liming
January 14, 2016, 4:24pm
1
I want the stepper motor to move one time clockwise and then one time anti-clockwise. It look likes back and forth.
But I found that the motor sometimes move two times clockwise or anti-clockwise.
I use AccelStepper library. Here is my code. Please help.
#include <AccelStepper.h>
int dir = 1;
int pos = 600;
AccelStepper stepper(1, 2, 3);
pinMode(7,OUTPUT); //MS1
pinMode(6,OUTPUT); //MS2
pinMode(5,OUTPUT); //MS3
digitalWrite(7,LOW);
digitalWrite(6,LOW);
digitalWrite(5,LOW);
stepper.setMaxSpeed(9000);
stepper.setAcceleration(13000);
if(stepper.distanceToGo()==0)
stepper.move(pos*dir);
dir = dir*(-1);
delay(200);
stepper.run();
You forgot to post the motor type and characteristics, wiring diagram (schematic, not Fritzing) and power supply characteristics.
liming
January 14, 2016, 5:13pm
3
I follow the web's diagram.
In this Arduino Tutorial we will learn how to control a Stepper Motor using the A4988 Stepper Driver. The A4988 is a microstepping driver for controlling bipolar stepper motors which has built-in translator for easy operation. This means that we can...
Est. reading time: 9 minutes
I use an arduino nano and a 16v/1.2A power supply.
A4988 Vref is 0.6V
Robin2
January 14, 2016, 5:33pm
4
I suggest you arrange for your code to print the value of pos*dir so that you can see what might be causing the problem.
...R
MarkT
January 14, 2016, 7:52pm
5
You must not use delay(), nothing happens to the motor during delay.
The run() method must be called very frequently, at least every time through loop() and avoid
any delay() calls.
Why use dir and why multiply to negate, why not the simple:
stepper.move (pos) ;
pos = -pos ;
stepper.run () ;
Robin2
January 14, 2016, 9:25pm
6
MarkT:
That occurred to me, but in this case the delay() is only called when the motor is stopped.
...R
MarkT
January 16, 2016, 10:05pm
7
Robin2:
...R
No, delay() is called after a call to move(), so its intended to do the move....
Robin2
January 17, 2016, 11:11am
8
MarkT:
I have looked at the code again. The call to stepper.run() is unaffected by the delay() as far as I can see.
Or, perhaps, the delay() should go before the call to stepper.move() so that it can immediately go from stepper.move() to stepper.run().
...R
MarkT
January 17, 2016, 2:58pm
9
Look again - delay is called between move and run, so the AccelStepper library ramping calculations will
be nonsensed I reckon.
dir = dir*(-1);
delay(200);
stepper.run();
The ramp is calculated w.r.t. the time move() is called and run() has to run often enough
to be able to feed out the actual steps in realtime.
Robin2
January 17, 2016, 5:24pm
10
MarkT:
Then I'm guessing that this would be OK - and would have the effect the OP is looking for.
delay(200);
dir = dir*(-1);
stepper.run();
...R
