A school project Garbage classification
hello!
Arduino IDE 2.3.3
Arduino Cloud Editor:
Adafruit_TFLite
model_data <this is my train modle
TensorFlowLite
ArduTFLite
boards manager use esp32 2.0.17
we have a project about Garbage classification , I use the colab to train the Model want to mix in arduino and use esp32-cam to Judge trash,but I still can't upload the program I try over and over and faill over and over I use chatGPT to help me,but can't work ;-; if have someone see this please help me --from taiwan High School Students
I have deleted your other cross-post @1003lee.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Hi @1003lee.
Please add a reply here on this forum thread to tell us which application you are using to perform the upload:
I ask because I would like to give you the appropriate instructions.
ok! thanks!
Arduino IDE 2.3.3
Adafruit_TFLite
TensorFlowLite
ArduTFLite
Arduino CLI no I don't have this
if I have any problem can tall me!!! thanks to teach me
I'm going to ask you to provide the full output from an upload attempt using Arduino IDE 2.3.3.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Attempt an upload, as you did before.
  2. Wait for the upload to fail.
  3. Right click on the black "Output" panel at the bottom of the Arduino IDE window.
    A context menu will open.
  4. Select Copy All from the menu.
  5. Open a forum reply here by clicking the "Reply" button.
  6. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  7. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the upload output into the code block.
  8. Move the cursor outside of the code block markup before you add any additional text to your reply.
  9. Click the "Reply" button to post the output.
I can't all reply because is too much ai say the library have problem I not sure that right I have check that and the library is have all about tensor
FQBN: esp32:esp32:esp32cam
使用檔案夾: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17 裏面平台的開發板 'esp32cam'
使用檔案夾: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17 裏面平台的核心 'esp32'
cmd /c if exist "C:\\Users\\User\\Desktop\\text\\partitions.csv" COPY /y "C:\\Users\\User\\Desktop\\text\\partitions.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\7B9D2C611DF8AFABF64374A4921092E4\\partitions.csv"
cmd /c if not exist "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\7B9D2C611DF8AFABF64374A4921092E4\\partitions.csv" if exist "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.17\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.17\\variants\\esp32\\partitions.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\7B9D2C611DF8AFABF64374A4921092E4\\partitions.csv"
cmd /c if not exist "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\7B9D2C611DF8AFABF64374A4921092E4\\partitions.csv" COPY "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.17\\tools\\partitions\\huge_app.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\7B9D2C611DF8AFABF64374A4921092E4\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\User\\Desktop\\text\\bootloader.bin" ( COPY /y "C:\\Users\\User\\Desktop\\text\\bootloader.bin" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\7B9D2C611DF8AFABF64374A4921092E4\\text.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.17\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.17\\variants\\esp32\\bootloader.bin" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\7B9D2C611DF8AFABF64374A4921092E4\\text.ino.bootloader.bin" ) ELSE ( "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\7B9D2C611DF8AFABF64374A4921092E4\\text.ino.bootloader.bin" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.17\\tools\\sdk\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\User\\Desktop\\text\\build_opt.h" COPY /y "C:\\Users\\User\\Desktop\\text\\build_opt.h" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\7B9D2C611DF8AFABF64374A4921092E4\\build_opt.h"
cmd /c if not exist "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\7B9D2C611DF8AFABF64374A4921092E4\\build_opt.h" type nul > "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\7B9D2C611DF8AFABF64374A4921092E4\\build_opt.h"
cmd /c type nul > "C:\\Users\\User\\AppData\\Local\\Temp\\arduino\\sketches\\7B9D2C611DF8AFABF64374A4921092E4/file_opts"
檢測有使用的程式庫...
C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/newlib/platform_include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freertos/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freertos/port/xtensa/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freertos/include/esp_additions -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/include/soc -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/port/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/heap/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/log/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/include/apps -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/include/apps/sntp -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/lwip/src/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/port/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/port/esp32/include/arch -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/soc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/soc/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/soc/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/hal/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/hal/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/hal/platform_port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_rom/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_rom/include/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_rom/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_system/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_system/port/soc -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_system/port/public_compat -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/xtensa/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/xtensa/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/driver/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/driver/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_pm/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_ringbuf/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/efuse/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/efuse/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/vfs/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_wifi/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_event/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_netif/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_eth/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/tcpip_adapter/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_phy/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_phy/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_ipc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/app_trace/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_timer/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/mbedtls/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/mbedtls/mbedtls/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/app_update/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/spi_flash/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bootloader_support/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/nvs_flash/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/pthread/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_gdbstub/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_gdbstub/xtensa -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_gdbstub/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espcoredump/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espcoredump/include/port/xtensa -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/wpa_supplicant/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/wpa_supplicant/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/ieee802154/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/console -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/asio/asio/asio/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/asio/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/common/osi/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/include/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/common/api/include/api -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/api -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/cbor/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/unity/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/unity/unity/src -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/cmock/CMock/src -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/coap/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/coap/libcoap/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/nghttp/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-tls -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_adc_cal/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hid/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/tcp_transport/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_http_client/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_http_server/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_https_ota/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_https_server/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_lcd/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_lcd/interface -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/protobuf-c/protobuf-c -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/protocomm/include/common -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/protocomm/include/security -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/protocomm/include/transports -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/mdns/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_local_ctrl/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/sdmmc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_serial_slave_link/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_websocket_client/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/expat/expat/expat/lib -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/expat/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/wear_levelling/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/fatfs/diskio -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/fatfs/vfs -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/fatfs/src -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freemodbus/freemodbus/common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/idf_test/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/idf_test/include/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/jsmn/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/json/cJSON -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/libsodium/port_include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/mqtt/esp-mqtt/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/openssl/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/perfmon/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/spiffs/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/ulp/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/wifi_provisioning/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/rmaker_common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_diagnostics/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/rtc_store/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_insights/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/json_parser/upstream/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/json_parser/upstream -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/json_generator/upstream -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_schedule/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_rainmaker/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/gpio_button/button/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/qrcode/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/ws2812_led -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_littlefs/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/tool -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/typedef -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/image -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/math -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/nn -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/layer -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/detect -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/model_zoo -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp32-camera/driver/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp32-camera/conversions/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/add/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/addc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mulc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/sub/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/test/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/fb_gfx/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\User\AppData\Local\Temp\arduino\sketches\7B9D2C611DF8AFABF64374A4921092E4/build_opt.h @C:\Users\User\AppData\Local\Temp\arduino\sketches\7B9D2C611DF8AFABF64374A4921092E4/file_opts -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17\cores\esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17\variants\esp32 C:\Users\User\AppData\Local\Temp\arduino\sketches\7B9D2C611DF8AFABF64374A4921092E4\sketch\text.ino.cpp -o nul
TensorFlowLite.h 的替代品: [Arduino_TensorFlowLite@2.4.0-ALPHA]
ResolveLibrary(TensorFlowLite.h)
  -> 候選: [Arduino_TensorFlowLite@2.4.0-ALPHA]
跳過預編譯程式庫  Arduino_TensorFlowLite 的相依偵測
C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/newlib/platform_include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freertos/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freertos/port/xtensa/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freertos/include/esp_additions -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/include/soc -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/port/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/heap/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/log/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/include/apps -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/include/apps/sntp -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/lwip/src/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/port/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/port/esp32/include/arch -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/soc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/soc/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/soc/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/hal/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/hal/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/hal/platform_port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_rom/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_rom/include/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_rom/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_system/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_system/port/soc -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_system/port/public_compat -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/xtensa/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/xtensa/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/driver/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/driver/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_pm/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_ringbuf/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/efuse/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/efuse/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/vfs/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_wifi/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_event/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_netif/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_eth/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/tcpip_adapter/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_phy/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_phy/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_ipc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/app_trace/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_timer/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/mbedtls/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/mbedtls/mbedtls/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/app_update/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/spi_flash/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bootloader_support/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/nvs_flash/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/pthread/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_gdbstub/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_gdbstub/xtensa -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_gdbstub/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espcoredump/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espcoredump/include/port/xtensa -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/wpa_supplicant/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/wpa_supplicant/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/ieee802154/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/console -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/asio/asio/asio/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/asio/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/common/osi/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/include/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/common/api/include/api -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/bt/esp_ble_mesh/api -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/cbor/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/unity/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/unity/unity/src -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/cmock/CMock/src -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/coap/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/coap/libcoap/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/nghttp/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-tls -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_adc_cal/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hid/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/tcp_transport/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_http_client/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_http_server/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_https_ota/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_https_server/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_lcd/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_lcd/interface -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/protobuf-c/protobuf-c -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/protocomm/include/common -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/protocomm/include/security -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/protocomm/include/transports -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/mdns/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_local_ctrl/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/sdmmc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_serial_slave_link/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_websocket_client/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/expat/expat/expat/lib -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/expat/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/wear_levelling/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/fatfs/diskio -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/fatfs/vfs -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/fatfs/src -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freemodbus/freemodbus/common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/idf_test/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/idf_test/include/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/jsmn/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/json/cJSON -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/libsodium/port_include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/mqtt/esp-mqtt/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/openssl/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/perfmon/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/spiffs/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/ulp/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/wifi_provisioning/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/rmaker_common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_diagnostics/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/rtc_store/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_insights/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/json_parser/upstream/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/json_parser/upstream -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/json_generator/upstream -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_schedule/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_rainmaker/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/gpio_button/button/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/qrcode/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/ws2812_led -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_littlefs/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/tool -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/typedef -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/image -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/math -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/nn -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/layer -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/detect -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp-dl/include/model_zoo -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp32-camera/driver/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp32-camera/conversions/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/add/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/addc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mulc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/sub/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/test/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/fb_gfx/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\User\AppData\Local\Temp\arduino\sketches\7B9D2C611DF8AFABF64374A4921092E4/build_opt.h @C:\Users\User\AppData\Local\Temp\arduino\sketches\7B9D2C611DF8AFABF64374A4921092E4/file_opts -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17\cores\esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17\variants\esp32 -Ic:\Users\User\Documents\Arduino\libraries\Arduino_TensorFlowLite\src C:\Users\User\AppData\Local\Temp\arduino\sketches\7B9D2C611DF8AFABF64374A4921092E4\sketch\text.ino.cpp -o nul
Wire.h 的替代品: [Wire@2.0.0]
ResolveLibrary(Wire.h)
  -> 候選: [Wire@2.0.0]
C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/newlib/platform_include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freertos/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freertos/port/xtensa/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freertos/include/esp_additions -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/include/soc -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/port/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/heap/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/log/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/include/apps -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/include/apps/sntp -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/lwip/src/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/port/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/lwip/port/esp32/include/arch -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/soc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/soc/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/soc/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/hal/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/hal/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/hal/platform_port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_rom/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_rom/include/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_rom/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_system/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_system/port/soc -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_system/port/public_compat -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/xtensa/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/xtensa/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/driver/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/driver/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_pm/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_ringbuf/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/efuse/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/efuse/esp32/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/vfs/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_wifi/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_event/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_netif/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_eth/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/tcpip_adapter/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_phy/include -rdware\esp32\2.0.17/tools/sdk/esp32/include/esp_local_ctrl/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/sdmmc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_serial_slave_link/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp_websocket_client/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/expat/expat/expat/lib -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/expat/port/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/wear_levelling/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/fatfs/diskio -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/fatfs/vfs -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/fatfs/src -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/freemodbus/freemodbus/common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/idf_test/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/idf_test/include/esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/jsmn/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/json/cJSON -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/libsodium/port_include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/mqtt/esp-mqtt/include -Iude -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/rmaker_common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\espdsp/modules/matrix/mul/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/add/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/addc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mulc/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/sub/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/test/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/fb_gfx/include -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\User\AppData\Local\Temp\arduino\sketches\7B9D2C611DF8AFABF64374A4921092E4/build_opt.h @C:\Users\User\AppData\Local\Temp\arduino\sketches\7B9D2C611DF8AFABF64374A4921092E4/file_opts -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17\cores\esp32 -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17\variants\esp32 -Ic:\Users\User\Documents\Arduino\libraries\Arduino_TensorFlowLite\src -IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17\libraries\Wire\src -Ic:\Users\User\Documents\Arduino\libraries\ArduTFLite\src -Ic:\Users\User\Documents\Arduino\libraries\Chirale_TensorFLowLite\src C:\Users\User\AppData\Local\Temp\arduino\sketches\7B9D2C611DF8AFABF64374A4921092E4\sketch\text.ino.cpp -o nul
偵測 C:\Users\User\AppData\Local\Temp\arduino\sketches\7B9D2C611DF8AFABF64374A4921092E4\sketch\text.ino.cpp 所包含的程式庫時出錯
c:\Users\User\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/peripherals/peripherals.h:61:2: error: #error "unsupported board"
exit status 1
Compilation error: exit status 1
all in all, Thanks to reply me!! I don't have ideal have a person can reply HAHA , this class is over I need after returning home only then can use computer(I'm at school now)
thanks again
Unfortunately the developers of the "Arduino_TensorFlowLite" library chose to arbitrarily limit its compatibility to the Nano 33 BLE Sense board:
https://github.com/tensorflow/tflite-micro-arduino-examples#compatibility
You can't use this library with the ESP32-CAM board. That is the reason why you get an error when attempting to compile any sketch that uses the library for an ESP32 board.
However, the TensorFlow Lite framework on which that library is built is not limited to the Nano 33 BLE Sense, so you can find other libraries that are compatible with the ESP32 boards. For example, I found this one from a search in the Arduino IDE Library Manager:
I got it I will try again
Thanks again;) that's very helpful
