial.print(posString);
// send current DEC coordinate of telescope from SpotNik to LX200 server (e.g. Sky Safari)
void sendLX200DEC()
  byte s = (abs(myCurrentDECsec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator
  byte m = (abs(myCurrentDECsec / 60)) % 60;
  byte h = (abs(myCurrentDECsec / 3600)) % 180;
  if (myCurrentDECsec > 0) posString = "+";
  else posString = "-";
  posString = posString + "*";
// \LX200 communication
// EEPROM
// save relevant data for next startup (e.g. target no,LCD brightness)
void saveSettingsToEeprom()
  // Serial.print(F("freeMemory()=")); //only used for testing
  // Serial.println(freeMemory());
  byte addr = EEPROM_VALUE_ADDR_SIGNATURE;
  byte myTargetNoLowByte = lowByte(myTargetNo); // myTargetNo is of type int - transfer into two bytes
  byte myTargetNoHighByte = highByte(myTargetNo);
  byte myReferenceNoLowByte = lowByte(myRefNo); // myTargetNo is of type int - transfer into two bytes
  byte myReferenceNoHighByte = highByte(myRefNo);
  EEPROM.update(addr, EEPROM_SIGNATURE); // use update for longer eeprom life
  addr += sizeof(EEPROM_SIGNATURE);
  EEPROM.update(addr, myReferenceNoLowByte);
  addr += sizeof(myReferenceNoLowByte);
  EEPROM.update(addr, myReferenceNoHighByte);
  addr += sizeof(myReferenceNoHighByte);
  EEPROM.update(addr, myTargetNoLowByte);
  addr += sizeof(myTargetNoLowByte);
  EEPROM.update(addr, myTargetNoHighByte);
  addr += sizeof(myTargetNoHighByte);
  EEPROM.update(addr, myRegionNo);
  addr += sizeof(myRegionNo);
  EEPROM.update(addr, myConstellationNo);
  addr += sizeof(myConstellationNo);
  EEPROM.update(addr, myLCDbacklight);
  addr += sizeof(myLCDbacklight);
  EEPROM.update(addr, myLCDcontrast);
// load relevant data at startup (e.g. target no, LCD brightness)
void getSettingsFromEeprom()
  byte addr = EEPROM_VALUE_ADDR_SIGNATURE, signature = 0, value, myReferenceNoLowByte, myReferenceNoHighByte, myTargetNoLowByte, myTargetNoHighByte; // myTargetNo is of type int,need to concatenated from two bytes
  EEPROM.get(addr, signature);
  if (signature != EEPROM_SIGNATURE) return; // maybe data from another sketch
  EEPROM.get(addr, value);
  myReferenceNoLowByte = value;
  myReferenceNoHighByte = value;
  if (value >= 0 && value <= 32767)  myRefNo = word(myReferenceNoHighByte, myReferenceNoLowByte);
  myTargetNoLowByte = value;
  myTargetNoHighByte = value;
  if (value >= 0 && value <= 32767)  myTargetNo = word(myTargetNoHighByte, myTargetNoLowByte);
  if (value >= 0 && value <= 255) myRegionNo = value;
  if (value >= 0 && value <= 255) myConstellationNo = value;
  if (value >= 0 && value <= 255) myLCDbacklight = value;
  if (value >= 0 && value <= 255) myLCDcontrast = value;
// \EEPROM
Hi there, I don't really understand how to program so can't speak the technical language your probably quite used to using especially as I'm an absolute beginner?novice......I'll send you the code and the Error messages to see if you can see anything. Here's the Very Long code.......
    SpotNik - by Max Reinecke
    Created: May 2021
    SpotNik is software for a stepto system for telescopes
     This program is free software: you can redistribute it and/or modify
     it under the terms of the GNU General Public License as published by
     the Free Software Foundation, either version 3 of the License, or
     (at your option) any later version.
     This program is distributed in the hope that it will be useful,
     but WITHOUT ANY WARRANTY; without even the implied warranty of
     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
     GNU General Public License for more details.
     You should have received a copy of the GNU General Public License
     along with this program.  If not, see <http://www.gnu.org/licenses/>.
#define VERSION 2.0
  // to be changed by user according to EQ mount - see instructions
  // total numbers of impulse of the rotary encoder of RA axis when turned 24h
#define IMPULSE24HRA 2772 // 6h - 690 Impulse --> 24h - 4 * 693 = 2772 / ~ 1:138
  //  total numbers of impulse of the rotary encoder of DEC axis when turned 360° // +/- for correct direction
#define IMPULSE360DEGDEC 1784  // 90° - 446 Impulse --> 360° - 4 * 446 = 1784 / ~ 1:88
#include <LiquidCrystal.h> // I2C LCD arbeitet nicht vernünftig mit Rotary Encoder zusammen,daher normales nehmen
#include <EEPROM.h>
  //#include <MemoryFree.h> // only used for testing
  // LCD
#define LCD_CONTRAST_PIN 11 //  LCD contrast - V0 // use high frequency PWM to avoid flickering (Leonardo,Micro,Yún 3 and 11: 980 Hz // Mega pins 4 and 13: 980 Hz)
#define LCD_BACKLIGHT_PIN 10 // LCD backlight - LCD A
  // EEPROM
#define EEPROM_SIGNATURE 117 // value 0-255 (byte) - signature/mark to recognize if the value fits to this sketch
#define EEPROM_VALUE_ADDR_SIGNATURE 0
  // rotary enoder HMI
#define ROTARY_SW 3 // use interrupt pin - digital pins for interrupts on Micro,Leonardo and other 32u4 based 0,1,2,3,7
#define ROTARY_DT 4
#define ROTARY_CLK 5
  // Sensor RA
#define SENS_RA_DT A0 // analog pins used as UNO has not that many digital pins
#define SENS_RA_CLK A1
  // Sensor DEC
#define SENS_DEC_DT A2
#define SENS_DEC_CLK A3
  // LX200 connection
#define BT_SWITCH 2
  // lookup table with names of deep sky objects
  struct DSONameStruct
    char objectName[9];
  const struct DSONameStruct DSO_NAME_PROGMEM[202] PROGMEM =
    {"3C273"},
    {"B"},
    {"IC"},
    {"M"},
    {"NGC"},
    {"#a"},
    {"#aA"},
    {"#aB"},
    {"#b"},
    {"#c"},
    {"#d"},
    {"#e"},
    {"#e1"},
    {"#e2"},
    {"#g"},
    {"#h"},
    {"#i"},
    {"#j"},
    {"#k"},
    {"#l"},
    {"#m"},
    {"#n"},
    {"#o"},
    {"#p"},
    {"#q"},
    {"#r"},
    {"#s"},
    {"#t"},
    {"#u"},
    {"#w"},
    {"#x"},
    {"#z"},
    {"AC"},
    {"Achernar"},
    {"Acrab"},
    {"Acrux"},
    {"Adhara"},
    {"Agena"},
    {"Alamak"},
    {"Aldebara"},
    {"Alderami"},
    {"AlDhanab"},
    {"Algenib"},
    {"Algieba"},
    {"Algol"},
    {"Alhena"},
    {"Alioth"},
    {"Alkaid"},
    {"AlNair"},
    {"Alnilam"},
    {"Alnitak"},
    {"Alphard"},
    {"Alphecca"},
    {"Alpherat"},
    {"Alsuhail"},
    {"Altair"},
    {"Aludra"},
    {"Ankaa"},
    {"Antares"},
    {"AQ"},
    {"Arcturus"},
    {"Arneb"},
    {"Aspidisk"},
    {"Atria"},
    {"Avior"},
    {"AW"},
    {"AX"},
    {"BD"},
    {"Becrux"},
    {"Bellatri"},
    {"Betelgeu"},
    {"BF"},
    {"BG"},
    {"BL"},
    {"BM"},
    {"BX"},
    {"Canopus"},
    {"Capella"},
    {"Caph"},
    {"Castor"},
    {"Cih"},
    {"CY"},
    {"Deneb"},
    {"DenebKai"},
    {"Denebola"},
    {"Diphda"},
    {"DR"},
    {"Dschubba"},
    {"Dubhe"},
    {"EL"},
    {"ElNath"},
    {"Eltanin"},
    {"Enif"},
    {"FO"},
    {"Fomalhau"},
    {"FU"},
    {"Gacrux"},
    {"Gemma"},
    {"Gienah"},
    {"Girtab"},
    {"GK"},
    {"GY"},
    {"H"},
    {"Hadar"},
    {"Hamal"},
    {"Han"},
    {"HD"},
    {"HJ"},
    {"HK"},
    {"HN"},
    {"Izar"},
    {"JC"},
    {"KausAust"},
    {"Kochab"},
    {"KooShe"},
    {"Markab"},
    {"Menkalin"},
    {"Menkar"},
    {"Menkent"},
    {"Merak"},
    {"Miaplaci"},
    {"Mimosa"},
    {"Mintaka"},
    {"Mirach"},
    {"Mirfak"},
    {"Mirzam"},
    {"Mizar"},
    {"Naos"},
    {"NQ"},
    {"NSV"},
    {"Nunki"},
    {"O#F"},
    {"Peacock"},
    {"Phecda"},
    {"Polaris"},
    {"Pollux"},
    {"Procyon"},
    {"PZ6"},
    {"R"},
    {"RasAlhag"},
    {"Regulus"},
    {"Rigel"},
    {"RigilKen"},
    {"RR"},
    {"RS"},
    {"RT"},
    {"RU"},
    {"RV"},
    {"RX"},
    {"RY"},
    {"RZ"},
    {"S"},
    {"S605"},
    {"Sabik"},
    {"Sadr"},
    {"Saiph"},
    {"SAO"},
    {"Sargas"},
    {"Scheat"},
    {"Schedar"},
    {"Shaula"},
    {"SHJ"},
    {"Sirius"},
    {"Spica"},
    {"SS"},
    {"ST"},
    {"SU"},
    {"SV"},
    {"SY"},
    {"SZ"},
    {"T"},
    {"TT"},
    {"TU"},
    {"Tureis"},
    {"TW"},
    {"TX"},
    {"U"},
    {"UU"},
    {"UV"},
    {"UX"},
    {"UY"},
    {"V"},
    {"Vega"},
    {"VW"},
    {"VX"},
    {"VY"},
    {"W"},
    {"Wei"},
    {"Wezen"},
    {"WO"},
    {"WW"},
    {"WX"},
    {"WZ"},
    {"X"},
    {"XS"},
    {"XX"},
    {"Y"},
    {"Z"},
    {"Zozma"},
    {"β648"},
    {"#F"},
    {"extern"}
  // data of deep sky objects
  struct DSOstruct
    byte objectPreFixNameNo; // number of name for lookup table
    unsigned int objectNumber; // if name contains a number
    byte objectTypeMagnitude; // object type & magnitude coded in one byte
    byte objectConst; // constellation of object
    unsigned int objectRA; //HHMM(SS/6)
    int objectDEC; //sHHMM
  DSOstruct myTarget; // object to store data of selected target
  DSOstruct myReference; // object to store data of selected target
  const unsigned int DSO_PROGMEM_size = 1204;
  const struct DSOstruct DSO_PROGMEM[DSO_PROGMEM_size] PROGMEM =
    {1, 0, 27, 86, 12291, 203},
    {2, 33, 42, 60, 5409, -228},
    {2, 65, 42, 77, 18027, -2750},
    {2, 86, 42, 59, 17196, -2642},
    {3, 342, 54, 11, 3468, 6806},
    {3, 405, 66, 8, 5165, 3421},
    {3, 410, 64, 8, 5227, 3325},
    {3, 434, 67, 60, 5410, -227},
    {3, 1396, 74, 16, 21391, 5730},
    {3, 4406, 95, 50, 14224, -4409},
    {3, 5067, 64, 31, 20508, 4421},
    {3, 5146, 80, 31, 21534, 4716},
    {4, 1, 106, 78, 5345, 2201},
    {4, 2, 119, 5, 21335, -49},
    {4, 3, 118, 30, 13422, 2823},
    {4, 4, 117, 72, 16236, -2632},
    {4, 5, 118, 74, 15186, 205},
    {4, 6, 130, 72, 17403, -3215},
    {4, 7, 129, 72, 17539, -3448},
    {4, 8, 75, 77, 18037, -2423},
    {4, 9, 120, 59, 17192, -1831},
    {4, 10, 119, 59, 16571, -406},
    {4, 11, 132, 73, 18511, -616},
    {4, 12, 118, 59, 16472, -157},
    {4, 13, 118, 40, 16417, 3628},
    {4, 14, 120, 59, 17376, -315},
    {4, 15, 118, 62, 21300, 1210},
    {4, 16, 76, 74, 18188, -1347},
    {4, 17, 76, 77, 18208, -1611},
    {4, 18, 133, 77, 18199, -1708},
    {4, 19, 119, 59, 17026, -2616},
    {4, 20, 76, 77, 18027, -2258},
    {4, 21, 132, 77, 18042, -2229},
    {4, 22, 117, 77, 18364, -2354},
    {4, 23, 132, 77, 17571, -1859},
    {4, 24, 129, 77, 18266, -1823},
    {4, 25, 131, 77, 18318, -1907},
    {4, 26, 134, 73, 18452, -924},
    {4, 27, 91, 88, 19596, 2243},
    {4, 28, 119, 77, 18245, -2452},
    {4, 29, 133, 31, 20239, 3832},
    {4, 30, 119, 12, 21404, -2311},
    {4, 31, 45, 1, 427, 4116},
    {4, 32, 50, 1, 427, 4052},
    {4, 33, 48, 81, 1339, 3039},
    {4, 34, 131, 63, 2421, 4247},
    {4, 35, 131, 38, 6089, 2421},
    {4, 36, 132, 8, 5363, 3408},
    {4, 37, 132, 8, 5523, 3233},
    {4, 38, 132, 8, 5287, 3551},
    {4, 39, 131, 31, 21322, 4826},
    {4, 40, 149, 83, 12219, 5806},
    {4, 41, 131, 20, 6460, -2045},
    {4, 42, 74, 60, 5353, -523},
    {4, 43, 63, 60, 5355, -516},
    {4, 44, 129, 22, 8400, 1940},
    {4, 45, 71, 78, 3470, 2407},
    {4, 46, 132, 68, 7418, -1449},
    {4, 47, 130, 68, 7366, -1429},
    {4, 48, 132, 42, 8137, -545},
    {4, 49, 50, 86, 12298, 800},
    {4, 50, 132, 55, 7025, -823},
    {4, 51, 50, 30, 13299, 4712},
    {4, 52, 133, 14, 23242, 6135},
    {4, 53, 120, 24, 13129, 1810},
    {4, 54, 120, 77, 18551, -3029},
    {4, 55, 118, 77, 19400, -3058},
    {4, 56, 120, 52, 19166, 3011},
    {4, 57, 93, 52, 18536, 3302},
    {4, 58, 52, 86, 12377, 1149},
    {4, 59, 52, 86, 12420, 1139},
    {4, 60, 51, 86, 12437, 1133},
    {4, 61, 52, 86, 12219, 428},
    {4, 62, 118, 59, 17012, -3007},
    {4, 63, 51, 30, 13158, 4202},
    {4, 64, 51, 24, 12567, 2141},
    {4, 65, 51, 46, 11189, 1305},
    {4, 66, 51, 46, 11202, 1300},
    {4, 67, 133, 22, 8508, 1149},
    {4, 68, 119, 42, 12395, -2645},
    {4, 69, 120, 77, 18314, -3221},
    {4, 70, 120, 77, 18432, -3218},
    {4, 71, 120, 76, 19538, 1847},
    {4, 72, 121, 5, 20535, -1232},
    {4, 73, 136, 5, 20590, -1238},
    {4, 74, 51, 67, 1367, 1547},
    {4, 75, 121, 77, 20061, -2155},
    {4, 76, 94, 63, 1423, 5135},
    {4, 77, 51, 17, 2427, -1},
    {4, 78, 64, 60, 5468, 5},
    {4, 79, 120, 47, 5242, -2431},
    {4, 80, 119, 72, 16170, -2259},
    {4, 81, 49, 83, 9556, 6904},
    {4, 82, 50, 83, 9559, 6941},
    {4, 83, 50, 42, 13370, -2952},
    {4, 84, 51, 86, 12251, 1253},
    {4, 85, 51, 24, 12254, 1811},
    {4, 86, 51, 86, 12262, 1257},
    {4, 87, 51, 86, 12308, 1223},
    {4, 88, 52, 24, 12320, 1425},
    {4, 89, 52, 86, 12357, 1233},
    {4, 90, 52, 86, 12368, 1310},
    {4, 91, 52, 24, 12354, 1430},
    {4, 92, 119, 40, 17171, 4308},
    {4, 93, 132, 68, 7445, -2351},
    {4, 94, 50, 30, 12509, 4107},
    {4, 95, 52, 46, 10440, 1142},
    {4, 96, 51, 46, 10468, 1149},
    {4, 97, 95, 83, 11148, 5501},
    {4, 98, 52, 24, 12138, 1454},
    {4, 99, 52, 24, 12188, 1425},
    {4, 100, 51, 24, 12229, 1549},
    {4, 101, 50, 83, 14032, 5421},
    {4, 102, 52, 34, 15065, 5546},
    {4, 103, 133, 14, 1334, 6039},
    {4, 104, 50, 86, 12400, -1137},
    {4, 105, 51, 46, 10478, 1235},
    {4, 106, 50, 30, 12190, 4718},
    {4, 107, 120, 59, 16325, -1303},
    {4, 108, 52, 83, 11115, 5540},
    {4, 109, 52, 83, 11576, 5322},
    {4, 110, 50, 1, 404, 4141},
    {5, 40, 94, 16, 130, 7231},
    {5, 55, 50, 71, 149, -3911},
    {5, 129, 133, 14, 300, 6013},
    {5, 136, 137, 14, 315, 6131},
    {5, 147, 52, 14, 332, 4830},
    {5, 157, 52, 17, 348, -824},
    {5, 185, 51, 14, 390, 4820},
    {5, 188, 134, 16, 475, 8514},
    {5, 210, 52, 17, 406, -1352},
    {5, 225, 133, 14, 436, 6146},
    {5, 246, 94, 17, 471, -1152},
    {5, 247, 51, 17, 471, -2046},
    {5, 253, 49, 71, 476, -2518},
    {5, 278, 52, 14, 521, 4733},
    {5, 281, 77, 14, 530, 5637},
    {5, 288, 120, 71, 528, -2635},
    {5, 300, 50, 71, 549, -3741},
    {5, 381, 135, 14, 1084, 6135},
    {5, 404, 52, 1, 1094, 3543},
    {5, 436, 135, 14, 1160, 5849},
    {5, 457, 132, 14, 1195, 5817},
    {5, 488, 52, 67, 1218, 515},
    {5, 524, 52, 67, 1248, 932},
    {5, 559, 136, 14, 1295, 6319},
    {5, 584, 52, 17, 1313, -652},
    {5, 596, 52, 17, 1329, -702},
    {5, 613, 52, 71, 1343, -2925},
    {5, 615, 53, 17, 1351, -720},
    {5, 637, 134, 14, 1431, 6402},
    {5, 654, 133, 14, 1440, 6153},
    {5, 659, 134, 14, 1444, 6040},
    {5, 663, 133, 14, 1460, 6115},
    {5, 672, 52, 81, 1479, 2726},
    {5, 720, 52, 17, 1530, -1344},
    {5, 752, 132, 1, 1577, 3740},
    {5, 772, 52, 7, 1593, 1900},
    {5, 779, 53, 17, 1597, -558},
    {5, 869, 131, 63, 2191, 5708},
    {5, 884, 132, 63, 2225, 5709},
    {5, 891, 52, 1, 2226, 4221},
    {5, 908, 52, 17, 2231, -2114},
    {5, 925, 52, 81, 2273, 3335},
    {5, 936, 52, 17, 2276, -109},
    {5, 986, 52, 37, 2336, -3903},
    {5, 1022, 53, 17, 2385, -641},
    {5, 1023, 51, 63, 2404, 3904},
    {5, 1027, 133, 14, 2426, 6136},
    {5, 1052, 52, 17, 2411, -815},
    {5, 1055, 52, 17, 2418, 27},
    {5, 1084, 52, 36, 2460, -735},
    {5, 1097, 52, 37, 2463, -3017},
    {5, 1232, 52, 36, 3098, -2035},
    {5, 1245, 134, 63, 3147, 4714},
    {5, 1261, 120, 41, 3123, -5513},
    {5, 1275, 53, 63, 3198, 4131},
    {5, 1291, 51, 36, 3173, -4106},
    {5, 1300, 52, 36, 3197, -1925},
    {5, 1316, 51, 37, 3227, -3713},
    {5, 1325, 53, 36, 3244, -2133},
    {5, 1332, 52, 36, 3263, -2120},
    {5, 1342, 133, 63, 3317, 3722},
    {5, 1360, 93, 37, 3332, -2552},
    {5, 1365, 52, 37, 3336, -3608},
    {5, 1374, 53, 37, 3353, -3514},
    {5, 1380, 54, 37, 3368, -3444},
    {5, 1398, 52, 37, 3389, -2620},
    {5, 1399, 52, 37, 3385, -3527},
    {5, 1407, 52, 36, 3402, -1835},
    {5, 1433, 52, 41, 3420, -4713},
    {5, 1444, 133, 63, 3494, 5240},
    {5, 1491, 70, 63, 4032, 5119},
    {5, 1499, 61, 63, 4032, 3622},
    {5, 1501, 96, 11, 4070, 6055},
    {5, 1502, 133, 11, 4078, 6220},
    {5, 1513, 134, 63, 4099, 4931},
    {5, 1514, 94, 78, 4093, 3047},
    {5, 1528, 132, 63, 4153, 5113},
    {5, 1532, 52, 36, 4121, -3252},
    {5, 1535, 93, 36, 4143, -1244},
    {5, 1545, 132, 63, 4209, 5015},
    {5, 1549, 52, 33, 4158, -5536},
    {5, 1566, 52, 33, 4200, -5456},
    {5, 1647, 132, 78, 4459, 1906},
    {5, 1664, 134, 8, 4511, 4341},
    {5, 1672, 52, 33, 4457, -5915},
    {5, 1788, 70, 60, 5069, -320},
    {5, 1792, 52, 23, 5052, -3759},
    {5, 1808, 52, 23, 5077, -3731},
    {5, 1817, 134, 78, 5124, 1641},
    {5, 1851, 119, 23, 5141, -4003},
    {5, 1857, 133, 8, 5201, 3921},
    {5, 1907, 134, 8, 5281, 3520},
    {5, 1909, 70, 36, 5045, -716},
    {5, 1931, 80, 8, 5314, 3415},
    {5, 1961, 53, 11, 5421, 6923},
    {5, 1964, 52, 47, 5334, -2157},
    {5, 1973, 63, 60, 5351, -444},
    {5, 1980, 73, 60, 5354, -555},
    {5, 1999, 70, 60, 5364, -643},
    {5, 2022, 95, 60, 5421, 905},
    {5, 2024, 70, 60, 5417, -151},
    {5, 2126, 136, 8, 6025, 4952},
    {5, 2129, 133, 38, 6007, 2319},
    {5, 2158, 135, 38, 6074, 2406},
    {5, 2169, 132, 60, 6084, 1358},
    {5, 2175, 77, 60, 6096, 2029},
    {5, 2185, 70, 55, 6110, -614},
    {5, 2186, 135, 60, 6121, 528},
    {5, 2194, 135, 60, 6138, 1248},
    {5, 2204, 135, 20, 6155, -1840},
    {5, 2207, 52, 20, 6164, -2122},
    {5, 2215, 134, 55, 6208, -717},
    {5, 2232, 130, 55, 6280, -451},
    {5, 2237, 76, 55, 6309, 503},
    {5, 2238, 62, 55, 6307, 501},
    {5, 2239, 131, 55, 6319, 457},
    {5, 2245, 70, 55, 6327, 1009},
    {5, 2251, 133, 55, 6346, 822},
    {5, 2261, 70, 55, 6392, 845},
    {5, 2264, 74, 55, 6410, 954},
    {5, 2266, 136, 38, 6433, 2658},
    {5, 2281, 131, 8, 6483, 4105},
    {5, 2286, 134, 55, 6477, -309},
    {5, 2300, 53, 16, 7323, 8543},
    {5, 2301, 132, 55, 6518, 28},
    {5, 2304, 136, 38, 6552, 1759},
    {5, 2311, 136, 55, 6578, -437},
    {5, 2324, 134, 55, 7041, 103},
    {5, 2335, 133, 55, 7068, -1002},
    {5, 2343, 133, 55, 7081, -1037},
    {5, 2346, 96, 55, 7094, -48},
    {5, 2353, 133, 55, 7145, -1016},
    {5, 2354, 133, 20, 7143, -2542},
    {5, 2355, 136, 38, 7170, 1345},
    {5, 2359, 70, 20, 7185, -1314},
    {5, 2360, 133, 20, 7177, -1538},
    {5, 2362, 130, 20, 7187, -2457},
    {5, 2371, 95, 38, 7256, 2929},
    {5, 2372, 95, 38, 7256, 2930},
    {5, 2383, 134, 20, 7247, -2057},
    {5, 2384, 133, 20, 7252, -2101},
    {5, 2392, 93, 38, 7292, 2055},
    {5, 2395, 134, 38, 7272, 1337},
    {5, 2403, 51, 11, 7368, 6536},
    {5, 2419, 122, 51, 7381, 3853},
    {5, 2420, 134, 38, 7384, 2134},
    {5, 2421, 134, 68, 7362, -2037},
    {5, 2423, 133, 68, 7371, -1352},
    {5, 2438, 95, 68, 7418, -1444},
    {5, 2439, 133, 68, 7408, -3142},
    {5, 2440, 95, 68, 7419, -1813},
    {5, 2467, 77, 68, 7525, -2626},
    {5, 2477, 132, 68, 7522, -3832},
    {5, 2479, 136, 68, 7551, -1742},
    {5, 2482, 133, 68, 7552, -2415},
    {5, 2489, 134, 68, 7563, -3004},
    {5, 2506, 134, 55, 8000, -1046},
    {5, 2509, 135, 68, 8008, -1903},
    {5, 2527, 133, 68, 8050, -2809},
    {5, 2539, 133, 68, 8106, -1249},
    {5, 2547, 131, 85, 8102, -4912},
    {5, 2567, 133, 68, 8185, -3039},
    {5, 2571, 133, 68, 8189, -2945},
    {5, 2613, 52, 69, 8334, -2258},
    {5, 2627, 134, 69, 8372, -2957},
    {5, 2655, 52, 11, 8556, 7813},
    {5, 2681, 52, 83, 8535, 5119},
    {5, 2683, 52, 51, 8527, 3325},
    {5, 2742, 53, 83, 9076, 6029},
    {5, 2768, 52, 83, 9116, 6002},
    {5, 2775, 52, 22, 9103, 702},
    {5, 2782, 53, 51, 9141, 4007},
    {5, 2784, 52, 42, 9123, -2410},
    {5, 2787, 52, 83, 9193, 6912},
    {5, 2811, 53, 42, 9162, -1619},
    {5, 2835, 52, 42, 9179, -2221},
    {5, 2841, 51, 83, 9220, 5059},
    {5, 2859, 52, 49, 9243, 3431},
    {5, 2867, 94, 13, 9214, -5819},
    {5, 2903, 51, 46, 9322, 2130},
    {5, 2950, 52, 83, 9426, 5851},
    {5, 2964, 53, 46, 9429, 3151},
    {5, 2974, 52, 75, 9426, -342},
    {5, 2976, 52, 83, 9472, 6755},
    {5, 2985, 52, 83, 9504, 7217},
    {5, 2997, 51, 2, 9456, -3111},
    {5, 3077, 52, 83, 10033, 6844},
    {5, 3079, 52, 83, 10020, 5541},
    {5, 3109, 52, 42, 10031, -2610},
    {5, 3115, 51, 75, 10052, -743},
    {5, 3132, 92, 85, 10070, -4026},
    {5, 3147, 52, 34, 10169, 7324},
    {5, 3166, 52, 75, 10138, 326},
    {5, 3169, 52, 75, 10142, 328},
    {5, 3184, 52, 83, 10183, 4125},
    {5, 3190, 53, 46, 10181, 2150},
    {5, 3193, 52, 46, 10184, 2154},
    {5, 3198, 52, 83, 10199, 4533},
    {5, 3201, 119, 85, 10176, -4625},
    {5, 3226, 53, 46, 10234, 1954},
    {5, 3227, 52, 46, 10235, 1952},
    {5, 3242, 93, 42, 10248, -1839},
    {5, 3245, 52, 49, 10273, 2830},
    {5, 3277, 53, 49, 10329, 2831},
    {5, 3294, 53, 49, 10363, 3719},
    {5, 3310, 52, 83, 10388, 5330},
    {5, 3344, 52, 49, 10435, 2455},
    {5, 3359, 52, 83, 10466, 6313},
    {5, 3372, 59, 13, 10451, -5952},
    {5, 3377, 52, 46, 10477, 1359},
    {5, 3384, 52, 46, 10483, 1238},
    {5, 3395, 54, 49, 10498, 3259},
    {5, 3412, 52, 46, 10509, 1325},
    {5, 3414, 53, 49, 10513, 2758},
    {5, 3432, 53, 49, 10525, 3637},
    {5, 3486, 52, 49, 11004, 2859},
    {5, 3489, 52, 46, 11003, 1354},
    {5, 3504, 53, 49, 11032, 2758},
    {5, 3521, 51, 46, 11058, -2},
    {5, 3532, 129, 13, 11052, -5844},
    {5, 3593, 52, 46, 11146, 1249},
    {5, 3607, 52, 46, 11169, 1803},
    {5, 3608, 52, 46, 11170, 1809},
    {5, 3610, 52, 83, 11184, 5847},
    {5, 3613, 52, 83, 11186, 5800},
    {5, 3619, 53, 83, 11194, 5745},
    {5, 3621, 52, 42, 11183, -3249},
    {5, 3626, 53, 46, 11201, 1821},
    {5, 3628, 52, 46, 11203, 1335},
    {5, 3631, 52, 83, 11210, 5310},
    {5, 3640, 52, 46, 11211, 314},
    {5, 3655, 53, 46, 11229, 1635},
    {5, 3665, 52, 83, 11247, 3846},
    {5, 3675, 52, 83, 11261, 4335},
    {5, 3686, 53, 46, 11277, 1713},
    {5, 3717, 53, 42, 11315, -3019},
    {5, 3718, 52, 83, 11326, 5304},
    {5, 3726, 52, 83, 11333, 4702},
    {5, 3729, 53, 83, 11338, 5308},
    {5, 3810, 52, 46, 11410, 1128},
    {5, 3813, 53, 83, 11413, 3633},
    {5, 3877, 53, 83, 11461, 4730},
    {5, 3893, 52, 83, 11486, 4843},
    {5, 3898, 52, 83, 11493, 5605},
    {5, 3900, 53, 46, 11492, 2701},
    {5, 3912, 54, 46, 11501, 2629},
    {5, 3918, 92, 15, 11503, -5711},
    {5, 3923, 52, 42, 11510, -2848},
    {5, 3938, 52, 83, 11528, 4407},
    {5, 3941, 52, 83, 11529, 3659},
    {5, 3945, 52, 83, 11532, 6040},
    {5, 3949, 53, 83, 11537, 4752},
    {5, 3953, 52, 83, 11538, 5219},
    {5, 3962, 52, 27, 11547, -1359},
    {5, 3982, 53, 83, 11565, 5507},
    {5, 3998, 52, 83, 11579, 5527},
    {5, 4013, 53, 83, 11585, 4357},
    {5, 4026, 52, 83, 11594, 5058},
    {5, 4027, 53, 29, 11595, -1916},
    {5, 4030, 52, 86, 12004, -106},
    {5, 4036, 52, 83, 12015, 6154},
    {5, 4038, 52, 29, 12019, -1852},
    {5, 4039, 52, 29, 12019, -1853},
    {5, 4041, 53, 83, 12022, 6208},
    {5, 4051, 52, 83, 12032, 4432},
    {5, 4085, 54, 83, 12054, 5021},
    {5, 4088, 52, 83, 12056, 5032},
    {5, 4096, 52, 83, 12060, 4729},
    {5, 4102, 53, 83, 12064, 5243},
    {5, 4105, 52, 42, 12067, -2946},
    {5, 4111, 52, 30, 12070, 4304},
    {5, 4125, 52, 34, 12081, 6510},
    {5, 4143, 52, 30, 12096, 4232},
    {5, 4147, 122, 24, 12101, 1833},
    {5, 4150, 53, 24, 12106, 3024},
    {5, 4151, 52, 30, 12105, 3924},
    {5, 4179, 53, 86, 12129, 118},
    {5, 4203, 52, 24, 12151, 3312},
    {5, 4214, 52, 30, 12156, 3620},
    {5, 4216, 52, 86, 12159, 1309},
    {5, 4236, 52, 34, 12167, 6928},
    {5, 4244, 52, 30, 12175, 3748},
    {5, 4245, 53, 24, 12176, 2936},
    {5, 4251, 52, 24, 12181, 2810},
    {5, 4261, 52, 86, 12194, 549},
    {5, 4273, 53, 86, 12199, 521},
    {5, 4274, 52, 24, 12198, 2937},
    {5, 4278, 52, 24, 12201, 2917},
    {5, 4281, 53, 86, 12204, 523},
    {5, 4293, 52, 24, 12212, 1823},
    {5, 4314, 52, 24, 12225, 2954},
    {5, 4346, 53, 30, 12235, 4700},
    {5, 4350, 53, 24, 12240, 1642},
    {5, 4361, 94, 29, 12245, -1847},
    {5, 4365, 52, 86, 12245, 719},
    {5, 4371, 52, 86, 12249, 1142},
    {5, 4388, 53, 86, 12258, 1240},
    {5, 4394, 52, 24, 12259, 1813},
    {5, 4395, 52, 30, 12258, 3333},
    {5, 4414, 52, 24, 12265, 3113},
    {5, 4419, 53, 24, 12269, 1503},
    {5, 4429, 52, 86, 12274, 1106},
    {5, 4435, 52, 86, 12277, 1305},
    {5, 4438, 52, 86, 12278, 1300},
    {5, 4442, 52, 86, 12281, 948},
    {5, 4448, 53, 24, 12283, 2837},
    {5, 4449, 52, 30, 12282, 4406},
    {5, 4450, 52, 24, 12285, 1705},
    {5, 4459, 52, 24, 12290, 1359},
    {5, 4473, 52, 24, 12298, 1326},
    {5, 4477, 52, 24, 12300, 1338},
    {5, 4478, 53, 86, 12303, 1220},
    {5, 4485, 53, 30, 12305, 4142},
    {5, 4490, 52, 30, 12306, 4139},
    {5, 4494, 52, 24, 12314, 2546},
    {5, 4517, 52, 86, 12328, 7},
    {5, 4526, 52, 86, 12340, 742},
    {5, 4527, 52, 86, 12341, 239},
    {5, 4535, 52, 86, 12343, 812},
    {5, 4536, 52, 86, 12344, 211},
    {5, 4546, 52, 86, 12355, -348},
    {5, 4550, 53, 86, 12355, 1213},
    {5, 4559, 52, 24, 12360, 2758},
    {5, 4565, 52, 24, 12363, 2559},
    {5, 4567, 53, 86, 12365, 1115},
    {5, 4568, 52, 86, 12366, 1114},
    {5, 4570, 52, 86, 12369, 715},
    {5, 4596, 52, 86, 12399, 1011},
    {5, 4605, 52, 83, 12400, 6136},
    {5, 4618, 52, 30, 12416, 4109},
    {5, 4631, 51, 30, 12421, 3232},
    {5, 4636, 52, 86, 12428, 241},
    {5, 4643, 52, 86, 12433, 159},
    {5, 4654, 52, 86, 12439, 1308},
    {5, 4656, 52, 30, 12440, 3210},
    {5, 4660, 53, 86, 12445, 1111},
    {5, 4665, 52, 86, 12451, 303},
    {5, 4666, 52, 86, 12451, -28},
    {5, 4689, 52, 24, 12478, 1346},
    {5, 4697, 51, 86, 12486, -548},
    {5, 4698, 52, 86, 12484, 829},
    {5, 4699, 52, 86, 12490, -840},
    {5, 4725, 51, 24, 12504, 2530},
    {5, 4753, 52, 86, 12524, -112},
    {5, 4754, 52, 86, 12523, 1119},
    {5, 4762, 52, 86, 12529, 1114},
    {5, 4781, 53, 86, 12544, -1032},
    {5, 4800, 53, 30, 12546, 4632},
    {5, 4845, 53, 86, 12580, 135},
    {5, 4856, 52, 86, 12594, -1503},
    {5, 4866, 53, 86, 12595, 1410},
    {5, 4889, 53, 24, 13001, 2759},
    {5, 4900, 53, 86, 13007, 230},
    {5, 4902, 52, 86, 13010, -1431},
    {5, 4945, 51, 15, 13054, -4928},
    {5, 4958, 52, 86, 13058, -801},
    {5, 4995, 53, 86, 13097, -750},
    {5, 5005, 52, 30, 13109, 3703},
    {5, 5033, 52, 30, 13135, 3636},
    {5, 5053, 122, 24, 13165, 1742},
    {5, 5054, 52, 86, 13170, -1638},
    {5, 5068, 52, 86, 13189, -2102},
    {5, 5078, 53, 42, 13198, -2725},
    {5, 5102, 52, 15, 13220, -3638},
    {5, 5128, 49, 15, 13255, -4301},
    {5, 5139, 116, 15, 13268, -4729},
    {5, 5247, 52, 86, 13380, -1753},
    {5, 5248, 52, 9, 13375, 853},
    {5, 5273, 53, 30, 13421, 3539},
    {5, 5286, 119, 15, 13464, -5122},
    {5, 5322, 52, 83, 13492, 6011},
    {5, 5350, 53, 30, 13534, 4022},
    {5, 5353, 53, 30, 13534, 4017},
    {5, 5354, 53, 30, 13534, 4018},
    {5, 5363, 52, 86, 13561, 515},
    {5, 5364, 52, 86, 13562, 501},
    {5, 5371, 52, 30, 13557, 4028},
    {5, 5427, 53, 86, 14034, -602},
    {5, 5466, 121, 9, 14055, 2832},
    {5, 5473, 53, 83, 14047, 5454},
    {5, 5474, 52, 83, 14050, 5340},
    {5, 5557, 53, 9, 14184, 3630},
    {5, 5566, 52, 86, 14203, 356},
    {5, 5576, 53, 86, 14211, 316},
    {5, 5631, 53, 83, 14266, 5635},
    {5, 5634, 122, 86, 14296, -559},
    {5, 5643, 52, 50, 14327, -4411},
    {5, 5676, 53, 9, 14328, 4927},
    {5, 5689, 53, 9, 14355, 4844},
    {5, 5694, 122, 42, 14396, -2632},
    {5, 5746, 52, 86, 14449, 157},
    {5, 5813, 52, 86, 15012, 142},
    {5, 5822, 133, 50, 15044, -5424},
    {5, 5823, 134, 19, 15055, -5536},
    {5, 5824, 121, 50, 15040, -3304},
    {5, 5846, 52, 86, 15065, 136},
    {5, 5850, 52, 86, 15071, 133},
    {5, 5897, 120, 48, 15174, -2101},
    {5, 5907, 52, 34, 15159, 5620},
    {5, 5927, 120, 50, 15280, -5040},
    {5, 5946, 120, 57, 15355, -5040},
    {5, 5982, 53, 34, 15387, 5921},
    {5, 5986, 120, 50, 15461, -3747},
    {5, 6067, 132, 57, 16132, -5413},
    {5, 6118, 53, 74, 16218, -217},
    {5, 6124, 132, 72, 16253, -4039},
    {5, 6134, 133, 57, 16278, -4909},
    {5, 6144, 121, 72, 16272, -2601},
    {5, 6192, 135, 72, 16404, -4322},
    {5, 6193, 131, 6, 16413, -4846},
    {5, 6204, 134, 6, 16462, -4701},
    {5, 6207, 53, 40, 16431, 3650},
    {5, 6210, 94, 40, 16445, 2348},
    {5, 6217, 53, 84, 16326, 7812},
    {5, 6222, 136, 72, 16494, -4444},
    {5, 6229, 121, 40, 16470, 4732},
    {5, 6231, 129, 72, 16542, -4149},
    {5, 6235, 121, 59, 16534, -2211},
    {5, 6242, 132, 72, 16556, -3928},
    {5, 6259, 134, 72, 17008, -4439},
    {5, 6281, 131, 72, 17047, -3759},
    {5, 6284, 121, 59, 17045, -2446},
    {5, 6287, 121, 59, 17052, -2242},
    {5, 6293, 120, 59, 17102, -2635},
    {5, 6302, 96, 72, 17137, -3706},
    {5, 6304, 120, 59, 17145, -2928},
    {5, 6309, 95, 59, 17141, -1255},
    {5, 6316, 120, 59, 17166, -2808},
    {5, 6334, 70, 72, 17208, -3606},
    {5, 6342, 122, 59, 17212, -1935},
    {5, 6352, 120, 6, 17255, -4825},
    {5, 6355, 121, 59, 17240, -2621},
    {5, 6356, 120, 59, 17236, -1749},
    {5, 6366, 122, 59, 17277, -505},
    {5, 6369, 95, 59, 17293, -2346},
    {5, 6388, 119, 72, 17363, -4444},
    {5, 6397, 117, 6, 17407, -5340},
    {5, 6401, 119, 59, 17386, -2355},
    {5, 6426, 122, 59, 17449, 310},
    {5, 6440, 121, 77, 17489, -2022},
    {5, 6441, 119, 72, 17502, -3703},
    {5, 6445, 97, 77, 17493, -2001},
    {5, 6451, 134, 72, 17507, -3013},
    {5, 6453, 122, 72, 17509, -3436},
    {5, 6503, 52, 34, 17495, 7009},
    {5, 6517, 122, 59, 18018, -858},
    {5, 6520, 134, 77, 18034, -2753},
    {5, 6522, 122, 77, 18036, -3002},
    {5, 6528, 122, 77, 18048, -3003},
    {5, 6535, 121, 74, 18038, -18},
    {5, 6539, 121, 74, 18048, -735},
    {5, 6541, 118, 25, 18080, -4342},
    {5, 6543, 92, 34, 17586, 6638},
    {5, 6544, 120, 77, 18073, -2500},
    {5, 6553, 120, 77, 18093, -2554},
    {5, 6568, 135, 77, 18128, -2135},
    {5, 6569, 120, 77, 18136, -3150},
    {5, 6572, 92, 59, 18121, 651},
    {5, 6583, 136, 77, 18158, -2208},
    {5, 6603, 137, 77, 18184, -1824},
    {5, 6624, 120, 77, 18237, -3022},
    {5, 6629, 94, 77, 18257, -2312},
    {5, 6633, 131, 59, 18273, 631},
    {5, 6638, 121, 77, 18309, -2530},
    {5, 6642, 121, 77, 18319, -2329},
    {5, 6645, 135, 77, 18320, -1653},
    {5, 6649, 135, 73, 18335, -1024},
    {5, 6652, 121, 77, 18358, -3259},
    {5, 6664, 134, 73, 18366, -749},
    {5, 6712, 120, 73, 18531, -842},
    {5, 6723, 119, 77, 18596, -3638},
    {5, 6726, 70, 25, 19017, -3653},
    {5, 6727, 70, 25, 19017, -3653},
    {5, 6729, 70, 25, 19019, -3657},
    {5, 6752, 117, 61, 19109, -5959},
    {5, 6755, 134, 4, 19078, 416},
    {5, 6756, 136, 4, 19087, 442},
    {5, 6760, 121, 4, 19112, 102},
    {5, 6781, 95, 4, 19185, 632},
    {5, 6791, 136, 52, 19207, 3751},
    {5, 6802, 135, 88, 19306, 2016},
    {5, 6818, 94, 77, 19440, -1409},
    {5, 6819, 133, 31, 19413, 4011},
    {5, 6822, 51, 77, 19449, -1448},
    {5, 6823, 133, 88, 19432, 2318},
    {5, 6826, 93, 31, 19448, 5032},
    {5, 6830, 134, 88, 19510, 2306},
    {5, 6834, 134, 31, 19522, 2924},
    {5, 6857, 67, 31, 20028, 3331},
    {5, 6866, 134, 31, 20039, 4410},
    {5, 6885, 134, 88, 20119, 2629},
    {5, 6888, 66, 31, 20128, 3819},
    {5, 6905, 96, 32, 20224, 2006},
    {5, 6907, 53, 12, 20251, -2449},
    {5, 6910, 133, 31, 20232, 4047},
    {5, 6934, 121, 32, 20342, 724},
    {5, 6939, 134, 16, 20315, 6040},
    {5, 6940, 132, 88, 20344, 2817},
    {5, 6946, 51, 16, 20349, 6009},
    {5, 6960, 105, 31, 20457, 3043},
    {5, 6974, 112, 31, 20511, 3150},
    {5, 6979, 70, 31, 20510, 3208},
    {5, 6992, 105, 31, 20564, 3143},
    {5, 6995, 105, 31, 20571, 3113},
    {5, 7000, 60, 31, 21018, 4412},
    {5, 7006, 122, 32, 21015, 1611},
    {5, 7008, 96, 31, 21005, 5433},
    {5, 7009, 92, 5, 21042, -1122},
    {5, 7023, 77, 16, 21005, 6810},
    {5, 7026, 96, 31, 21063, 4751},
    {5, 7027, 94, 31, 21070, 4214},
    {5, 7044, 138, 31, 21129, 4229},
    {5, 7062, 134, 31, 21235, 4623},
    {5, 7086, 134, 31, 21305, 5136},
    {5, 7090, 52, 44, 21365, -5433},
    {5, 7128, 136, 31, 21440, 5343},
    {5, 7129, 81, 16, 21430, 6607},
    {5, 7142, 135, 16, 21452, 6546},
    {5, 7160, 132, 16, 21537, 6236},
    {5, 7184, 52, 5, 22027, -2049},
    {5, 7209, 134, 45, 22051, 4629},
    {5, 7217, 52, 62, 22079, 3122},
    {5, 7243, 132, 45, 22151, 4954},
    {5, 7293, 90, 5, 22296, -2050},
    {5, 7296, 136, 45, 22282, 5217},
    {5, 7320, 54, 62, 22361, 3357},
    {5, 7331, 52, 62, 22371, 3425},
    {5, 7380, 133, 16, 22473, 5808},
    {5, 7424, 52, 39, 22573, -4104},
    {5, 7448, 53, 62, 23001, 1559},
    {5, 7479, 52, 62, 23049, 1219},
    {5, 7510, 134, 16, 23115, 6034},
    {5, 7582, 52, 39, 23184, -4222},
    {5, 7606, 52, 5, 23191, -829},
    {5, 7619, 53, 62, 23202, 812},
    {5, 7635, 67, 14, 23202, 6111},
    {5, 7662, 93, 1, 23259, 4232},
    {5, 7686, 132, 1, 23301, 4908},
    {5, 7723, 53, 5, 23390, -1258},
    {5, 7727, 52, 5, 23399, -1218},
    {5, 7789, 133, 14, 23574, 5643},
    {5, 7790, 135, 14, 23584, 6113},
    {5, 7793, 51, 71, 23578, -3236},
    {5, 7814, 52, 62, 32, 1609},
    {0, 36, 146, 1, 550, +2338},
    {15, 0, 142, 1, 2039, +4220},
    {201, 228, 147, 1, 2140, +4729},
    {201, 3050, 146, 1, 23595, +3343},
    {0, 56, 146, 1, 1562, +3715},
    {0, 59, 146, 1, 2109, +3902},
    {24, 0, 146, 4, 19487, +1149},
    {201, 2404, 147, 4, 18508, +1059},
    {201, 2532, 146, 4, 19302, 254},
    {0, 5, 146, 4, 18465, -58},
    {0, 11, 145, 4, 18591, +1338},
    {0, 15, 146, 4, 19050, -402},
    {0, 57, 146, 4, 19546, -814},
    {201, 2838, 146, 5, 21546, -318},
    {32, 0, 144, 5, 22288, -1},
    {0, 12, 146, 5, 21041, -549},
    {0, 41, 146, 5, 22143, -2104},
    {0, 53, 146, 5, 22266, -1645},
    {0, 94, 145, 5, 23191, -1328},
    {0, 107, 146, 5, 23460, -1841},
    {12, 0, 145, 7, 2592, +2120},
    {15, 0, 145, 7, 1535, +1918},
    {20, 0, 145, 7, 1579, +2336},
    {24, 0, 145, 7, 2493, +1728},
    {201, 394, 147, 7, 3280, +2028},
    {0, 1, 146, 7, 1501, +2217},
    {0, 30, 147, 7, 2370, +2439},
    {0, 33, 145, 7, 2407, +2704},
    {16, 0, 143, 8, 5597, +3713},
    {201, 644, 147, 8, 5103, +3718},
    {201, 698, 147, 8, 5252, +3451},
    {201, 872, 147, 8, 6156, +3609},
    {29, 0, 145, 8, 4593, +3753},
    {30, 0, 145, 8, 6467, +4335},
    {0, 14, 145, 8, 5154, +3241},
    {0, 26, 145, 8, 5386, +3030},
    {0, 41, 146, 8, 6116, +4843},
    {132, 147, 147, 8, 6343, +3805},
    {11, 0, 144, 9, 15155, +3319},
    {12, 0, 143, 9, 14450, +2704},
    {17, 0, 145, 9, 14162, +5122},
    {19, 0, 145, 9, 14135, +5147},
    {21, 0, 144, 9, 15245, +3723},
    {24, 0, 145, 9, 14407, +1625},
    {201, 1825, 146, 9, 14165, +2007},
    {201, 1835, 145, 9, 14234, +827},
    {201, 1884, 147, 9, 14484, +2422},
    {31, 0, 145, 9, 14514, +1906},
    {32, 0, 144, 9, 14411, +1344},
    {0, 39, 146, 9, 14497, +4843},
    {0, 44, 145, 9, 15038, +4739},
    {162, 191, 147, 9, 14596, +5352},
    {201, 1694, 145, 11, 12492, +8325},
    {201, 400, 147, 11, 3350, +6002},
    {201, 485, 147, 11, 4078, +6220},
    {0, 1, 146, 11, 4320, +5355},
    {0, 11, 145, 11, 5061, +5858},
    {6, 0, 144, 12, 20176, -1230},
    {23, 0, 146, 12, 20299, -1835},
    {24, 0, 145, 12, 20273, -1813},
    {26, 0, 145, 12, 20289, -1749},
    {27, 0, 145, 12, 20194, -1907},
    {17, 0, 145, 14, 2291, +6724},
    {18, 0, 144, 14, 491, +5749},
    {27, 0, 145, 14, 23590, +5545},
    {201, 163, 147, 14, 1513, +6451},
    {201, 3053, 146, 14, 26, +6606},
    {201, 3062, 146, 14, 63, +5826},
    {0, 3, 145, 15, 13518, -3300},
    {9, 0, 143, 16, 21287, +7034},
    {11, 0, 144, 16, 22292, +5825},
    {19, 0, 144, 16, 20089, +7743},
    {201, 2780, 147, 16, 21118, +5959},
    {201, 2816, 146, 16, 21390, +5729},
    {201, 2840, 146, 16, 21520, +5548},
    {201, 460, 146, 16, 4100, +8042},
    {31, 0, 144, 16, 22038, +6438},
    {132, 461, 147, 16, 22039, +5949},
    {10, 0, 145, 17, 1496, -1041},
    {15, 0, 144, 17, 2433, +314},
    {201, 186, 147, 17, 1559, +151},
    {0, 66, 146, 17, 2128, -224},
    {6, 0, 140, 20, 6451, -1643},
    {12, 0, 142, 20, 6586, -2858},
    {21, 0, 145, 20, 6561, -1403},
    {108, 3945, 145, 20, 7166, -2319},
    {17, 0, 144, 22, 8467, +2846},
    {25, 0, 146, 22, 8268, +2656},
    {201, 1177, 147, 22, 8056, +2732},
    {201, 1245, 146, 22, 8358, 637},
    {201, 1254, 147, 22, 8404, +1940},
    {201, 1311, 147, 22, 9074, +2259},
    {32, 0, 145, 22, 8122, +1739},
    {0, 57, 146, 22, 8542, +3035},
    {0, 66, 146, 22, 9014, +3215},
    {201, 1633, 147, 24, 12207, +2703},
    {201, 1639, 147, 24, 12244, +2535},
    {0, 2, 146, 24, 12043, +2128},
    {0, 24, 145, 24, 12351, +1823},
    {0, 35, 145, 24, 12533, +2115},
    {15, 0, 145, 25, 19064, -3704},
    {19, 0, 146, 25, 18334, -3844},
    {15, 0, 144, 26, 15427, +2618},
    {18, 0, 146, 26, 15232, +3017},
    {27, 0, 146, 26, 16147, +3352},
    {32, 0, 145, 26, 15394, +3638},
    {132, 128, 146, 26, 16117, +3321},
    {11, 0, 143, 29, 12299, -1631},
    {201, 1604, 147, 29, 12095, -1151},
    {6, 0, 143, 30, 12560, +3819},
    {0, 2, 146, 30, 12161, +4040},
    {9, 0, 143, 31, 19307, +2758},
    {11, 0, 143, 31, 19450, +4508},
    {20, 0, 145, 31, 20474, +3629},
    {21, 0, 145, 31, 21441, +2845},
    {201, 2486, 147, 31, 19121, +4951},
    {30, 0, 145, 31, 19556, +5226},
    {0, 16, 146, 31, 19418, +5032},
    {0, 31, 144, 31, 20136, +4644},
    {0, 49, 146, 31, 20410, +3218},
    {0, 61, 145, 31, 21069, +3845},
    {132, 130, 146, 31, 21208, +3227},
    {103, 5137, 146, 31, 19459, +3501},
    {15, 0, 144, 32, 20467, +1607},
    {12, 0, 144, 34, 19482, +7016},
    {21, 0, 146, 34, 17053, +5428},
    {22, 0, 145, 34, 17322, +5511},
    {23, 0, 145, 34, 18512, +5923},
    {201, 2155, 147, 34, 17161, +6043},
    {201, 2348, 146, 34, 18339, +5221},
    {30, 0, 145, 34, 17419, +7209},
    {0, 17, 145, 34, 16362, +5255},
    {0, 41, 146, 34, 18002, +8000},
    {132, 123, 147, 34, 13271, +6444},
    {12, 0, 145, 35, 20591, +418},
    {201, 2742, 147, 35, 21022, +711},
    {16, 0, 143, 36, 2583, -4018},
    {11, 5, 146, 36, 1398, -5612},
    {0, 55, 147, 36, 4436, -848},
    {108, 3556, 146, 36, 3124, -4425},
    {29, 0, 145, 37, 2338, -2814},
    {6, 0, 142, 38, 7346, +3153},
    {11, 0, 144, 38, 7201, +2159},
    {19, 0, 144, 38, 7444, +2424},
    {201, 1083, 147, 38, 7256, +2030},
    {201, 1108, 147, 38, 7328, +2253},
    {0, 38, 145, 38, 6546, +1311},
    {162, 70, 147, 38, 6278, +2047},
    {6, 0, 143, 40, 17146, +1423},
    {11, 0, 143, 40, 17150, +2450},
    {19, 0, 145, 40, 16081, +1703},
    {26, 0, 145, 40, 17237, +3709},
    {201, 2052, 147, 40, 16289, +1825},
    {201, 2063, 146, 40, 16318, +4536},
    {201, 2315, 147, 40, 18250, +2724},
    {201, 2411, 147, 40, 18523, +1432},
    {0, 37, 146, 40, 16406, +413},
    {0, 56, 146, 40, 16550, +2544},
    {0, 95, 145, 40, 18015, +2136},
    {0, 100, 146, 40, 18078, +2606},
    {132, 129, 147, 40, 18359, +1659},
    {12, 0, 143, 42, 8468, +625},
    {201, 1348, 148, 42, 9245, +621},
    {201, 1355, 147, 42, 9273, +614},
    {201, 1365, 147, 42, 9315, +128},
    {28, 0, 145, 42, 9291, -246},
    {103, 396, 146, 42, 11323, -2916},
    {201, 2894, 146, 45, 22189, +3746},
    {0, 8, 146, 45, 22359, +3938},
    {6, 0, 141, 46, 10084, +1158},
    {15, 0, 142, 46, 10200, +1950},
    {28, 0, 145, 46, 11279, +251},
    {0, 6, 145, 46, 9320, +943},
    {0, 49, 146, 46, 10350, +839},
    {0, 54, 144, 46, 10556, +2445},
    {0, 81, 146, 46, 11256, +1627},
    {0, 83, 147, 46, 11268, +301},
    {0, 90, 146, 46, 11347, +1648},
    {132, 215, 147, 46, 10163, +1744},
    {15, 0, 144, 47, 5445, -2227},
    {108, 3750, 145, 47, 5204, -2114},
    {21, 0, 145, 48, 14493, -1409},
    {23, 0, 146, 48, 15210, -1533},
    {201, 1962, 146, 48, 15387, -847},
    {31, 0, 145, 50, 15569, -3358},
    {201, 1282, 147, 51, 8508, +3504},
    {201, 1333, 147, 51, 9184, +3522},
    {201, 1338, 147, 51, 9210, +3811},
    {201, 1369, 147, 51, 9354, +3958},
    {201, 958, 146, 51, 6482, +5542},
    {0, 12, 145, 51, 6462, +5927},
    {0, 19, 146, 51, 7229, +5517},
    {0, 38, 144, 51, 9188, +3648},
    {9, 0, 144, 52, 18501, +3322},
    {13, 0, 145, 52, 18443, +3940},
    {14, 0, 145, 52, 18443, +3940},
    {18, 0, 144, 52, 19138, +3909},
    {201, 2474, 147, 52, 19091, +3436},
    {32, 0, 144, 52, 18448, +3736},
    {200, 0, 145, 52, 18570, +3254},
    {162, 282, 146, 52, 18549, +3358},
    {108, 5218, 147, 54, 20454, -3029},
    {9, 0, 145, 55, 6288, -702},
    {12, 0, 144, 55, 6238, +436},
    {20, 0, 144, 59, 16309, +159},
    {23, 0, 145, 59, 17180, -2417},
    {26, 0, 145, 59, 16256, -2327},
    {201, 2276, 147, 59, 18057, +1200},
    {28, 0, 145, 59, 18031, -811},
    {0, 36, 145, 59, 17153, -2636},
    {0, 61, 146, 59, 17446, +235},
    {0, 70, 144, 59, 18055, +230},
    {9, 0, 140, 60, 5145, -812},
    {11, 0, 142, 60, 5320, -18},
    {16, 0, 145, 60, 5353, -523},
    {17, 0, 143, 60, 5354, -555},
    {18, 0, 144, 60, 5245, -224},
    {20, 0, 144, 60, 5351, +956},
    {26, 0, 145, 60, 5133, +252},
    {27, 0, 144, 60, 5387, -236},
    {201, 747, 145, 60, 5350, -600},
    {201, 790, 146, 60, 5460, -416},
    {32, 0, 142, 60, 5407, -157},
    {0, 14, 146, 60, 5079, +830},
    {0, 23, 145, 60, 5228, +333},
    {0, 32, 144, 60, 5308, 557},
    {0, 33, 146, 60, 5312, +318},
    {0, 52, 146, 60, 5480, +627},
    {12, 0, 143, 62, 21442, +953},
    {201, 2841, 146, 62, 21543, +1943},
    {201, 3007, 147, 62, 23228, +2034},
    {0, 1, 144, 62, 21221, +1948},
    {18, 0, 144, 63, 2507, +5554},
    {201, 162, 146, 63, 1493, +4754},
    {201, 331, 145, 63, 3009, +5221},
    {201, 336, 147, 63, 3015, +3225},
    {201, 369, 147, 63, 3171, +4029},
    {0, 56, 146, 63, 4246, +3358},
    {11, 24, 146, 66, 22366, -3140},
    {6, 0, 144, 67, 2020, +246},
    {201, 22, 147, 67, 174, +853},
    {201, 3009, 147, 67, 23243, +343},
    {30, 0, 145, 67, 1057, +2128},
    {32, 0, 145, 67, 1137, +735},
    {0, 35, 144, 67, 150, +849},
    {0, 55, 146, 67, 399, +2126},
    {0, 65, 146, 67, 499, +2743},
    {0, 66, 146, 67, 546, +1911},
    {0, 77, 146, 67, 1058, +455},
    {112, 0, 145, 68, 7183, -3644},
    {110, 19, 146, 68, 7343, -2328},
    {103, 327, 144, 68, 7388, -2648},
    {6, 0, 141, 72, 16294, -2626},
    {9, 0, 143, 72, 16054, -1948},
    {22, 0, 144, 72, 16120, -1928},
    {31, 0, 145, 72, 16044, -1122},
    {11, 0, 144, 74, 15348, +1032},
    {16, 0, 145, 74, 18562, +412},
    {201, 1919, 147, 74, 15127, +1917},
    {0, 59, 145, 74, 18272, +12},
    {132, 127, 146, 74, 15402, +1203},
    {15, 0, 145, 75, 9525, -806},
    {153, 0, 147, 75, 9541, +457},
    {0, 35, 146, 75, 10433, +445},
    {0, 40, 147, 75, 10493, -401},
    {32, 0, 145, 76, 19490, +1909},
    {110, 84, 146, 76, 19394, +1634},
    {138, 0, 145, 77, 17591, -3015},
    {0, 54, 145, 77, 19407, -1618},
    {108, 5082, 146, 77, 19031, -1915},
    {10, 0, 145, 78, 4226, +2538},
    {25, 0, 145, 78, 4204, +2721},
    {201, 422, 146, 78, 3368, +35},
    {201, 495, 146, 78, 4077, +1510},
    {201, 572, 147, 78, 4385, +2656},
    {0, 7, 147, 78, 3344, +2428},
    {0, 62, 146, 78, 4240, +2418},
    {0, 118, 146, 78, 5293, +2509},
    {201, 239, 147, 81, 2174, +2845},
    {0, 6, 145, 81, 2124, +3018},
    {27, 0, 145, 83, 9104, +6708},
    {201, 1520, 147, 83, 11161, +5246},
    {201, 1523, 144, 83, 11182, +3132},
    {201, 1695, 146, 83, 12563, +5406},
    {32, 0, 142, 83, 13239, +5456},
    {132, 126, 146, 83, 11323, +6105},
    {6, 0, 142, 84, 2318, +8916},
    {201, 1972, 147, 84, 15292, +8027},
    {108, 2682, 147, 84, 13407, +7651},
    {11, 70, 145, 85, 8295, -4443},
    {108, 4191, 145, 85, 9144, -4314},
    {15, 0, 143, 86, 12417, -127},
    {28, 0, 144, 86, 14016, +133},
    {0, 17, 147, 86, 12225, +518},
    {60, 0, 161, 1, 275, 3535},
    {166, 0, 162, 1, 23388, 3546},
    {167, 0, 162, 1, 46, 4333},
    {181, 0, 161, 1, 2384, 3910},
    {185, 0, 162, 1, 199, 4443},
    {107, 5223, 162, 1, 542, 2404},
    {130, 15196, 162, 1, 542, 2404},
    {179, 0, 162, 4, 18585, 1422},
    {182, 0, 161, 4, 19044, -541},
    {182, 1469, 162, 4, 20011, 931},
    {130, 11960, 161, 4, 19232, -1042},
    {147, 0, 163, 5, 23244, -1719},
    {182, 0, 162, 7, 2150, 1214},
    {90, 0, 163, 8, 5034, 5038},
    {96, 0, 162, 8, 5481, 3038},
    {148, 0, 164, 8, 6348, 4230},
    {152, 0, 162, 8, 5271, 3409},
    {176, 0, 163, 8, 5091, 3900},
    {178, 0, 159, 8, 6365, 3827},
    {179, 0, 161, 8, 5218, 3231},
    {182, 0, 163, 8, 6240, 4742},
    {182, 346, 163, 8, 4526, 3830},
    {149, 0, 163, 9, 14242, 2542},
    {147, 0, 162, 11, 7217, 6940},
    {152, 0, 162, 11, 5410, 6848},
    {166, 0, 161, 11, 4512, 6810},
    {177, 0, 161, 11, 3418, 6239},
    {179, 0, 162, 11, 4059, 6148},
    {196, 0, 161, 11, 4086, 5322},
    {146, 0, 161, 12, 20171, -2119},
    {129, 0, 164, 14, 246, 5417},
    {166, 0, 165, 14, 175, 1714},
    {187, 0, 162, 14, 549, 5834},
    {191, 0, 163, 14, 1336, 5745},
    {193, 0, 161, 14, 13, 6021},
    {182, 623, 161, 14, 3114, 5754},
    {21, 0, 162, 16, 21435, 5848},
    {152, 0, 161, 16, 21352, 7837},
    {107, 16115, 162, 17, 2351, -927},
    {157, 129989, 162, 17, 2351, -9264},
    {187, 0, 160, 20, 7081, -1155},
    {139, 0, 161, 21, 7087, 1001},
    {171, 0, 162, 22, 8567, 1931},
    {194, 0, 160, 22, 8554, 1714},
    {139, 0, 160, 26, 15486, 2809},
    {182, 0, 161, 26, 15495, 3934},
    {172, 0, 162, 30, 12594, 3749},
    {197, 0, 159, 30, 12451, 4526},
    {66, 0, 161, 31, 19288, 4603},
    {67, 0, 162, 31, 19572, 4416},
    {82, 0, 162, 31, 20468, 4603},
    {145, 0, 161, 31, 20134, 3844},
    {148, 0, 161, 31, 21433, 3801},
    {150, 0, 163, 31, 20104, 3557},
    {168, 0, 163, 31, 20095, 4752},
    {172, 0, 161, 31, 19409, 3237},
    {177, 0, 160, 31, 20196, 4754},
    {182, 0, 162, 31, 20413, 4808},
    {192, 0, 163, 31, 20186, 3727},
    {182, 460, 160, 31, 21420, 3531},
    {107, 189256, 162, 31, 19572, 4418},
    {157, 106516, 162, 32, 20486, 1750},
    {150, 0, 160, 34, 12564, 6560},
    {171, 0, 161, 34, 17564, 5813},
    {180, 0, 160, 34, 19216, 7634},
    {169, 0, 162, 36, 5098, -531},
    {75, 0, 162, 38, 7209, 2460},
    {129, 0, 161, 38, 7319, 2430},
    {173, 0, 161, 38, 6109, 2601},
    {184, 0, 162, 38, 6421, 3127},
    {33, 0, 161, 40, 18303, 2152},
    {144, 0, 162, 40, 16042, 5030},
    {157, 46574, 161, 40, 17135, 4206},
    {177, 0, 159, 42, 10376, -1323},
    {182, 0, 161, 42, 10516, -2115},
    {197, 0, 161, 42, 9511, -2301},
    {139, 0, 160, 46, 9476, 1124},
    {139, 0, 160, 47, 4596, -1448},
    {197, 0, 161, 51, 7282, 460},
    {109, 0, 162, 52, 18428, 3658},
    {171, 0, 162, 52, 18323, 3660},
    {177, 0, 162, 52, 19202, 3753},
    {73, 0, 163, 55, 6564, 76},
    {96, 0, 163, 55, 6224, 325},
    {102, 0, 162, 55, 6532, -435},
    {148, 0, 161, 55, 6584, 610},
    {150, 0, 162, 55, 7069, -733},
    {182, 614, 161, 55, 7010, -315},
    {175, 0, 161, 59, 17297, -1928},
    {182, 0, 161, 59, 16267, -1226},
    {74, 0, 160, 60, 6255, 1443},
    {101, 0, 164, 60, 6177, 831},
    {146, 0, 162, 60, 5332, 709},
    {190, 0, 160, 60, 5054, 111},
    {149, 0, 162, 62, 21564, 2248},
    {33, 0, 163, 63, 3451, 4447},
    {149, 0, 162, 63, 21564, 2252},
    {151, 0, 162, 63, 22059, 3330},
    {197, 0, 162, 63, 3277, 4411},
    {182, 466, 162, 63, 3415, 5130},
    {176, 0, 159, 67, 23464, 329},
    {198, 0, 161, 67, 1161, 2546},
    {107, 26, 162, 67, 54, 847},
    {157, 109003, 162, 67, 54, 847},
    {157, 128396, 163, 67, 23491, 623},
    {147, 0, 162, 68, 8075, -2255},
    {148, 0, 163, 73, 18474, -1313},
    {149, 0, 162, 73, 18370, -736},
    {165, 0, 160, 73, 18583, -754},
    {171, 0, 162, 73, 18554, -86},
    {87, 0, 162, 74, 18474, 530},
    {94, 0, 163, 74, 18194, -1537},
    {72, 0, 163, 76, 20024, 2105},
    {76, 0, 162, 76, 20024, 2036},
    {195, 0, 161, 76, 20051, 2039},
    {60, 0, 161, 77, 19343, -1622},
    {170, 0, 162, 77, 17449, -1839},
    {182, 1942, 161, 77, 19192, -1555},
    {167, 0, 163, 78, 5491, 1904},
    {172, 0, 162, 78, 4515, 2832},
    {173, 0, 160, 78, 5452, 2425},
    {197, 0, 161, 78, 5457, 2042},
    {146, 0, 163, 83, 9184, 5124},
    {186, 0, 160, 83, 10451, 6725},
    {147, 0, 162, 86, 12473, 409},
    {165, 0, 160, 86, 12252, 46},
    {107, 113801, 163, 86, 13064, -2004},
    {157, 157721, 163, 86, 13064, -2004},
    {68, 0, 162, 88, 20373, 2630},
    {130, 13571, 162, 88, 21099, 2637},
    {34, 0, 169, 36, 1377, -5714},
    {35, 0, 171, 72, 16054, -1948},
    {36, 0, 169, 28, 12266, -6306},
    {37, 0, 170, 20, 6586, -2858},
    {38, 0, 169, 15, 14038, -6022},
    {39, 0, 170, 1, 2039, 4220},
    {40, 0, 169, 78, 4359, 1631},
    {41, 0, 170, 16, 21186, 6235},
    {42, 0, 170, 39, 22427, -4653},
    {43, 0, 170, 63, 3243, 4952},
    {44, 0, 170, 46, 10200, 1950},
    {45, 0, 170, 63, 3082, 4057},
    {46, 0, 170, 38, 6377, 1624},
    {47, 0, 170, 83, 12540, 5558},
    {48, 0, 170, 83, 13475, 4919},
    {49, 0, 170, 39, 22082, -4658},
    {50, 0, 170, 60, 5362, -112},
    {51, 0, 170, 60, 5408, -157},
    {52, 0, 170, 42, 9276, -840},
    {53, 0, 170, 26, 15347, 2643},
    {54, 0, 170, 1, 84, 2905},
    {55, 0, 170, 85, 8095, -4720},
    {56, 0, 169, 4, 19508, 852},
    {57, 0, 170, 20, 7241, -2918},
    {58, 0, 170, 64, 263, -4218},
    {59, 0, 169, 72, 16294, -2626},
    {61, 0, 168, 9, 14157, 1911},
    {62, 0, 171, 47, 5327, -1749},
    {63, 0, 170, 13, 9171, -5917},
    {64, 0, 170, 80, 16487, -6902},
    {65, 0, 170, 13, 8225, -5931},
    {69, 0, 169, 28, 12477, -5941},
    {70, 0, 170, 60, 5251, 621},
    {71, 0, 169, 60, 5552, 724},
    {77, 0, 168, 13, 6240, -5242},
    {78, 0, 168, 8, 5167, 4560},
    {79, 0, 170, 14, 92, 5909},
    {80, 0, 170, 38, 7346, 3153},
    {81, 0, 170, 14, 567, 6043},
    {83, 0, 169, 31, 20414, 4517},
    {84, 0, 170, 17, 436, -1759},
    {85, 0, 170, 46, 11491, 1434},
    {86, 0, 170, 17, 436, -1759},
    {88, 0, 170, 72, 16003, -2237},
    {89, 0, 170, 83, 11037, 6145},
    {91, 0, 170, 78, 5263, 2836},
    {92, 0, 170, 34, 17566, 5129},
    {93, 0, 170, 62, 21442, 953},
    {95, 0, 169, 66, 22577, -2937},
    {97, 0, 170, 28, 12312, -5707},
    {98, 0, 170, 26, 15347, 2643},
    {99, 0, 171, 31, 20462, 3358},
    {100, 0, 170, 72, 17425, -3902},
    {104, 0, 169, 15, 14038, -6022},
    {105, 0, 170, 7, 2072, 2328},
    {106, 0, 171, 59, 16372, -1034},
    {111, 0, 170, 9, 14450, 2704},
    {113, 0, 170, 77, 18242, -3423},
    {114, 0, 170, 84, 14507, 7409},
    {115, 0, 170, 85, 8447, -5443},
    {116, 0, 170, 62, 23048, 1512},
    {117, 0, 170, 8, 5595, 4457},
    {118, 0, 171, 17, 3023, 405},
    {119, 0, 170, 15, 14067, -3622},
    {120, 0, 170, 83, 11018, 5623},
    {121, 0, 170, 13, 9132, -6943},
    {122, 0, 169, 28, 12477, -5941},
    {123, 0, 170, 60, 5320, -18},
    {124, 0, 170, 1, 1097, 3537},
    {125, 0, 170, 63, 3243, 4952},
    {126, 0, 170, 20, 6227, -1757},
    {127, 0, 170, 83, 13239, 5456},
    {128, 0, 170, 68, 8036, -4000},
    {131, 0, 170, 77, 18553, -2618},
    {133, 0, 170, 61, 20256, -5644},
    {134, 0, 170, 83, 11538, 5342},
    {135, 0, 170, 84, 2318, 8916},
    {136, 0, 169, 38, 7453, 2802},
    {137, 0, 168, 21, 7393, 514},
    {140, 0, 170, 59, 17349, 1234},
    {141, 0, 169, 46, 10084, 1158},
    {142, 0, 168, 60, 5145, -812},
    {143, 0, 168, 15, 14396, -6050},
    {154, 0, 170, 59, 17104, -1543},
    {155, 0, 170, 31, 20222, 4015},
    {156, 0, 170, 60, 5478, -940},
    {158, 0, 170, 72, 17373, -4260},
    {159, 0, 170, 62, 23038, 2805},
    {160, 0, 170, 14, 405, 5632},
    {161, 0, 170, 72, 17336, -3706},
    {163, 0, 168, 20, 6451, -1643},
    {164, 0, 169, 86, 13252, -1110},
    {174, 0, 170, 13, 9171, -5917},
    {183, 0, 168, 52, 18369, 3847},
    {188, 0, 170, 72, 16502, -3418},
    {189, 0, 170, 20, 7084, -2624},
    {199, 0, 171, 46, 11141, 2031},
    {7, 0, 168, 15, 14396, -6050},
    {8, 0, 169, 15, 14396, -6050},
    {6, 0, 170, 50, 14419, -4723},
    {9, 0, 170, 39, 22427, -4653},
    {15, 0, 170, 14, 567, 6043},
    {15, 0, 170, 15, 12415, -4858},
    {11, 0, 171, 15, 12084, -5043},
    {11, 0, 170, 85, 8447, -5443},
    {12, 0, 170, 15, 13399, -5328},
    {32, 0, 171, 15, 13555, -4717},
    {32, 0, 171, 59, 16372, -1034},
    {18, 0, 170, 15, 14355, -4209},
    {19, 0, 170, 85, 9221, -5501},
    {20, 0, 170, 85, 9080, -4326}
  // variables for button - instead of bounce lib - save flash memory
  const int DEBOUNCE_DELAY = 50;   // the debounce time; increase if the output flickers
  int lastSteadyState = LOW;       // the previous steady state from the input pin
  int lastFlickerableState = LOW;  // the previous flickerable state from the input pin
  int currentState;                // the current reading from the input pin
  unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
  unsigned long lastPressedTime = 0;
  // LCD - VSS - GND // VCC - 5V // RW - GND // K - GND
  const byte rs = 12;
  const byte en = 13;
  const byte d4 = 9;
  const byte d5 = 8;
  const byte d6 = 7;
  const byte d7 = 6;
  LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
  byte myLCDbacklight = 255;
  byte myLCDcontrast = 100;
  // variables to steer menu
  byte myDisplayMode = 0;
  const char *const menuTopic[] = {"DEC", "Align", "Target", "Region", "Const", "Brightness", "Contrast", "Sensors", "LX200"};
  const byte menuTopic_size = sizeof(menuTopic) / sizeof(menuTopic[0]);
  byte myMenuTopicNo = 0;
  // definition of special / greek characters - for LCD 1602 chinese version - adapt to your LCD if needed
  // used lcd is like this https://www.waveshare.com/datasheet/LCD_en_PDF/LCD1602.pdf (see 14. font table)
  const char ch_deg = (char)(223); // degree symbol
  const char ch_sigma = (char)(246); // uppercase Sigma
  // greek alphabet 1-24 = α β γ δ ε ζ η θ ι κ λ μ ν ξ ο π ρ σ τ υ φ χ ψ ω
  // maximum 8 custom characters
  // γ
  char ch_def_1 = 'g'; // for identificatrion & replacement
  byte ch_custom_1[] = {
    B00000,
    B10011,
    B10010,
    B10010,
    B01110,
    B00100,
    B00100,
    B00100
  // δ
  char ch_def_2 = 'd';
  byte ch_custom_2[] = {
    B00110,
    B01001,
    B00100,
    B01110,
    B10001,
    B10001,
    B01110,
    B00000
  // ζ
  char ch_def_3 = 'z';
  byte ch_custom_3[] = {
    B01111,
    B00010,
    B00100,
    B01000,
    B01000,
    B01111,
    B00001,
    B00110
  // λ
  char ch_def_4 = 'l';
  byte ch_custom_4[] = {
    B01100,
    B00100,
    B00100,
    B01010,
    B01010,
    B10001,
    B10001,
    B00000
  // ξ
  char ch_def_5 = 'x';
  byte ch_custom_5[] = {
    B11111,
    B00100,
    B01000,
    B00111,
    B01000,
    B10000,
    B11111,
    B00010
  // φ
  char ch_def_6 = 'p';
  byte ch_custom_6[] = {
    B00000,
    B10111,
    B10101,
    B10101,
    B10101,
    B01110,
    B00100,
    B00100
  // ψ
  char ch_def_7 = 's';
  byte ch_custom_7[] = {
    B00000,
    B00100,
    B10101,
    B10101,
    B10101,
    B01110,
    B00100,
    B00100
  // Δ
  char ch_def_8 = 'D';
  byte ch_custom_8[] = {
    B00000,
    B00100,
    B01010,
    B01010,
    B10001,
    B10001,
    B11111,
    B00000
  // lookup table placeholder chars with greek symbols
  struct greekSymbols {
    char originalChar;
    char replaceChar;
  const unsigned int greekSymbols_size = 26;
  const struct greekSymbols greekSymbols[greekSymbols_size]  =
    {'a', (char)(224)}, // α
    {'b', (char)(226)}, // β
    {'g', 'g'}, // γ custom character
    {'d', 'd'}, // δ custom character
    {'e', (char)(227)}, // ε
    {'z', 'z'}, // ζ custom character
    {'j', 'n'}, // η
    {'h', (char)(242)}, // θ
    {'i', 'l'}, // ι
    {'k', 'k'}, // κ
    {'l', 'l'}, // λ custom character
    {'m', (char)(228)}, // μ
    {'n', 'v'}, // ν
    {'x', 'x'}, // ξ custom character
    {'o', 'o'}, // ο
    {'p', (char)(247)}, // π
    {'r', (char)(230)}, // ρ
    {'s', (char)(229)}, // σ
    {'t', 't'}, // τ
    {'y', (char)(232)}, // υ
    {'q', 'p'}, // φ custom character
    {'c', 'x'}, // χ
    {'w', 's'}, // ψ custom character
    {'u', 'w'},
    {'F', (char)(246)}, // Σ
    {'D', '/'} // Δ
  // definition of constellation names
  struct constStruct {
    char constName[4];
  constStruct myConstellation;
  const unsigned int constStruct_size = 89;
  const struct constStruct const_PROGMEM[constStruct_size] PROGMEM = {
    {"all"}, {"And"}, {"Ant"}, {"Aps"}, {"Aql"}, {"Aqr"}, {"Ara"}, {"Ari"}, {"Aur"}, {"Boo"}, {"Cae"}, {"Cam"}, {"Cap"}, {"Car"}, {"Cas"}, {"Cen"}, {"Cep"}, {"Cet"}, {"Cha"}, {"Cir"},
    {"CMa"}, {"CMi"}, {"Cnc"}, {"Col"}, {"Com"}, {"CrA"}, {"CrB"}, {"Crt"}, {"Cru"}, {"Crv"}, {"CVn"}, {"Cyg"}, {"Del"}, {"Dor"}, {"Dra"}, {"Equ"}, {"Eri"}, {"For"}, {"Gem"}, {"Gru"},
    {"Her"}, {"Hor"}, {"Hya"}, {"Hyi"}, {"Ind"}, {"Lac"}, {"Leo"}, {"Lep"}, {"Lib"}, {"LMi"}, {"Lup"}, {"Lyn"}, {"Lyr"}, {"Men"}, {"Mic"}, {"Mon"}, {"Mus"}, {"Nor"}, {"Oct"}, {"Oph"},
    {"Ori"}, {"Pav"}, {"Peg"}, {"Per"}, {"Phe"}, {"Pic"}, {"PsA"}, {"Psc"}, {"Pup"}, {"Pyx"}, {"Ret"}, {"Scl"}, {"Sco"}, {"Sct"}, {"Ser"}, {"Sex"}, {"Sge"}, {"Sgr"}, {"Tau"}, {"Tel"},
    {"TrA"}, {"Tri"}, {"Tuc"}, {"UMa"}, {"UMi"}, {"Vel"}, {"Vir"}, {"Vol"}, {"Vul"}
  byte myConstellationNo = 0;
  String myConstellationName = "";
  // object type name and variables for deep sky objects
  const char* myObjectTypeName[] = {"Quasar", "Dark Nebula", "Galaxy", "Bright Neb", "Clust + Neb", "Planet Neb", "SN Rem", "Glob Cluster", "Open Cluster", "Double Star", "Red Star", "Reference", "any"};
  unsigned int myRefNo = 0; // number of selected reference star
  unsigned int  myTargetNo = 0; // number of selected target
  // definition of cellestial regions = constellations of seasons defined in groups (as in Deep Sky Atlas) to filter targets and reference stars
  // constellation for which deep sky objects exist in the list 0 = all
  const byte myAllCONST[] = {0, 1, 2, 4, 5, 6, 7, 8, 9, 11, 12, 13, 14, 15, 16, 17, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 44, 45, 46, 47, 48, 49, 50, 51, 52, 54, 55, 57, 59, 60, 61, 62, 63, 64, 66, 67, 68, 69, 71, 72, 73, 74, 75, 76, 77, 78, 80, 81, 83, 84, 85, 86, 88};
  const byte myAllCONST_size = sizeof(myAllCONST) / sizeof(myAllCONST[0]);
  // North - UMI,UMA,DRA,CEP,CAS,CAM
  const byte myNorthCONST[] = {84, 83, 34, 16, 14, 11};
  const byte myNorthCONST_size = sizeof(myNorthCONST) / sizeof(myNorthCONST[0]);
  // Spring - LEO,LMI,SEX,HYA,CVN,COM,VIR,CRT,CRV,BOO,CRB,SER
  const byte mySpringCONST[] = {46, 49, 75, 42, 30, 24, 86, 27, 29, 9, 26, 74};
  const byte mySpringCONST_size = sizeof(mySpringCONST) / sizeof(mySpringCONST[0]);
  // Summer - HER,LYR,OPH,SCO,CYG,VUL,SGE,DEL,EQU,AQL,SCT,SER,SGR,CAP
  const byte mySummerCONST[] = {40, 52, 59, 72, 31, 88, 76, 32, 35, 4, 73, 74, 77, 12};
  const byte mySummerCONST_size = sizeof(mySummerCONST) / sizeof(mySummerCONST[0]);
  // Autumn - LAC,PEG,AQR,PSA,AND,TRI,PER,ARI,PSC,CET,SCL,FOR,ERI
  const byte myAutumnCONST[] = {45, 62, 5, 66, 1, 81, 63, 7, 67, 17, 71, 37, 36};
  const byte myAutumnCONST_size = sizeof(myAutumnCONST) / sizeof(myAutumnCONST[0]);
  // Winter - AUR,TAU,ORI,LEP,LYN,GEM,CMI,MON,CMA,PUP,CNC
  const byte myWinterCONST[] = {8, 78, 60, 47, 51, 38, 21, 55, 20, 68, 22};
  const byte myWinterCONST_size = sizeof(myWinterCONST) / sizeof(myWinterCONST[0]);
  // South - ANT,VEL,CAR,VOL,CHA,MUS,CRU,CEN,CRU,TRA,LUP,NOR,ARA,SCO,SGR,CRA,TEL,MIC,IND,PAV,GRU,PHE,SCL,FOR,ERI,HOR,RET,HYI,TUC,DOR,CAE,COL,PUP,PYX,PIC,MEN,APS,OCT
  const byte mySouthCONST[] = {2, 85, 13, 28, 15, 28, 80, 50, 57, 6, 72, 77, 25, 54, 44, 61, 39, 64, 71, 37, 36, 41, 33, 23, 68, 69, 65};
  const byte mySouthCONST_size = sizeof(mySouthCONST) / sizeof(mySouthCONST[0]);
  const char* myregionNAME[] = {"all", "North", "Spring", "Summer", "Autumn", "Winter", "South"}; // no south to save flash
  const byte regionArraySize = sizeof(myregionNAME) / sizeof(myregionNAME[0]); // Anzahl der Einträge
  byte myRegionNo = 0; // all - 0; North - 1; .... ; South - 6
  String myregionName = "";
  // variables for calculation of position // all positions are calculated in seconds
  long myRefStartTimeSec = 0; // Startzeit beim Setzen des Referenzsterns in Sekunden
  long myCurrentRAsec = 0; // meine aktuelle Rektaszension in Sekunden
  long myCurrentDECsec = 0; // meine aktuelle Deklination in Sekunden
  long myLastRAsec = 0; // meine letzte Rektaszension in Sekunden
  long myLastDECsec = 0; // meine letzte Deklination in Sekunden
  long myReferenceRAsec = 0; // meine Rektaszensionsreferenz in Sekunden
  long myReferenceDECsec = 0; // meine Deklinationsreferenz in Sekunden
  long mySensorRAsec = 0; // Sensorwert der Rektaszension in Sekunden
  long mySensorDECsec = 0; // Sensorwert der Deklination in Sekunden
  long myTargetRAsec = 0; // Rektaszension des Ziels in Sekunden
  long myTargetDECsec = 0; // Deklination des Ziels in Sekunden
  const int secPerStepRA = 86400L / IMPULSE24HRA; // defines how many seconds RA is changed per rotary step //  (24h * 3600sec = 86400sec) / (1:139 * 20 impulse = 2780) --> 31,079 sec / i
  const int secPerStepDEC = 1296000L / IMPULSE360DEGDEC; // defines how many seconds DEC is changed per rotary step //  (360° * 3600sec = 1296000sec) / (1:96 * 20 impulse = 1920) / --> 675 sec / i
  int myDirectionDEC = 1; // saves the value of the direction of the DEC axis, important if the telescope is turned over
  // for rotary encoders
  static uint8_t prevNextCode_ROT = 0;
  static uint16_t store_ROT = 0;
  static uint8_t prevNextCode_RA = 0;
  static uint16_t store_RA = 0;
  static uint8_t prevNextCode_DEC = 0;
  static uint16_t store_DEC = 0;
  static int8_t val_ROT, val_RA, val_DEC;
  int myImpulseRA = 0, myImpulseDEC = 0;
  int myLastImpulseRA = 0, myLastImpulseDEC = 0;
  const int8_t enc_table[] = {0, 1, 1, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 1, 1, 0};
  // variables for LX200
  byte statusLX200 = 0; // 0 - BT switched off / 1 - BT switched on / 2 - connected via BT & LX200 (frequent connect to LX200)
  byte statusLX200old = 0;
  byte btStatus = 0; // 0 - off / 1 - on
  unsigned long lastLX200Message = 0;
  DSOstruct externalObject; // instance LX200 object
  // setup
    // for LX200 protocol & debugging
    Serial.begin (9600);
    // while(!Serial); // attention - only for debugging when in use with IDE!
    // Serial.println(F("started"));
    getSettingsFromEeprom(); // load settings (brightness,contrast,...)
    setReference(); // set reference object to saved values
    setTarget(); // set target object to saved values
    setupLCD();
    createCustomCharacters();
    setupRotaryEncoders();
    initExternalObject();
  // software reset https://www.instructables.com/two-ways-to-reset-arduino-in-software/
  void(* resetFunc) (void) = 0;//declare reset function at address 0
  void setupLCD()
    lcd.begin(16, 2);
    updateLCD();
    pinMode(LCD_BACKLIGHT_PIN, OUTPUT);
    analogWrite(LCD_CONTRAST_PIN, myLCDcontrast); //set contrast
  //Creating custom characters in CG-RAM
  void createCustomCharacters()
    lcd.createChar(1 , ch_custom_1);
    lcd.createChar(2 , ch_custom_2);
    lcd.createChar(3 , ch_custom_3);
    lcd.createChar(4 , ch_custom_4);
    lcd.createChar(5 , ch_custom_5);
    lcd.createChar(6 , ch_custom_6);
    lcd.createChar(7 , ch_custom_7);
    lcd.createChar(8 , ch_custom_8);
  void setupRotaryEncoders()
    // HMI rotary encoder button
    pinMode(ROTARY_SW, INPUT_PULLUP);
    pinMode(ROTARY_CLK, INPUT);
    pinMode(ROTARY_DT, INPUT);
    // it is better to use the integrated pull-ups of KY-040 (this requires "+" to be connected to 5V) - https://forum.arduino.cc/index.php?topic=242356.0
    // as analog pins are used for rotary encoders - internal pull-ups are additionally used to avoid akward behaviour if not connected to sensors
    // RA rotary encoder
    pinMode(SENS_RA_CLK, INPUT_PULLUP);
    pinMode(SENS_RA_DT, INPUT_PULLUP);
    // DEC rotary encoder
    pinMode(SENS_DEC_CLK, INPUT_PULLUP);
    pinMode(SENS_DEC_DT, INPUT_PULLUP);
    // switch for BT module
    pinMode(BT_SWITCH, OUTPUT);
  // initialise external object struct for receiving via LX200
  void initExternalObject()
    externalObject.objectPreFixNameNo = 202; // is "external" in DSO PROGMEM
    externalObject.objectNumber = 0; // empty - no number in name
    externalObject.objectTypeMagnitude = 0;
    externalObject.objectConst = 0; // "all" in constellations
    externalObject.objectRA = 0;
    externalObject.objectDEC = 0;
  // \setup
  // loop
    analogWrite(LCD_BACKLIGHT_PIN, myLCDbacklight);  // LCD backlight analogWrite: values from 0 to 255
    updateRotaryEncoderButton();
    updateRotaryEncoders();
    calcCurrentPosition();
    if (myDisplayMode == 9) displaySensorValue();
    if (myDisplayMode == 11) displayCurrPos();
    if (myDisplayMode == 12) displayTargetPos();
    if (myDisplayMode == 13) displayDiffTargetCurrPos();
    // LX200 status
    updateLX200Status();
    readSendLX200();
  // \loop
  // read sensor values
  // reads rotary encoders
  void updateRotaryEncoders()
    if (val_ROT = read_rotary_ROT()) switchSelection(val_ROT);
    if (val_RA = read_rotary_RA())
      mySensorRAsec = mySensorRAsec + val_RA * secPerStepRA;
      myImpulseRA = myImpulseRA + val_RA; // for sensor test
    if (val_DEC = read_rotary_DEC())
      mySensorDECsec = mySensorDECsec + val_DEC * secPerStepDEC * myDirectionDEC;
      myImpulseDEC = myImpulseDEC + val_DEC * myDirectionDEC; // for sensor test
  // reads rotary encoder button
  void updateRotaryEncoderButton()
    // copy from https://arduinogetstarted.com/tutorials/arduino-button-debounce
    currentState = digitalRead(ROTARY_SW);
    if (currentState != lastFlickerableState)
      lastDebounceTime = millis();
      lastFlickerableState = currentState;
    if ((millis() - lastDebounceTime) > DEBOUNCE_DELAY)
      if (lastSteadyState == HIGH && currentState == LOW)
        switchMode();
        updateLCD();
        lastPressedTime = millis();
      else if (lastSteadyState == LOW && currentState == HIGH)
        // if button pressed > 5 seconds -> reset
        if (millis() - lastPressedTime > 5000) resetFunc(); // call reset
      lastSteadyState = currentState;
  // read rotary encoder for HMI
  // robust rotary encoder reading https://www.best-microcontroller-projects.com/rotary-encoder.html
  // A vald CW or  CCW move returns 1,invalid returns 0.
  int8_t read_rotary_ROT()
    prevNextCode_ROT <<= 2;
    if (digitalRead(ROTARY_DT)) prevNextCode_ROT |= 0x02;
    if (digitalRead(ROTARY_CLK)) prevNextCode_ROT |= 0x01;
    prevNextCode_ROT &= 0x0f;
    // If valid then store as 16 bit data.
    if  (enc_table[prevNextCode_ROT] )
      store_ROT <<= 4;
      store_ROT |= prevNextCode_ROT;
      if ((store_ROT & 0xff) == 0x2b) return -1;
      if ((store_ROT & 0xff) == 0x17) return 1;
    return 0;
  // read rotary encoder for RA
  int8_t read_rotary_RA()
    prevNextCode_RA <<= 2;
    if (digitalRead(SENS_RA_DT)) prevNextCode_RA |= 0x02;
    if (digitalRead(SENS_RA_CLK)) prevNextCode_RA |= 0x01;
    prevNextCode_RA &= 0x0f;
    if  (enc_table[prevNextCode_RA] )
      store_RA <<= 4;
      store_RA |= prevNextCode_RA;
      if ((store_RA & 0xff) == 0x2b) return -1;
      if ((store_RA & 0xff) == 0x17) return 1;
    return 0;
  // read rotary encoder for DEC
  int8_t read_rotary_DEC()
    prevNextCode_DEC <<= 2;
    if (digitalRead(SENS_DEC_DT)) prevNextCode_DEC |= 0x02;
    if (digitalRead(SENS_DEC_CLK)) prevNextCode_DEC |= 0x01;
    prevNextCode_DEC &= 0x0f;
    if  (enc_table[prevNextCode_DEC] )
      store_DEC <<= 4;
      store_DEC |= prevNextCode_DEC;
      if ((store_DEC & 0xff) == 0x2b) return -1;
      if ((store_DEC & 0xff) == 0x17) return 1;
    return 0;
  // get & set of object data
  // returns the type as number of a deep sky object
  byte getObjectType(byte typeMagnitude)
    return (typeMagnitude / 14); // decoding of object type from typeMagnitude
  // returns the type as string of a deep sky object
  String getObjectTypeName(byte typeMagnitude)
    return myObjectTypeName[(typeMagnitude / 14) - 1];
  // returns the magnitude of a deep sky object
  String getMagnitude(byte typeMagnitude)  // calcs the right magnitude - here modulo 14 as coded
    String strFlMag = (String)(typeMagnitude % 14) +  "m";
    return strFlMag;
  // returns the name of a constellation as string from a lookup tabel according to its number
  String getConstName(int no)
    constStruct oneConstellation;
    // copy constellations data from PROGMEM into oneConstellation according to no
    memcpy_P (&oneConstellation, &const_PROGMEM[no], sizeof oneConstellation);
    return (String)oneConstellation.constName;
  // returns the current constellation for filtering
  String getCurrentConstName()
    String constellationName;
    constellationName = getConstName(myConstellationNo);
    return constellationName;
  // returns the current cellestial region
  String getSetregionName()
    return myregionNAME[myRegionNo];
  // set reference star
  void setReference()
    // copy reference data from PROGMEM into myReference according to myRefNo
    memcpy_P (&myReference, &DSO_PROGMEM[myRefNo], sizeof myReference);
    setReferenceRA_DEC();
  // RA and DEC of selected target are set
  void setReferenceRA_DEC()
    // transfer RA / DEC into internal format (seconds)
    myReferenceRAsec = calcRAsecFromRA(myReference.objectRA);
    myReferenceDECsec = calcDECsecFromDEC(myReference.objectDEC);
  // set target
  void setTarget()
    // copy reference data from PROGMEM into myTarget according to myTargetNo
    memcpy_P (&myTarget, &DSO_PROGMEM[myTargetNo], sizeof myTarget);
    setTargetRA_DEC();
  void setTargetRA_DEC()
    myTargetRAsec = calcRAsecFromRA(myTarget.objectRA);
    myTargetDECsec = calcDECsecFromDEC(myTarget.objectDEC);
  // \get & set of object data
  // calculations and settings of positions
  // calculation of RA seconds
  unsigned int calcRAsecFromRA(unsigned int ra)
    int h = ra / 1000;
    int m = (ra - h * 1000) / 10;
    int s = (ra - h * 1000 - m * 10) * 6;
    unsigned int raSec = h * 3600L + m * 60 + s;
    return raSec;
  // calculation of DEC seconds
  long calcDECsecFromDEC(int dec)
    int deg = dec / 100;
    int m = (dec - deg * 100);
    long decSec = deg * 3600L + m * 60;
    return decSec;
  // calculation of current telescope position
  void calcCurrentPosition()
    myCurrentRAsec = myReferenceRAsec + myRefStartTimeSec + mySensorRAsec - millis() / 1000;
    myCurrentDECsec = myReferenceDECsec + mySensorDECsec;
  // sets the sensor values to zero - needed for alignment with reference star
  void resetSensorTime()
    myRefStartTimeSec = millis() / 1000;
  // \calculations and settings of positions
  // display information
  // display the current position
  void displayCurrPos()
    if (myLastRAsec != myCurrentRAsec || myLastDECsec != myCurrentDECsec)
      myLastRAsec = myCurrentRAsec;
      myLastDECsec = myCurrentDECsec;
      displayRA_DEC("Curr   ", "Coord", myCurrentRAsec, myCurrentDECsec);
  // display position of selected target
  void displayTargetPos()
    displayRA_DEC(getObjectName(myTarget.objectPreFixNameNo, myTarget.objectNumber, myTarget.objectConst), "Coord", myTargetRAsec, myTargetDECsec);
  // calulation & display of difference between current position & target position
  void displayDiffTargetCurrPos()
    long diffRAsec = myTargetRAsec - myCurrentRAsec;
    long diffDECsec = myTargetDECsec - myCurrentDECsec;
    if (myLastRAsec != myCurrentRAsec ||  myLastDECsec != myCurrentDECsec) // only if position has changed
      displayRA_DEC(getObjectName(myTarget.objectPreFixNameNo, myTarget.objectNumber, myTarget.objectConst), "Diff ", diffRAsec , diffDECsec);
  // display of RA and DEC - generic use for reference stars & target
  void displayRA_DEC(String text1, String text2, long rekSec, long dekSec)
    // Rektaszension //
    int sign = 1.0;
    if (rekSec < 0) sign = -1.0;
    byte s = (abs(rekSec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator // vorher int
    byte m  = (abs(rekSec / 60)) % 60;
    byte h  = (abs(rekSec / 3600)) % 24;
    lcd.setCursor(0, 0);
    printObjectName(text1);
    lcd.setCursor(8, 0);
    if (sign < 0) lcd.print(F("-"));
    else lcd.print(F("+"));
    if (h < 10) lcd.print(F(" "));
    lcd.print(h);
    lcd.print(F(":"));
    if (m < 10) lcd.print(F("0"));
    lcd.print(m);
    lcd.print(F(","));
    lcd.print(s / 6);
    // DEC // +90° - -90°
    sign = 1.0;
    if (dekSec < 0) sign = -1.0;
    s = (abs(dekSec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator
    m = (abs(dekSec / 60)) % 60;
    h = (abs(dekSec / 3600)) % 180;
    lcd.setCursor(0, 1);
    lcd.print(text2);
    lcd.setCursor(8, 1);
    lcd.print(h);
    lcd.print(ch_deg);
    lcd.print(m);
    lcd.print(F("'"));
  // display current sensor values
  void displaySensorValue()
    if (myImpulseRA != myLastImpulseRA || myImpulseDEC != myLastImpulseDEC)
      lcd.clear();
      lcd.print(F("Imp RA"));
      lcd.print(F("Imp DEC"));
      lcd.setCursor(10, 0);
      lcd.print(myImpulseRA);
      lcd.setCursor(10, 1);
      lcd.print(myImpulseDEC);
      myLastImpulseRA = myImpulseRA;
      myLastImpulseDEC = myImpulseDEC;
  // update LCD according to selected display mode
  void updateLCD()
    lcd.clear();
    if (myDisplayMode == 0)
      lcd.print(F("SpotNik   v")); // DO NOT REMOVE
      lcd.print(VERSION);
      lcd.print(F("developed by MR")); // DO NOT REMOVE
    if (myDisplayMode == 1) // main menu
      lcd.print(F(">"));
      lcd.setCursor(1, 0);
      lcd.print(menuTopic[myMenuTopicNo]); // {" reverse", "Ref","Target","region","Const","Bright","Contr","Test"};
      switch (myMenuTopicNo) {
        case 0:
          if (myDirectionDEC == 1) lcd.print(F("normal"));
          else lcd.print(F("reverse"));
        case 1:
          printObjectName(getObjectName(myReference.objectPreFixNameNo, myReference.objectNumber, myReference.objectConst));
        case 2:
          printObjectName(getObjectName(myTarget.objectPreFixNameNo, myTarget.objectNumber, myTarget.objectConst));
          //if (statusLX200 != 2) printObjectName(getObjectName(myTarget.objectPreFixNameNo,myTarget.objectNumber,myTarget.objectConst));
          //else lcd.print(F("external")); // if connection to LX200 source - no usage of internal star database
        case 3:
          lcd.print(getSetregionName());
          // if (statusLX200 != 2) lcd.print(getSetregionName());
          // else lcd.print(F("external"));
        case 4:
          lcd.print(getCurrentConstName());
          // if (statusLX200 != 2) lcd.print(getCurrentConstName());
        case 8:
          if (statusLX200 == 0) lcd.print(F("BT off"));
          if (statusLX200 == 1) lcd.print(F("BT on"));
          if (statusLX200 == 2) lcd.print(F("conn"));
      lcd.setCursor(1, 1);
      if (myMenuTopicNo + 1 < menuTopic_size)
        lcd.print(menuTopic[myMenuTopicNo + 1]);
        lcd.print(menuTopic[0]);
    if (myDisplayMode == 2)
      lcd.print(F("Direction of DEC"));
      lcd.print(F(">"));
    if (myDisplayMode == 3)
      lcd.setCursor(13, 0);
      lcd.print(getConstName(myReference.objectConst));
      lcd.print(getObjectTypeName(myReference.objectTypeMagnitude));
      lcd.setCursor(13, 1);
      lcd.print(getMagnitude(myReference.objectTypeMagnitude));
    if (myDisplayMode == 4)
      lcd.print(getConstName(myTarget.objectConst));
      lcd.print(getObjectTypeName(myTarget.objectTypeMagnitude));
      lcd.print(getMagnitude(myTarget.objectTypeMagnitude));
    if (myDisplayMode == 5)
      lcd.print(F("Celestial Region"));
      lcd.print(F(">"));
    if (myDisplayMode == 6)
      lcd.print(F("Constellation"));
      lcd.setCursor(11, 1);
      lcd.print(F(">"));
    if (myDisplayMode == 7)
      lcd.print(F("LCD Brightness"));
      lcd.print(F(">"));
      lcd.print(myLCDbacklight);
    if (myDisplayMode == 8)
      lcd.print(F("LCD Contrast"));
      lcd.print(F(">"));
      lcd.print(myLCDcontrast);
      lcd.print(F("For test"));
      lcd.print(F("turn DEC / RA"));
      myImpulseRA = 0;
      myImpulseDEC = 0;
      myLastImpulseRA = 0;
    if (myDisplayMode == 10)
      lcd.print(F("LX200 Connection"));
      lcd.print(F(">"));
      if (statusLX200 == 0) lcd.print(F("Bluetooth off"));
      if (statusLX200 == 1) lcd.print(F("Bluetooth on"));
      if (statusLX200 == 2) lcd.print(F("LX200 connected"));
  // returns name of deep sky object based on coded name its number and its constellation
  String getObjectName(byte objectprefixNameNo, unsigned int objectNumber, byte objectConst)
    String objectName = "";
    int indexOfHash = -1;
    DSONameStruct oneDSONameStruct;
    if (objectprefixNameNo > 0)
      // get name accordng to name number from lookup table
      memcpy_P (&oneDSONameStruct, &DSO_NAME_PROGMEM[objectprefixNameNo - 1], sizeof oneDSONameStruct);
      objectName = oneDSONameStruct.objectName;
      indexOfHash = objectName.indexOf('#');
      if (indexOfHash > -1)
        // replace char with greek char
        String charToReplace = objectName.substring(indexOfHash + 1, indexOfHash + 2);
        objectName = objectName.substring(0, indexOfHash) + objectName.substring(indexOfHash + 2); // delete # and next char from string
        // loop over the greek symbols
        for (int i; i < greekSymbols_size; i++)
          if ((String)charToReplace == (String)greekSymbols[i].originalChar)
            charToReplace = greekSymbols[i].replaceChar;
            objectName = objectName + charToReplace;
    if (objectNumber > 0)
      objectName = objectName + (String)objectNumber;
    // if object is only number,greek Symbol or max. two characters,accept 'M' - add constellation for identification
    if (objectName.charAt(1) == NULL || objectprefixNameNo == 0 || (objectName.charAt(2) == NULL && objectNumber == 0)) // oder nur Zahlen!!!
      objectName = objectName + ' ' + getConstName(objectConst);
    return objectName;
  // some greek symbols are custom, print function needed
  void printObjectName(String objectName)
    byte customChar = 0;
    char charAt0 = objectName.charAt(0);
    if (charAt0 == ch_def_1) customChar = 1;
    else if (charAt0 == ch_def_2) customChar = 2;
    else if (charAt0 == ch_def_3) customChar = 3;
    else if (charAt0 == ch_def_4) customChar = 4;
    else if (charAt0 == ch_def_5) customChar = 5;
    else if (charAt0 == ch_def_6) customChar = 6;
    else if (charAt0 == ch_def_7) customChar = 7;
    if (customChar > 0) lcd.write(customChar);
      lcd.print(objectName);
      return;
    lcd.print(F(" "));
    lcd.print(objectName.substring(2, 8));
  // \display information
  // switching
  // myDisplayMode - rotary encoder for change
  // 0 = welcome, 1 = top menu, 2 = change direction, 3 = set reference, 4 = set target, 5 = set region, 6 = set constellation, 7 = set LCD brightness, 8 = set LCD contrast
  // 9 = sensor test, 10 = set bluetooth, 11 = show current position, 12 = show target position, 13 = show difference target - current position
  void switchMode()
    saveSettingsToEeprom(); // save settings to eeprom each time the button is pressed
    if (myDisplayMode == 0) // welcome
      myDisplayMode = 1; // top menue
    else if (myDisplayMode == 1)
      myDisplayMode = myMenuTopicNo + 2;
    else if (myDisplayMode == 3) // set reference
      resetSensorTime();
      myLastDECsec = 0; // set once to zero to update display
      myDisplayMode = 11; // show current position
    else if (myDisplayMode == 4) // set target
      setTargetRA_DEC();
      myDisplayMode = 13; // show diff position
    // set direction // region // constellation // set brightness  // set contrast // sensor test // show current position // show diff position
    else if (myDisplayMode == 2 || myDisplayMode >= 5)
      myDisplayMode = 1; // return to top level menu
    lcd.clear();
  // function of rotary encoder changes acording to current display mode
  void switchSelection(int dir)
      myDisplayMode = 1;
      updateLCD();
    else if (myDisplayMode == 1) changeMenu(dir);
    if (myDisplayMode == 2) changeDirectionDEC(dir);
    if (myDisplayMode == 3) changeReference(dir);
    if (myDisplayMode == 4) changeTarget(dir);
    if (myDisplayMode == 5) changeregion(dir);
    if (myDisplayMode == 6) changeConstellation(dir);
    if (myDisplayMode == 7) changeLCDBacklight(dir);
    if (myDisplayMode == 8) changeLCDcontrast(dir);
    if (myDisplayMode == 10) changeBTconnection(dir);
    if (myDisplayMode == 11 || myDisplayMode == 12 || myDisplayMode == 13) changeView(dir);
    updateLCD();
  // change menu topics
  void changeMenu(int dir)
    if (dir == 1)
      if ((myMenuTopicNo + 1) < menuTopic_size)
        myMenuTopicNo = myMenuTopicNo + 1;
        myMenuTopicNo = 0;
    else if (dir == -1)
      if (myMenuTopicNo > 0)
        myMenuTopicNo = myMenuTopicNo - 1;
        myMenuTopicNo = menuTopic_size - 1;
  // according to the direction of the DEC axis the value of the DEC sensor has to be reverted
  void changeDirectionDEC(int dir)
    if (dir == 1 || dir == -1)
      if (myDirectionDEC == 1) myDirectionDEC = -1;
      else myDirectionDEC = 1;
  // calls changeObject for object type reference
  void changeReference (int dir)
    changeObject(dir, 'r');
  // calls changeObject for object type target
  void changeTarget(int dir)
    changeObject(dir, 't');
  // change referenc star including filter according to selected sky region
  void changeObject (int dir, char objectType)
    bool constFound = false;
    DSOstruct oneObject; // instance of reference for search & filter
    unsigned int objectNo;
    unsigned int numberOfLoops = 0;
    if (objectType == 'r')
      objectNo = myRefNo; // set start no of object
      objectNo = myTargetNo;
    while (constFound == false)
      if (dir == 1)
        if ((objectNo + 1) < DSO_PROGMEM_size)
          objectNo = objectNo + 1;
          objectNo = 0;
      if (dir == -1) // before else if - but what if no fitting star at beginning before rotary turning?
        if (objectNo > 0)
          objectNo = objectNo - 1;
          objectNo = DSO_PROGMEM_size - 1;
      memcpy_P (&oneObject, &DSO_PROGMEM[objectNo], sizeof oneObject); // get next DSO object from struct and copy it into oneObject
      // filter on a constellation
      // if a constellation is selected,object is a target and constellation of object fits to selected constellation
      if (objectType == 't' && myConstellationNo > 0 && getObjectType(oneObject.objectTypeMagnitude) > 0  && getObjectType(oneObject.objectTypeMagnitude) < 12 && oneObject.objectConst == myConstellationNo)
        constFound = true;
      // filter on regions
      else if ( (objectType == 'r' && getObjectType(oneObject.objectTypeMagnitude) == 12) || // reference stars     // filter on objects of type "reference" = no 12
                (myConstellationNo == 0 && objectType == 't' && getObjectType(oneObject.objectTypeMagnitude) > 0  && getObjectType(oneObject.objectTypeMagnitude) < 12)) // target objects
        // filter targets by constellations of the selected region
        // myregionNAME[]={"All","North","Spring","Summer","Autumn","Winter","South"};
        if (myRegionNo == 1) // region = north
          for (int i = 0; i < myNorthCONST_size; i++)
            if (oneObject.objectConst == myNorthCONST[i])
              constFound = true;
        else if (myRegionNo == 2) // region = spring
          for (int i = 0; i < mySpringCONST_size; i++)
            if (oneObject.objectConst == mySpringCONST[i])
              constFound = true;
        else if (myRegionNo == 3) // region = summer
          for (int i = 0; i < mySummerCONST_size; i++)
            if (oneObject.objectConst == mySummerCONST[i])
              constFound = true;
        else if (myRegionNo == 4) // region = autumn
          for (int i = 0; i < myAutumnCONST_size; i++)
            if (oneObject.objectConst == myAutumnCONST[i])
              constFound = true;
        else if (myRegionNo == 5) // region = winter
          for (int i = 0; i < myWinterCONST_size; i++)
            if (oneObject.objectConst == myWinterCONST[i])
              constFound = true;
        else if (myRegionNo == 6) // region = south
          for (int i = 0; i < mySouthCONST_size; i++)
            if (oneObject.objectConst == mySouthCONST[i])
              constFound = true;
        else // all constellations
          constFound = true;
    }// end while
      myRefNo = objectNo;
      myReference = oneObject; // copy selected reference object in my reference object
      myTargetNo = objectNo;
      myTarget = oneObject; // copy selected target object in my target object
      setTargetRA_DEC();
    updateLCD();
  // change region
  void changeregion(int dir)
    if (dir == 1)
      if ((myRegionNo + 1) < regionArraySize) {
        myRegionNo = myRegionNo + 1;
      else {
        myRegionNo = 0;
    else if (dir == -1)
      if (myRegionNo > 0) {
        myRegionNo = myRegionNo - 1;
      else {
        myRegionNo = regionArraySize - 1;
    myTargetNo = 0; // reset target,when aera has changed
    myConstellationNo = 0; // reset constellation,when aera has changed
    updateLCD();
  // set constellation
  void changeConstellation(int dir)
      if (dir == 1)
        if ((myConstellationNo) < constStruct_size - 1) {
          myConstellationNo = myConstellationNo + 1;
        else {
      else if (dir == -1)
        if (myConstellationNo > 0) {
          myConstellationNo = myConstellationNo - 1;
        else {
          myConstellationNo = constStruct_size - 1;
          if (myConstellationNo == myNorthCONST[i])
            constFound = true;
          if (myConstellationNo == mySpringCONST[i])
            constFound = true;
          if (myConstellationNo == mySummerCONST[i])
            constFound = true;
          if (myConstellationNo == myAutumnCONST[i])
            constFound = true;
          if (myConstellationNo == myWinterCONST[i])
            constFound = true;
          if (myConstellationNo == mySouthCONST[i])
            constFound = true;
        for (int i = 0; i < myAllCONST_size; i++)
          if (myConstellationNo == myAllCONST[i])
            constFound = true;
    myTargetNo = 0; // reset target every time when constellation was changed
    updateLCD();
  // switch view between current position, diff position & target coordinates
  void changeView(int dir)
    lcd.clear();
    myDisplayMode = myDisplayMode + dir;
    if (myDisplayMode > 13) myDisplayMode = 11;
    if (myDisplayMode < 11) myDisplayMode = 13;
  // set LCD brightness
  void changeLCDBacklight(int dir)
    myLCDbacklight = myLCDbacklight + dir * 8;
    if (myLCDbacklight > 255) myLCDbacklight = 0;
    if (myLCDbacklight < 0) myLCDbacklight = 255;
  // set LCD contrast
  void changeLCDcontrast(int dir)
    myLCDcontrast = myLCDcontrast + dir * 5;
    if (myLCDcontrast > 255) myLCDcontrast = 0;
    if (myLCDcontrast < 0) myLCDcontrast = 255;
  void changeBTconnection(int dir)
    if (btStatus == 0) // switch BT on if off
      btStatus = 1;
      statusLX200 = 1;
      digitalWrite(BT_SWITCH, HIGH);
    else if (btStatus != 0) // switch BT off
      btStatus = 0;
      statusLX200 = 0;
      digitalWrite(BT_SWITCH, LOW);
    updateLCD();
  // \switching
  // LX200 communication
  // set the status of LX200 to control LCD etc
  void updateLX200Status()
    if (btStatus == 1)
      // if frequent feedback from LX200 - last request > 4 sek
      if ((millis() - lastLX200Message) > 4000)
        statusLX200 = 1; // BT on - but no LX200 connection
        statusLX200 = 2; // LX200 connected
    // LX200 status changend - update lcd in relevant views (main menu & BT)
    if (statusLX200 != statusLX200old && (myDisplayMode == 10 || myDisplayMode == 1))
      updateLCD();
      statusLX200old = statusLX200;
  // called if a LX200 message was received
  void receivedLX200message() // received
    lastLX200Message = millis();
  // read the bluetooth message and trigger functions according to message type
  void readSendLX200()
    if (Serial.available())
      char message[14] = "";
      byte i = 0;
      while (Serial.available() > 0)
        char a = Serial.read(); // Stores current byte
        message[i] += a;      // Append current byte to message String
        delay(10);
        i++;
      // all LX200 info from https://www.meade.com/support/TelescopeProtocol_2010-10.pdf
      // LX200 message :GR#
      // Get Telescope RA
      // Returns: HH:MM.T#  or  HH:MM:SS#Depending which precision is set for the telescope
      if (message[0] == ':' && message[1] == 'G' && message[2] == 'R' && message[3] == '#')
        receivedLX200message();
        sendLX200RA();
      // LX200 message :GD# or :RS#:GD# or :RM#:GD#
      // Get Telescope Declination.
      // Returns: sDD*MM# or sDD*MM’SS#Depending upon the current precision setting for the telescope.
      if (message[0] == ':' && message[1] == 'G' && message[2] == 'D' && message[3] == '#' ||
          message[4] == ':' && message[5] == 'G' && message[6] == 'D' && message[7] == '#')
        sendLX200DEC();
      // LX200 message :CM#
      // Synchronizes the telescope's position with the currently selected database object's coordinates.
      // Returns:LX200's - a "#" terminated string with the name of the object that was synced
      if (message[0] == ':' && message[1] == 'C' && message[2] == 'M')
        Serial.print("#");
      // LX200 message :SrHH:MM.T# or :SrHH:MM:SS#
      // Set target object RA to HH:MM.T or HH:MM:SS depending on the current precision setting.
      // Returns:0 – Invalid1 - Valid
      // output HHMM(S/6)
      if (message[0] == ':' && message[1] == 'S' && message[2] == 'r')
        setRAtoLX200message(message);
      // LX200 message :SdsDD*MM#
      // Set target object declination to sDD*MM or sDD*MM:SS depending on the current precision setting
      // Returns:1 - Dec Accepted0 – Dec invalid
      // output sHHMM
      if (message[0] == ':' && message[1] == 'S' && message[2] == 'd')
        setDECtoLX200message(message);
      //  Serial.print("BT message "); // for debugging
      //  Serial.println(message);
  // set RA coordinates of placeholder externalobject to received LX200 message
  void setRAtoLX200message(char message[10])
      long(atoi(message + 3)) * 1000 + // HH // access at array different when using atoi - use address
      long(atoi(message + 6)) * 10; // MM - Minuten passen noch nicht bei zweistelligen gibt es Fehler
    if (message[8] == ':') // : or .
      externalObject.objectRA = externalObject.objectRA +
                                long(atoi(message + 9)) / 6; // SS/6
    else if (message[8] == '.')
      externalObject.objectRA = externalObject.objectRA + atoi(message + 9); // T
    Serial.println(); // leave this command, as otherwise no update on goto from LX200 source
  // set DEC coordinates of placeholder externalobject to received LX200 message & update the (reference or target) object
  void setDECtoLX200message(char message[9])
    int sign;
    if (message[3] == '-') sign = -1;
    else sign = 1;
      sign * ( // s
        long(atoi(message + 4)) * 100 + // DD
        long(atoi(message + 7))); // MM
    // assumption - first RA then DEC - then set target to external object
    if (myDisplayMode == 3 || myDisplayMode == 11) // if view shows reference selection or current position then copy external object into reference object
      externalObject.objectTypeMagnitude = 168;
      myReference = externalObject; // copy external object to my reference object
      resetSensorTime();
    else // in all other cases copy to target
      externalObject.objectTypeMagnitude = 182;
      myTarget = externalObject; // copy external object to my target object
      setTargetRA_DEC();
    updateLCD();
  // send current RA coordinate of telescope from SpotNik to LX200 server (e.g. Sky Safari)
  void sendLX200RA()
    byte s = (abs(myCurrentRAsec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator
    byte m  = (abs(myCurrentRAsec / 60)) % 60;
    byte h  = (abs(myCurrentRAsec / 3600)) % 24;
    String posString = "";
    if (h < 10) posString = "0";
    posString = posString + String(h);
    posString = posString + ":";
    if (m < 10) posString = posString + "0";
    posString = posString + String(m);
    if (s < 10) posString = posString + "0";
    posString = posString + String(s);
    posString = posString + "#";
    Serial.print(posString);
  // send current DEC coordinate of telescope from SpotNik to LX200 server (e.g. Sky Safari)
  void sendLX200DEC()
    byte s = (abs(myCurrentDECsec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator
    byte m = (abs(myCurrentDECsec / 60)) % 60;
    byte h = (abs(myCurrentDECsec / 3600)) % 180;
    if (myCurrentDECsec > 0) posString = "+";
    else posString = "-";
    posString = posString + "*";
  // \LX200 communication
  // EEPROM
  // save relevant data for next startup (e.g. target no,LCD brightness)
  void saveSettingsToEeprom()
    // Serial.print(F("freeMemory()=")); //only used for testing
    // Serial.println(freeMemory());
    byte addr = EEPROM_VALUE_ADDR_SIGNATURE;
    byte myTargetNoLowByte = lowByte(myTargetNo); // myTargetNo is of type int - transfer into two bytes
    byte myTargetNoHighByte = highByte(myTargetNo);
    byte myReferenceNoLowByte = lowByte(myRefNo); // myTargetNo is of type int - transfer into two bytes
    byte myReferenceNoHighByte = highByte(myRefNo);
    EEPROM.update(addr, EEPROM_SIGNATURE); // use update for longer eeprom life
    addr += sizeof(EEPROM_SIGNATURE);
    EEPROM.update(addr, myReferenceNoLowByte);
    addr += sizeof(myReferenceNoLowByte);
    EEPROM.update(addr, myReferenceNoHighByte);
    addr += sizeof(myReferenceNoHighByte);
    EEPROM.update(addr, myTargetNoLowByte);
    addr += sizeof(myTargetNoLowByte);
    EEPROM.update(addr, myTargetNoHighByte);
    addr += sizeof(myTargetNoHighByte);
    EEPROM.update(addr, myRegionNo);
    addr += sizeof(myRegionNo);
    EEPROM.update(addr, myConstellationNo);
    addr += sizeof(myConstellationNo);
    EEPROM.update(addr, myLCDbacklight);
    addr += sizeof(myLCDbacklight);
    EEPROM.update(addr, myLCDcontrast);
  // load relevant data at startup (e.g. target no, LCD brightness)
  void getSettingsFromEeprom()
    byte addr = EEPROM_VALUE_ADDR_SIGNATURE, signature = 0, value, myReferenceNoLowByte, myReferenceNoHighByte, myTargetNoLowByte, myTargetNoHighByte; // myTargetNo is of type int,need to concatenated from two bytes
    EEPROM.get(addr, signature);
    if (signature != EEPROM_SIGNATURE) return; // maybe data from another sketch
    EEPROM.get(addr, value);
    myReferenceNoLowByte = value;
    myReferenceNoHighByte = value;
    if (value >= 0 && value <= 32767)  myRefNo = word(myReferenceNoHighByte, myReferenceNoLowByte);
    myTargetNoLowByte = value;
    myTargetNoHighByte = value;
    if (value >= 0 && value <= 32767)  myTargetNo = word(myTargetNoHighByte, myTargetNoLowByte);
    if (value >= 0 && value <= 255) myRegionNo = value;
    if (value >= 0 && value <= 255) myConstellationNo = value;
    if (value >= 0 && value <= 255) myLCDbacklight = value;
    if (value >= 0 && value <= 255) myLCDcontrast = value;
  // \EEPROM
So. That's the code that I cannot upload to the Arduino Uno R3 board or the Arduino mega either won't work for me!
So, here is a copy off the error report which was generated after an upload attempt.
Hi David, I just tried out what you suggested and sadly--no luck.
here's a copy of the error report from the arduino IDE
Arduino: 1.8.20 Hourly Build 2021/12/20 07:33 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
type or paste code here
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09c\sketch_jul09c.ino: In function 'void setup()':
sketch_jul09c:3:3: error: 'SpotNik' was not declared in this scope
   SpotNik - by Max Reinecke
sketch_jul09c:3:13: error: 'by' was not declared in this scope
sketch_jul09c:12:31: error: 'without' was not declared in this scope
     but WITHOUT ANY WARRANTY; without even the implied warranty of
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09c\sketch_jul09c.ino:12:31: note: suggested alternative: 'stdout'
                               stdout
In file included from C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09c\sketch_jul09c.ino:29:0:
\\admin-che\c$\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:130:5: error: invalid declaration of member template in local class
     template< typename T > T &get( int idx, T &t ){
\\admin-che\c$\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:137:5: error: invalid declaration of member template in local class
     template< typename T > const T &put( int idx, const T &t ){
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09c\sketch_jul09c.ino:1495:1: warning: narrowing conversion of '129989' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09c\sketch_jul09c.ino:1495:1: warning: large integer implicitly truncated to unsigned type [-Woverflow]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09c\sketch_jul09c.ino:1495:1: warning: narrowing conversion of '189256' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09c\sketch_jul09c.ino:1495:1: warning: narrowing conversion of '106516' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09c\sketch_jul09c.ino:1495:1: warning: narrowing conversion of '109003' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09c\sketch_jul09c.ino:1495:1: warning: narrowing conversion of '128396' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09c\sketch_jul09c.ino:1495:1: warning: narrowing conversion of '113801' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09c\sketch_jul09c.ino:1495:1: warning: narrowing conversion of '157721' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
sketch_jul09c:1518:1: error: 'LiquidCrystal' was not declared in this scope
 LiquidCrystal lcd(rs,en,d4,d5,d6,d7);
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\sketch_jul09c\sketch_jul09c.ino:1518:1: note: suggested alternative: 'LiquidCrystal_h'
 LiquidCrystal_h
sketch_jul09c:1777:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:1796:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:1805:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:1817:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:1840:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:1856:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:1881:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:1899:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:1930:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:1949:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:1968:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:1994:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2000:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2006:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2013:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2022:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2030:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2036:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2044:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2052:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2060:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2075:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2085:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2094:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2101:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2116:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2127:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2133:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2147:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2190:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2209:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2353:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2401:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2433:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2465:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2487:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2514:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2524:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2530:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2536:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2680:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2706:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2815:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2824:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2832:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2841:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2866:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2891:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2897:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2963:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:2982:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:3011:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:3031:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:3057:1: error: a function-definition is not allowed here before '{' token
sketch_jul09c:3088:1: error: a function-definition is not allowed here before '{' token
exit status 1
option enabled in File -> Preferences.
Apart from any other problems you have two setup() functions in your sketch as pointed out by @david_2018
Start by deleting the first line of code, ie this one
or copy the fixed version that he posted
You also have two loop() functions, again not allowed. @david_2018 also fixed that
Hi Uk Helibob, I copied Daves suggested altered sketch and tried running/uploading more endless error messages I'm afraid.........here's a copy of the sketch followed by the error messages. Thanks for your help in this matter, much appreciated.
Created: May 2021
  SpotNik is software for a stepto system for telescopes
This program is free software : you can redistribute it and / or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
      This program is distributed in the hope that it will be useful,
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  GNU General Public License for more details.
  You should have received a copy of the GNU General Public License
along with this program.  If not, see < http : //www.gnu.org/licenses/>.
#define VERSION 2.0
  // to be changed by user according to EQ mount - see instructions
  // total numbers of impulse of the rotary encoder of RA axis when turned 24h
#define IMPULSE24HRA 2772 // 6h - 690 Impulse --> 24h - 4 * 693 = 2772 / ~ 1:138
  //  total numbers of impulse of the rotary encoder of DEC axis when turned 360° // +/- for correct direction
#define IMPULSE360DEGDEC 1784  // 90° - 446 Impulse --> 360° - 4 * 446 = 1784 / ~ 1:88
#include <LiquidCrystal.h> // I2C LCD arbeitet nicht vernünftig mit Rotary Encoder zusammen,daher normales nehmen
#include <EEPROM.h>
  //#include <MemoryFree.h> // only used for testing
  // LCD
#define LCD_CONTRAST_PIN 11 //  LCD contrast - V0 // use high frequency PWM to avoid flickering (Leonardo,Micro,Yún 3 and 11: 980 Hz // Mega pins 4 and 13: 980 Hz)
#define LCD_BACKLIGHT_PIN 10 // LCD backlight - LCD A
  // EEPROM
#define EEPROM_SIGNATURE 117 // value 0-255 (byte) - signature/mark to recognize if the value fits to this sketch
#define EEPROM_VALUE_ADDR_SIGNATURE 0
  // rotary enoder HMI
#define ROTARY_SW 3 // use interrupt pin - digital pins for interrupts on Micro,Leonardo and other 32u4 based 0,1,2,3,7
#define ROTARY_DT 4
#define ROTARY_CLK 5
  // Sensor RA
#define SENS_RA_DT A0 // analog pins used as UNO has not that many digital pins
#define SENS_RA_CLK A1
  // Sensor DEC
#define SENS_DEC_DT A2
#define SENS_DEC_CLK A3
  // LX200 connection
#define BT_SWITCH 2
  // lookup table with names of deep sky objects
  struct DSONameStruct
    char objectName[9];
  const struct DSONameStruct DSO_NAME_PROGMEM[202] PROGMEM =
    {"3C273"},
    {"B"},
    {"IC"},
    {"M"},
    {"NGC"},
    {"#a"},
    {"#aA"},
    {"#aB"},
    {"#b"},
    {"#c"},
    {"#d"},
    {"#e"},
    {"#e1"},
    {"#e2"},
    {"#g"},
    {"#h"},
    {"#i"},
    {"#j"},
    {"#k"},
    {"#l"},
    {"#m"},
    {"#n"},
    {"#o"},
    {"#p"},
    {"#q"},
    {"#r"},
    {"#s"},
    {"#t"},
    {"#u"},
    {"#w"},
    {"#x"},
    {"#z"},
    {"AC"},
    {"Achernar"},
    {"Acrab"},
    {"Acrux"},
    {"Adhara"},
    {"Agena"},
    {"Alamak"},
    {"Aldebara"},
    {"Alderami"},
    {"AlDhanab"},
    {"Algenib"},
    {"Algieba"},
    {"Algol"},
    {"Alhena"},
    {"Alioth"},
    {"Alkaid"},
    {"AlNair"},
    {"Alnilam"},
    {"Alnitak"},
    {"Alphard"},
    {"Alphecca"},
    {"Alpherat"},
    {"Alsuhail"},
    {"Altair"},
    {"Aludra"},
    {"Ankaa"},
    {"Antares"},
    {"AQ"},
    {"Arcturus"},
    {"Arneb"},
    {"Aspidisk"},
    {"Atria"},
    {"Avior"},
    {"AW"},
    {"AX"},
    {"BD"},
    {"Becrux"},
    {"Bellatri"},
    {"Betelgeu"},
    {"BF"},
    {"BG"},
    {"BL"},
    {"BM"},
    {"BX"},
    {"Canopus"},
    {"Capella"},
    {"Caph"},
    {"Castor"},
    {"Cih"},
    {"CY"},
    {"Deneb"},
    {"DenebKai"},
    {"Denebola"},
    {"Diphda"},
    {"DR"},
    {"Dschubba"},
    {"Dubhe"},
    {"EL"},
    {"ElNath"},
    {"Eltanin"},
    {"Enif"},
    {"FO"},
    {"Fomalhau"},
    {"FU"},
    {"Gacrux"},
    {"Gemma"},
    {"Gienah"},
    {"Girtab"},
    {"GK"},
    {"GY"},
    {"H"},
    {"Hadar"},
    {"Hamal"},
    {"Han"},
    {"HD"},
    {"HJ"},
    {"HK"},
    {"HN"},
    {"Izar"},
    {"JC"},
    {"KausAust"},
    {"Kochab"},
    {"KooShe"},
    {"Markab"},
    {"Menkalin"},
    {"Menkar"},
    {"Menkent"},
    {"Merak"},
    {"Miaplaci"},
    {"Mimosa"},
    {"Mintaka"},
    {"Mirach"},
    {"Mirfak"},
    {"Mirzam"},
    {"Mizar"},
    {"Naos"},
    {"NQ"},
    {"NSV"},
    {"Nunki"},
    {"O#F"},
    {"Peacock"},
    {"Phecda"},
    {"Polaris"},
    {"Pollux"},
    {"Procyon"},
    {"PZ6"},
    {"R"},
    {"RasAlhag"},
    {"Regulus"},
    {"Rigel"},
    {"RigilKen"},
    {"RR"},
    {"RS"},
    {"RT"},
    {"RU"},
    {"RV"},
    {"RX"},
    {"RY"},
    {"RZ"},
    {"S"},
    {"S605"},
    {"Sabik"},
    {"Sadr"},
    {"Saiph"},
    {"SAO"},
    {"Sargas"},
    {"Scheat"},
    {"Schedar"},
    {"Shaula"},
    {"SHJ"},
    {"Sirius"},
    {"Spica"},
    {"SS"},
    {"ST"},
    {"SU"},
    {"SV"},
    {"SY"},
    {"SZ"},
    {"T"},
    {"TT"},
    {"TU"},
    {"Tureis"},
    {"TW"},
    {"TX"},
    {"U"},
    {"UU"},
    {"UV"},
    {"UX"},
    {"UY"},
    {"V"},
    {"Vega"},
    {"VW"},
    {"VX"},
    {"VY"},
    {"W"},
    {"Wei"},
    {"Wezen"},
    {"WO"},
    {"WW"},
    {"WX"},
    {"WZ"},
    {"X"},
    {"XS"},
    {"XX"},
    {"Y"},
    {"Z"},
    {"Zozma"},
    {"β648"},
    {"#F"},
    {"extern"}
  // data of deep sky objects
  struct DSOstruct
    byte objectPreFixNameNo; // number of name for lookup table
    unsigned int objectNumber; // if name contains a number
    byte objectTypeMagnitude; // object type & magnitude coded in one byte
    byte objectConst; // constellation of object
    unsigned int objectRA; //HHMM(SS/6)
    int objectDEC; //sHHMM
  DSOstruct myTarget; // object to store data of selected target
  DSOstruct myReference; // object to store data of selected target
  const unsigned int DSO_PROGMEM_size = 1204;
  const struct DSOstruct DSO_PROGMEM[DSO_PROGMEM_size] PROGMEM =
    {1, 0, 27, 86, 12291, 203},
    {2, 33, 42, 60, 5409, -228},
    {2, 65, 42, 77, 18027, -2750},
    {2, 86, 42, 59, 17196, -2642},
    {3, 342, 54, 11, 3468, 6806},
    {3, 405, 66, 8, 5165, 3421},
    {3, 410, 64, 8, 5227, 3325},
    {3, 434, 67, 60, 5410, -227},
    {3, 1396, 74, 16, 21391, 5730},
    {3, 4406, 95, 50, 14224, -4409},
    {3, 5067, 64, 31, 20508, 4421},
    {3, 5146, 80, 31, 21534, 4716},
    {4, 1, 106, 78, 5345, 2201},
    {4, 2, 119, 5, 21335, -49},
    {4, 3, 118, 30, 13422, 2823},
    {4, 4, 117, 72, 16236, -2632},
    {4, 5, 118, 74, 15186, 205},
    {4, 6, 130, 72, 17403, -3215},
    {4, 7, 129, 72, 17539, -3448},
    {4, 8, 75, 77, 18037, -2423},
    {4, 9, 120, 59, 17192, -1831},
    {4, 10, 119, 59, 16571, -406},
    {4, 11, 132, 73, 18511, -616},
    {4, 12, 118, 59, 16472, -157},
    {4, 13, 118, 40, 16417, 3628},
    {4, 14, 120, 59, 17376, -315},
    {4, 15, 118, 62, 21300, 1210},
    {4, 16, 76, 74, 18188, -1347},
    {4, 17, 76, 77, 18208, -1611},
    {4, 18, 133, 77, 18199, -1708},
    {4, 19, 119, 59, 17026, -2616},
    {4, 20, 76, 77, 18027, -2258},
    {4, 21, 132, 77, 18042, -2229},
    {4, 22, 117, 77, 18364, -2354},
    {4, 23, 132, 77, 17571, -1859},
    {4, 24, 129, 77, 18266, -1823},
    {4, 25, 131, 77, 18318, -1907},
    {4, 26, 134, 73, 18452, -924},
    {4, 27, 91, 88, 19596, 2243},
    {4, 28, 119, 77, 18245, -2452},
    {4, 29, 133, 31, 20239, 3832},
    {4, 30, 119, 12, 21404, -2311},
    {4, 31, 45, 1, 427, 4116},
    {4, 32, 50, 1, 427, 4052},
    {4, 33, 48, 81, 1339, 3039},
    {4, 34, 131, 63, 2421, 4247},
    {4, 35, 131, 38, 6089, 2421},
    {4, 36, 132, 8, 5363, 3408},
    {4, 37, 132, 8, 5523, 3233},
    {4, 38, 132, 8, 5287, 3551},
    {4, 39, 131, 31, 21322, 4826},
    {4, 40, 149, 83, 12219, 5806},
    {4, 41, 131, 20, 6460, -2045},
    {4, 42, 74, 60, 5353, -523},
    {4, 43, 63, 60, 5355, -516},
    {4, 44, 129, 22, 8400, 1940},
    {4, 45, 71, 78, 3470, 2407},
    {4, 46, 132, 68, 7418, -1449},
    {4, 47, 130, 68, 7366, -1429},
    {4, 48, 132, 42, 8137, -545},
    {4, 49, 50, 86, 12298, 800},
    {4, 50, 132, 55, 7025, -823},
    {4, 51, 50, 30, 13299, 4712},
    {4, 52, 133, 14, 23242, 6135},
    {4, 53, 120, 24, 13129, 1810},
    {4, 54, 120, 77, 18551, -3029},
    {4, 55, 118, 77, 19400, -3058},
    {4, 56, 120, 52, 19166, 3011},
    {4, 57, 93, 52, 18536, 3302},
    {4, 58, 52, 86, 12377, 1149},
    {4, 59, 52, 86, 12420, 1139},
    {4, 60, 51, 86, 12437, 1133},
    {4, 61, 52, 86, 12219, 428},
    {4, 62, 118, 59, 17012, -3007},
    {4, 63, 51, 30, 13158, 4202},
    {4, 64, 51, 24, 12567, 2141},
    {4, 65, 51, 46, 11189, 1305},
    {4, 66, 51, 46, 11202, 1300},
    {4, 67, 133, 22, 8508, 1149},
    {4, 68, 119, 42, 12395, -2645},
    {4, 69, 120, 77, 18314, -3221},
    {4, 70, 120, 77, 18432, -3218},
    {4, 71, 120, 76, 19538, 1847},
    {4, 72, 121, 5, 20535, -1232},
    {4, 73, 136, 5, 20590, -1238},
    {4, 74, 51, 67, 1367, 1547},
    {4, 75, 121, 77, 20061, -2155},
    {4, 76, 94, 63, 1423, 5135},
    {4, 77, 51, 17, 2427, -1},
    {4, 78, 64, 60, 5468, 5},
    {4, 79, 120, 47, 5242, -2431},
    {4, 80, 119, 72, 16170, -2259},
    {4, 81, 49, 83, 9556, 6904},
    {4, 82, 50, 83, 9559, 6941},
    {4, 83, 50, 42, 13370, -2952},
    {4, 84, 51, 86, 12251, 1253},
    {4, 85, 51, 24, 12254, 1811},
    {4, 86, 51, 86, 12262, 1257},
    {4, 87, 51, 86, 12308, 1223},
    {4, 88, 52, 24, 12320, 1425},
    {4, 89, 52, 86, 12357, 1233},
    {4, 90, 52, 86, 12368, 1310},
    {4, 91, 52, 24, 12354, 1430},
    {4, 92, 119, 40, 17171, 4308},
    {4, 93, 132, 68, 7445, -2351},
    {4, 94, 50, 30, 12509, 4107},
    {4, 95, 52, 46, 10440, 1142},
    {4, 96, 51, 46, 10468, 1149},
    {4, 97, 95, 83, 11148, 5501},
    {4, 98, 52, 24, 12138, 1454},
    {4, 99, 52, 24, 12188, 1425},
    {4, 100, 51, 24, 12229, 1549},
    {4, 101, 50, 83, 14032, 5421},
    {4, 102, 52, 34, 15065, 5546},
    {4, 103, 133, 14, 1334, 6039},
    {4, 104, 50, 86, 12400, -1137},
    {4, 105, 51, 46, 10478, 1235},
    {4, 106, 50, 30, 12190, 4718},
    {4, 107, 120, 59, 16325, -1303},
    {4, 108, 52, 83, 11115, 5540},
    {4, 109, 52, 83, 11576, 5322},
    {4, 110, 50, 1, 404, 4141},
    {5, 40, 94, 16, 130, 7231},
    {5, 55, 50, 71, 149, -3911},
    {5, 129, 133, 14, 300, 6013},
    {5, 136, 137, 14, 315, 6131},
    {5, 147, 52, 14, 332, 4830},
    {5, 157, 52, 17, 348, -824},
    {5, 185, 51, 14, 390, 4820},
    {5, 188, 134, 16, 475, 8514},
    {5, 210, 52, 17, 406, -1352},
    {5, 225, 133, 14, 436, 6146},
    {5, 246, 94, 17, 471, -1152},
    {5, 247, 51, 17, 471, -2046},
    {5, 253, 49, 71, 476, -2518},
    {5, 278, 52, 14, 521, 4733},
    {5, 281, 77, 14, 530, 5637},
    {5, 288, 120, 71, 528, -2635},
    {5, 300, 50, 71, 549, -3741},
    {5, 381, 135, 14, 1084, 6135},
    {5, 404, 52, 1, 1094, 3543},
    {5, 436, 135, 14, 1160, 5849},
    {5, 457, 132, 14, 1195, 5817},
    {5, 488, 52, 67, 1218, 515},
    {5, 524, 52, 67, 1248, 932},
    {5, 559, 136, 14, 1295, 6319},
    {5, 584, 52, 17, 1313, -652},
    {5, 596, 52, 17, 1329, -702},
    {5, 613, 52, 71, 1343, -2925},
    {5, 615, 53, 17, 1351, -720},
    {5, 637, 134, 14, 1431, 6402},
    {5, 654, 133, 14, 1440, 6153},
    {5, 659, 134, 14, 1444, 6040},
    {5, 663, 133, 14, 1460, 6115},
    {5, 672, 52, 81, 1479, 2726},
    {5, 720, 52, 17, 1530, -1344},
    {5, 752, 132, 1, 1577, 3740},
    {5, 772, 52, 7, 1593, 1900},
    {5, 779, 53, 17, 1597, -558},
    {5, 869, 131, 63, 2191, 5708},
    {5, 884, 132, 63, 2225, 5709},
    {5, 891, 52, 1, 2226, 4221},
    {5, 908, 52, 17, 2231, -2114},
    {5, 925, 52, 81, 2273, 3335},
    {5, 936, 52, 17, 2276, -109},
    {5, 986, 52, 37, 2336, -3903},
    {5, 1022, 53, 17, 2385, -641},
    {5, 1023, 51, 63, 2404, 3904},
    {5, 1027, 133, 14, 2426, 6136},
    {5, 1052, 52, 17, 2411, -815},
    {5, 1055, 52, 17, 2418, 27},
    {5, 1084, 52, 36, 2460, -735},
    {5, 1097, 52, 37, 2463, -3017},
    {5, 1232, 52, 36, 3098, -2035},
    {5, 1245, 134, 63, 3147, 4714},
    {5, 1261, 120, 41, 3123, -5513},
    {5, 1275, 53, 63, 3198, 4131},
    {5, 1291, 51, 36, 3173, -4106},
    {5, 1300, 52, 36, 3197, -1925},
    {5, 1316, 51, 37, 3227, -3713},
    {5, 1325, 53, 36, 3244, -2133},
    {5, 1332, 52, 36, 3263, -2120},
    {5, 1342, 133, 63, 3317, 3722},
    {5, 1360, 93, 37, 3332, -2552},
    {5, 1365, 52, 37, 3336, -3608},
    {5, 1374, 53, 37, 3353, -3514},
    {5, 1380, 54, 37, 3368, -3444},
    {5, 1398, 52, 37, 3389, -2620},
    {5, 1399, 52, 37, 3385, -3527},
    {5, 1407, 52, 36, 3402, -1835},
    {5, 1433, 52, 41, 3420, -4713},
    {5, 1444, 133, 63, 3494, 5240},
    {5, 1491, 70, 63, 4032, 5119},
    {5, 1499, 61, 63, 4032, 3622},
    {5, 1501, 96, 11, 4070, 6055},
    {5, 1502, 133, 11, 4078, 6220},
    {5, 1513, 134, 63, 4099, 4931},
    {5, 1514, 94, 78, 4093, 3047},
    {5, 1528, 132, 63, 4153, 5113},
    {5, 1532, 52, 36, 4121, -3252},
    {5, 1535, 93, 36, 4143, -1244},
    {5, 1545, 132, 63, 4209, 5015},
    {5, 1549, 52, 33, 4158, -5536},
    {5, 1566, 52, 33, 4200, -5456},
    {5, 1647, 132, 78, 4459, 1906},
    {5, 1664, 134, 8, 4511, 4341},
    {5, 1672, 52, 33, 4457, -5915},
    {5, 1788, 70, 60, 5069, -320},
    {5, 1792, 52, 23, 5052, -3759},
    {5, 1808, 52, 23, 5077, -3731},
    {5, 1817, 134, 78, 5124, 1641},
    {5, 1851, 119, 23, 5141, -4003},
    {5, 1857, 133, 8, 5201, 3921},
    {5, 1907, 134, 8, 5281, 3520},
    {5, 1909, 70, 36, 5045, -716},
    {5, 1931, 80, 8, 5314, 3415},
    {5, 1961, 53, 11, 5421, 6923},
    {5, 1964, 52, 47, 5334, -2157},
    {5, 1973, 63, 60, 5351, -444},
    {5, 1980, 73, 60, 5354, -555},
    {5, 1999, 70, 60, 5364, -643},
    {5, 2022, 95, 60, 5421, 905},
    {5, 2024, 70, 60, 5417, -151},
    {5, 2126, 136, 8, 6025, 4952},
    {5, 2129, 133, 38, 6007, 2319},
    {5, 2158, 135, 38, 6074, 2406},
    {5, 2169, 132, 60, 6084, 1358},
    {5, 2175, 77, 60, 6096, 2029},
    {5, 2185, 70, 55, 6110, -614},
    {5, 2186, 135, 60, 6121, 528},
    {5, 2194, 135, 60, 6138, 1248},
    {5, 2204, 135, 20, 6155, -1840},
    {5, 2207, 52, 20, 6164, -2122},
    {5, 2215, 134, 55, 6208, -717},
    {5, 2232, 130, 55, 6280, -451},
    {5, 2237, 76, 55, 6309, 503},
    {5, 2238, 62, 55, 6307, 501},
    {5, 2239, 131, 55, 6319, 457},
    {5, 2245, 70, 55, 6327, 1009},
    {5, 2251, 133, 55, 6346, 822},
    {5, 2261, 70, 55, 6392, 845},
    {5, 2264, 74, 55, 6410, 954},
    {5, 2266, 136, 38, 6433, 2658},
    {5, 2281, 131, 8, 6483, 4105},
    {5, 2286, 134, 55, 6477, -309},
    {5, 2300, 53, 16, 7323, 8543},
    {5, 2301, 132, 55, 6518, 28},
    {5, 2304, 136, 38, 6552, 1759},
    {5, 2311, 136, 55, 6578, -437},
    {5, 2324, 134, 55, 7041, 103},
    {5, 2335, 133, 55, 7068, -1002},
    {5, 2343, 133, 55, 7081, -1037},
    {5, 2346, 96, 55, 7094, -48},
    {5, 2353, 133, 55, 7145, -1016},
    {5, 2354, 133, 20, 7143, -2542},
    {5, 2355, 136, 38, 7170, 1345},
    {5, 2359, 70, 20, 7185, -1314},
    {5, 2360, 133, 20, 7177, -1538},
    {5, 2362, 130, 20, 7187, -2457},
    {5, 2371, 95, 38, 7256, 2929},
    {5, 2372, 95, 38, 7256, 2930},
    {5, 2383, 134, 20, 7247, -2057},
    {5, 2384, 133, 20, 7252, -2101},
    {5, 2392, 93, 38, 7292, 2055},
    {5, 2395, 134, 38, 7272, 1337},
    {5, 2403, 51, 11, 7368, 6536},
    {5, 2419, 122, 51, 7381, 3853},
    {5, 2420, 134, 38, 7384, 2134},
    {5, 2421, 134, 68, 7362, -2037},
    {5, 2423, 133, 68, 7371, -1352},
    {5, 2438, 95, 68, 7418, -1444},
    {5, 2439, 133, 68, 7408, -3142},
    {5, 2440, 95, 68, 7419, -1813},
    {5, 2467, 77, 68, 7525, -2626},
    {5, 2477, 132, 68, 7522, -3832},
    {5, 2479, 136, 68, 7551, -1742},
    {5, 2482, 133, 68, 7552, -2415},
    {5, 2489, 134, 68, 7563, -3004},
    {5, 2506, 134, 55, 8000, -1046},
    {5, 2509, 135, 68, 8008, -1903},
    {5, 2527, 133, 68, 8050, -2809},
    {5, 2539, 133, 68, 8106, -1249},
    {5, 2547, 131, 85, 8102, -4912},
    {5, 2567, 133, 68, 8185, -3039},
    {5, 2571, 133, 68, 8189, -2945},
    {5, 2613, 52, 69, 8334, -2258},
    {5, 2627, 134, 69, 8372, -2957},
    {5, 2655, 52, 11, 8556, 7813},
    {5, 2681, 52, 83, 8535, 5119},
    {5, 2683, 52, 51, 8527, 3325},
    {5, 2742, 53, 83, 9076, 6029},
    {5, 2768, 52, 83, 9116, 6002},
    {5, 2775, 52, 22, 9103, 702},
    {5, 2782, 53, 51, 9141, 4007},
    {5, 2784, 52, 42, 9123, -2410},
    {5, 2787, 52, 83, 9193, 6912},
    {5, 2811, 53, 42, 9162, -1619},
    {5, 2835, 52, 42, 9179, -2221},
    {5, 2841, 51, 83, 9220, 5059},
    {5, 2859, 52, 49, 9243, 3431},
    {5, 2867, 94, 13, 9214, -5819},
    {5, 2903, 51, 46, 9322, 2130},
    {5, 2950, 52, 83, 9426, 5851},
    {5, 2964, 53, 46, 9429, 3151},
    {5, 2974, 52, 75, 9426, -342},
    {5, 2976, 52, 83, 9472, 6755},
    {5, 2985, 52, 83, 9504, 7217},
    {5, 2997, 51, 2, 9456, -3111},
    {5, 3077, 52, 83, 10033, 6844},
    {5, 3079, 52, 83, 10020, 5541},
    {5, 3109, 52, 42, 10031, -2610},
    {5, 3115, 51, 75, 10052, -743},
    {5, 3132, 92, 85, 10070, -4026},
    {5, 3147, 52, 34, 10169, 7324},
    {5, 3166, 52, 75, 10138, 326},
    {5, 3169, 52, 75, 10142, 328},
    {5, 3184, 52, 83, 10183, 4125},
    {5, 3190, 53, 46, 10181, 2150},
    {5, 3193, 52, 46, 10184, 2154},
    {5, 3198, 52, 83, 10199, 4533},
    {5, 3201, 119, 85, 10176, -4625},
    {5, 3226, 53, 46, 10234, 1954},
    {5, 3227, 52, 46, 10235, 1952},
    {5, 3242, 93, 42, 10248, -1839},
    {5, 3245, 52, 49, 10273, 2830},
    {5, 3277, 53, 49, 10329, 2831},
    {5, 3294, 53, 49, 10363, 3719},
    {5, 3310, 52, 83, 10388, 5330},
    {5, 3344, 52, 49, 10435, 2455},
    {5, 3359, 52, 83, 10466, 6313},
    {5, 3372, 59, 13, 10451, -5952},
    {5, 3377, 52, 46, 10477, 1359},
    {5, 3384, 52, 46, 10483, 1238},
    {5, 3395, 54, 49, 10498, 3259},
    {5, 3412, 52, 46, 10509, 1325},
    {5, 3414, 53, 49, 10513, 2758},
    {5, 3432, 53, 49, 10525, 3637},
    {5, 3486, 52, 49, 11004, 2859},
    {5, 3489, 52, 46, 11003, 1354},
    {5, 3504, 53, 49, 11032, 2758},
    {5, 3521, 51, 46, 11058, -2},
    {5, 3532, 129, 13, 11052, -5844},
    {5, 3593, 52, 46, 11146, 1249},
    {5, 3607, 52, 46, 11169, 1803},
    {5, 3608, 52, 46, 11170, 1809},
    {5, 3610, 52, 83, 11184, 5847},
    {5, 3613, 52, 83, 11186, 5800},
    {5, 3619, 53, 83, 11194, 5745},
    {5, 3621, 52, 42, 11183, -3249},
    {5, 3626, 53, 46, 11201, 1821},
    {5, 3628, 52, 46, 11203, 1335},
    {5, 3631, 52, 83, 11210, 5310},
    {5, 3640, 52, 46, 11211, 314},
    {5, 3655, 53, 46, 11229, 1635},
    {5, 3665, 52, 83, 11247, 3846},
    {5, 3675, 52, 83, 11261, 4335},
    {5, 3686, 53, 46, 11277, 1713},
    {5, 3717, 53, 42, 11315, -3019},
    {5, 3718, 52, 83, 11326, 5304},
    {5, 3726, 52, 83, 11333, 4702},
    {5, 3729, 53, 83, 11338, 5308},
    {5, 3810, 52, 46, 11410, 1128},
    {5, 3813, 53, 83, 11413, 3633},
    {5, 3877, 53, 83, 11461, 4730},
    {5, 3893, 52, 83, 11486, 4843},
    {5, 3898, 52, 83, 11493, 5605},
    {5, 3900, 53, 46, 11492, 2701},
    {5, 3912, 54, 46, 11501, 2629},
    {5, 3918, 92, 15, 11503, -5711},
    {5, 3923, 52, 42, 11510, -2848},
    {5, 3938, 52, 83, 11528, 4407},
    {5, 3941, 52, 83, 11529, 3659},
    {5, 3945, 52, 83, 11532, 6040},
    {5, 3949, 53, 83, 11537, 4752},
    {5, 3953, 52, 83, 11538, 5219},
    {5, 3962, 52, 27, 11547, -1359},
    {5, 3982, 53, 83, 11565, 5507},
    {5, 3998, 52, 83, 11579, 5527},
    {5, 4013, 53, 83, 11585, 4357},
    {5, 4026, 52, 83, 11594, 5058},
    {5, 4027, 53, 29, 11595, -1916},
    {5, 4030, 52, 86, 12004, -106},
    {5, 4036, 52, 83, 12015, 6154},
    {5, 4038, 52, 29, 12019, -1852},
    {5, 4039, 52, 29, 12019, -1853},
    {5, 4041, 53, 83, 12022, 6208},
    {5, 4051, 52, 83, 12032, 4432},
    {5, 4085, 54, 83, 12054, 5021},
    {5, 4088, 52, 83, 12056, 5032},
    {5, 4096, 52, 83, 12060, 4729},
    {5, 4102, 53, 83, 12064, 5243},
    {5, 4105, 52, 42, 12067, -2946},
    {5, 4111, 52, 30, 12070, 4304},
    {5, 4125, 52, 34, 12081, 6510},
    {5, 4143, 52, 30, 12096, 4232},
    {5, 4147, 122, 24, 12101, 1833},
    {5, 4150, 53, 24, 12106, 3024},
    {5, 4151, 52, 30, 12105, 3924},
    {5, 4179, 53, 86, 12129, 118},
    {5, 4203, 52, 24, 12151, 3312},
    {5, 4214, 52, 30, 12156, 3620},
    {5, 4216, 52, 86, 12159, 1309},
    {5, 4236, 52, 34, 12167, 6928},
    {5, 4244, 52, 30, 12175, 3748},
    {5, 4245, 53, 24, 12176, 2936},
    {5, 4251, 52, 24, 12181, 2810},
    {5, 4261, 52, 86, 12194, 549},
    {5, 4273, 53, 86, 12199, 521},
    {5, 4274, 52, 24, 12198, 2937},
    {5, 4278, 52, 24, 12201, 2917},
    {5, 4281, 53, 86, 12204, 523},
    {5, 4293, 52, 24, 12212, 1823},
    {5, 4314, 52, 24, 12225, 2954},
    {5, 4346, 53, 30, 12235, 4700},
    {5, 4350, 53, 24, 12240, 1642},
    {5, 4361, 94, 29, 12245, -1847},
    {5, 4365, 52, 86, 12245, 719},
    {5, 4371, 52, 86, 12249, 1142},
    {5, 4388, 53, 86, 12258, 1240},
    {5, 4394, 52, 24, 12259, 1813},
    {5, 4395, 52, 30, 12258, 3333},
    {5, 4414, 52, 24, 12265, 3113},
    {5, 4419, 53, 24, 12269, 1503},
    {5, 4429, 52, 86, 12274, 1106},
    {5, 4435, 52, 86, 12277, 1305},
    {5, 4438, 52, 86, 12278, 1300},
    {5, 4442, 52, 86, 12281, 948},
    {5, 4448, 53, 24, 12283, 2837},
    {5, 4449, 52, 30, 12282, 4406},
    {5, 4450, 52, 24, 12285, 1705},
    {5, 4459, 52, 24, 12290, 1359},
    {5, 4473, 52, 24, 12298, 1326},
    {5, 4477, 52, 24, 12300, 1338},
    {5, 4478, 53, 86, 12303, 1220},
    {5, 4485, 53, 30, 12305, 4142},
    {5, 4490, 52, 30, 12306, 4139},
    {5, 4494, 52, 24, 12314, 2546},
    {5, 4517, 52, 86, 12328, 7},
    {5, 4526, 52, 86, 12340, 742},
    {5, 4527, 52, 86, 12341, 239},
    {5, 4535, 52, 86, 12343, 812},
    {5, 4536, 52, 86, 12344, 211},
    {5, 4546, 52, 86, 12355, -348},
    {5, 4550, 53, 86, 12355, 1213},
    {5, 4559, 52, 24, 12360, 2758},
    {5, 4565, 52, 24, 12363, 2559},
    {5, 4567, 53, 86, 12365, 1115},
    {5, 4568, 52, 86, 12366, 1114},
    {5, 4570, 52, 86, 12369, 715},
    {5, 4596, 52, 86, 12399, 1011},
    {5, 4605, 52, 83, 12400, 6136},
    {5, 4618, 52, 30, 12416, 4109},
    {5, 4631, 51, 30, 12421, 3232},
    {5, 4636, 52, 86, 12428, 241},
    {5, 4643, 52, 86, 12433, 159},
    {5, 4654, 52, 86, 12439, 1308},
    {5, 4656, 52, 30, 12440, 3210},
    {5, 4660, 53, 86, 12445, 1111},
    {5, 4665, 52, 86, 12451, 303},
    {5, 4666, 52, 86, 12451, -28},
    {5, 4689, 52, 24, 12478, 1346},
    {5, 4697, 51, 86, 12486, -548},
    {5, 4698, 52, 86, 12484, 829},
    {5, 4699, 52, 86, 12490, -840},
    {5, 4725, 51, 24, 12504, 2530},
    {5, 4753, 52, 86, 12524, -112},
    {5, 4754, 52, 86, 12523, 1119},
    {5, 4762, 52, 86, 12529, 1114},
    {5, 4781, 53, 86, 12544, -1032},
    {5, 4800, 53, 30, 12546, 4632},
    {5, 4845, 53, 86, 12580, 135},
    {5, 4856, 52, 86, 12594, -1503},
    {5, 4866, 53, 86, 12595, 1410},
    {5, 4889, 53, 24, 13001, 2759},
    {5, 4900, 53, 86, 13007, 230},
    {5, 4902, 52, 86, 13010, -1431},
    {5, 4945, 51, 15, 13054, -4928},
    {5, 4958, 52, 86, 13058, -801},
    {5, 4995, 53, 86, 13097, -750},
    {5, 5005, 52, 30, 13109, 3703},
    {5, 5033, 52, 30, 13135, 3636},
    {5, 5053, 122, 24, 13165, 1742},
    {5, 5054, 52, 86, 13170, -1638},
    {5, 5068, 52, 86, 13189, -2102},
    {5, 5078, 53, 42, 13198, -2725},
    {5, 5102, 52, 15, 13220, -3638},
    {5, 5128, 49, 15, 13255, -4301},
    {5, 5139, 116, 15, 13268, -4729},
    {5, 5247, 52, 86, 13380, -1753},
    {5, 5248, 52, 9, 13375, 853},
    {5, 5273, 53, 30, 13421, 3539},
    {5, 5286, 119, 15, 13464, -5122},
    {5, 5322, 52, 83, 13492, 6011},
    {5, 5350, 53, 30, 13534, 4022},
    {5, 5353, 53, 30, 13534, 4017},
    {5, 5354, 53, 30, 13534, 4018},
    {5, 5363, 52, 86, 13561, 515},
    {5, 5364, 52, 86, 13562, 501},
    {5, 5371, 52, 30, 13557, 4028},
    {5, 5427, 53, 86, 14034, -602},
    {5, 5466, 121, 9, 14055, 2832},
    {5, 5473, 53, 83, 14047, 5454},
    {5, 5474, 52, 83, 14050, 5340},
    {5, 5557, 53, 9, 14184, 3630},
    {5, 5566, 52, 86, 14203, 356},
    {5, 5576, 53, 86, 14211, 316},
    {5, 5631, 53, 83, 14266, 5635},
    {5, 5634, 122, 86, 14296, -559},
    {5, 5643, 52, 50, 14327, -4411},
    {5, 5676, 53, 9, 14328, 4927},
    {5, 5689, 53, 9, 14355, 4844},
    {5, 5694, 122, 42, 14396, -2632},
    {5, 5746, 52, 86, 14449, 157},
    {5, 5813, 52, 86, 15012, 142},
    {5, 5822, 133, 50, 15044, -5424},
    {5, 5823, 134, 19, 15055, -5536},
    {5, 5824, 121, 50, 15040, -3304},
    {5, 5846, 52, 86, 15065, 136},
    {5, 5850, 52, 86, 15071, 133},
    {5, 5897, 120, 48, 15174, -2101},
    {5, 5907, 52, 34, 15159, 5620},
    {5, 5927, 120, 50, 15280, -5040},
    {5, 5946, 120, 57, 15355, -5040},
    {5, 5982, 53, 34, 15387, 5921},
    {5, 5986, 120, 50, 15461, -3747},
    {5, 6067, 132, 57, 16132, -5413},
    {5, 6118, 53, 74, 16218, -217},
    {5, 6124, 132, 72, 16253, -4039},
    {5, 6134, 133, 57, 16278, -4909},
    {5, 6144, 121, 72, 16272, -2601},
    {5, 6192, 135, 72, 16404, -4322},
    {5, 6193, 131, 6, 16413, -4846},
    {5, 6204, 134, 6, 16462, -4701},
    {5, 6207, 53, 40, 16431, 3650},
    {5, 6210, 94, 40, 16445, 2348},
    {5, 6217, 53, 84, 16326, 7812},
    {5, 6222, 136, 72, 16494, -4444},
    {5, 6229, 121, 40, 16470, 4732},
    {5, 6231, 129, 72, 16542, -4149},
    {5, 6235, 121, 59, 16534, -2211},
    {5, 6242, 132, 72, 16556, -3928},
    {5, 6259, 134, 72, 17008, -4439},
    {5, 6281, 131, 72, 17047, -3759},
    {5, 6284, 121, 59, 17045, -2446},
    {5, 6287, 121, 59, 17052, -2242},
    {5, 6293, 120, 59, 17102, -2635},
    {5, 6302, 96, 72, 17137, -3706},
    {5, 6304, 120, 59, 17145, -2928},
    {5, 6309, 95, 59, 17141, -1255},
    {5, 6316, 120, 59, 17166, -2808},
    {5, 6334, 70, 72, 17208, -3606},
    {5, 6342, 122, 59, 17212, -1935},
    {5, 6352, 120, 6, 17255, -4825},
    {5, 6355, 121, 59, 17240, -2621},
    {5, 6356, 120, 59, 17236, -1749},
    {5, 6366, 122, 59, 17277, -505},
    {5, 6369, 95, 59, 17293, -2346},
    {5, 6388, 119, 72, 17363, -4444},
    {5, 6397, 117, 6, 17407, -5340},
    {5, 6401, 119, 59, 17386, -2355},
    {5, 6426, 122, 59, 17449, 310},
    {5, 6440, 121, 77, 17489, -2022},
    {5, 6441, 119, 72, 17502, -3703},
    {5, 6445, 97, 77, 17493, -2001},
    {5, 6451, 134, 72, 17507, -3013},
    {5, 6453, 122, 72, 17509, -3436},
    {5, 6503, 52, 34, 17495, 7009},
    {5, 6517, 122, 59, 18018, -858},
    {5, 6520, 134, 77, 18034, -2753},
    {5, 6522, 122, 77, 18036, -3002},
    {5, 6528, 122, 77, 18048, -3003},
    {5, 6535, 121, 74, 18038, -18},
    {5, 6539, 121, 74, 18048, -735},
    {5, 6541, 118, 25, 18080, -4342},
    {5, 6543, 92, 34, 17586, 6638},
    {5, 6544, 120, 77, 18073, -2500},
    {5, 6553, 120, 77, 18093, -2554},
    {5, 6568, 135, 77, 18128, -2135},
    {5, 6569, 120, 77, 18136, -3150},
    {5, 6572, 92, 59, 18121, 651},
    {5, 6583, 136, 77, 18158, -2208},
    {5, 6603, 137, 77, 18184, -1824},
    {5, 6624, 120, 77, 18237, -3022},
    {5, 6629, 94, 77, 18257, -2312},
    {5, 6633, 131, 59, 18273, 631},
    {5, 6638, 121, 77, 18309, -2530},
    {5, 6642, 121, 77, 18319, -2329},
    {5, 6645, 135, 77, 18320, -1653},
    {5, 6649, 135, 73, 18335, -1024},
    {5, 6652, 121, 77, 18358, -3259},
    {5, 6664, 134, 73, 18366, -749},
    {5, 6712, 120, 73, 18531, -842},
    {5, 6723, 119, 77, 18596, -3638},
    {5, 6726, 70, 25, 19017, -3653},
    {5, 6727, 70, 25, 19017, -3653},
    {5, 6729, 70, 25, 19019, -3657},
    {5, 6752, 117, 61, 19109, -5959},
    {5, 6755, 134, 4, 19078, 416},
    {5, 6756, 136, 4, 19087, 442},
    {5, 6760, 121, 4, 19112, 102},
    {5, 6781, 95, 4, 19185, 632},
    {5, 6791, 136, 52, 19207, 3751},
    {5, 6802, 135, 88, 19306, 2016},
    {5, 6818, 94, 77, 19440, -1409},
    {5, 6819, 133, 31, 19413, 4011},
    {5, 6822, 51, 77, 19449, -1448},
    {5, 6823, 133, 88, 19432, 2318},
    {5, 6826, 93, 31, 19448, 5032},
    {5, 6830, 134, 88, 19510, 2306},
    {5, 6834, 134, 31, 19522, 2924},
    {5, 6857, 67, 31, 20028, 3331},
    {5, 6866, 134, 31, 20039, 4410},
    {5, 6885, 134, 88, 20119, 2629},
    {5, 6888, 66, 31, 20128, 3819},
    {5, 6905, 96, 32, 20224, 2006},
    {5, 6907, 53, 12, 20251, -2449},
    {5, 6910, 133, 31, 20232, 4047},
    {5, 6934, 121, 32, 20342, 724},
    {5, 6939, 134, 16, 20315, 6040},
    {5, 6940, 132, 88, 20344, 2817},
    {5, 6946, 51, 16, 20349, 6009},
    {5, 6960, 105, 31, 20457, 3043},
    {5, 6974, 112, 31, 20511, 3150},
    {5, 6979, 70, 31, 20510, 3208},
    {5, 6992, 105, 31, 20564, 3143},
    {5, 6995, 105, 31, 20571, 3113},
    {5, 7000, 60, 31, 21018, 4412},
    {5, 7006, 122, 32, 21015, 1611},
    {5, 7008, 96, 31, 21005, 5433},
    {5, 7009, 92, 5, 21042, -1122},
    {5, 7023, 77, 16, 21005, 6810},
    {5, 7026, 96, 31, 21063, 4751},
    {5, 7027, 94, 31, 21070, 4214},
    {5, 7044, 138, 31, 21129, 4229},
    {5, 7062, 134, 31, 21235, 4623},
    {5, 7086, 134, 31, 21305, 5136},
    {5, 7090, 52, 44, 21365, -5433},
    {5, 7128, 136, 31, 21440, 5343},
    {5, 7129, 81, 16, 21430, 6607},
    {5, 7142, 135, 16, 21452, 6546},
    {5, 7160, 132, 16, 21537, 6236},
    {5, 7184, 52, 5, 22027, -2049},
    {5, 7209, 134, 45, 22051, 4629},
    {5, 7217, 52, 62, 22079, 3122},
    {5, 7243, 132, 45, 22151, 4954},
    {5, 7293, 90, 5, 22296, -2050},
    {5, 7296, 136, 45, 22282, 5217},
    {5, 7320, 54, 62, 22361, 3357},
    {5, 7331, 52, 62, 22371, 3425},
    {5, 7380, 133, 16, 22473, 5808},
    {5, 7424, 52, 39, 22573, -4104},
    {5, 7448, 53, 62, 23001, 1559},
    {5, 7479, 52, 62, 23049, 1219},
    {5, 7510, 134, 16, 23115, 6034},
    {5, 7582, 52, 39, 23184, -4222},
    {5, 7606, 52, 5, 23191, -829},
    {5, 7619, 53, 62, 23202, 812},
    {5, 7635, 67, 14, 23202, 6111},
    {5, 7662, 93, 1, 23259, 4232},
    {5, 7686, 132, 1, 23301, 4908},
    {5, 7723, 53, 5, 23390, -1258},
    {5, 7727, 52, 5, 23399, -1218},
    {5, 7789, 133, 14, 23574, 5643},
    {5, 7790, 135, 14, 23584, 6113},
    {5, 7793, 51, 71, 23578, -3236},
    {5, 7814, 52, 62, 32, 1609},
    {0, 36, 146, 1, 550, +2338},
    {15, 0, 142, 1, 2039, +4220},
    {201, 228, 147, 1, 2140, +4729},
    {201, 3050, 146, 1, 23595, +3343},
    {0, 56, 146, 1, 1562, +3715},
    {0, 59, 146, 1, 2109, +3902},
    {24, 0, 146, 4, 19487, +1149},
    {201, 2404, 147, 4, 18508, +1059},
    {201, 2532, 146, 4, 19302, 254},
    {0, 5, 146, 4, 18465, -58},
    {0, 11, 145, 4, 18591, +1338},
    {0, 15, 146, 4, 19050, -402},
    {0, 57, 146, 4, 19546, -814},
    {201, 2838, 146, 5, 21546, -318},
    {32, 0, 144, 5, 22288, -1},
    {0, 12, 146, 5, 21041, -549},
    {0, 41, 146, 5, 22143, -2104},
    {0, 53, 146, 5, 22266, -1645},
    {0, 94, 145, 5, 23191, -1328},
    {0, 107, 146, 5, 23460, -1841},
    {12, 0, 145, 7, 2592, +2120},
    {15, 0, 145, 7, 1535, +1918},
    {20, 0, 145, 7, 1579, +2336},
    {24, 0, 145, 7, 2493, +1728},
    {201, 394, 147, 7, 3280, +2028},
    {0, 1, 146, 7, 1501, +2217},
    {0, 30, 147, 7, 2370, +2439},
    {0, 33, 145, 7, 2407, +2704},
    {16, 0, 143, 8, 5597, +3713},
    {201, 644, 147, 8, 5103, +3718},
    {201, 698, 147, 8, 5252, +3451},
    {201, 872, 147, 8, 6156, +3609},
    {29, 0, 145, 8, 4593, +3753},
    {30, 0, 145, 8, 6467, +4335},
    {0, 14, 145, 8, 5154, +3241},
    {0, 26, 145, 8, 5386, +3030},
    {0, 41, 146, 8, 6116, +4843},
    {132, 147, 147, 8, 6343, +3805},
    {11, 0, 144, 9, 15155, +3319},
    {12, 0, 143, 9, 14450, +2704},
    {17, 0, 145, 9, 14162, +5122},
    {19, 0, 145, 9, 14135, +5147},
    {21, 0, 144, 9, 15245, +3723},
    {24, 0, 145, 9, 14407, +1625},
    {201, 1825, 146, 9, 14165, +2007},
    {201, 1835, 145, 9, 14234, +827},
    {201, 1884, 147, 9, 14484, +2422},
    {31, 0, 145, 9, 14514, +1906},
    {32, 0, 144, 9, 14411, +1344},
    {0, 39, 146, 9, 14497, +4843},
    {0, 44, 145, 9, 15038, +4739},
    {162, 191, 147, 9, 14596, +5352},
    {201, 1694, 145, 11, 12492, +8325},
    {201, 400, 147, 11, 3350, +6002},
    {201, 485, 147, 11, 4078, +6220},
    {0, 1, 146, 11, 4320, +5355},
    {0, 11, 145, 11, 5061, +5858},
    {6, 0, 144, 12, 20176, -1230},
    {23, 0, 146, 12, 20299, -1835},
    {24, 0, 145, 12, 20273, -1813},
    {26, 0, 145, 12, 20289, -1749},
    {27, 0, 145, 12, 20194, -1907},
    {17, 0, 145, 14, 2291, +6724},
    {18, 0, 144, 14, 491, +5749},
    {27, 0, 145, 14, 23590, +5545},
    {201, 163, 147, 14, 1513, +6451},
    {201, 3053, 146, 14, 26, +6606},
    {201, 3062, 146, 14, 63, +5826},
    {0, 3, 145, 15, 13518, -3300},
    {9, 0, 143, 16, 21287, +7034},
    {11, 0, 144, 16, 22292, +5825},
    {19, 0, 144, 16, 20089, +7743},
    {201, 2780, 147, 16, 21118, +5959},
    {201, 2816, 146, 16, 21390, +5729},
    {201, 2840, 146, 16, 21520, +5548},
    {201, 460, 146, 16, 4100, +8042},
    {31, 0, 144, 16, 22038, +6438},
    {132, 461, 147, 16, 22039, +5949},
    {10, 0, 145, 17, 1496, -1041},
    {15, 0, 144, 17, 2433, +314},
    {201, 186, 147, 17, 1559, +151},
    {0, 66, 146, 17, 2128, -224},
    {6, 0, 140, 20, 6451, -1643},
    {12, 0, 142, 20, 6586, -2858},
    {21, 0, 145, 20, 6561, -1403},
    {108, 3945, 145, 20, 7166, -2319},
    {17, 0, 144, 22, 8467, +2846},
    {25, 0, 146, 22, 8268, +2656},
    {201, 1177, 147, 22, 8056, +2732},
    {201, 1245, 146, 22, 8358, 637},
    {201, 1254, 147, 22, 8404, +1940},
    {201, 1311, 147, 22, 9074, +2259},
    {32, 0, 145, 22, 8122, +1739},
    {0, 57, 146, 22, 8542, +3035},
    {0, 66, 146, 22, 9014, +3215},
    {201, 1633, 147, 24, 12207, +2703},
    {201, 1639, 147, 24, 12244, +2535},
    {0, 2, 146, 24, 12043, +2128},
    {0, 24, 145, 24, 12351, +1823},
    {0, 35, 145, 24, 12533, +2115},
    {15, 0, 145, 25, 19064, -3704},
    {19, 0, 146, 25, 18334, -3844},
    {15, 0, 144, 26, 15427, +2618},
    {18, 0, 146, 26, 15232, +3017},
    {27, 0, 146, 26, 16147, +3352},
    {32, 0, 145, 26, 15394, +3638},
    {132, 128, 146, 26, 16117, +3321},
    {11, 0, 143, 29, 12299, -1631},
    {201, 1604, 147, 29, 12095, -1151},
    {6, 0, 143, 30, 12560, +3819},
    {0, 2, 146, 30, 12161, +4040},
    {9, 0, 143, 31, 19307, +2758},
    {11, 0, 143, 31, 19450, +4508},
    {20, 0, 145, 31, 20474, +3629},
    {21, 0, 145, 31, 21441, +2845},
    {201, 2486, 147, 31, 19121, +4951},
    {30, 0, 145, 31, 19556, +5226},
    {0, 16, 146, 31, 19418, +5032},
    {0, 31, 144, 31, 20136, +4644},
    {0, 49, 146, 31, 20410, +3218},
    {0, 61, 145, 31, 21069, +3845},
    {132, 130, 146, 31, 21208, +3227},
    {103, 5137, 146, 31, 19459, +3501},
    {15, 0, 144, 32, 20467, +1607},
    {12, 0, 144, 34, 19482, +7016},
    {21, 0, 146, 34, 17053, +5428},
    {22, 0, 145, 34, 17322, +5511},
    {23, 0, 145, 34, 18512, +5923},
    {201, 2155, 147, 34, 17161, +6043},
    {201, 2348, 146, 34, 18339, +5221},
    {30, 0, 145, 34, 17419, +7209},
    {0, 17, 145, 34, 16362, +5255},
    {0, 41, 146, 34, 18002, +8000},
    {132, 123, 147, 34, 13271, +6444},
    {12, 0, 145, 35, 20591, +418},
    {201, 2742, 147, 35, 21022, +711},
    {16, 0, 143, 36, 2583, -4018},
    {11, 5, 146, 36, 1398, -5612},
    {0, 55, 147, 36, 4436, -848},
    {108, 3556, 146, 36, 3124, -4425},
    {29, 0, 145, 37, 2338, -2814},
    {6, 0, 142, 38, 7346, +3153},
    {11, 0, 144, 38, 7201, +2159},
    {19, 0, 144, 38, 7444, +2424},
    {201, 1083, 147, 38, 7256, +2030},
    {201, 1108, 147, 38, 7328, +2253},
    {0, 38, 145, 38, 6546, +1311},
    {162, 70, 147, 38, 6278, +2047},
    {6, 0, 143, 40, 17146, +1423},
    {11, 0, 143, 40, 17150, +2450},
    {19, 0, 145, 40, 16081, +1703},
    {26, 0, 145, 40, 17237, +3709},
    {201, 2052, 147, 40, 16289, +1825},
    {201, 2063, 146, 40, 16318, +4536},
    {201, 2315, 147, 40, 18250, +2724},
    {201, 2411, 147, 40, 18523, +1432},
    {0, 37, 146, 40, 16406, +413},
    {0, 56, 146, 40, 16550, +2544},
    {0, 95, 145, 40, 18015, +2136},
    {0, 100, 146, 40, 18078, +2606},
    {132, 129, 147, 40, 18359, +1659},
    {12, 0, 143, 42, 8468, +625},
    {201, 1348, 148, 42, 9245, +621},
    {201, 1355, 147, 42, 9273, +614},
    {201, 1365, 147, 42, 9315, +128},
    {28, 0, 145, 42, 9291, -246},
    {103, 396, 146, 42, 11323, -2916},
    {201, 2894, 146, 45, 22189, +3746},
    {0, 8, 146, 45, 22359, +3938},
    {6, 0, 141, 46, 10084, +1158},
    {15, 0, 142, 46, 10200, +1950},
    {28, 0, 145, 46, 11279, +251},
    {0, 6, 145, 46, 9320, +943},
    {0, 49, 146, 46, 10350, +839},
    {0, 54, 144, 46, 10556, +2445},
    {0, 81, 146, 46, 11256, +1627},
    {0, 83, 147, 46, 11268, +301},
    {0, 90, 146, 46, 11347, +1648},
    {132, 215, 147, 46, 10163, +1744},
    {15, 0, 144, 47, 5445, -2227},
    {108, 3750, 145, 47, 5204, -2114},
    {21, 0, 145, 48, 14493, -1409},
    {23, 0, 146, 48, 15210, -1533},
    {201, 1962, 146, 48, 15387, -847},
    {31, 0, 145, 50, 15569, -3358},
    {201, 1282, 147, 51, 8508, +3504},
    {201, 1333, 147, 51, 9184, +3522},
    {201, 1338, 147, 51, 9210, +3811},
    {201, 1369, 147, 51, 9354, +3958},
    {201, 958, 146, 51, 6482, +5542},
    {0, 12, 145, 51, 6462, +5927},
    {0, 19, 146, 51, 7229, +5517},
    {0, 38, 144, 51, 9188, +3648},
    {9, 0, 144, 52, 18501, +3322},
    {13, 0, 145, 52, 18443, +3940},
    {14, 0, 145, 52, 18443, +3940},
    {18, 0, 144, 52, 19138, +3909},
    {201, 2474, 147, 52, 19091, +3436},
    {32, 0, 144, 52, 18448, +3736},
    {200, 0, 145, 52, 18570, +3254},
    {162, 282, 146, 52, 18549, +3358},
    {108, 5218, 147, 54, 20454, -3029},
    {9, 0, 145, 55, 6288, -702},
    {12, 0, 144, 55, 6238, +436},
    {20, 0, 144, 59, 16309, +159},
    {23, 0, 145, 59, 17180, -2417},
    {26, 0, 145, 59, 16256, -2327},
    {201, 2276, 147, 59, 18057, +1200},
    {28, 0, 145, 59, 18031, -811},
    {0, 36, 145, 59, 17153, -2636},
    {0, 61, 146, 59, 17446, +235},
    {0, 70, 144, 59, 18055, +230},
    {9, 0, 140, 60, 5145, -812},
    {11, 0, 142, 60, 5320, -18},
    {16, 0, 145, 60, 5353, -523},
    {17, 0, 143, 60, 5354, -555},
    {18, 0, 144, 60, 5245, -224},
    {20, 0, 144, 60, 5351, +956},
    {26, 0, 145, 60, 5133, +252},
    {27, 0, 144, 60, 5387, -236},
    {201, 747, 145, 60, 5350, -600},
    {201, 790, 146, 60, 5460, -416},
    {32, 0, 142, 60, 5407, -157},
    {0, 14, 146, 60, 5079, +830},
    {0, 23, 145, 60, 5228, +333},
    {0, 32, 144, 60, 5308, 557},
    {0, 33, 146, 60, 5312, +318},
    {0, 52, 146, 60, 5480, +627},
    {12, 0, 143, 62, 21442, +953},
    {201, 2841, 146, 62, 21543, +1943},
    {201, 3007, 147, 62, 23228, +2034},
    {0, 1, 144, 62, 21221, +1948},
    {18, 0, 144, 63, 2507, +5554},
    {201, 162, 146, 63, 1493, +4754},
    {201, 331, 145, 63, 3009, +5221},
    {201, 336, 147, 63, 3015, +3225},
    {201, 369, 147, 63, 3171, +4029},
    {0, 56, 146, 63, 4246, +3358},
    {11, 24, 146, 66, 22366, -3140},
    {6, 0, 144, 67, 2020, +246},
    {201, 22, 147, 67, 174, +853},
    {201, 3009, 147, 67, 23243, +343},
    {30, 0, 145, 67, 1057, +2128},
    {32, 0, 145, 67, 1137, +735},
    {0, 35, 144, 67, 150, +849},
    {0, 55, 146, 67, 399, +2126},
    {0, 65, 146, 67, 499, +2743},
    {0, 66, 146, 67, 546, +1911},
    {0, 77, 146, 67, 1058, +455},
    {112, 0, 145, 68, 7183, -3644},
    {110, 19, 146, 68, 7343, -2328},
    {103, 327, 144, 68, 7388, -2648},
    {6, 0, 141, 72, 16294, -2626},
    {9, 0, 143, 72, 16054, -1948},
    {22, 0, 144, 72, 16120, -1928},
    {31, 0, 145, 72, 16044, -1122},
    {11, 0, 144, 74, 15348, +1032},
    {16, 0, 145, 74, 18562, +412},
    {201, 1919, 147, 74, 15127, +1917},
    {0, 59, 145, 74, 18272, +12},
    {132, 127, 146, 74, 15402, +1203},
    {15, 0, 145, 75, 9525, -806},
    {153, 0, 147, 75, 9541, +457},
    {0, 35, 146, 75, 10433, +445},
    {0, 40, 147, 75, 10493, -401},
    {32, 0, 145, 76, 19490, +1909},
    {110, 84, 146, 76, 19394, +1634},
    {138, 0, 145, 77, 17591, -3015},
    {0, 54, 145, 77, 19407, -1618},
    {108, 5082, 146, 77, 19031, -1915},
    {10, 0, 145, 78, 4226, +2538},
    {25, 0, 145, 78, 4204, +2721},
    {201, 422, 146, 78, 3368, +35},
    {201, 495, 146, 78, 4077, +1510},
    {201, 572, 147, 78, 4385, +2656},
    {0, 7, 147, 78, 3344, +2428},
    {0, 62, 146, 78, 4240, +2418},
    {0, 118, 146, 78, 5293, +2509},
    {201, 239, 147, 81, 2174, +2845},
    {0, 6, 145, 81, 2124, +3018},
    {27, 0, 145, 83, 9104, +6708},
    {201, 1520, 147, 83, 11161, +5246},
    {201, 1523, 144, 83, 11182, +3132},
    {201, 1695, 146, 83, 12563, +5406},
    {32, 0, 142, 83, 13239, +5456},
    {132, 126, 146, 83, 11323, +6105},
    {6, 0, 142, 84, 2318, +8916},
    {201, 1972, 147, 84, 15292, +8027},
    {108, 2682, 147, 84, 13407, +7651},
    {11, 70, 145, 85, 8295, -4443},
    {108, 4191, 145, 85, 9144, -4314},
    {15, 0, 143, 86, 12417, -127},
    {28, 0, 144, 86, 14016, +133},
    {0, 17, 147, 86, 12225, +518},
    {60, 0, 161, 1, 275, 3535},
    {166, 0, 162, 1, 23388, 3546},
    {167, 0, 162, 1, 46, 4333},
    {181, 0, 161, 1, 2384, 3910},
    {185, 0, 162, 1, 199, 4443},
    {107, 5223, 162, 1, 542, 2404},
    {130, 15196, 162, 1, 542, 2404},
    {179, 0, 162, 4, 18585, 1422},
    {182, 0, 161, 4, 19044, -541},
    {182, 1469, 162, 4, 20011, 931},
    {130, 11960, 161, 4, 19232, -1042},
    {147, 0, 163, 5, 23244, -1719},
    {182, 0, 162, 7, 2150, 1214},
    {90, 0, 163, 8, 5034, 5038},
    {96, 0, 162, 8, 5481, 3038},
    {148, 0, 164, 8, 6348, 4230},
    {152, 0, 162, 8, 5271, 3409},
    {176, 0, 163, 8, 5091, 3900},
    {178, 0, 159, 8, 6365, 3827},
    {179, 0, 161, 8, 5218, 3231},
    {182, 0, 163, 8, 6240, 4742},
    {182, 346, 163, 8, 4526, 3830},
    {149, 0, 163, 9, 14242, 2542},
    {147, 0, 162, 11, 7217, 6940},
    {152, 0, 162, 11, 5410, 6848},
    {166, 0, 161, 11, 4512, 6810},
    {177, 0, 161, 11, 3418, 6239},
    {179, 0, 162, 11, 4059, 6148},
    {196, 0, 161, 11, 4086, 5322},
    {146, 0, 161, 12, 20171, -2119},
    {129, 0, 164, 14, 246, 5417},
    {166, 0, 165, 14, 175, 1714},
    {187, 0, 162, 14, 549, 5834},
    {191, 0, 163, 14, 1336, 5745},
    {193, 0, 161, 14, 13, 6021},
    {182, 623, 161, 14, 3114, 5754},
    {21, 0, 162, 16, 21435, 5848},
    {152, 0, 161, 16, 21352, 7837},
    {107, 16115, 162, 17, 2351, -927},
    {157, 129989, 162, 17, 2351, -9264},
    {187, 0, 160, 20, 7081, -1155},
    {139, 0, 161, 21, 7087, 1001},
    {171, 0, 162, 22, 8567, 1931},
    {194, 0, 160, 22, 8554, 1714},
    {139, 0, 160, 26, 15486, 2809},
    {182, 0, 161, 26, 15495, 3934},
    {172, 0, 162, 30, 12594, 3749},
    {197, 0, 159, 30, 12451, 4526},
    {66, 0, 161, 31, 19288, 4603},
    {67, 0, 162, 31, 19572, 4416},
    {82, 0, 162, 31, 20468, 4603},
    {145, 0, 161, 31, 20134, 3844},
    {148, 0, 161, 31, 21433, 3801},
    {150, 0, 163, 31, 20104, 3557},
    {168, 0, 163, 31, 20095, 4752},
    {172, 0, 161, 31, 19409, 3237},
    {177, 0, 160, 31, 20196, 4754},
    {182, 0, 162, 31, 20413, 4808},
    {192, 0, 163, 31, 20186, 3727},
    {182, 460, 160, 31, 21420, 3531},
    {107, 189256, 162, 31, 19572, 4418},
    {157, 106516, 162, 32, 20486, 1750},
    {150, 0, 160, 34, 12564, 6560},
    {171, 0, 161, 34, 17564, 5813},
    {180, 0, 160, 34, 19216, 7634},
    {169, 0, 162, 36, 5098, -531},
    {75, 0, 162, 38, 7209, 2460},
    {129, 0, 161, 38, 7319, 2430},
    {173, 0, 161, 38, 6109, 2601},
    {184, 0, 162, 38, 6421, 3127},
    {33, 0, 161, 40, 18303, 2152},
    {144, 0, 162, 40, 16042, 5030},
    {157, 46574, 161, 40, 17135, 4206},
    {177, 0, 159, 42, 10376, -1323},
    {182, 0, 161, 42, 10516, -2115},
    {197, 0, 161, 42, 9511, -2301},
    {139, 0, 160, 46, 9476, 1124},
    {139, 0, 160, 47, 4596, -1448},
    {197, 0, 161, 51, 7282, 460},
    {109, 0, 162, 52, 18428, 3658},
    {171, 0, 162, 52, 18323, 3660},
    {177, 0, 162, 52, 19202, 3753},
    {73, 0, 163, 55, 6564, 76},
    {96, 0, 163, 55, 6224, 325},
    {102, 0, 162, 55, 6532, -435},
    {148, 0, 161, 55, 6584, 610},
    {150, 0, 162, 55, 7069, -733},
    {182, 614, 161, 55, 7010, -315},
    {175, 0, 161, 59, 17297, -1928},
    {182, 0, 161, 59, 16267, -1226},
    {74, 0, 160, 60, 6255, 1443},
    {101, 0, 164, 60, 6177, 831},
    {146, 0, 162, 60, 5332, 709},
    {190, 0, 160, 60, 5054, 111},
    {149, 0, 162, 62, 21564, 2248},
    {33, 0, 163, 63, 3451, 4447},
    {149, 0, 162, 63, 21564, 2252},
    {151, 0, 162, 63, 22059, 3330},
    {197, 0, 162, 63, 3277, 4411},
    {182, 466, 162, 63, 3415, 5130},
    {176, 0, 159, 67, 23464, 329},
    {198, 0, 161, 67, 1161, 2546},
    {107, 26, 162, 67, 54, 847},
    {157, 109003, 162, 67, 54, 847},
    {157, 128396, 163, 67, 23491, 623},
    {147, 0, 162, 68, 8075, -2255},
    {148, 0, 163, 73, 18474, -1313},
    {149, 0, 162, 73, 18370, -736},
    {165, 0, 160, 73, 18583, -754},
    {171, 0, 162, 73, 18554, -86},
    {87, 0, 162, 74, 18474, 530},
    {94, 0, 163, 74, 18194, -1537},
    {72, 0, 163, 76, 20024, 2105},
    {76, 0, 162, 76, 20024, 2036},
    {195, 0, 161, 76, 20051, 2039},
    {60, 0, 161, 77, 19343, -1622},
    {170, 0, 162, 77, 17449, -1839},
    {182, 1942, 161, 77, 19192, -1555},
    {167, 0, 163, 78, 5491, 1904},
    {172, 0, 162, 78, 4515, 2832},
    {173, 0, 160, 78, 5452, 2425},
    {197, 0, 161, 78, 5457, 2042},
    {146, 0, 163, 83, 9184, 5124},
    {186, 0, 160, 83, 10451, 6725},
    {147, 0, 162, 86, 12473, 409},
    {165, 0, 160, 86, 12252, 46},
    {107, 113801, 163, 86, 13064, -2004},
    {157, 157721, 163, 86, 13064, -2004},
    {68, 0, 162, 88, 20373, 2630},
    {130, 13571, 162, 88, 21099, 2637},
    {34, 0, 169, 36, 1377, -5714},
    {35, 0, 171, 72, 16054, -1948},
    {36, 0, 169, 28, 12266, -6306},
    {37, 0, 170, 20, 6586, -2858},
    {38, 0, 169, 15, 14038, -6022},
    {39, 0, 170, 1, 2039, 4220},
    {40, 0, 169, 78, 4359, 1631},
    {41, 0, 170, 16, 21186, 6235},
    {42, 0, 170, 39, 22427, -4653},
    {43, 0, 170, 63, 3243, 4952},
    {44, 0, 170, 46, 10200, 1950},
    {45, 0, 170, 63, 3082, 4057},
    {46, 0, 170, 38, 6377, 1624},
    {47, 0, 170, 83, 12540, 5558},
    {48, 0, 170, 83, 13475, 4919},
    {49, 0, 170, 39, 22082, -4658},
    {50, 0, 170, 60, 5362, -112},
    {51, 0, 170, 60, 5408, -157},
    {52, 0, 170, 42, 9276, -840},
    {53, 0, 170, 26, 15347, 2643},
    {54, 0, 170, 1, 84, 2905},
    {55, 0, 170, 85, 8095, -4720},
    {56, 0, 169, 4, 19508, 852},
    {57, 0, 170, 20, 7241, -2918},
    {58, 0, 170, 64, 263, -4218},
    {59, 0, 169, 72, 16294, -2626},
    {61, 0, 168, 9, 14157, 1911},
    {62, 0, 171, 47, 5327, -1749},
    {63, 0, 170, 13, 9171, -5917},
    {64, 0, 170, 80, 16487, -6902},
    {65, 0, 170, 13, 8225, -5931},
    {69, 0, 169, 28, 12477, -5941},
    {70, 0, 170, 60, 5251, 621},
    {71, 0, 169, 60, 5552, 724},
    {77, 0, 168, 13, 6240, -5242},
    {78, 0, 168, 8, 5167, 4560},
    {79, 0, 170, 14, 92, 5909},
    {80, 0, 170, 38, 7346, 3153},
    {81, 0, 170, 14, 567, 6043},
    {83, 0, 169, 31, 20414, 4517},
    {84, 0, 170, 17, 436, -1759},
    {85, 0, 170, 46, 11491, 1434},
    {86, 0, 170, 17, 436, -1759},
    {88, 0, 170, 72, 16003, -2237},
    {89, 0, 170, 83, 11037, 6145},
    {91, 0, 170, 78, 5263, 2836},
    {92, 0, 170, 34, 17566, 5129},
    {93, 0, 170, 62, 21442, 953},
    {95, 0, 169, 66, 22577, -2937},
    {97, 0, 170, 28, 12312, -5707},
    {98, 0, 170, 26, 15347, 2643},
    {99, 0, 171, 31, 20462, 3358},
    {100, 0, 170, 72, 17425, -3902},
    {104, 0, 169, 15, 14038, -6022},
    {105, 0, 170, 7, 2072, 2328},
    {106, 0, 171, 59, 16372, -1034},
    {111, 0, 170, 9, 14450, 2704},
    {113, 0, 170, 77, 18242, -3423},
    {114, 0, 170, 84, 14507, 7409},
    {115, 0, 170, 85, 8447, -5443},
    {116, 0, 170, 62, 23048, 1512},
    {117, 0, 170, 8, 5595, 4457},
    {118, 0, 171, 17, 3023, 405},
    {119, 0, 170, 15, 14067, -3622},
    {120, 0, 170, 83, 11018, 5623},
    {121, 0, 170, 13, 9132, -6943},
    {122, 0, 169, 28, 12477, -5941},
    {123, 0, 170, 60, 5320, -18},
    {124, 0, 170, 1, 1097, 3537},
    {125, 0, 170, 63, 3243, 4952},
    {126, 0, 170, 20, 6227, -1757},
    {127, 0, 170, 83, 13239, 5456},
    {128, 0, 170, 68, 8036, -4000},
    {131, 0, 170, 77, 18553, -2618},
    {133, 0, 170, 61, 20256, -5644},
    {134, 0, 170, 83, 11538, 5342},
    {135, 0, 170, 84, 2318, 8916},
    {136, 0, 169, 38, 7453, 2802},
    {137, 0, 168, 21, 7393, 514},
    {140, 0, 170, 59, 17349, 1234},
    {141, 0, 169, 46, 10084, 1158},
    {142, 0, 168, 60, 5145, -812},
    {143, 0, 168, 15, 14396, -6050},
    {154, 0, 170, 59, 17104, -1543},
    {155, 0, 170, 31, 20222, 4015},
    {156, 0, 170, 60, 5478, -940},
    {158, 0, 170, 72, 17373, -4260},
    {159, 0, 170, 62, 23038, 2805},
    {160, 0, 170, 14, 405, 5632},
    {161, 0, 170, 72, 17336, -3706},
    {163, 0, 168, 20, 6451, -1643},
    {164, 0, 169, 86, 13252, -1110},
    {174, 0, 170, 13, 9171, -5917},
    {183, 0, 168, 52, 18369, 3847},
    {188, 0, 170, 72, 16502, -3418},
    {189, 0, 170, 20, 7084, -2624},
    {199, 0, 171, 46, 11141, 2031},
    {7, 0, 168, 15, 14396, -6050},
    {8, 0, 169, 15, 14396, -6050},
    {6, 0, 170, 50, 14419, -4723},
    {9, 0, 170, 39, 22427, -4653},
    {15, 0, 170, 14, 567, 6043},
    {15, 0, 170, 15, 12415, -4858},
    {11, 0, 171, 15, 12084, -5043},
    {11, 0, 170, 85, 8447, -5443},
    {12, 0, 170, 15, 13399, -5328},
    {32, 0, 171, 15, 13555, -4717},
    {32, 0, 171, 59, 16372, -1034},
    {18, 0, 170, 15, 14355, -4209},
    {19, 0, 170, 85, 9221, -5501},
    {20, 0, 170, 85, 9080, -4326}
  // variables for button - instead of bounce lib - save flash memory
  const int DEBOUNCE_DELAY = 50;   // the debounce time; increase if the output flickers
  int lastSteadyState = LOW;       // the previous steady state from the input pin
  int lastFlickerableState = LOW;  // the previous flickerable state from the input pin
  int currentState;                // the current reading from the input pin
  unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
  unsigned long lastPressedTime = 0;
  // LCD - VSS - GND // VCC - 5V // RW - GND // K - GND
  const byte rs = 12;
  const byte en = 13;
  const byte d4 = 9;
  const byte d5 = 8;
  const byte d6 = 7;
  const byte d7 = 6;
  LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
  byte myLCDbacklight = 255;
  byte myLCDcontrast = 100;
  // variables to steer menu
  byte myDisplayMode = 0;
  const char *const menuTopic[] = {"DEC", "Align", "Target", "Region", "Const", "Brightness", "Contrast", "Sensors", "LX200"};
  const byte menuTopic_size = sizeof(menuTopic) / sizeof(menuTopic[0]);
  byte myMenuTopicNo = 0;
  // definition of special / greek characters - for LCD 1602 chinese version - adapt to your LCD if needed
  // used lcd is like this https://www.waveshare.com/datasheet/LCD_en_PDF/LCD1602.pdf (see 14. font table)
  const char ch_deg = (char)(223); // degree symbol
  const char ch_sigma = (char)(246); // uppercase Sigma
  // greek alphabet 1-24 = α β γ δ ε ζ η θ ι κ λ μ ν ξ ο π ρ σ τ υ φ χ ψ ω
  // maximum 8 custom characters
  // γ
  char ch_def_1 = 'g'; // for identificatrion & replacement
  byte ch_custom_1[] = {
    B00000,
    B10011,
    B10010,
    B10010,
    B01110,
    B00100,
    B00100,
    B00100
  // δ
  char ch_def_2 = 'd';
  byte ch_custom_2[] = {
    B00110,
    B01001,
    B00100,
    B01110,
    B10001,
    B10001,
    B01110,
    B00000
  // ζ
  char ch_def_3 = 'z';
  byte ch_custom_3[] = {
    B01111,
    B00010,
    B00100,
    B01000,
    B01000,
    B01111,
    B00001,
    B00110
  // λ
  char ch_def_4 = 'l';
  byte ch_custom_4[] = {
    B01100,
    B00100,
    B00100,
    B01010,
    B01010,
    B10001,
    B10001,
    B00000
  // ξ
  char ch_def_5 = 'x';
  byte ch_custom_5[] = {
    B11111,
    B00100,
    B01000,
    B00111,
    B01000,
    B10000,
    B11111,
    B00010
  // φ
  char ch_def_6 = 'p';
  byte ch_custom_6[] = {
    B00000,
    B10111,
    B10101,
    B10101,
    B10101,
    B01110,
    B00100,
    B00100
  // ψ
  char ch_def_7 = 's';
  byte ch_custom_7[] = {
    B00000,
    B00100,
    B10101,
    B10101,
    B10101,
    B01110,
    B00100,
    B00100
  // Δ
  char ch_def_8 = 'D';
  byte ch_custom_8[] = {
    B00000,
    B00100,
    B01010,
    B01010,
    B10001,
    B10001,
    B11111,
    B00000
  // lookup table placeholder chars with greek symbols
  struct greekSymbols {
    char originalChar;
    char replaceChar;
  const unsigned int greekSymbols_size = 26;
  const struct greekSymbols greekSymbols[greekSymbols_size]  =
    {'a', (char)(224)}, // α
    {'b', (char)(226)}, // β
    {'g', 'g'}, // γ custom character
    {'d', 'd'}, // δ custom character
    {'e', (char)(227)}, // ε
    {'z', 'z'}, // ζ custom character
    {'j', 'n'}, // η
    {'h', (char)(242)}, // θ
    {'i', 'l'}, // ι
    {'k', 'k'}, // κ
    {'l', 'l'}, // λ custom character
    {'m', (char)(228)}, // μ
    {'n', 'v'}, // ν
    {'x', 'x'}, // ξ custom character
    {'o', 'o'}, // ο
    {'p', (char)(247)}, // π
    {'r', (char)(230)}, // ρ
    {'s', (char)(229)}, // σ
    {'t', 't'}, // τ
    {'y', (char)(232)}, // υ
    {'q', 'p'}, // φ custom character
    {'c', 'x'}, // χ
    {'w', 's'}, // ψ custom character
    {'u', 'w'},
    {'F', (char)(246)}, // Σ
    {'D', '/'} // Δ
  // definition of constellation names
  struct constStruct {
    char constName[4];
  constStruct myConstellation;
  const unsigned int constStruct_size = 89;
  const struct constStruct const_PROGMEM[constStruct_size] PROGMEM = {
    {"all"}, {"And"}, {"Ant"}, {"Aps"}, {"Aql"}, {"Aqr"}, {"Ara"}, {"Ari"}, {"Aur"}, {"Boo"}, {"Cae"}, {"Cam"}, {"Cap"}, {"Car"}, {"Cas"}, {"Cen"}, {"Cep"}, {"Cet"}, {"Cha"}, {"Cir"},
    {"CMa"}, {"CMi"}, {"Cnc"}, {"Col"}, {"Com"}, {"CrA"}, {"CrB"}, {"Crt"}, {"Cru"}, {"Crv"}, {"CVn"}, {"Cyg"}, {"Del"}, {"Dor"}, {"Dra"}, {"Equ"}, {"Eri"}, {"For"}, {"Gem"}, {"Gru"},
    {"Her"}, {"Hor"}, {"Hya"}, {"Hyi"}, {"Ind"}, {"Lac"}, {"Leo"}, {"Lep"}, {"Lib"}, {"LMi"}, {"Lup"}, {"Lyn"}, {"Lyr"}, {"Men"}, {"Mic"}, {"Mon"}, {"Mus"}, {"Nor"}, {"Oct"}, {"Oph"},
    {"Ori"}, {"Pav"}, {"Peg"}, {"Per"}, {"Phe"}, {"Pic"}, {"PsA"}, {"Psc"}, {"Pup"}, {"Pyx"}, {"Ret"}, {"Scl"}, {"Sco"}, {"Sct"}, {"Ser"}, {"Sex"}, {"Sge"}, {"Sgr"}, {"Tau"}, {"Tel"},
    {"TrA"}, {"Tri"}, {"Tuc"}, {"UMa"}, {"UMi"}, {"Vel"}, {"Vir"}, {"Vol"}, {"Vul"}
  byte myConstellationNo = 0;
  String myConstellationName = "";
  // object type name and variables for deep sky objects
  const char* myObjectTypeName[] = {"Quasar", "Dark Nebula", "Galaxy", "Bright Neb", "Clust + Neb", "Planet Neb", "SN Rem", "Glob Cluster", "Open Cluster", "Double Star", "Red Star", "Reference", "any"};
  unsigned int myRefNo = 0; // number of selected reference star
  unsigned int  myTargetNo = 0; // number of selected target
  // definition of cellestial regions = constellations of seasons defined in groups (as in Deep Sky Atlas) to filter targets and reference stars
  // constellation for which deep sky objects exist in the list 0 = all
  const byte myAllCONST[] = {0, 1, 2, 4, 5, 6, 7, 8, 9, 11, 12, 13, 14, 15, 16, 17, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 44, 45, 46, 47, 48, 49, 50, 51, 52, 54, 55, 57, 59, 60, 61, 62, 63, 64, 66, 67, 68, 69, 71, 72, 73, 74, 75, 76, 77, 78, 80, 81, 83, 84, 85, 86, 88};
  const byte myAllCONST_size = sizeof(myAllCONST) / sizeof(myAllCONST[0]);
  // North - UMI,UMA,DRA,CEP,CAS,CAM
  const byte myNorthCONST[] = {84, 83, 34, 16, 14, 11};
  const byte myNorthCONST_size = sizeof(myNorthCONST) / sizeof(myNorthCONST[0]);
  // Spring - LEO,LMI,SEX,HYA,CVN,COM,VIR,CRT,CRV,BOO,CRB,SER
  const byte mySpringCONST[] = {46, 49, 75, 42, 30, 24, 86, 27, 29, 9, 26, 74};
  const byte mySpringCONST_size = sizeof(mySpringCONST) / sizeof(mySpringCONST[0]);
  // Summer - HER,LYR,OPH,SCO,CYG,VUL,SGE,DEL,EQU,AQL,SCT,SER,SGR,CAP
  const byte mySummerCONST[] = {40, 52, 59, 72, 31, 88, 76, 32, 35, 4, 73, 74, 77, 12};
  const byte mySummerCONST_size = sizeof(mySummerCONST) / sizeof(mySummerCONST[0]);
  // Autumn - LAC,PEG,AQR,PSA,AND,TRI,PER,ARI,PSC,CET,SCL,FOR,ERI
  const byte myAutumnCONST[] = {45, 62, 5, 66, 1, 81, 63, 7, 67, 17, 71, 37, 36};
  const byte myAutumnCONST_size = sizeof(myAutumnCONST) / sizeof(myAutumnCONST[0]);
  // Winter - AUR,TAU,ORI,LEP,LYN,GEM,CMI,MON,CMA,PUP,CNC
  const byte myWinterCONST[] = {8, 78, 60, 47, 51, 38, 21, 55, 20, 68, 22};
  const byte myWinterCONST_size = sizeof(myWinterCONST) / sizeof(myWinterCONST[0]);
  // South - ANT,VEL,CAR,VOL,CHA,MUS,CRU,CEN,CRU,TRA,LUP,NOR,ARA,SCO,SGR,CRA,TEL,MIC,IND,PAV,GRU,PHE,SCL,FOR,ERI,HOR,RET,HYI,TUC,DOR,CAE,COL,PUP,PYX,PIC,MEN,APS,OCT
  const byte mySouthCONST[] = {2, 85, 13, 28, 15, 28, 80, 50, 57, 6, 72, 77, 25, 54, 44, 61, 39, 64, 71, 37, 36, 41, 33, 23, 68, 69, 65};
  const byte mySouthCONST_size = sizeof(mySouthCONST) / sizeof(mySouthCONST[0]);
  const char* myregionNAME[] = {"all", "North", "Spring", "Summer", "Autumn", "Winter", "South"}; // no south to save flash
  const byte regionArraySize = sizeof(myregionNAME) / sizeof(myregionNAME[0]); // Anzahl der Einträge
  byte myRegionNo = 0; // all - 0; North - 1; .... ; South - 6
  String myregionName = "";
  // variables for calculation of position // all positions are calculated in seconds
  long myRefStartTimeSec = 0; // Startzeit beim Setzen des Referenzsterns in Sekunden
  long myCurrentRAsec = 0; // meine aktuelle Rektaszension in Sekunden
  long myCurrentDECsec = 0; // meine aktuelle Deklination in Sekunden
  long myLastRAsec = 0; // meine letzte Rektaszension in Sekunden
  long myLastDECsec = 0; // meine letzte Deklination in Sekunden
  long myReferenceRAsec = 0; // meine Rektaszensionsreferenz in Sekunden
  long myReferenceDECsec = 0; // meine Deklinationsreferenz in Sekunden
  long mySensorRAsec = 0; // Sensorwert der Rektaszension in Sekunden
  long mySensorDECsec = 0; // Sensorwert der Deklination in Sekunden
  long myTargetRAsec = 0; // Rektaszension des Ziels in Sekunden
  long myTargetDECsec = 0; // Deklination des Ziels in Sekunden
  const int secPerStepRA = 86400L / IMPULSE24HRA; // defines how many seconds RA is changed per rotary step //  (24h * 3600sec = 86400sec) / (1:139 * 20 impulse = 2780) --> 31,079 sec / i
  const int secPerStepDEC = 1296000L / IMPULSE360DEGDEC; // defines how many seconds DEC is changed per rotary step //  (360° * 3600sec = 1296000sec) / (1:96 * 20 impulse = 1920) / --> 675 sec / i
  int myDirectionDEC = 1; // saves the value of the direction of the DEC axis, important if the telescope is turned over
  // for rotary encoders
  static uint8_t prevNextCode_ROT = 0;
  static uint16_t store_ROT = 0;
  static uint8_t prevNextCode_RA = 0;
  static uint16_t store_RA = 0;
  static uint8_t prevNextCode_DEC = 0;
  static uint16_t store_DEC = 0;
  static int8_t val_ROT, val_RA, val_DEC;
  int myImpulseRA = 0, myImpulseDEC = 0;
  int myLastImpulseRA = 0, myLastImpulseDEC = 0;
  const int8_t enc_table[] = {0, 1, 1, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 1, 1, 0};
  // variables for LX200
  byte statusLX200 = 0; // 0 - BT switched off / 1 - BT switched on / 2 - connected via BT & LX200 (frequent connect to LX200)
  byte statusLX200old = 0;
  byte btStatus = 0; // 0 - off / 1 - on
  unsigned long lastLX200Message = 0;
  DSOstruct externalObject; // instance LX200 object
  // setup
    // for LX200 protocol & debugging
    Serial.begin (9600);
    // while(!Serial); // attention - only for debugging when in use with IDE!
    // Serial.println(F("started"));
    getSettingsFromEeprom(); // load settings (brightness,contrast,...)
    setReference(); // set reference object to saved values
    setTarget(); // set target object to saved values
    setupLCD();
    createCustomCharacters();
    setupRotaryEncoders();
    initExternalObject();
  // software reset https://www.instructables.com/two-ways-to-reset-arduino-in-software/
  void(* resetFunc) (void) = 0;//declare reset function at address 0
  void setupLCD()
    lcd.begin(16, 2);
    updateLCD();
    pinMode(LCD_BACKLIGHT_PIN, OUTPUT);
    analogWrite(LCD_CONTRAST_PIN, myLCDcontrast); //set contrast
  //Creating custom characters in CG-RAM
  void createCustomCharacters()
    lcd.createChar(1 , ch_custom_1);
    lcd.createChar(2 , ch_custom_2);
    lcd.createChar(3 , ch_custom_3);
    lcd.createChar(4 , ch_custom_4);
    lcd.createChar(5 , ch_custom_5);
    lcd.createChar(6 , ch_custom_6);
    lcd.createChar(7 , ch_custom_7);
    lcd.createChar(8 , ch_custom_8);
  void setupRotaryEncoders()
    // HMI rotary encoder button
    pinMode(ROTARY_SW, INPUT_PULLUP);
    pinMode(ROTARY_CLK, INPUT);
    pinMode(ROTARY_DT, INPUT);
    // it is better to use the integrated pull-ups of KY-040 (this requires "+" to be connected to 5V) - https://forum.arduino.cc/index.php?topic=242356.0
    // as analog pins are used for rotary encoders - internal pull-ups are additionally used to avoid akward behaviour if not connected to sensors
    // RA rotary encoder
    pinMode(SENS_RA_CLK, INPUT_PULLUP);
    pinMode(SENS_RA_DT, INPUT_PULLUP);
    // DEC rotary encoder
    pinMode(SENS_DEC_CLK, INPUT_PULLUP);
    pinMode(SENS_DEC_DT, INPUT_PULLUP);
    // switch for BT module
    pinMode(BT_SWITCH, OUTPUT);
  // initialise external object struct for receiving via LX200
  void initExternalObject()
    externalObject.objectPreFixNameNo = 202; // is "external" in DSO PROGMEM
    externalObject.objectNumber = 0; // empty - no number in name
    externalObject.objectTypeMagnitude = 0;
    externalObject.objectConst = 0; // "all" in constellations
    externalObject.objectRA = 0;
    externalObject.objectDEC = 0;
  // \setup
  // loop
    analogWrite(LCD_BACKLIGHT_PIN, myLCDbacklight);  // LCD backlight analogWrite: values from 0 to 255
    updateRotaryEncoderButton();
    updateRotaryEncoders();
    calcCurrentPosition();
    if (myDisplayMode == 9) displaySensorValue();
    if (myDisplayMode == 11) displayCurrPos();
    if (myDisplayMode == 12) displayTargetPos();
    if (myDisplayMode == 13) displayDiffTargetCurrPos();
    // LX200 status
    updateLX200Status();
    readSendLX200();
  // \loop
  // read sensor values
  // reads rotary encoders
  void updateRotaryEncoders()
    if (val_ROT = read_rotary_ROT()) switchSelection(val_ROT);
    if (val_RA = read_rotary_RA())
      mySensorRAsec = mySensorRAsec + val_RA * secPerStepRA;
      myImpulseRA = myImpulseRA + val_RA; // for sensor test
    if (val_DEC = read_rotary_DEC())
      mySensorDECsec = mySensorDECsec + val_DEC * secPerStepDEC * myDirectionDEC;
      myImpulseDEC = myImpulseDEC + val_DEC * myDirectionDEC; // for sensor test
  // reads rotary encoder button
  void updateRotaryEncoderButton()
    // copy from https://arduinogetstarted.com/tutorials/arduino-button-debounce
    currentState = digitalRead(ROTARY_SW);
    if (currentState != lastFlickerableState)
      lastDebounceTime = millis();
      lastFlickerableState = currentState;
    if ((millis() - lastDebounceTime) > DEBOUNCE_DELAY)
      if (lastSteadyState == HIGH && currentState == LOW)
        switchMode();
        updateLCD();
        lastPressedTime = millis();
      else if (lastSteadyState == LOW && currentState == HIGH)
        // if button pressed > 5 seconds -> reset
        if (millis() - lastPressedTime > 5000) resetFunc(); // call reset
      lastSteadyState = currentState;
  // read rotary encoder for HMI
  // robust rotary encoder reading https://www.best-microcontroller-projects.com/rotary-encoder.html
  // A vald CW or  CCW move returns 1,invalid returns 0.
  int8_t read_rotary_ROT()
    prevNextCode_ROT <<= 2;
    if (digitalRead(ROTARY_DT)) prevNextCode_ROT |= 0x02;
    if (digitalRead(ROTARY_CLK)) prevNextCode_ROT |= 0x01;
    prevNextCode_ROT &= 0x0f;
    // If valid then store as 16 bit data.
    if  (enc_table[prevNextCode_ROT] )
      store_ROT <<= 4;
      store_ROT |= prevNextCode_ROT;
      if ((store_ROT & 0xff) == 0x2b) return -1;
      if ((store_ROT & 0xff) == 0x17) return 1;
    return 0;
  // read rotary encoder for RA
  int8_t read_rotary_RA()
    prevNextCode_RA <<= 2;
    if (digitalRead(SENS_RA_DT)) prevNextCode_RA |= 0x02;
    if (digitalRead(SENS_RA_CLK)) prevNextCode_RA |= 0x01;
    prevNextCode_RA &= 0x0f;
    if  (enc_table[prevNextCode_RA] )
      store_RA <<= 4;
      store_RA |= prevNextCode_RA;
      if ((store_RA & 0xff) == 0x2b) return -1;
      if ((store_RA & 0xff) == 0x17) return 1;
    return 0;
  // read rotary encoder for DEC
  int8_t read_rotary_DEC()
    prevNextCode_DEC <<= 2;
    if (digitalRead(SENS_DEC_DT)) prevNextCode_DEC |= 0x02;
    if (digitalRead(SENS_DEC_CLK)) prevNextCode_DEC |= 0x01;
    prevNextCode_DEC &= 0x0f;
    if  (enc_table[prevNextCode_DEC] )
      store_DEC <<= 4;
      store_DEC |= prevNextCode_DEC;
      if ((store_DEC & 0xff) == 0x2b) return -1;
      if ((store_DEC & 0xff) == 0x17) return 1;
    return 0;
  // get & set of object data
  // returns the type as number of a deep sky object
  byte getObjectType(byte typeMagnitude)
    return (typeMagnitude / 14); // decoding of object type from typeMagnitude
  // returns the type as string of a deep sky object
  String getObjectTypeName(byte typeMagnitude)
    return myObjectTypeName[(typeMagnitude / 14) - 1];
  // returns the magnitude of a deep sky object
  String getMagnitude(byte typeMagnitude)  // calcs the right magnitude - here modulo 14 as coded
    String strFlMag = (String)(typeMagnitude % 14) +  "m";
    return strFlMag;
  // returns the name of a constellation as string from a lookup tabel according to its number
  String getConstName(int no)
    constStruct oneConstellation;
    // copy constellations data from PROGMEM into oneConstellation according to no
    memcpy_P (&oneConstellation, &const_PROGMEM[no], sizeof oneConstellation);
    return (String)oneConstellation.constName;
  // returns the current constellation for filtering
  String getCurrentConstName()
    String constellationName;
    constellationName = getConstName(myConstellationNo);
    return constellationName;
  // returns the current cellestial region
  String getSetregionName()
    return myregionNAME[myRegionNo];
  // set reference star
  void setReference()
    // copy reference data from PROGMEM into myReference according to myRefNo
    memcpy_P (&myReference, &DSO_PROGMEM[myRefNo], sizeof myReference);
    setReferenceRA_DEC();
  // RA and DEC of selected target are set
  void setReferenceRA_DEC()
    // transfer RA / DEC into internal format (seconds)
    myReferenceRAsec = calcRAsecFromRA(myReference.objectRA);
    myReferenceDECsec = calcDECsecFromDEC(myReference.objectDEC);
  // set target
  void setTarget()
    // copy reference data from PROGMEM into myTarget according to myTargetNo
    memcpy_P (&myTarget, &DSO_PROGMEM[myTargetNo], sizeof myTarget);
    setTargetRA_DEC();
  void setTargetRA_DEC()
    myTargetRAsec = calcRAsecFromRA(myTarget.objectRA);
    myTargetDECsec = calcDECsecFromDEC(myTarget.objectDEC);
  // \get & set of object data
  // calculations and settings of positions
  // calculation of RA seconds
  unsigned int calcRAsecFromRA(unsigned int ra)
    int h = ra / 1000;
    int m = (ra - h * 1000) / 10;
    int s = (ra - h * 1000 - m * 10) * 6;
    unsigned int raSec = h * 3600L + m * 60 + s;
    return raSec;
  // calculation of DEC seconds
  long calcDECsecFromDEC(int dec)
    int deg = dec / 100;
    int m = (dec - deg * 100);
    long decSec = deg * 3600L + m * 60;
    return decSec;
  // calculation of current telescope position
  void calcCurrentPosition()
    myCurrentRAsec = myReferenceRAsec + myRefStartTimeSec + mySensorRAsec - millis() / 1000;
    myCurrentDECsec = myReferenceDECsec + mySensorDECsec;
  // sets the sensor values to zero - needed for alignment with reference star
  void resetSensorTime()
    myRefStartTimeSec = millis() / 1000;
  // \calculations and settings of positions
  // display information
  // display the current position
  void displayCurrPos()
    if (myLastRAsec != myCurrentRAsec || myLastDECsec != myCurrentDECsec)
      myLastRAsec = myCurrentRAsec;
      myLastDECsec = myCurrentDECsec;
      displayRA_DEC("Curr   ", "Coord", myCurrentRAsec, myCurrentDECsec);
  // display position of selected target
  void displayTargetPos()
    displayRA_DEC(getObjectName(myTarget.objectPreFixNameNo, myTarget.objectNumber, myTarget.objectConst), "Coord", myTargetRAsec, myTargetDECsec);
  // calulation & display of difference between current position & target position
  void displayDiffTargetCurrPos()
    long diffRAsec = myTargetRAsec - myCurrentRAsec;
    long diffDECsec = myTargetDECsec - myCurrentDECsec;
    if (myLastRAsec != myCurrentRAsec ||  myLastDECsec != myCurrentDECsec) // only if position has changed
      displayRA_DEC(getObjectName(myTarget.objectPreFixNameNo, myTarget.objectNumber, myTarget.objectConst), "Diff ", diffRAsec , diffDECsec);
  // display of RA and DEC - generic use for reference stars & target
  void displayRA_DEC(String text1, String text2, long rekSec, long dekSec)
    // Rektaszension //
    int sign = 1.0;
    if (rekSec < 0) sign = -1.0;
    byte s = (abs(rekSec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator // vorher int
    byte m  = (abs(rekSec / 60)) % 60;
    byte h  = (abs(rekSec / 3600)) % 24;
    lcd.setCursor(0, 0);
    printObjectName(text1);
    lcd.setCursor(8, 0);
    if (sign < 0) lcd.print(F("-"));
    else lcd.print(F("+"));
    if (h < 10) lcd.print(F(" "));
    lcd.print(h);
    lcd.print(F(":"));
    if (m < 10) lcd.print(F("0"));
    lcd.print(m);
    lcd.print(F(","));
    lcd.print(s / 6);
    // DEC // +90° - -90°
    sign = 1.0;
    if (dekSec < 0) sign = -1.0;
    s = (abs(dekSec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator
    m = (abs(dekSec / 60)) % 60;
    h = (abs(dekSec / 3600)) % 180;
    lcd.setCursor(0, 1);
    lcd.print(text2);
    lcd.setCursor(8, 1);
    lcd.print(h);
    lcd.print(ch_deg);
    lcd.print(m);
    lcd.print(F("'"));
  // display current sensor values
  void displaySensorValue()
    if (myImpulseRA != myLastImpulseRA || myImpulseDEC != myLastImpulseDEC)
      lcd.clear();
      lcd.print(F("Imp RA"));
      lcd.print(F("Imp DEC"));
      lcd.setCursor(10, 0);
      lcd.print(myImpulseRA);
      lcd.setCursor(10, 1);
      lcd.print(myImpulseDEC);
      myLastImpulseRA = myImpulseRA;
      myLastImpulseDEC = myImpulseDEC;
  // update LCD according to selected display mode
  void updateLCD()
    lcd.clear();
    if (myDisplayMode == 0)
      lcd.print(F("SpotNik   v")); // DO NOT REMOVE
      lcd.print(VERSION);
      lcd.print(F("developed by MR")); // DO NOT REMOVE
    if (myDisplayMode == 1) // main menu
      lcd.print(F(">"));
      lcd.setCursor(1, 0);
      lcd.print(menuTopic[myMenuTopicNo]); // {" reverse", "Ref","Target","region","Const","Bright","Contr","Test"};
      switch (myMenuTopicNo) {
        case 0:
          if (myDirectionDEC == 1) lcd.print(F("normal"));
          else lcd.print(F("reverse"));
        case 1:
          printObjectName(getObjectName(myReference.objectPreFixNameNo, myReference.objectNumber, myReference.objectConst));
        case 2:
          printObjectName(getObjectName(myTarget.objectPreFixNameNo, myTarget.objectNumber, myTarget.objectConst));
          //if (statusLX200 != 2) printObjectName(getObjectName(myTarget.objectPreFixNameNo,myTarget.objectNumber,myTarget.objectConst));
          //else lcd.print(F("external")); // if connection to LX200 source - no usage of internal star database
        case 3:
          lcd.print(getSetregionName());
          // if (statusLX200 != 2) lcd.print(getSetregionName());
          // else lcd.print(F("external"));
        case 4:
          lcd.print(getCurrentConstName());
          // if (statusLX200 != 2) lcd.print(getCurrentConstName());
        case 8:
          if (statusLX200 == 0) lcd.print(F("BT off"));
          if (statusLX200 == 1) lcd.print(F("BT on"));
          if (statusLX200 == 2) lcd.print(F("conn"));
      lcd.setCursor(1, 1);
      if (myMenuTopicNo + 1 < menuTopic_size)
        lcd.print(menuTopic[myMenuTopicNo + 1]);
        lcd.print(menuTopic[0]);
    if (myDisplayMode == 2)
      lcd.print(F("Direction of DEC"));
      lcd.print(F(">"));
    if (myDisplayMode == 3)
      lcd.setCursor(13, 0);
      lcd.print(getConstName(myReference.objectConst));
      lcd.print(getObjectTypeName(myReference.objectTypeMagnitude));
      lcd.setCursor(13, 1);
      lcd.print(getMagnitude(myReference.objectTypeMagnitude));
    if (myDisplayMode == 4)
      lcd.print(getConstName(myTarget.objectConst));
      lcd.print(getObjectTypeName(myTarget.objectTypeMagnitude));
      lcd.print(getMagnitude(myTarget.objectTypeMagnitude));
    if (myDisplayMode == 5)
      lcd.print(F("Celestial Region"));
      lcd.print(F(">"));
    if (myDisplayMode == 6)
      lcd.print(F("Constellation"));
      lcd.setCursor(11, 1);
      lcd.print(F(">"));
    if (myDisplayMode == 7)
      lcd.print(F("LCD Brightness"));
      lcd.print(F(">"));
      lcd.print(myLCDbacklight);
    if (myDisplayMode == 8)
      lcd.print(F("LCD Contrast"));
      lcd.print(F(">"));
      lcd.print(myLCDcontrast);
      lcd.print(F("For test"));
      lcd.print(F("turn DEC / RA"));
      myImpulseRA = 0;
      myImpulseDEC = 0;
      myLastImpulseRA = 0;
    if (myDisplayMode == 10)
      lcd.print(F("LX200 Connection"));
      lcd.print(F(">"));
      if (statusLX200 == 0) lcd.print(F("Bluetooth off"));
      if (statusLX200 == 1) lcd.print(F("Bluetooth on"));
      if (statusLX200 == 2) lcd.print(F("LX200 connected"));
  // returns name of deep sky object based on coded name its number and its constellation
  String getObjectName(byte objectprefixNameNo, unsigned int objectNumber, byte objectConst)
    String objectName = "";
    int indexOfHash = -1;
    DSONameStruct oneDSONameStruct;
    if (objectprefixNameNo > 0)
      // get name accordng to name number from lookup table
      memcpy_P (&oneDSONameStruct, &DSO_NAME_PROGMEM[objectprefixNameNo - 1], sizeof oneDSONameStruct);
      objectName = oneDSONameStruct.objectName;
      indexOfHash = objectName.indexOf('#');
      if (indexOfHash > -1)
        // replace char with greek char
        String charToReplace = objectName.substring(indexOfHash + 1, indexOfHash + 2);
        objectName = objectName.substring(0, indexOfHash) + objectName.substring(indexOfHash + 2); // delete # and next char from string
        // loop over the greek symbols
        for (int i; i < greekSymbols_size; i++)
          if ((String)charToReplace == (String)greekSymbols[i].originalChar)
            charToReplace = greekSymbols[i].replaceChar;
            objectName = objectName + charToReplace;
    if (objectNumber > 0)
      objectName = objectName + (String)objectNumber;
    // if object is only number,greek Symbol or max. two characters,accept 'M' - add constellation for identification
    if (objectName.charAt(1) == NULL || objectprefixNameNo == 0 || (objectName.charAt(2) == NULL && objectNumber == 0)) // oder nur Zahlen!!!
      objectName = objectName + ' ' + getConstName(objectConst);
    return objectName;
  // some greek symbols are custom, print function needed
  void printObjectName(String objectName)
    byte customChar = 0;
    char charAt0 = objectName.charAt(0);
    if (charAt0 == ch_def_1) customChar = 1;
    else if (charAt0 == ch_def_2) customChar = 2;
    else if (charAt0 == ch_def_3) customChar = 3;
    else if (charAt0 == ch_def_4) customChar = 4;
    else if (charAt0 == ch_def_5) customChar = 5;
    else if (charAt0 == ch_def_6) customChar = 6;
    else if (charAt0 == ch_def_7) customChar = 7;
    if (customChar > 0) lcd.write(customChar);
      lcd.print(objectName);
      return;
    lcd.print(F(" "));
    lcd.print(objectName.substring(2, 8));
  // \display information
  // switching
  // myDisplayMode - rotary encoder for change
  // 0 = welcome, 1 = top menu, 2 = change direction, 3 = set reference, 4 = set target, 5 = set region, 6 = set constellation, 7 = set LCD brightness, 8 = set LCD contrast
  // 9 = sensor test, 10 = set bluetooth, 11 = show current position, 12 = show target position, 13 = show difference target - current position
  void switchMode()
    saveSettingsToEeprom(); // save settings to eeprom each time the button is pressed
    if (myDisplayMode == 0) // welcome
      myDisplayMode = 1; // top menue
    else if (myDisplayMode == 1)
      myDisplayMode = myMenuTopicNo + 2;
    else if (myDisplayMode == 3) // set reference
      resetSensorTime();
      myLastDECsec = 0; // set once to zero to update display
      myDisplayMode = 11; // show current position
    else if (myDisplayMode == 4) // set target
      setTargetRA_DEC();
      myDisplayMode = 13; // show diff position
    // set direction // region // constellation // set brightness  // set contrast // sensor test // show current position // show diff position
    else if (myDisplayMode == 2 || myDisplayMode >= 5)
      myDisplayMode = 1; // return to top level menu
    lcd.clear();
  // function of rotary encoder changes acording to current display mode
  void switchSelection(int dir)
      myDisplayMode = 1;
      updateLCD();
    else if (myDisplayMode == 1) changeMenu(dir);
    if (myDisplayMode == 2) changeDirectionDEC(dir);
    if (myDisplayMode == 3) changeReference(dir);
    if (myDisplayMode == 4) changeTarget(dir);
    if (myDisplayMode == 5) changeregion(dir);
    if (myDisplayMode == 6) changeConstellation(dir);
    if (myDisplayMode == 7) changeLCDBacklight(dir);
    if (myDisplayMode == 8) changeLCDcontrast(dir);
    if (myDisplayMode == 10) changeBTconnection(dir);
    if (myDisplayMode == 11 || myDisplayMode == 12 || myDisplayMode == 13) changeView(dir);
    updateLCD();
  // change menu topics
  void changeMenu(int dir)
    if (dir == 1)
      if ((myMenuTopicNo + 1) < menuTopic_size)
        myMenuTopicNo = myMenuTopicNo + 1;
        myMenuTopicNo = 0;
    else if (dir == -1)
      if (myMenuTopicNo > 0)
        myMenuTopicNo = myMenuTopicNo - 1;
        myMenuTopicNo = menuTopic_size - 1;
  // according to the direction of the DEC axis the value of the DEC sensor has to be reverted
  void changeDirectionDEC(int dir)
    if (dir == 1 || dir == -1)
      if (myDirectionDEC == 1) myDirectionDEC = -1;
      else myDirectionDEC = 1;
  // calls changeObject for object type reference
  void changeReference (int dir)
    changeObject(dir, 'r');
  // calls changeObject for object type target
  void changeTarget(int dir)
    changeObject(dir, 't');
  // change referenc star including filter according to selected sky region
  void changeObject (int dir, char objectType)
    bool constFound = false;
    DSOstruct oneObject; // instance of reference for search & filter
    unsigned int objectNo;
    unsigned int numberOfLoops = 0;
    if (objectType == 'r')
      objectNo = myRefNo; // set start no of object
      objectNo = myTargetNo;
    while (constFound == false)
      if (dir == 1)
        if ((objectNo + 1) < DSO_PROGMEM_size)
          objectNo = objectNo + 1;
          objectNo = 0;
      if (dir == -1) // before else if - but what if no fitting star at beginning before rotary turning?
        if (objectNo > 0)
          objectNo = objectNo - 1;
          objectNo = DSO_PROGMEM_size - 1;
      memcpy_P (&oneObject, &DSO_PROGMEM[objectNo], sizeof oneObject); // get next DSO object from struct and copy it into oneObject
      // filter on a constellation
      // if a constellation is selected,object is a target and constellation of object fits to selected constellation
      if (objectType == 't' && myConstellationNo > 0 && getObjectType(oneObject.objectTypeMagnitude) > 0  && getObjectType(oneObject.objectTypeMagnitude) < 12 && oneObject.objectConst == myConstellationNo)
        constFound = true;
      // filter on regions
      else if ( (objectType == 'r' && getObjectType(oneObject.objectTypeMagnitude) == 12) || // reference stars     // filter on objects of type "reference" = no 12
                (myConstellationNo == 0 && objectType == 't' && getObjectType(oneObject.objectTypeMagnitude) > 0  && getObjectType(oneObject.objectTypeMagnitude) < 12)) // target objects
        // filter targets by constellations of the selected region
        // myregionNAME[]={"All","North","Spring","Summer","Autumn","Winter","South"};
        if (myRegionNo == 1) // region = north
          for (int i = 0; i < myNorthCONST_size; i++)
            if (oneObject.objectConst == myNorthCONST[i])
              constFound = true;
        else if (myRegionNo == 2) // region = spring
          for (int i = 0; i < mySpringCONST_size; i++)
            if (oneObject.objectConst == mySpringCONST[i])
              constFound = true;
        else if (myRegionNo == 3) // region = summer
          for (int i = 0; i < mySummerCONST_size; i++)
            if (oneObject.objectConst == mySummerCONST[i])
              constFound = true;
        else if (myRegionNo == 4) // region = autumn
          for (int i = 0; i < myAutumnCONST_size; i++)
            if (oneObject.objectConst == myAutumnCONST[i])
              constFound = true;
        else if (myRegionNo == 5) // region = winter
          for (int i = 0; i < myWinterCONST_size; i++)
            if (oneObject.objectConst == myWinterCONST[i])
              constFound = true;
        else if (myRegionNo == 6) // region = south
          for (int i = 0; i < mySouthCONST_size; i++)
            if (oneObject.objectConst == mySouthCONST[i])
              constFound = true;
        else // all constellations
          constFound = true;
    }// end while
      myRefNo = objectNo;
      myReference = oneObject; // copy selected reference object in my reference object
      myTargetNo = objectNo;
      myTarget = oneObject; // copy selected target object in my target object
      setTargetRA_DEC();
    updateLCD();
  // change region
  void changeregion(int dir)
    if (dir == 1)
      if ((myRegionNo + 1) < regionArraySize) {
        myRegionNo = myRegionNo + 1;
      else {
        myRegionNo = 0;
    else if (dir == -1)
      if (myRegionNo > 0) {
        myRegionNo = myRegionNo - 1;
      else {
        myRegionNo = regionArraySize - 1;
    myTargetNo = 0; // reset target,when aera has changed
    myConstellationNo = 0; // reset constellation,when aera has changed
    updateLCD();
  // set constellation
  void changeConstellation(int dir)
      if (dir == 1)
        if ((myConstellationNo) < constStruct_size - 1) {
          myConstellationNo = myConstellationNo + 1;
        else {
      else if (dir == -1)
        if (myConstellationNo > 0) {
          myConstellationNo = myConstellationNo - 1;
        else {
          myConstellationNo = constStruct_size - 1;
          if (myConstellationNo == myNorthCONST[i])
            constFound = true;
          if (myConstellationNo == mySpringCONST[i])
            constFound = true;
          if (myConstellationNo == mySummerCONST[i])
            constFound = true;
          if (myConstellationNo == myAutumnCONST[i])
            constFound = true;
          if (myConstellationNo == myWinterCONST[i])
            constFound = true;
          if (myConstellationNo == mySouthCONST[i])
            constFound = true;
        for (int i = 0; i < myAllCONST_size; i++)
          if (myConstellationNo == myAllCONST[i])
            constFound = true;
    myTargetNo = 0; // reset target every time when constellation was changed
    updateLCD();
  // switch view between current position, diff position & target coordinates
  void changeView(int dir)
    lcd.clear();
    myDisplayMode = myDisplayMode + dir;
    if (myDisplayMode > 13) myDisplayMode = 11;
    if (myDisplayMode < 11) myDisplayMode = 13;
  // set LCD brightness
  void changeLCDBacklight(int dir)
    myLCDbacklight = myLCDbacklight + dir * 8;
    if (myLCDbacklight > 255) myLCDbacklight = 0;
    if (myLCDbacklight < 0) myLCDbacklight = 255;
  // set LCD contrast
  void changeLCDcontrast(int dir)
    myLCDcontrast = myLCDcontrast + dir * 5;
    if (myLCDcontrast > 255) myLCDcontrast = 0;
    if (myLCDcontrast < 0) myLCDcontrast = 255;
  void changeBTconnection(int dir)
    if (btStatus == 0) // switch BT on if off
      btStatus = 1;
      statusLX200 = 1;
      digitalWrite(BT_SWITCH, HIGH);
    else if (btStatus != 0) // switch BT off
      btStatus = 0;
      statusLX200 = 0;
      digitalWrite(BT_SWITCH, LOW);
    updateLCD();
  // \switching
  // LX200 communication
  // set the status of LX200 to control LCD etc
  void updateLX200Status()
    if (btStatus == 1)
      // if frequent feedback from LX200 - last request > 4 sek
      if ((millis() - lastLX200Message) > 4000)
        statusLX200 = 1; // BT on - but no LX200 connection
        statusLX200 = 2; // LX200 connected
    // LX200 status changend - update lcd in relevant views (main menu & BT)
    if (statusLX200 != statusLX200old && (myDisplayMode == 10 || myDisplayMode == 1))
      updateLCD();
      statusLX200old = statusLX200;
  // called if a LX200 message was received
  void receivedLX200message() // received
    lastLX200Message = millis();
  // read the bluetooth message and trigger functions according to message type
  void readSendLX200()
    if (Serial.available())
      char message[14] = "";
      byte i = 0;
      while (Serial.available() > 0)
        char a = Serial.read(); // Stores current byte
        message[i] += a;      // Append current byte to message String
        delay(10);
        i++;
      // all LX200 info from https://www.meade.com/support/TelescopeProtocol_2010-10.pdf
      // LX200 message :GR#
      // Get Telescope RA
      // Returns: HH:MM.T#  or  HH:MM:SS#Depending which precision is set for the telescope
      if (message[0] == ':' && message[1] == 'G' && message[2] == 'R' && message[3] == '#')
        receivedLX200message();
        sendLX200RA();
      // LX200 message :GD# or :RS#:GD# or :RM#:GD#
      // Get Telescope Declination.
      // Returns: sDD*MM# or sDD*MM’SS#Depending upon the current precision setting for the telescope.
      if (message[0] == ':' && message[1] == 'G' && message[2] == 'D' && message[3] == '#' ||
          message[4] == ':' && message[5] == 'G' && message[6] == 'D' && message[7] == '#')
        sendLX200DEC();
      // LX200 message :CM#
      // Synchronizes the telescope's position with the currently selected database object's coordinates.
      // Returns:LX200's - a "#" terminated string with the name of the object that was synced
      if (message[0] == ':' && message[1] == 'C' && message[2] == 'M')
        Serial.print("#");
      // LX200 message :SrHH:MM.T# or :SrHH:MM:SS#
      // Set target object RA to HH:MM.T or HH:MM:SS depending on the current precision setting.
      // Returns:0 – Invalid1 - Valid
      // output HHMM(S/6)
      if (message[0] == ':' && message[1] == 'S' && message[2] == 'r')
        setRAtoLX200message(message);
      // LX200 message :SdsDD*MM#
      // Set target object declination to sDD*MM or sDD*MM:SS depending on the current precision setting
      // Returns:1 - Dec Accepted0 – Dec invalid
      // output sHHMM
      if (message[0] == ':' && message[1] == 'S' && message[2] == 'd')
        setDECtoLX200message(message);
      //  Serial.print("BT message "); // for debugging
      //  Serial.println(message);
  // set RA coordinates of placeholder externalobject to received LX200 message
  void setRAtoLX200message(char message[10])
      long(atoi(message + 3)) * 1000 + // HH // access at array different when using atoi - use address
      long(atoi(message + 6)) * 10; // MM - Minuten passen noch nicht bei zweistelligen gibt es Fehler
    if (message[8] == ':') // : or .
      externalObject.objectRA = externalObject.objectRA +
                                long(atoi(message + 9)) / 6; // SS/6
    else if (message[8] == '.')
      externalObject.objectRA = externalObject.objectRA + atoi(message + 9); // T
    Serial.println(); // leave this command, as otherwise no update on goto from LX200 source
  // set DEC coordinates of placeholder externalobject to received LX200 message & update the (reference or target) object
  void setDECtoLX200message(char message[9])
    int sign;
    if (message[3] == '-') sign = -1;
    else sign = 1;
      sign * ( // s
        long(atoi(message + 4)) * 100 + // DD
        long(atoi(message + 7))); // MM
    // assumption - first RA then DEC - then set target to external object
    if (myDisplayMode == 3 || myDisplayMode == 11) // if view shows reference selection or current position then copy external object into reference object
      externalObject.objectTypeMagnitude = 168;
      myReference = externalObject; // copy external object to my reference object
      resetSensorTime();
    else // in all other cases copy to target
      externalObject.objectTypeMagnitude = 182;
      myTarget = externalObject; // copy external object to my target object
      setTargetRA_DEC();
    updateLCD();
  // send current RA coordinate of telescope from SpotNik to LX200 server (e.g. Sky Safari)
  void sendLX200RA()
    byte s = (abs(myCurrentRAsec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator
    byte m  = (abs(myCurrentRAsec / 60)) % 60;
    byte h  = (abs(myCurrentRAsec / 3600)) % 24;
    String posString = "";
    if (h < 10) posString = "0";
    posString = posString + String(h);
    posString = posString + ":";
    if (m < 10) posString = posString + "0";
    posString = posString + String(m);
    if (s < 10) posString = posString + "0";
    posString = posString + String(s);
    posString = posString + "#";
    Serial.print(posString);
  // send current DEC coordinate of telescope from SpotNik to LX200 server (e.g. Sky Safari)
  void sendLX200DEC()
    byte s = (abs(myCurrentDECsec)) % 60; // Das Zeichen: "%" ist der Modulo-Operator
    byte m = (abs(myCurrentDECsec / 60)) % 60;
    byte h = (abs(myCurrentDECsec / 3600)) % 180;
    if (myCurrentDECsec > 0) posString = "+";
    else posString = "-";
    posString = posString + "*";
  // \LX200 communication
  // EEPROM
  // save relevant data for next startup (e.g. target no,LCD brightness)
  void saveSettingsToEeprom()
    // Serial.print(F("freeMemory()=")); //only used for testing
    // Serial.println(freeMemory());
    byte addr = EEPROM_VALUE_ADDR_SIGNATURE;
    byte myTargetNoLowByte = lowByte(myTargetNo); // myTargetNo is of type int - transfer into two bytes
    byte myTargetNoHighByte = highByte(myTargetNo);
    byte myReferenceNoLowByte = lowByte(myRefNo); // myTargetNo is of type int - transfer into two bytes
    byte myReferenceNoHighByte = highByte(myRefNo);
    EEPROM.update(addr, EEPROM_SIGNATURE); // use update for longer eeprom life
    addr += sizeof(EEPROM_SIGNATURE);
    EEPROM.update(addr, myReferenceNoLowByte);
    addr += sizeof(myReferenceNoLowByte);
    EEPROM.update(addr, myReferenceNoHighByte);
    addr += sizeof(myReferenceNoHighByte);
    EEPROM.update(addr, myTargetNoLowByte);
    addr += sizeof(myTargetNoLowByte);
    EEPROM.update(addr, myTargetNoHighByte);
    addr += sizeof(myTargetNoHighByte);
    EEPROM.update(addr, myRegionNo);
    addr += sizeof(myRegionNo);
    EEPROM.update(addr, myConstellationNo);
    addr += sizeof(myConstellationNo);
    EEPROM.update(addr, myLCDbacklight);
    addr += sizeof(myLCDbacklight);
    EEPROM.update(addr, myLCDcontrast);
  // load relevant data at startup (e.g. target no, LCD brightness)
  void getSettingsFromEeprom()
    byte addr = EEPROM_VALUE_ADDR_SIGNATURE, signature = 0, value, myReferenceNoLowByte, myReferenceNoHighByte, myTargetNoLowByte, myTargetNoHighByte; // myTargetNo is of type int,need to concatenated from two bytes
    EEPROM.get(addr, signature);
    if (signature != EEPROM_SIGNATURE) return; // maybe data from another sketch
    EEPROM.get(addr, value);
    myReferenceNoLowByte = value;
    myReferenceNoHighByte = value;
    if (value >= 0 && value <= 32767)  myRefNo = word(myReferenceNoHighByte, myReferenceNoLowByte);
    myTargetNoLowByte = value;
    myTargetNoHighByte = value;
    if (value >= 0 && value <= 32767)  myTargetNo = word(myTargetNoHighByte, myTargetNoLowByte);
    if (value >= 0 && value <= 255) myRegionNo = value;
    if (value >= 0 && value <= 255) myConstellationNo = value;
    if (value >= 0 && value <= 255) myLCDbacklight = value;
    if (value >= 0 && value <= 255) myLCDcontrast = value;
  // \EEPROM
  //###############################################################################################################put your setup code here, to run once:
And here's the latest error message compilation...
The sketch name had to be modified.
Sketch names must start with a letter or number, followed by letters,
numbers, dashes, dots and underscores. Maximum length is 63 characters.
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\spotnik_thursday\spotnik_thursday.ino: In function 'void setup()':
spotnik_thursday:3:3: error: 'SpotNik' was not declared in this scope
   SpotNik - by Max Reinecke
spotnik_thursday:3:13: error: 'by' was not declared in this scope
spotnik_thursday:12:38: error: 'without' was not declared in this scope
            but WITHOUT ANY WARRANTY; without even the implied warranty of
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\spotnik_thursday\spotnik_thursday.ino:12:38: note: suggested alternative: 'stdout'
                                      stdout
In file included from C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\spotnik_thursday\spotnik_thursday.ino:29:0:
\\admin-che\c$\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:130:5: error: invalid declaration of member template in local class
     template< typename T > T &get( int idx, T &t ){
\\admin-che\c$\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src/EEPROM.h:137:5: error: invalid declaration of member template in local class
     template< typename T > const T &put( int idx, const T &t ){
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\spotnik_thursday\spotnik_thursday.ino:1495:3: warning: narrowing conversion of '129989' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\spotnik_thursday\spotnik_thursday.ino:1495:3: warning: large integer implicitly truncated to unsigned type [-Woverflow]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\spotnik_thursday\spotnik_thursday.ino:1495:3: warning: narrowing conversion of '189256' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\spotnik_thursday\spotnik_thursday.ino:1495:3: warning: narrowing conversion of '106516' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\spotnik_thursday\spotnik_thursday.ino:1495:3: warning: narrowing conversion of '109003' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\spotnik_thursday\spotnik_thursday.ino:1495:3: warning: narrowing conversion of '128396' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\spotnik_thursday\spotnik_thursday.ino:1495:3: warning: narrowing conversion of '113801' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\spotnik_thursday\spotnik_thursday.ino:1495:3: warning: narrowing conversion of '157721' from 'long int' to 'unsigned int' inside { } [-Wnarrowing]
spotnik_thursday:1518:3: error: 'LiquidCrystal' was not declared in this scope
C:\users\hendersonc\OneDrive - St. Mary Redcliffe and Temple School\Documents\Arduino\spotnik_thursday\spotnik_thursday.ino:1518:3: note: suggested alternative: 'LiquidCrystal_h'
   LiquidCrystal_h
spotnik_thursday:1780:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:1799:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:1808:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:1820:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:1843:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:1859:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:1884:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:1902:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:1933:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:1952:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:1971:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:1997:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2003:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2009:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2016:3: error: a function-definition is not allowed here before '{' token
   ^Use code tags to format code for the forum
spotnik_thursday:2025:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2033:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2039:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2047:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2055:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2063:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2078:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2088:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2097:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2104:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2119:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2130:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2136:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2150:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2193:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2212:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2356:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2404:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2436:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2468:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2490:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2517:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2527:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2533:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2539:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2683:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2709:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2818:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2827:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2835:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2844:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2869:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2894:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2900:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2966:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:2985:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:3014:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:3034:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:3060:3: error: a function-definition is not allowed here before '{' token
spotnik_thursday:3091:3: error: a function-definition is not allowed here before '{' token
exit status 1
```Use code tags to format code for the forum
That is not a copy of what @david_2018 posted
The first line of his sketch in post #10 is the start of a block comment. The first line of what you say is a copy of it is
Hi @hendyhenderson. It seems the problems you are experiencing stem from you attempting to copy the code from the GitHub website, then paste it into Arduino IDE. You are ending up corrupting the by fumbling during that procedure.
I recommend starting fresh, but this time just download the file from GitHub, so that you are working with the exact code created by the author. This will leave less opportunities for you to mess up the code. I'll provide instructions you can follow to do that:
  1. Click the following link to open the GitHub page for the sketch file:
    https://github.com/surfer-max/SpotNik/blob/main/spotnik.ino
  2. Click the downward pointing arrow icon ("Download raw file") at the right side of the toolbar:
  3. Wait for the download to finish.
  4. Start Arduino IDE if it is not already running.
  5. Select File > Open... from the Arduino IDE menus.
    The "Open" dialog will open.
  6. Select the downloaded spotnik.ino in the dialog.
    The "Moving" dialog will open:
    The file "spotnik.ino" needs to be inside a sketch folder named "spotnik".
    Create this folder, move the file, and continue?
  7. Click the "OK" button in the "Moving" dialog.
    The "spotnik" sketch will open in a new Arduino IDE window.
Now try compiling that "spotnik" sketch. Hopefully everything will work as expected this time.
